[U-Boot] [U-BOOT] [RFC PATCH] EMAC driver for H3/A64
Hello
I wanted to contribute and in the process trying to add support for the driver for EMAC controller found on H3/A64 based SoC.
Sorry, I don't want to post it at this moment but I am kind of stuck from last few days.
What is working: - Able to establish the link between host and Organepi pc(H3). - Tx on host side getting incremented. - When ping from Orangepi PC to host machine , I see ONE packet is trasnmitted over wire but its bad packet with following output after running tcpdump on host
20:41:49.148111 00:00:00:00:00:00 (oui Ethernet) > 00:00:00:00:00:00 (oui Ethernet) Null Information, send seq 0, rcv seq 0, Flags [Command], length 46 0x0000: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0010: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0020: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0030: 0000 0000 0000 0000 0000 0000 ............
What needs to be done: - Why bad packet is transmitted over the wire from Orangepi pc to Host ? - Make it compatible with external PHY.
This Patch is based on LABBE Corentin's and Chen-Yu Tsai's work done for Linux Kernel(Thanks to both of them).
Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- arch/arm/dts/sun8i-h3-orangepi-pc.dts | 10 + arch/arm/dts/sun8i-h3.dtsi | 7 + configs/orangepi_pc_defconfig | 2 + drivers/net/Makefile | 1 + drivers/net/sun8i_emac.c | 619 +++++++++++++++++++++++++++++++++ 5 files changed, 639 insertions(+) create mode 100644 drivers/net/sun8i_emac.c
diff --git a/arch/arm/dts/sun8i-h3-orangepi-pc.dts b/arch/arm/dts/sun8i-h3-orangepi-pc.dts index 30ccca0..3a40fb8 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-pc.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-pc.dts @@ -173,3 +173,13 @@ /* USB VBUS is always on */ status = "okay"; }; + +&emac { + phy = <&phy1>; + phy-mode = "mii"; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; diff --git a/arch/arm/dts/sun8i-h3.dtsi b/arch/arm/dts/sun8i-h3.dtsi index c2f63c5..19be60c 100644 --- a/arch/arm/dts/sun8i-h3.dtsi +++ b/arch/arm/dts/sun8i-h3.dtsi @@ -616,6 +616,13 @@ status = "disabled"; };
+ emac: ethernet@01c30000 { + compatible = "allwinner,sun8i-h3-emac"; + reg = <0x01c30000 0x1054>; + #address-cells = <1>; + #size-cells = <0>; + }; + gic: interrupt-controller@01c81000 { compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; reg = <0x01c81000 0x1000>, diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 8d78b47..0c129ee 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -16,3 +16,5 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_USB3_VBUS_PIN="" +#CONFIG_SUN8I_EMAC=y +CONFIG_SYS_EXTRA_OPTIONS="SUN8I_EMAC, PHYLIB" diff --git a/drivers/net/Makefile b/drivers/net/Makefile index fbedd04..f78fdc5 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -74,3 +74,4 @@ obj-$(CONFIG_FSL_MC_ENET) += ldpaa_eth/ obj-$(CONFIG_FSL_MEMAC) += fm/memac_phy.o obj-$(CONFIG_VSC9953) += vsc9953.o obj-$(CONFIG_PIC32_ETH) += pic32_mdio.o pic32_eth.o +obj-$(CONFIG_SUN8I_EMAC) = sun8i_emac.o diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c new file mode 100644 index 0000000..e2e5a28 --- /dev/null +++ b/drivers/net/sun8i_emac.c @@ -0,0 +1,619 @@ +/* + * (C) Copyright 2016 + * Author: Amit Singh Tomar, amittomer25@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Ethernet driver for H3/A64 based SoC + */ + +#include <common.h> +#include <dm.h> +#include <linux/err.h> +#include <malloc.h> +#include <miiphy.h> +#include <net.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/gpio.h> + +#define CONFIG_PHY_ADDR 0x1 + +#define SUN8I_AHB2_EPHY 0x02c8 + +#define AHB2_CFG_REG 0x005c + +#define BUS_SOFT_RST_REG0 0x02c0 +#define BUS_SOFT_RST_REG2 0x02c8 + +#define EPHY_RST (0x1 << 2) +#define EMAC_RST (0x1 << 17) + +#define SUN8I_CCU_BASE 0x01c20000 +#define SUN8I_SCTL_BASE 0x01c00000 + +#define SCTL_EMAC_TX_CLK_SRC_MII ((1 << 1) | (1 << 0)) +#define SCTL_EMAC_EPIT_MII (1 << 2) +#define SCTL_EMAC_CLK_SEL (1 << 18) /* 25 Mhz */ + +#define MDIO_CMD_MII_BUSY BIT(0) +#define MDIO_CMD_MII_WRITE BIT(1) + +#define MDIO_CMD_MII_PHY_REG_ADDR_MASK 0x000001f0 +#define MDIO_CMD_MII_PHY_REG_ADDR_SHIFT 4 +#define MDIO_CMD_MII_PHY_ADDR_MASK 0x0001f000 +#define MDIO_CMD_MII_PHY_ADDR_SHIFT 12 + +#define RX_INT BIT(8) +#define TX_INT BIT(0) +#define TX_UNF_INT BIT(4) + +#define CONFIG_TX_DESCR_NUM 128 +#define CONFIG_RX_DESCR_NUM 64 +#define CONFIG_ETH_BUFSIZE 2048 +#define TX_TOTAL_BUFSIZE (CONFIG_ETH_BUFSIZE * CONFIG_TX_DESCR_NUM) +#define RX_TOTAL_BUFSIZE (CONFIG_ETH_BUFSIZE * CONFIG_RX_DESCR_NUM) + +#define REG_DEFAULT_VALUE 0x58000 +#define REG_DEFAULT_MASK GENMASK(31, 15) + +#define REG_PHY_ADDR_SHIFT 20 +#define REG_PHY_ADDR_MASK GENMASK(4, 0) +#define REG_LED_POL BIT(17) /* 1: active low, 0: active high */ +#define REG_SHUTDOWN BIT(16) /* 1: shutdown, 0: power up */ +#define REG_PHY_SELECT BIT(15) /* 1: internal PHY, 0: external PHY */ + + +#define RX_BUF_SZ (2048*64) + +#define CONFIG_MDIO_TIMEOUT (3 * CONFIG_SYS_HZ) + +#define AHB_GATE_OFFSET_GMAC 17 +#define AHB_GATE_OFFSET_EPHY 0 + +#define SUN8I_GPD8_GMAC 4 + +/* H3/A64 EMAC Register Base*/ +#define SUN8I_EMAC_BASE 0x01c30000 + +/* H3/A64 EMAC Register's offset */ +#define CTL0 0x00 +#define CTL1 0x04 +#define INT_STA 0x08 +#define INT_EN 0x0c +#define TX_CTL0 0x10 +#define TX_CTL1 0x14 +#define TX_FLOW_CTL 0x1c +#define TX_DMA_DESC 0x20 +#define RX_CTL0 0x24 +#define RX_CTL1 0x28 +#define RX_DMA_DESC 0x34 +#define MII_CMD 0x48 +#define MII_DATA 0x4c +#define ADDR0_HIGH 0x50 +#define ADDR0_LOW 0x54 +#define TX_DMA_STA 0xb0 +#define TX_CUR_DESC 0xb4 +#define TX_CUR_BUF 0xb8 +#define RX_DMA_STA 0xc0 +#define RX_CUR_DESC 0xc4 +#define TX_CUR_BUF 0xc8 + +/* CCM Register base */ +#define SUN8I_CCM_BASE 0x01c20000 + +/* CCM Regsiter's offset */ +#define CLK_GATING_REG0 0x60 +#define CLK_GATING_REG1 0x64 +#define CLK_GATING_REG2 0x68 +#define CLK_GATING_REG3 0x6c +#define CLK_GATING_REG4 0x70 + +/* System Control Register base */ +#define