[U-Boot] [RFC DO-NOT-APPLY 1/1] .travis.yml: use GRUB from Docker image
For GitLab we create our own GRUB binaries. Use them for Travis CI too.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Hello Tom,
with this patch every single of the 78 sub-job will pull our Docker image resulting in 78 times 2GB traffic and 78 times 3 min for pulling the image.
This cannot be the right way to do it. I think it would be preferable to copy our GRUB images only. Can't we have a repository on gitlab.denx.de where we put all Travis CI binary dependencies:
* GRUB images * QEMU images * cross compilers
Best regards
Heinrich --- .travis.yml | 18 ++++++++++++++---- 1 file changed, 14 insertions(+), 4 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 38fc10318e..6c1dc53fe4 100644 --- a/.travis.yml +++ b/.travis.yml @@ -8,6 +8,9 @@ dist: trusty
language: c
+services: + - docker + addons: apt: sources: @@ -54,10 +57,17 @@ install: - pip install pyelftools - grub-mkimage -o ~/grub_x86.efi -O i386-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd - grub-mkimage -o ~/grub_x64.efi -O x86_64-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd - - mkdir ~/grub2-arm - - ( cd ~/grub2-arm; wget -O - http://download.opensuse.org/ports/armv7hl/distribution/leap/42.2/repo/oss/s... | rpm2cpio | cpio -di ) - - mkdir ~/grub2-arm64 - - ( cd ~/grub2-arm64; wget -O - http://download.opensuse.org/ports/aarch64/distribution/leap/42.2/repo/oss/s... | rpm2cpio | cpio -di ) + - export DOCKER_IMAGE=trini/u-boot-gitlab-ci-runner:xenial-20190720-29Jul2019 + - sudo docker pull $DOCKER_IMAGE + - sudo docker create -ti $DOCKER_IMAGE + - export DOCKER_CONTAINER=$(sudo docker ps -aqf "ancestor=$DOCKER_IMAGE") + - mkdir -p ~/grub2-arm/usr/lib/efi/ + - mkdir -p ~/grub2-arm/usr/lib/grub2/arm-efi/ + - sudo docker cp $DOCKER_CONTAINER:/opt/grub/grubarm.efi ~/grub2-arm/usr/lib/efi/ + - sudo docker cp $DOCKER_CONTAINER:/opt/grub/grubaa64.efi ~/grub2-arm/usr/lib/grub2/arm-efi/ + - sudo docker rm $DOCKER_CONTAINER + - unset DOCKER_CONTAINER + - unset DOCKER_IMAGE
env: global: -- 2.20.1
Hello Tom,
- GRUB images
- QEMU images
- cross compilers
I was hoping that we could tell Travis to just fully use our Docker images. Looking at https://docs.travis-ci.com/user/build-stages/share-docker-image/ maybe we can just restrict the Docker pull to the test.py stages that use GRUB for tests? And then as part of a move to Xenial we could also copy out QEMU.
Hello Tom,
- GRUB images
- QEMU images
- cross compilers
We would still be downloading gitabyes where we only need a few MBs of files.
Best regards
Heinrich
Hello Tom,
- GRUB images
- QEMU images
- cross compilers
Yes, but we could also kill out some building time with the move to xenial, might end up being no real change in overall time.
