[PATCH] riscv: fix compitible with binutils 2.38
commit 6df2a016c0c8a3d0933ef33dd192ea6606b115e3 from linux kernel
Since binutils 2.38, default ISA spec version switch to 20191213, in this version, original I extension be split into I, Zicsr and Zifencei. Zicsr is csr read/write (csrr*/csrw*) instructions, and Zifencei is fence.i instruction. This will cause compile error like this: Error: unrecognized opcode `csrr a5,0xc01' Error: unrecognized opcode `fence.i'
This commit add code to detect new Zicsr and Zifencei extensions, and enable it when needed.
Signed-off-by: Coelacanthus coelacanthus@outlook.com Cc: Rick Chen rick@andestech.com Cc: Leo ycliang@andestech.com --- arch/riscv/Makefile | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/Makefile b/arch/riscv/Makefile index 0b80eb8d86..62712f8d38 100644 --- a/arch/riscv/Makefile +++ b/arch/riscv/Makefile @@ -24,7 +24,14 @@ ifeq ($(CONFIG_CMODEL_MEDANY),y) CMODEL = medany endif
-ARCH_FLAGS = -march=$(ARCH_BASE)$(ARCH_A)$(ARCH_C) -mabi=$(ABI) \ +RISCV_MARCH_y = $(ARCH_BASE)$(ARCH_A)$(ARCH_C) + +# Newer binutils versions default to ISA spec version 20191213 which moves some +# instructions from the I extension to the Zicsr and Zifencei extensions. +toolchain-need-zicsr-zifencei := $(call cc-option-yn, -mabi=$(ABI) -march=$(RISCV_MARCH_y)_zicsr_zifencei) +RISCV_MARCH_$(toolchain-need-zicsr-zifencei) := $(RISCV_MARCH_y)_zicsr_zifencei + +ARCH_FLAGS = -march=$(RISCV_MARCH_y) -mabi=$(ABI) \ -mcmodel=$(CMODEL)
PLATFORM_CPPFLAGS += $(ARCH_FLAGS)
Am Montag, 23. Mai 2022, 14:05:27 CEST schrieb Coelacanthus:
while this fixes the build issue I'm seeing after a recent binutils, there has been already a patch proposed for this fix [0] and in that thread some pending issue was discussed as well.
So please coordinate with the other people over there :-)
Thanks Heiko
[0] https://lore.kernel.org/all/20220128134713.2322800-1-alexandre.ghiti@canonic...
Coelacanthus
Heiko Stübner
