[U-Boot] Help With TFTP
Hello. I seem to be having a small problem with transfering files from my machine to the at91sam9261-ek board via tftp. I'm using the following:
--Files Used (Build From newest Buildroot using "at91sam9261ek_defconfig")-- Bootstrap: at91sam9261ek-dataflashboot-2.3.4.bin U-Boot: at91sam9261ek-u-boot-1.2.0-atmel-20081003.bin Kernel: at91sam9261ek-linux-2.6.24.3-20081003.gz FS: rootfs.arm-20081003.ext2 AutoScript: autoscript.at91sam9261ek
--TFPT Server Computer-- ipaddr: 192.168.50.95 gatewayip: 192.168.50.1 netmask: 255.255.255.0
--My Computer-- ipaddr: 10.0.2.54 gatewayip: 10.0.0.1 netmask: 255.255.0.0
--at91sam9261ek Board-- ipaddr: 10.0.2.105 gatewayip: 10.0.0.1 netmask: 255.255.0.0 [serverip: 192.186.50.95]
I EraseAll on DataFlash/NandFlash and transfer the Bootstrap/U-Boot to my board via SAMBA and then boot up. I then do the default "defenv" "run config" "run get", however, "run get" never completes. I get a lot of Timeouts (~1000) and then it eventually does "Retry count exceeded; starting again".
"run config" requests the "autoscript.at91sam9261ek" file and completes in about 1 seconds (500byte file). "run get" downloads about 800KB's of the 1.5MB linux kernal (I can see the percentage of the file transfer on the TFTP Server machine) in about 30 seconds and then stops and retries again from the beginning.
When I use "My Computer" to request the kernel via a FTPT Client I am able to receive the file in about 2 or 3 seconds. Also the rootfs is 5MB's and I can receive that in about 6 seconds; as a result I don't think it is a problem with the TFTP Server.
I think the problem is that U-Boot shows "operating at 100M full duplex mode" when my board is probably "Half Duplex". I am unable to find how to force the connection type via u-boot.
--Various Other Notes-- The "dhcp" command does not work for me in uboot, it just "BOOTP 1,2,3,4... etc" forever but since I'm able to get small files I didn't think this was too big an issue; this is probably a security thing on my internal network. Also the at91sam9261ek board is unable to connect to a tftp server hosted on my computer which is why I use the external server; again probably security on my network.
I am able to transfer the files via serial port however this takes ~50 mins for a 5MB file which gets on my nervs a bit *smiles*, but, at the very least makes it more of an inconvinence than a major problem.
Would anyone know how I might be able to solve this problem? Maybe by increasing the "MAX_NET_RETRY_COUNT", perhaps by an environment variable inside u-boot *hopes*? I wasn't able to find the exact file/line to change if recompiling u-boot is needed. Or maybe by trying to set it to half-duplex? Or maybe I have some other settings wrong? If you need more information I can try to provide it. I attached an example U-Boot Log below. Thanks
-------------------------------------------------------------------------------- -------------------------------------------------------------------------------- UBOOT Log -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- U-Boot> RomBOOT
Start AT91Bootstrap... AT45DB642D detected Loading from Dataflash[0x00008400] to SDRAM[0x23F00000]
Loading complete, [0x00032000] bytes Start application at [0x23F00000]
U-Boot 1.2.0 (Oct 3 2008 - 13:40:25)
DRAM: 64 MB NAND: NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3, 3V 8-bit) NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bi t) 256 MiB DataFlash:AT45DB642 Nb pages: 8192 Page Size: 1056 Size= 8650752 bytes Logical address: 0xC0000000 Area 0: C0000000 to C00041FF (RO) Bootstrap (16kB) Area 1: C0004200 to C00083FF Environment (8kB) Area 2: C0008400 to C0039BFF (RO) U-Boot (192kB) Area 3: C0039C00 to C0041FFF (RO) Secondary Boot (32kB) Area 4: C0042000 to C01CDFFF OS Area 5: C01CE000 to C083FFFF FS In: serial Out: serial Err: serial dm9000 i/o: 0x30000000, id: 0x90000a46 MAC: 04:25:fe:ed:00:18 operating at 100M full duplex mode Hit any key to stop autoboot: 0 U-Boot> defenv Can't overwrite "ethaddr" len=149: root=/dev/ram rw initrd=0x2118C000,6000000 ramdisk_size=15360 ip=10.0 .2.105:192.168.50.95:10.0.0.1:255.255.0.0 console=ttyS0,115200,mem=64M U-Boot> run config dm9000 i/o: 0x30000000, id: 0x90000a46 MAC: 04:25:fe:ed:00:18 operating at 100M full duplex mode TFTP from server 192.168.50.95; our IP address is 10.0.2.105; sending through ga teway 10.0.0.1 Filename 'autoscript.at91sam9261ek'. Load address: 0x2118c000 Loading: T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T done Bytes transferred = 553 (229 hex) ## Executing script at 2118c000 Can't overwrite "ethaddr" U-Boot> run get dm9000 i/o: 0x30000000, id: 0x90000a46 MAC: 04:25:fe:ed:00:18 operating at 100M full duplex mode TFTP from server 192.168.50.95; our IP address is 10.0.2.105; sending through ga teway 10.0.0.1 Filename 'at91sam9261ek-linux-2.6.24.3-20081003.gz'. Load address: 0x21000000 Loading: T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T [...]SNIP[...] T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T Retry count exceeded; starting again TFTP from server 192.168.50.95; our IP address is 10.0.2.105; sending through ga teway 10.0.0.1 Filename 'at91sam9261ek-linux-2.6.24.3-20081003.gz'. Load address: 0x21000000 Loading: T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T #T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T Abort U-Boot> -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- _________________________________________________________________
Quick X
