[U-Boot] ppc: How to get uboot (relocated) start address in RAM
I a world post-ppc-relocation-patch, with gd->reloc_off removed,
I seem to have lost my way of figuring out uboot's address in RAM at run time. Previously, I am able to use (gd->reloc_off+CONFIG_SYS_MONITOR_BASE) to get the answer.
Knowing the address is very useful for debuggging uboot using gdb.
The only spot that works now is the dest_addr variable in lib_ppc/board.c::board_init_r
debug ("Now running in RAM - U-Boot at: %08lx\n", dest_addr);
But the dest_addr is not saved into a global data variable.
Is it ok if I submit a patch that copies this dest_addr to gd->relocaddr (currently only used by CONFIG_AMIGAONEG3SE) and print it as part of bdinfo?
Or is there a better method I am missing?
Regards,
- Richard Retanubun
Hi Richard,
Actually I also realised lately that the missing reloc_off makes debugging harder :(
I did not come around looking into it more closely, but your approach seems to be a good plan. Can you please cook up a patch so we can have a look at it?
Thanks Detlev
Detlev Zundel
Richard Retanubun
