[PATCH v2 1/3] efi_loader: enable QueryVariableInfo at runtime for file backed variables
Since commit c28d32f946f0 ("efi_loader: conditionally enable SetvariableRT") we are enabling the last bits of missing runtime services. Add support for QueryVariableInfo which we already support at boottime and we just need to mark some fucntions available at runtime and move some checks around.
It's worth noting that pointer checks for maxmimum and remaining variable storage aren't when we store variables on the RPMB, since the Secure World backend is already performing them.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since v1: - require EFI_VARIABLE_RUNTIME_ACCESS to be set at runtime - return EFI_UNSUPPORTED for auth variables lib/efi_loader/efi_runtime.c | 4 +++ lib/efi_loader/efi_var_common.c | 6 ----- lib/efi_loader/efi_variable.c | 25 ++++++++++++++----- lib/efi_loader/efi_variable_tee.c | 5 ++++ .../efi_selftest_variables_runtime.c | 14 ++++++++--- 5 files changed, 39 insertions(+), 15 deletions(-)
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 73831c527e00..011bcd04836d 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -129,6 +129,10 @@ efi_status_t efi_init_runtime_supported(void) EFI_RT_SUPPORTED_SET_VIRTUAL_ADDRESS_MAP | EFI_RT_SUPPORTED_CONVERT_POINTER;
+ if (IS_ENABLED(CONFIG_EFI_VARIABLE_FILE_STORE)) + rt_table->runtime_services_supported |= + EFI_RT_SUPPORTED_QUERY_VARIABLE_INFO; + if (IS_ENABLED(CONFIG_EFI_RT_VOLATILE_STORE)) { u8 s = 0;
diff --git a/lib/efi_loader/efi_var_common.c b/lib/efi_loader/efi_var_common.c index 961139f005af..ea8d2a4cf98c 100644 --- a/lib/efi_loader/efi_var_common.c +++ b/lib/efi_loader/efi_var_common.c @@ -1,4 +1,3 @@ -// SPDX-License-Identifier: GPL-2.0+ /* * UEFI runtime variable services * @@ -163,11 +162,6 @@ efi_status_t EFIAPI efi_query_variable_info( EFI_ENTRY("%x %p %p %p", attributes, maximum_variable_storage_size, remaining_variable_storage_size, maximum_variable_size);
- if (!maximum_variable_storage_size || - !remaining_variable_storage_size || - !maximum_variable_size) - return EFI_EXIT(EFI_INVALID_PARAMETER); - ret = efi_query_variable_info_int(attributes, maximum_variable_storage_size, remaining_variable_storage_size, diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index 0cbed53d1dbf..1cc02acb3b26 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -406,12 +406,15 @@ efi_status_t efi_set_variable_int(const u16 *variable_name, return EFI_SUCCESS; }
-efi_status_t efi_query_variable_info_int(u32 attributes, - u64 *maximum_variable_storage_size, - u64 *remaining_variable_storage_size, - u64 *maximum_variable_size) +efi_status_t __efi_runtime +efi_query_variable_info_int(u32 attributes, + u64 *maximum_variable_storage_size, + u64 *remaining_variable_storage_size, + u64 *maximum_variable_size) { - if (attributes == 0) + if (!maximum_variable_storage_size || + !remaining_variable_storage_size || + !maximum_variable_size || !attributes) return EFI_INVALID_PARAMETER;
/* EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS is deprecated */ @@ -460,7 +463,17 @@ static efi_status_t __efi_runtime EFIAPI efi_query_variable_info_runtime( u64 *remaining_variable_storage_size, u64 *maximum_variable_size) { - return EFI_UNSUPPORTED; + if (!(attributes & EFI_VARIABLE_RUNTIME_ACCESS)) + return EFI_INVALID_PARAMETER; + if ((attributes & (EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS | + EFI_VARIABLE_TIME_BASED_AUTHENTICATED_WRITE_ACCESS | + EFI_VARIABLE_ENHANCED_AUTHENTICATED_ACCESS))) + return EFI_UNSUPPORTED; + + return efi_query_variable_info_int(attributes, + maximum_variable_storage_size, + remaining_variable_storage_size, + maximum_variable_size); }
/** diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index 4f1aa298da13..8b6b0a390869 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -873,6 +873,11 @@ efi_status_t efi_query_variable_info_int(u32 attributes, efi_status_t ret; u8 *comm_buf;
+ if (!max_variable_storage_size || + !remain_variable_storage_size || + !max_variable_size || !attributes) + return EFI_INVALID_PARAMETER; + payload_size = sizeof(*mm_query_info); comm_buf = setup_mm_hdr((void **)&mm_query_info, payload_size, SMM_VARIABLE_FUNCTION_QUERY_VARIABLE_INFO, diff --git a/lib/efi_selftest/efi_selftest_variables_runtime.c b/lib/efi_selftest/efi_selftest_variables_runtime.c index afa91be62c85..5794a7b2d405 100644 --- a/lib/efi_selftest/efi_selftest_variables_runtime.c +++ b/lib/efi_selftest/efi_selftest_variables_runtime.c @@ -60,9 +60,17 @@ static int execute(void) ret = runtime->query_variable_info(EFI_VARIABLE_BOOTSERVICE_ACCESS, &max_storage, &rem_storage, &max_size); - if (ret != EFI_UNSUPPORTED) { - efi_st_error("QueryVariableInfo failed\n"); - return EFI_ST_FAILURE; + + if (IS_ENABLED(CONFIG_EFI_VARIABLE_FILE_STORE)) { + if (ret != EFI_SUCCESS) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + } else { + if (ret != EFI_UNSUPPORTED) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } }
ret = runtime->set_variable(u"efi_st_var0", &guid_vendor0, -- 2.40.1
Since we support QueryVariableInfo at runtime now add the relevant tests. Since we want those to be reusable at bootime, add them in a separate file
Add tests for - Test QueryVariableInfo returns EFI_SUCCESS - Test null pointers for the function arguments - Test invalid combination of attributes
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since v1: - Pass the attributers as well in efi_st_query_variable_common() and check for runtime/boottime include/efi_selftest.h | 11 +++ lib/efi_selftest/Makefile | 1 + .../efi_selftest_variables_common.c | 99 +++++++++++++++++++ .../efi_selftest_variables_runtime.c | 11 ++- 4 files changed, 118 insertions(+), 4 deletions(-) create mode 100644 lib/efi_selftest/efi_selftest_variables_common.c
diff --git a/include/efi_selftest.h b/include/efi_selftest.h index 5bcebb368287..1b708849bcb9 100644 --- a/include/efi_selftest.h +++ b/include/efi_selftest.h @@ -147,6 +147,17 @@ void *efi_st_get_config_table(const efi_guid_t *guid); */ u16 efi_st_get_key(void);
+/** + * efi_st_query_variable_common - Common variable tests for boottime/runtime + * + * @runtime: Pointer to services table + * @attributes: Attributes used + * + * Return: EFI_ST_SUCCESS/FAILURE + */ +int efi_st_query_variable_common(struct efi_runtime_services *runtime, + u32 attributes); + /** * struct efi_unit_test - EFI unit test * diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index e4d75420bff6..414701893f65 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -45,6 +45,7 @@ efi_selftest_textinputex.o \ efi_selftest_textoutput.o \ efi_selftest_tpl.o \ efi_selftest_util.o \ +efi_selftest_variables_common.o \ efi_selftest_variables.o \ efi_selftest_variables_runtime.o \ efi_selftest_watchdog.o diff --git a/lib/efi_selftest/efi_selftest_variables_common.c b/lib/efi_selftest/efi_selftest_variables_common.c new file mode 100644 index 000000000000..e29a4be74a57 --- /dev/null +++ b/lib/efi_selftest/efi_selftest_variables_common.c @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * efi_selftest_variables_runtime + * + * Copyright (c) 2024 Ilias Apalodimas ilias.apalodimas@linaro.org + * + * This unit test checks common service across boottime/runtime + */ + +#include <efi_selftest.h> + +#define EFI_INVALID_ATTR BIT(30) + +int efi_st_query_variable_common(struct efi_runtime_services *runtime, + u32 attributes) +{ + efi_status_t ret; + u64 max_storage, rem_storage, max_size; + + ret = runtime->query_variable_info(attributes, + &max_storage, &rem_storage, + &max_size); + if (ret != EFI_SUCCESS) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + ret = runtime->query_variable_info(EFI_VARIABLE_RUNTIME_ACCESS, + &max_storage, &rem_storage, + &max_size); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + ret = runtime->query_variable_info(attributes, + NULL, &rem_storage, + &max_size); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + ret = runtime->query_variable_info(attributes, + &max_storage, NULL, + &max_size); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + ret = runtime->query_variable_info(attributes, + &max_storage, &rem_storage, + NULL); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + ret = runtime->query_variable_info(0, &max_storage, &rem_storage, + &max_size); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + ret = runtime->query_variable_info(attributes | + EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS | + EFI_VARIABLE_NON_VOLATILE, + &max_storage, &rem_storage, + &max_size); + if (ret != EFI_UNSUPPORTED) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + ret = runtime->query_variable_info(EFI_VARIABLE_NON_VOLATILE, + &max_storage, &rem_storage, + &max_size); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + /* + * Use a mix existing/non-existing attribute bits from the + * UEFI spec + */ + ret = runtime->query_variable_info(attributes | EFI_INVALID_ATTR | + EFI_VARIABLE_NON_VOLATILE, + &max_storage, &rem_storage, + &max_size); + if (ret != EFI_INVALID_PARAMETER) { + efi_st_error("QueryVariableInfo failed\n"); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; +} diff --git a/lib/efi_selftest/efi_selftest_variables_runtime.c b/lib/efi_selftest/efi_selftest_variables_runtime.c index 5794a7b2d405..379c4f9c47b7 100644 --- a/lib/efi_selftest/efi_selftest_variables_runtime.c +++ b/lib/efi_selftest/efi_selftest_variables_runtime.c @@ -55,18 +55,21 @@ static int execute(void) u16 varname[EFI_ST_MAX_VARNAME_SIZE]; efi_guid_t guid; u64 max_storage, rem_storage, max_size; + int test_ret;
memset(v2, 0x1, sizeof(v2)); - ret = runtime->query_variable_info(EFI_VARIABLE_BOOTSERVICE_ACCESS, - &max_storage, &rem_storage, - &max_size);
if (IS_ENABLED(CONFIG_EFI_VARIABLE_FILE_STORE)) { - if (ret != EFI_SUCCESS) { + test_ret = efi_st_query_variable_common(runtime, EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS); + if (test_ret != EFI_ST_SUCCESS) { efi_st_error("QueryVariableInfo failed\n"); return EFI_ST_FAILURE; } } else { + ret = runtime->query_variable_info(EFI_VARIABLE_BOOTSERVICE_ACCESS, + &max_storage, &rem_storage, + &max_size); if (ret != EFI_UNSUPPORTED) { efi_st_error("QueryVariableInfo failed\n"); return EFI_ST_FAILURE; -- 2.40.1
Previous patches added QueryVariableInfo at runtime tests and split a common function that can be used at boottime. Weire it up and run a similar set of tets. While at it move a test which is checiking for 0 available storage in the common code
