[PATCH v5 0/2] arm: dts: rockchip: rk3399: usb: ehci: Fix EHCI probe in rk3399 to access peripherals by USB 2.
arch/arm/dts/rk3399.dtsi has a node
usb_host0_ehci: usb@fe380000 { compatible = "generic-ehci";
with clocks:
clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, <&u2phy0>;
The first 2 refer to nodes with class UCLASS_CLK, but &u2phy0 has class UCLASS_PHY.
u2phy0: usb2phy@e450 { compatible = "rockchip,rk3399-usb2phy";
Since clk_get_bulk() only looks for devices with UCLASS_CLK, it fails with -ENODEV and then ehci_usb_probe() aborts.
The consequence is peripherals connected to a USB 2 port (e.g. in a Rock Pi 4 one of the two ports nearer the edge) not being detected. They're detected if CONFIG_USB_OHCI_GENERIC is selected in Kconfig, because ohci_usb_probe() does not abort when one clk_get_by_index() fails, but then they work in USB 1 mode,.
rk3399.dtsi comes from linux and the u2phy0 was added[1] to the clock list in:
commit b5d1c57299734f5b54035ef2e61706b83041f20c Author: William wu wulf@rock-chips.com Date: Wed Dec 21 18:41:05 2016 +0800
arm64: dts: rockchip: add u2phy clock for ehci and ohci of rk3399
We found that the suspend process was blocked when it run into ehci/ohci module due to clk-480m of usb2-phy was disabled. [...]
Suspend concerns don't apply to U-Boot, and the problem with U-Boot failing to probe EHCI doesn't apply to linux, because in linux rockchip_usb2phy_clk480m_register makes u2phy0 a proper clock provider when called by rockchip_usb2phy_probe().
So I can think of a few alternative solutions:
1- Change ehci_usb_probe() to make it more similar to ohci_usb_probe(), and survive failure to get one clock. Looks a little harder, and I don't know whether it could break something if it ignored a clock that was important for something else than suspend. (tried in v2)
2- Change rk3399.dtsi effecttively reverting the linux commit b5d1c57299734f5b54035ef2e61706b83041f20c. This dealigns the .dtsi from linux and seems fragile at the next synchronisation.
3- Change the clock list in rk3399-u-boot.dtsi or somewhere else. This survives .dts* sync but may survive "too much" and miss some change from linux that we might want. (tried in v1)
4- Enable CONFIG_USB_OHCI_GENERIC and use the ports in USB 1 mode. This would need to be made for all boards using rk3399. In a simple test reading one file from USB storage it gave 769.5 KiB/s instead of 20.5 MiB/s with solution 2.
5- Trying to replicate linux and have usb2phy somehow provide a clk, or have a separate clock device for usb2phy in addition to the phy device. (tried in v3 and this v5, v4 did it wrong)
This series is a third attempt to implement option 5 as Marek Vasut requested in December 5th. Options 1 and 3 didn't get through[2,3].
The first patch in the series (identical to v3) just registers usb2phy as a clock driver, without any specific operations, so that ehci-generic.c finds it and is happy. It worked in my tests on a Rock Pi 4 B+ (rk3399).
Since Marek Vasut objected to an operationless driver[4], the second patch adds enable and disable operations adapted from linux prepare and unprepare operations (and round_rate(), which doesn't seem very useful anyway since it's a fixed clock). Since there're no users of this clock in u-boot, I can't see any difference in my tests with only the first patch or both, so I can't be sure it really works if it's ever needed, but it's hopefully more complete.
Links: [1] https://lkml.kernel.org/lkml/1731551.Q6cHK6n5ZM@phil/T/ [2] https://patchwork.ozlabs.org/project/uboot/patch/20220701185959.GC1700@begut... [3] https://patchwork.ozlabs.org/project/uboot/patch/Y44+ayJfUlI08ptM@localhost/... [4] https://patchwork.ozlabs.org/project/uboot/patch/Y5IWpjYLB4aXMy9o@localhost/...
Cc: Simon Glass sjg@chromium.org Cc: Philipp Tomsich philipp.tomsich@vrull.eu Cc: Kever Yang kever.yang@rock-chips.com Cc: Lukasz Majewski lukma@denx.de Cc: Sean Anderson seanga2@gmail.com Cc: Marek Vasut marex@denx.de Cc: Christoph Fritz chf.fritz@googlemail.com Signed-off-by: Xavier Drudis Ferran xdrudis@tinet.cat ---
Changes:
v5: fixes a bug that Christoph Fritz discovered, consisting in the wrong eror code returned when enabling or disabling the clock because property_enable() returns an error code in linux but the modified register value in U-Boot. This caused the clk disable to abort before freeing the clock and it apparently left things bad enough to cause a hang or a reset.
