[PATCH 1/2] configs: gwventana_emmc_defconfig: add MV88E61XX DSA switch support
The MV88E61XX switch is used on the GW5904 which is an eMMC based board. Adding it here allows us to remove the gwventana_gw5904_defconfig.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- configs/gwventana_emmc_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 032dcfe343cd..ee833a59f3d4 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -114,9 +114,12 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y +CONFIG_PHY_FIXED=y CONFIG_DM_MDIO=y +CONFIG_DM_DSA=y CONFIG_E1000=y CONFIG_FEC_MXC=y +CONFIG_MV88E6XXX=y CONFIG_MII=y CONFIG_PCI=y CONFIG_PCIE_IMX=y
Now that the gwventana_emmc_defconfig is the same as the gwventana_gw5904_defconfig we can remove the latter.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/MAINTAINERS | 1 - configs/gwventana_gw5904_defconfig | 179 ------------------------- 2 files changed, 180 deletions(-) delete mode 100644 configs/gwventana_gw5904_defconfig
diff --git a/board/gateworks/gw_ventana/MAINTAINERS b/board/gateworks/gw_ventana/MAINTAINERS index 1619d23c8790..f9872806c0c5 100644 --- a/board/gateworks/gw_ventana/MAINTAINERS +++ b/board/gateworks/gw_ventana/MAINTAINERS @@ -5,7 +5,6 @@ F: board/gateworks/gw_ventana/ F: include/configs/gw_ventana.h F: configs/gwventana_nand_defconfig F: configs/gwventana_emmc_defconfig -F: configs/gwventana_gw5904_defconfig F: arch/arm/dts/imx6dl-gw51xx.dts F: arch/arm/dts/imx6dl-gw52xx.dts F: arch/arm/dts/imx6dl-gw53xx.dts diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig deleted file mode 100644 index ee833a59f3d4..000000000000 --- a/configs/gwventana_gw5904_defconfig +++ /dev/null @@ -1,179 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_TEXT_BASE=0x17800000 -CONFIG_SYS_MALLOC_LEN=0xa00000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0xB1400 -CONFIG_MX6QDL=y -CONFIG_TARGET_GW_VENTANA=y -CONFIG_SYS_I2C_MXC_I2C1=y -CONFIG_SYS_I2C_MXC_I2C2=y -CONFIG_SYS_I2C_MXC_I2C3=y -CONFIG_CMD_EECONFIG=y -CONFIG_DEFAULT_DEVICE_TREE="imx6q-gw54xx" -CONFIG_SPL_TEXT_BASE=0x00908000 -CONFIG_SYS_PROMPT="Ventana > " -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x18000000 -CONFIG_SPL=y -CONFIG_ENV_OFFSET_REDUND=0xD1400 -CONFIG_CMD_HDMIDETECT=y -CONFIG_AHCI=y -CONFIG_SYS_MONITOR_LEN=409600 -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="for btype in ${bootdevs}; do echo; echo Attempting ${btype} boot...; if run ${btype}_boot; then; fi; done" -CONFIG_USE_PREBOOT=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HWCONFIG=y -CONFIG_MISC_INIT_R=y -CONFIG_PCI_INIT_R=y -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SPL_FIT_IMAGE_TINY=y -CONFIG_SPL_DMA=y -CONFIG_SPL_I2C=y -CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_SPL_ARGS_ADDR=0x18000000 -CONFIG_SPL_FALCON_BOOT_MMCSD=y -CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1000 -CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x800 -CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS=0x100 -CONFIG_SPL_POWER=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=32 -CONFIG_SYS_PBSIZE=539 -CONFIG_CMD_BOOTZ=y -CONFIG_SYS_BOOTM_LEN=0x4000000 -CONFIG_CMD_SPL_WRITE_SIZE=0x20000 -CONFIG_CMD_UNZIP=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y -CONFIG_CMD_PCI=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_BMP=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_TIME=y -# CONFIG_CMD_VIDCONSOLE is not set -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:16m(uboot),1m(env),-(rootfs)" -CONFIG_CMD_UBI=y -CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="imx6q-gw51xx imx6dl-gw51xx imx6q-gw52xx imx6dl-gw52xx imx6q-gw53xx imx6dl-gw53xx imx6q-gw54xx imx6dl-gw54xx imx6q-gw551x imx6dl-gw551x imx6q-gw552x imx6dl-gw552x imx6q-gw553x imx6dl-gw553x imx6q-gw560x imx6dl-gw560x imx6q-gw5903 imx6dl-gw5903 imx6q-gw5904 imx6dl-gw5904 imx6q-gw5907 imx6dl-gw5907 imx6q-gw5910 imx6dl-gw5910 imx6q-gw5912 imx6dl-gw5912 imx6q-gw5913 imx6dl-gw5913" -CONFIG_MULTI_DTB_FIT=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_PART=1 -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_NETCONSOLE=y -CONFIG_USE_IPADDR=y -CONFIG_IPADDR="192.168.1.1" -CONFIG_USE_SERVERIP=y -CONFIG_SERVERIP="192.168.1.146" -CONFIG_BOUNCE_BUFFER=y -CONFIG_DWC_AHSATA=y -CONFIG_LBA48=y -CONFIG_DM_I2C=y -CONFIG_SPL_SYS_I2C_LEGACY=y -CONFIG_SYS_I2C_MXC=y -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_SUPPORT_EMMC_RPMB=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_USDHC=y -CONFIG_MTD=y -CONFIG_PHYLIB=y -CONFIG_PHY_FIXED=y -CONFIG_DM_MDIO=y -CONFIG_DM_DSA=y -CONFIG_E1000=y -CONFIG_FEC_MXC=y -CONFIG_MV88E6XXX=y -CONFIG_MII=y -CONFIG_PCI=y -CONFIG_PCIE_IMX=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_IMX6=y -CONFIG_POWER_LEGACY=y -CONFIG_POWER_LTC3676=y -CONFIG_POWER_PFUZE100=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_POWER_I2C=y -CONFIG_CONS_INDEX=2 -CONFIG_DM_SERIAL=y -CONFIG_MXC_UART=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_MXC_SPI=y -CONFIG_SYSRESET=y -CONFIG_SYSRESET_WATCHDOG=y -CONFIG_DM_THERMAL=y -CONFIG_IMX_THERMAL=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_ASIX88179=y -CONFIG_USB_ETHER_LAN75XX=y -CONFIG_USB_ETHER_LAN78XX=y -CONFIG_USB_ETHER_MCS7830=y -CONFIG_USB_ETHER_RTL8152=y -CONFIG_USB_ETHER_SMSC95XX=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Gateworks" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_ETHER=y -CONFIG_USB_ETH_CDC=y -CONFIG_VIDEO=y -CONFIG_VIDEO_LOGO=y -# CONFIG_BACKLIGHT is not set -# CONFIG_VIDEO_BPP8 is not set -# CONFIG_VIDEO_BPP32 is not set -# CONFIG_VIDEO_ANSI is not set -CONFIG_SYS_WHITE_ON_BLACK=y -# CONFIG_PANEL is not set -CONFIG_I2C_EDID=y -CONFIG_VIDEO_IPUV3=y -CONFIG_IMX_VIDEO_SKIP=y -CONFIG_IMX_HDMI=y -CONFIG_SPLASH_SCREEN=y -CONFIG_SPLASH_SCREEN_ALIGN=y -CONFIG_HIDE_LOGO_VERSION=y -CONFIG_WATCHDOG_TIMEOUT_MSECS=60000 -CONFIG_IMX_WATCHDOG=y -CONFIG_FDT_FIXUP_PARTITIONS=y
Now that the gwventana_emmc_defconfig is the same as the gwventana_gw5904_defconfig we can remove the latter. Signed-off-by: Tim Harvey tharvey@gateworks.com
Applied to u-boot-imx, next, thanks !
Best regards, Stefano Babic
The MV88E61XX switch is used on the GW5904 which is an eMMC based board. Adding it here allows us to remove the gwventana_gw5904_defconfig. Signed-off-by: Tim Harvey tharvey@gateworks.com
sbabic@denx.de
Tim Harvey