SUN8I_SCTL_BASE 0x01c00000 + +/* System Control Register's offset */ +#define VER_REG 0x24 +#define EMAC_CLK_REG 0x30 + +struct emac_dma_desc { + u32 status; + u32 st; + void *buf_addr; + struct emac_dma_desc *next; +} __aligned(4); + +struct emac_eth_dev { + struct emac_dma_desc rx_chain[CONFIG_TX_DESCR_NUM]; + struct emac_dma_desc tx_chain[CONFIG_RX_DESCR_NUM]; + char rxbuffer[RX_TOTAL_BUFSIZE] __aligned(ARCH_DMA_MINALIGN); + char txbuffer[TX_TOTAL_BUFSIZE] __aligned(ARCH_DMA_MINALIGN); + + u32 interface; + u32 link; + u32 speed; + u32 duplex; + u32 phy_configured; + u32 tx_currdescnum; + u32 rx_currdescnum; + u32 addr; + u32 tx_slot; + void *mac_reg; + void *sysctl_reg; + void *ccu_reg; + struct phy_device *phydev; + struct mii_dev *bus; +}; + +static int sun8i_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + struct emac_eth_dev *priv = bus->priv; + ulong start; + u32 miiaddr; + int timeout = CONFIG_MDIO_TIMEOUT; + + /*miiaddr = ((addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) & MDIO_CMD_MII_PHY_ADDR_MASK ) | + ((reg << MDIO_CMD_MII_PHY_REG_ADDR_SHIFT) & MDIO_CMD_MII_PHY_REG_ADDR_MASK); + + writel(miiaddr | MDIO_CMD_MII_BUSY, &mac_p->miicmd);*/ + miiaddr &= ~MDIO_CMD_MII_WRITE; + miiaddr &= ~MDIO_CMD_MII_PHY_REG_ADDR_MASK; + miiaddr |= (reg << MDIO_CMD_MII_PHY_REG_ADDR_SHIFT) & + MDIO_CMD_MII_PHY_REG_ADDR_MASK; + + miiaddr &= ~MDIO_CMD_MII_PHY_ADDR_MASK; + + miiaddr |= (addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) & + MDIO_CMD_MII_PHY_ADDR_MASK; + + miiaddr |= MDIO_CMD_MII_BUSY; + + writel(miiaddr, priv->mac_reg + MII_CMD); + + start = get_timer(0); + while (get_timer(start) < timeout) { + if (!(readl(priv->mac_reg + MII_CMD) & MDIO_CMD_MII_BUSY)) + return readl(priv->mac_reg + MII_DATA); + udelay(10); + }; + + return -1; +} + +static int sun8i_mdio_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 val) +{ + struct emac_eth_dev *priv = bus->priv; + ulong start; + u32 miiaddr; + int ret = -1, timeout = CONFIG_MDIO_TIMEOUT; + + /*writel(val, &mac_p->miidata); + miiaddr = ((addr << MIIADDRSHIFT) & MII_ADDRMSK) | + ((reg << MIIREGSHIFT) & MII_REGMSK) | MII_WRITE; + + writel(miiaddr | MII_BUSY, &mac_p->miiaddr);*/ + + miiaddr &= ~MDIO_CMD_MII_PHY_REG_ADDR_MASK; + miiaddr |= (reg << MDIO_CMD_MII_PHY_REG_ADDR_SHIFT) & + MDIO_CMD_MII_PHY_REG_ADDR_MASK; + + miiaddr &= ~MDIO_CMD_MII_PHY_ADDR_MASK; + miiaddr |= (addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) & + MDIO_CMD_MII_PHY_ADDR_MASK; + + miiaddr |= MDIO_CMD_MII_WRITE; + miiaddr |= MDIO_CMD_MII_BUSY; + + writel(miiaddr, priv->mac_reg + MII_CMD); + writel(val, priv->mac_reg + MII_DATA); + + start = get_timer(0); + while (get_timer(start) < timeout) { + if (!