v4: move v3 to one patch in the series and add a second patch to add operations to enable disable the usb2phy 480Mhz clock. Also, honour clock-output-names for what is worth.
v3: implement option 5 (bind usb2phy as a clk driver too) instead of option 1 (ehci-generic.c tolerates missing clocks).
v2: implement option 1 (ehci-generic.c tolerates missing clocks) instead of option 3 (change dts node to remove the missing clock).
with clocks:
Link: [1] https://lkml.kernel.org/lkml/1731551.Q6cHK6n5ZM@phil/T/
Signed-off-by: Xavier Drudis Ferran xdrudis@tinet.cat --- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 23 ++++++++++++++++++- 1 file changed, 22 insertions(+), 1 deletion(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index b32a498ea7..9769ada376 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -7,7 +7,7 @@ */
#include <common.h> -#include <clk.h> +#include <clk-uclass.h> #include <dm.h> #include <asm/global_data.h> #include <dm/device_compat.h> @@ -168,6 +168,9 @@ static struct phy_ops rockchip_usb2phy_ops = { .of_xlate = rockchip_usb2phy_of_xlate, };
+static struct clk_ops rockchip_usb2phy_clk_ops = { +}; + static int rockchip_usb2phy_probe(struct udevice *dev) { struct rockchip_usb2phy *priv = dev_get_priv(dev); @@ -240,6 +243,18 @@ static int rockchip_usb2phy_bind(struct udevice *dev) } }
+ if (!ret) { + node = dev_ofnode(dev); + name = ofnode_get_name(node); + dev_dbg(dev, "clk for node %s\n", name); + ret = device_bind_driver_to_node(dev, "rockchip_usb2phy_clock", + name, node, &usb2phy_dev); + if (ret) { + dev_err(dev, + "'%s' cannot bind 'rockchip_usb2phy_clock'\n", name); + } + } + return ret; }
@@ -303,6 +318,12 @@ U_BOOT_DRIVER(rockchip_usb2phy_port) = { .ops = &rockchip_usb2phy_ops, };
+U_BOOT_DRIVER(rockchip_usb2phy_clock) = { + .name = "rockchip_usb2phy_clock", + .id = UCLASS_CLK, + .ops = &rockchip_usb2phy_clk_ops, +}; + U_BOOT_DRIVER(rockchip_usb2phy) = { .name = "rockchip_usb2phy", .id = UCLASS_PHY,
This clock has no users but appears in a phandle list used by ehci-generic.c to bulk enable it. The phandle list comes from linux, where it is needed for suspend/resume to work [1].
My tests give the same results with or without this patch, but Marek Vasut found it weird to declare an empty clk_ops.
So I adapted the code from linux 6.1-rc8 so that it hopefully works if it ever has some user. For now, without real users, it seems to at least not give any errors.
v5: ignores the return value from property_enable() which is not an error code in U-Boot (unlike in linux). This avoid a false failure of rockchip_usb2phy_clk_disable() that interfered with clock disable and appeared to cause hang or reset.
--- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 78 ++++++++++++++++++- 1 file changed, 76 insertions(+), 2 deletions(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index 9769ada376..66e0e5aed5 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -55,6 +55,7 @@ struct rockchip_usb2phy_port_cfg {
struct rockchip_usb2phy_cfg { unsigned int reg; + struct usb2phy_reg clkout_ctl; const struct rockchip_usb2phy_port_cfg port_cfgs[USB2PHY_NUM_PORTS]; };
@@ -76,6 +77,18 @@ static inline int property_enable(void *reg_base, return writel(val, reg_base + reg->offset); }
+static inline bool property_enabled(void *reg_base, + const struct usb2phy_reg *reg) +{ + unsigned int tmp, orig; + unsigned int mask = GENMASK(reg->bitend, reg->bitstart); + + orig = readl(reg_base + reg->offset); + + tmp = (orig & mask) >> reg->bitstart; + return tmp != reg->disable; +} + static const struct rockchip_usb2phy_port_cfg *us2phy_get_port(struct phy *phy) { @@ -168,7 +181,63 @@ static struct phy_ops rockchip_usb2phy_ops = { .of_xlate = rockchip_usb2phy_of_xlate, };
