[U-Boot] [PATCH 1/2] usb: gadget: sdp: add missing line breaks
Cosmetic change.
Signed-off-by: Andre Heider a.heider@gmail.com --- cmd/usb_gadget_sdp.c | 4 ++-- common/spl/spl_sdp.c | 4 ++-- drivers/usb/gadget/f_sdp.c | 14 +++++++------- 3 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/cmd/usb_gadget_sdp.c b/cmd/usb_gadget_sdp.c index ae4d73c125..97d00ec545 100644 --- a/cmd/usb_gadget_sdp.c +++ b/cmd/usb_gadget_sdp.c @@ -28,13 +28,13 @@ static int do_sdp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
ret = sdp_init(controller_index); if (ret) { - pr_err("SDP init failed: %d", ret); + pr_err("SDP init failed: %d\n", ret); goto exit; }
/* This command typically does not return but jumps to an image */ sdp_handle(controller_index); - pr_err("SDP ended"); + pr_err("SDP ended\n");
exit: g_dnl_unregister(); diff --git a/common/spl/spl_sdp.c b/common/spl/spl_sdp.c index 333d518f4d..0c4603a3db 100644 --- a/common/spl/spl_sdp.c +++ b/common/spl/spl_sdp.c @@ -24,13 +24,13 @@ static int spl_sdp_load_image(struct spl_image_info *spl_image,
ret = sdp_init(controller_index); if (ret) { - pr_err("SDP init failed: %d", ret); + pr_err("SDP init failed: %d\n", ret); return -ENODEV; }
return -EINVAL; } diff --git a/drivers/usb/gadget/f_sdp.c b/drivers/usb/gadget/f_sdp.c index dd7b9cddb1..6da0530095 100644 --- a/drivers/usb/gadget/f_sdp.c +++ b/drivers/usb/gadget/f_sdp.c @@ -238,12 +238,12 @@ static void sdp_rx_command_complete(struct usb_ep *ep, struct usb_request *req) u8 report = data[0];
if (status != 0) { - pr_err("Status: %d", status); + pr_err("Status: %d\n", status); return; }
if (report != 1) { - pr_err("Unexpected report %d", report); + pr_err("Unexpected report %d\n", report); return; }
@@ -323,12 +323,12 @@ static void sdp_rx_data_complete(struct usb_ep *ep, struct usb_request *req) int datalen = req->length - 1;
if (report != 2) { - pr_err("Unexpected report %d", report); + pr_err("Unexpected report %d\n", report); return; }
@@ -361,7 +361,7 @@ static void sdp_rx_data_complete(struct usb_ep *ep, struct usb_request *req) sdp->state = SDP_STATE_TX_SEC_CONF; break; default: - pr_err("Invalid state: %d", sdp->state); + pr_err("Invalid state: %d\n", sdp->state); } }
@@ -371,7 +371,7 @@ static void sdp_tx_complete(struct usb_ep *ep, struct usb_request *req) int status = req->status;
@@ -394,7 +394,7 @@ static void sdp_tx_complete(struct usb_ep *ep, struct usb_request *req) sdp->state = SDP_STATE_IDLE; break; default: - pr_err("Wrong State: %d", sdp->state); + pr_err("Wrong State: %d\n", sdp->state); sdp->state = SDP_STATE_IDLE; break; }
The SDP protocol contains multiple 32bit pointers. Add a helper function to get a valid pointer from these values and use it.
Signed-off-by: Andre Heider a.heider@gmail.com --- drivers/usb/gadget/f_sdp.c | 13 +++++++++---- 1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/gadget/f_sdp.c b/drivers/usb/gadget/f_sdp.c index 6da0530095..43c5cfbb77 100644 --- a/drivers/usb/gadget/f_sdp.c +++ b/drivers/usb/gadget/f_sdp.c @@ -230,6 +230,11 @@ static struct usb_gadget_strings *sdp_generic_strings[] = { NULL, };
+static inline void *sdp_ptr(u32 val) +{ + return (void *)(uintptr_t)val; +} + static void sdp_rx_command_complete(struct usb_ep *ep, struct usb_request *req) { struct f_sdp *sdp = req->context; @@ -344,7 +349,7 @@ static void sdp_rx_data_complete(struct usb_ep *ep, struct usb_request *req) }
if (sdp->state == SDP_STATE_RX_FILE_DATA) { - memcpy((void *)sdp->dnl_address, req->buf + 1, datalen); + memcpy(sdp_ptr(sdp->dnl_address), req->buf + 1, datalen); sdp->dnl_address += datalen; }
@@ -622,7 +627,7 @@ static u32 sdp_jump_imxheader(void *address) }
printf("Jumping to 0x%08x\n", headerv2->entry); - entry = (void *)headerv2->entry; + entry = sdp_ptr(headerv2->entry); entry();
/* The image probably never returns hence we won't reach that point */ @@ -665,7 +670,7 @@ static void sdp_handle_in_ep(void) if (datalen > 64) datalen = 64;
- memcpy(&data[1], (void *)sdp_func->dnl_address, datalen); + memcpy(&data[1], sdp_ptr(sdp_func->dnl_address), datalen); sdp_func->in_req->length = 65;
sdp_func->dnl_bytes_remaining -= datalen; @@ -676,7 +681,7 @@ static void sdp_handle_in_ep(void) break; case SDP_STATE_JUMP: printf("Jumping to header at 0x%08x\n", sdp_func->jmp_address); - status = sdp_jump_imxheader((void *)sdp_func->jmp_address); + status = sdp_jump_imxheader(sdp_ptr(sdp_func->jmp_address));
/* If imx header fails, try some U-Boot specific headers */ if (status) {
Hi Andre,
Is there any special rationale behind this?