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since v1: - efi_st_query_variable_common() called with EFI_VARIABLE_BOOTSERVICE_ACCESS only lib/efi_selftest/efi_selftest_variables.c | 13 +++++-------- lib/efi_selftest/efi_selftest_variables_common.c | 3 +++ 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest_variables.c b/lib/efi_selftest/efi_selftest_variables.c index 39ad03a090d4..3d5f38c68978 100644 --- a/lib/efi_selftest/efi_selftest_variables.c +++ b/lib/efi_selftest/efi_selftest_variables.c @@ -51,15 +51,12 @@ static int execute(void) u16 varname[EFI_ST_MAX_VARNAME_SIZE]; int flag; efi_guid_t guid; - u64 max_storage, rem_storage, max_size; + int test_ret;
- ret = runtime->query_variable_info(EFI_VARIABLE_BOOTSERVICE_ACCESS, - &max_storage, &rem_storage, - &max_size); - if (ret != EFI_SUCCESS) { - efi_st_todo("QueryVariableInfo failed\n"); - } else if (!max_storage || !rem_storage || !max_size) { - efi_st_error("QueryVariableInfo: wrong info\n"); + test_ret = efi_st_query_variable_common(runtime, + EFI_VARIABLE_BOOTSERVICE_ACCESS); + if (test_ret != EFI_ST_SUCCESS) { + efi_st_error("QueryVariableInfo failed\n"); return EFI_ST_FAILURE; } /* Set variable 0 */ diff --git a/lib/efi_selftest/efi_selftest_variables_common.c b/lib/efi_selftest/efi_selftest_variables_common.c index e29a4be74a57..453bc8709a6f 100644 --- a/lib/efi_selftest/efi_selftest_variables_common.c +++ b/lib/efi_selftest/efi_selftest_variables_common.c @@ -23,6 +23,9 @@ int efi_st_query_variable_common(struct efi_runtime_services *runtime, if (ret != EFI_SUCCESS) { efi_st_error("QueryVariableInfo failed\n"); return EFI_ST_FAILURE; + } else if (!max_storage || !rem_storage || !max_size) { + efi_st_error("QueryVariableInfo: wrong info\n"); + return EFI_ST_FAILURE; }
ret = runtime->query_variable_info(EFI_VARIABLE_RUNTIME_ACCESS, -- 2.40.1
Changes since v1:
- if (IS_ENABLED(CONFIG_EFI_VARIABLE_FILE_STORE))
- if (IS_ENABLED(CONFIG_EFI_RT_VOLATILE_STORE)) { u8 s = 0;
- UEFI runtime variable services
{u64 *maximum_variable_size)
According to the UEFI 2.10 specification EFI_UNSUPPORTED must be returned if
"The attribute is not supported on this platform, and the MaximumVariableStorageSize, RemainingVariableStorageSize, MaximumVariableSize are undefined."
I wonder if in the spec the 'and' should be replaced by 'or'.
I guess we should return EFI_UNSUPPORTED if CONFIG_EFI_VARIABLE_RUNTIME_ACCESS=n and change the corresponding test accordingly. This check should be placed first.
Best regards
Heinrich
- if (!max_variable_storage_size ||
- payload_size = sizeof(*mm_query_info); comm_buf = setup_mm_hdr((void **)&mm_query_info, payload_size, SMM_VARIABLE_FUNCTION_QUERY_VARIABLE_INFO,
} else {
-- 2.40.1
Hi Heinrich,
Changes since v1:
!maximum_variable_size || !attributes) return EFI_INVALID_PARAMETER; /* EFI_VARIABLE_AUTHENTICATED_WRITE_ACCESS is deprecated */
Probably 'or'
The spec isn't clear indeed, but looking at the flags usually passed in QueyVariable, there's nothing that checks for SetVariable at runtime -- which isn't even an attr, it's a property of the RT_PROP table. We do return EFI_UNSUPPORTED for authenticated variables, which we can't reliably support (and auth variables have their own attr). I would prefer merging this with the existing checks and in the future (perhaps the next stable release) make CONFIG_EFI_RT_VOLATILE_STORE=y by default or get rid of the config options entirely once the userspace tools are mature enough to support it.
In any case, I don't have a strong opinion, I am fine with both. Just tell me what you prefer.
Regards /Ilias
Best regards
Heinrich
} else {
} } ret = runtime->set_variable(u"efi_st_var0", &guid_vendor0,
-- 2.40.1
Ilias Apalodimas