+/** + * round_rate() - Adjust a rate to the exact rate a clock can provide. + * @clk: The clock to manipulate. + * @rate: Desidered clock rate in Hz. + * + * Return: rounded rate in Hz, or -ve error code. + */ +ulong rockchip_usb2phy_clk_round_rate(struct clk *clk, ulong rate) +{ + return 480000000; +} + +/** + * enable() - Enable a clock. + * @clk: The clock to manipulate. + * + * Return: zero on success, or -ve error code. + */ +int rockchip_usb2phy_clk_enable(struct clk *clk) +{ + struct udevice *parent = dev_get_parent(clk->dev); + struct rockchip_usb2phy *priv = dev_get_priv(parent); + const struct rockchip_usb2phy_cfg *phy_cfg = priv->phy_cfg; + + /* turn on 480m clk output if it is off */ + if (!property_enabled(priv->reg_base, &phy_cfg->clkout_ctl)) { + property_enable(priv->reg_base, &phy_cfg->clkout_ctl, true); + + /* waiting for the clk become stable */ + usleep_range(1200, 1300); + } + + return 0; +} + +/** + * disable() - Disable a clock. + * @clk: The clock to manipulate. + * + * Return: zero on success, or -ve error code. + */ +int rockchip_usb2phy_clk_disable(struct clk *clk) +{ + struct udevice *parent = dev_get_parent(clk->dev); + struct rockchip_usb2phy *priv = dev_get_priv(parent); + const struct rockchip_usb2phy_cfg *phy_cfg = priv->phy_cfg; + + /* turn off 480m clk output */ + property_enable(priv->reg_base, &phy_cfg->clkout_ctl, false); + + return 0; +} + static struct clk_ops rockchip_usb2phy_clk_ops = { + .enable = rockchip_usb2phy_clk_enable, + .disable = rockchip_usb2phy_clk_disable, + .round_rate = rockchip_usb2phy_clk_round_rate };
static int rockchip_usb2phy_probe(struct udevice *dev) @@ -245,8 +314,11 @@ static int rockchip_usb2phy_bind(struct udevice *dev)
if (!ret) { node = dev_ofnode(dev); - name = ofnode_get_name(node); - dev_dbg(dev, "clk for node %s\n", name); + name = "clk_usbphy_480m"; + dev_read_string_index(dev, "clock-output-names", 0, &name); + + dev_dbg(dev, "clk %s for node %s\n", name, ofnode_get_name(node)); + ret = device_bind_driver_to_node(dev, "rockchip_usb2phy_clock", name, node, &usb2phy_dev); if (ret) { @@ -261,6 +333,7 @@ static int rockchip_usb2phy_bind(struct udevice *dev) static const struct rockchip_usb2phy_cfg rk3399_usb2phy_cfgs[] = { { .reg = 0xe450, + .clkout_ctl = { 0xe450, 4, 4, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_OTG] = { .phy_sus = { 0xe454, 1, 0, 2, 1 }, @@ -282,6 +355,7 @@ static const struct rockchip_usb2phy_cfg rk3399_usb2phy_cfgs[] = { }, { .reg = 0xe460, + .clkout_ctl = { 0xe460, 4, 4, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_OTG] = { .phy_sus = { 0xe464, 1, 0, 2, 1 },
Changes:
With your patches ontop of v2023.04-rc2, xhci works now fine on a rk3399 board:
=> usb start starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus usb@fe800000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fe900000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 4 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe800000 for devices... 3 USB Device(s) found scanning bus usb@fe900000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found
Totally unrelated to your patches, stopping usb still crashes (with or without your patch) but only when a USB-Ethernet-Dongle (+HUB) is connected:
=> usb start starting USB... do_usb_start, 581 Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus usb@fe800000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fe900000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 3 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe800000 for devices... 1 USB Device(s) found scanning bus usb@fe900000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Hub (480 Mb/s, 100mA) | USB2.0 Hub | +-3 Human Interface (12 Mb/s, 400mA) ILITEK ILITEK-TP
1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) U-Boot XHCI Host Controller
=> usb stop stopping USB.. => usb start starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus usb@fe800000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fe900000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 4 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe800000 for devices... 3 USB Device(s) found scanning bus usb@fe900000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Hub (480 Mb/s, 100mA) | USB2.0 Hub | +-3 Hub (480 Mb/s, 0mA) | VIA Labs, Inc. USB2.0 Hub | +-4 Human Interface (12 Mb/s, 400mA) ILITEK ILITEK-TP
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Hub (5 Gb/s, 0mA) | VIA Labs, Inc. USB3.0 Hub | +-3 Vendor specific (5 Gb/s, 36mA) Realtek USB 10/100/1000 LAN 00E04C68034E
=> usb stop stopping USB.. <hangs here forever>
I just quirked/masked the underlying issue by not doing usb_stop() at all in drivers/usb/host/usb-uclass.c.
El Fri, Mar 03, 2023 at 10:42:20AM +0100, Christoph Fritz deia:
Changes:
Fine, thanks a lot for testing. I thought the problem was with EHCI.
Well, but with v4 you got a couple more messages about devices not removed but children gone. With v5 those messages don't show any more. So v5 fixes one of the bugs you were seeing, more bugs remain.