- return (void *)(uintptr_t)val;
From what I see from the code the (void *) cast shall be enough.
datalen);
datalen);
status =
sdp_jump_imxheader(sdp_ptr(sdp_func->jmp_address)); /* If imx header fails, try some U-Boot specific headers */ if (status) {
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Lukasz,
On 15/02/18 09:49, Lukasz Majewski wrote:
Hi Andre,
It's been a while, but if i remember correctly SDP worked on 64bit.
This fixes at least warnings on 64bit: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
Should I reword that?
Thanks, Andre
- static void sdp_rx_command_complete(struct usb_ep *ep, struct
datalen);
datalen);
status =
Lukasz Majewski
Hi Andre,
Hi Lukasz,
Hi Andre,
Yes, please.
Also please add the info regarding the warning, which we try to remove.
Best regards, Łukasz Majewski
Thanks, Andre
datalen);
datalen);
status =
Lukasz Majewski
Lukasz Majewski
This fixes the following warnings:
drivers/usb/gadget/f_sdp.c: In function ‘sdp_rx_data_complete’: drivers/usb/gadget/f_sdp.c:347:10: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] memcpy((void *)sdp->dnl_address, req->buf + 1, datalen); ^ drivers/usb/gadget/f_sdp.c: In function ‘sdp_jump_imxheader’: drivers/usb/gadget/f_sdp.c:625:10: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] entry = (void *)headerv2->entry; ^ drivers/usb/gadget/f_sdp.c: In function ‘sdp_handle_in_ep’: drivers/usb/gadget/f_sdp.c:668:20: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] memcpy(&data[1], (void *)sdp_func->dnl_address, datalen); ^ drivers/usb/gadget/f_sdp.c:679:31: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] status = sdp_jump_imxheader((void *)sdp_func->jmp_address); ^
On Thu, 15 Feb 2018 07:08:55 +0100 Andre Heider a.heider@gmail.com wrote:
Cosmetic change.
diff --git a/cmd/usb_gadget_sdp.c b/cmd/usb_gadget_sdp.c index ae4d73c125..97d00ec545 100644 --- a/cmd/usb_gadget_sdp.c +++ b/cmd/usb_gadget_sdp.c @@ -28,13 +28,13 @@ static int do_sdp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ret = sdp_init(controller_index); if (ret) {
goto exit; }
- pr_err("SDP ended\n");
exit: g_dnl_unregister(); diff --git a/common/spl/spl_sdp.c b/common/spl/spl_sdp.c index 333d518f4d..0c4603a3db 100644 --- a/common/spl/spl_sdp.c +++ b/common/spl/spl_sdp.c @@ -24,13 +24,13 @@ static int spl_sdp_load_image(struct spl_image_info *spl_image, ret = sdp_init(controller_index); if (ret) {
return -ENODEV; }
return -EINVAL;
if (status != 0) {
return; }
if (report != 1) {
return; }pr_err("Unexpected report %d\n", report);
if (status != 0) {
return; }
if (report != 2) {
}pr_err("Invalid state: %d\n", sdp->state);
if (status != 0) {
return; }pr_err("Status: %d\n", status);
sdp->state = SDP_STATE_IDLE; break; }pr_err("Wrong State: %d\n", sdp->state);
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
Cosmetic change.
Hm, this got introduced by commit 9b643e312d52 ("treewide: replace with error() with pr_err()")
error() did print the newline...
Acked-by: Stefan Agner stefan.agner@toradex.com
Best regards, Stefan
goto exit; }
return -ENODEV; }
return -EINVAL;
if (status != 0) {
return; }
if (report != 1) {
if (status != 0) {
return; }
if (report != 2) {
if (status != 0) {
Lukasz Majewski
Andre Heider
Lukasz Majewski
Stefan Agner
