[U-Boot] [PATCH] help: Correct syntax of nandecc help output.
"nandecc" help output should not reproduce the command name, nor have a trailing newline.
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
compiled, loaded and run to verify correct output.
diff --git a/cpu/arm_cortexa8/omap3/board.c b/cpu/arm_cortexa8/omap3/board.c index dd2c940..2aa69b3 100644 --- a/cpu/arm_cortexa8/omap3/board.c +++ b/cpu/arm_cortexa8/omap3/board.c @@ -328,7 +328,7 @@ usage:
U_BOOT_CMD( nandecc, 2, 1, do_switch_ecc, - "nandecc - switch OMAP3 NAND ECC calculation algorithm\n", + "switch OMAP3 NAND ECC calculation algorithm", "[hw/sw] - Switch between NAND hardware (hw) or software (sw) ecc algorithm" );
======================================================================== Robert P. J. Day Waterloo, Ontario, CANADA
Linux Consulting, Training and Kernel Pedantry.
Web page: http://crashcourse.ca Twitter: http://twitter.com/rpjday ========================================================================
Dear "Robert P. J. Day",
Applied, thanks.
Tom, Sandeep, I hope this is OK with you.
Robert P. J. Day