Unfortunately I don't think I have any usb-ethernet dongle here to test...
Ok, so this was with a keyboard or something connected to a USB 2 port and nothing in the blue USB 3 port, right?
And this was with the keyboard in USB2 and a USB3 VIA Labs hub connected to the USB3 port and a Realtek ethernet-USB dongle attached to that USB3 hub, right?
Does usb reset also hang ? If so the problem then must be that you are left with no way to rescan for devices that were not connected at usb start but get connected later ?
Did you say before it all worked if you unconfigured EHCI and worked with XHCI only? (or OHCI + XHCI but no EHCI). Might it have to do with the same hub hanging from the EHCI and XHCI controller? (but it doesn't sound strange to me, the hub doesn't know what devices will be connected to it...)
If you leave drivers/usb/host/usb-uclass.c as it was but drop some #define DEBUG in device-remove.c does it give any hint ?
I'll try to do some more tests with a USB3 hub and usb storage...
Thanks again for testing.
I'm sorry but I haven't been able to reproduce your issue.
El Fri, Mar 03, 2023 at 11:26:46AM +0100, Xavier Drudis Ferran deia:
I tried with a USB3 hub connected to a usb3 port, a sata adapter connected to the USB3 hub, and a SATA disk connected to the SATA adapter, and I could read the disk.
The difference is that in my tree both the USB2 and the USB 3 hub hang from the XHCI controller, not one from EHCI and one from XHCI.
This with my v5 patches on top of 4eb7c5030d3f3c70 (2023-02-19) and some minor config changes that don't seem to matter.
=> usb start starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus usb@fe800000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fe900000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe800000 for devices... 4 USB Device(s) found scanning bus usb@fe900000 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | |+-2 Hub (5 Gb/s, 0mA) | | GenesysLogic USB3.0 Hub | | | |+-4 Mass Storage (5 Gb/s, 24mA) | Prolific Technology Inc. ATAPI-6 Bridge Controller 0123456789000000005 | |+-3 Hub (480 Mb/s, 100mA) GenesysLogic USB2.0 Hub
=> ls usb 0 <DIR> 4096 . <DIR> 4096 .. <DIR> 16384 lost+found <DIR> 4096 var <DIR> 12288 etc [...] => usb stop stopping USB.. => usb start starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus usb@fe800000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus usb@fe900000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus usb@fe800000 for devices... 4 USB Device(s) found scanning bus usb@fe900000 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | |+-2 Hub (480 Mb/s, 100mA) | GenesysLogic USB2.0 Hub | |+-3 Hub (5 Gb/s, 0mA) | GenesysLogic USB3.0 Hub | |+-4 Mass Storage (5 Gb/s, 24mA) Prolific Technology Inc. ATAPI-6 Bridge Controller 0123456789000000005
[no hang]
I don't know how to help, maybe just try to increase log verbosity or something...
Sorry
-- Xavier Drudis Ferran
Changes:
Any news about the next revision of this patch? RK3399 has broken since release due to this issue. This fix might make upcoming release workable.
Please let us know.
Thanks, Jagan.
El Fri, Jun 02, 2023 at 12:11:13PM +0530, Jagan Teki deia:
Please let us know.
Sorry, I'm not sure you meant to send this to me ?
For my side I stopped working on it after I got no feedback for my last version:
https://lists.denx.de/pipermail/u-boot/2023-February/510672.html https://lists.denx.de/pipermail/u-boot/2023-February/510676.html https://lists.denx.de/pipermail/u-boot/2023-February/510678.html
I got no replies.
I asked whether I should resend.
https://lists.denx.de/pipermail/u-boot/2023-March/511621.html
Btw, my v5 seems not to be correctly in patchwork, should I resend ? I guess I messed up subject lines ?
And I got no answer, so I thought there were still no interest and gave up.
Now I see I answered to a question to Eugen only, not the list, so maybe the list kept waiting for my answer.
Might be some misunderstanding.
Should I try again with the current next branch and send v6 ?
Please let us know.
I got no replies.
Please send.
Thanks, Jagan.
El Fri, Jun 02, 2023 at 03:34:37PM +0530, Jagan Teki deia:
Please send.
Thanks, Jagan.
I will try asap, thanks.
El Sat, Jun 03, 2023 at 09:23:36AM +0200, Xavier Drudis Ferran deia:
Please send.
Thanks, Jagan.
Done
https://patchwork.ozlabs.org/project/uboot/list/?series=358005
Tests, etc. welcome.
Christoph Fritz issue with his USB-ethernet adapter on XHCI may still be there, it looked unrelated and I can't test it.
Christoph Fritz
Jagan Teki