(readl(priv->mac_reg + MII_CMD) & MDIO_CMD_MII_BUSY)) { + ret = 0; + break; + } + udelay(10); + }; + + return ret; +} + +static int sun8i_phy_init(struct emac_eth_dev *priv, void *dev) +{ + u32 val; + int mask = 0xffffffff; + +#ifdef CONFIG_PHY_ADDR + mask = 1 << CONFIG_PHY_ADDR; +#endif + struct phy_device *phydev; + + /* H3 based SoC has an Internal PHY that needs + to be configured and powered up befoe use + */ + + val = readl(priv->sysctl_reg + EMAC_CLK_REG); + val = (val & ~REG_DEFAULT_MASK) | REG_DEFAULT_VALUE; + + val |= CONFIG_PHY_ADDR << REG_PHY_ADDR_SHIFT; + val &= ~REG_SHUTDOWN; + val |= REG_PHY_SELECT; + + setbits_le32((priv->sysctl_reg + EMAC_CLK_REG), (1 << 13)); + writel(val, (priv->sysctl_reg + EMAC_CLK_REG)); + + phydev = phy_find_by_mask(priv->bus, mask, + PHY_INTERFACE_MODE_MII); + if (!phydev) + return -ENODEV; + + phy_connect_dev(phydev, dev); + + priv->phydev = phydev; + phy_config(phydev); + + return 0; +} + +static void sun8i_adjust_link(struct emac_eth_dev *priv, + struct phy_device *phydev) +{ + u32 v; + v = readl(priv->mac_reg + CTL0); + + if (phydev->duplex) + v |= BIT(0); + else + v &= ~BIT(0); + + v &= ~0x0C; + + switch (phydev->speed) { + case 1000: + break; + case 100: + v |= BIT(2); + v |= BIT(3); + break; + case 10: + v |= BIT(3); + break; + } + writel(v, priv->mac_reg + CTL0); +} + +static void rx_descs_init(struct emac_eth_dev *priv) +{ + struct emac_dma_desc *desc_table_p = &priv->rx_chain[0]; + char *rxbuffs = &priv->rxbuffer[0]; + struct emac_dma_desc *desc_p; + u32 idx; + + flush_dcache_range((unsigned int)rxbuffs, (unsigned int)rxbuffs + + RX_TOTAL_BUFSIZE); + + for (idx = 0; idx < CONFIG_RX_DESCR_NUM; idx++) { + desc_p = &desc_table_p[idx]; + desc_p->buf_addr = &rxbuffs[idx * CONFIG_ETH_BUFSIZE]; + desc_p->next = &desc_table_p[idx + 1]; + } + + /* Correcting the last pointer of the chain */ + desc_p->next = &desc_table_p[0]; + flush_dcache_range((unsigned int)priv->rx_chain, + (unsigned int)priv->rx_chain + + sizeof(priv->rx_chain)); + + writel((ulong)&desc_table_p[0], (priv->mac_reg + RX_DMA_DESC)); + priv->rx_currdescnum = 0; +} + +static void tx_descs_init(struct emac_eth_dev *priv) +{ + struct emac_dma_desc *desc_table_p = &priv->tx_chain[0]; + char *txbuffs = &priv->txbuffer[0]; + struct emac_dma_desc *desc_p; + u32 idx; + + for (idx = 0; idx < CONFIG_TX_DESCR_NUM; idx++) { + desc_p = &desc_table_p[idx]; + desc_p->buf_addr = &txbuffs[idx * CONFIG_ETH_BUFSIZE]; + desc_p->next = &desc_table_p[idx + 1]; + desc_p->status = 0; + desc_p->st = 0; + } + + /* Correcting the last pointer of the chain */ + desc_p->next = &desc_table_p[0]; + flush_dcache_range((unsigned int)priv->tx_chain, + (unsigned int)priv->tx_chain + + sizeof(priv->tx_chain)); + + writel((ulong)&desc_table_p[0], priv->mac_reg + TX_DMA_DESC); + priv->tx_currdescnum = 0; +} + +static int _sun8i_emac_eth_init(struct emac_eth_dev *priv, u8 *enetaddr) +{ + u32 reg, v; + priv->tx_slot = 0; + + reg = readl((priv->mac_reg + CTL1)); + + if (!(reg & 0x1)) { + /* Soft reset MAC */ + setbits_le32((priv->mac_reg + CTL1), 0x1 << 0); + do { + reg = readl(priv->mac_reg + CTL1); + } while ((reg & 0x01) != 0); + } + + /* Rewrite mac addres after reset */ + writel((enetaddr[3] << 24 | enetaddr[2] << 16 | enetaddr[1] << 8 + | enetaddr[0]), priv->mac_reg + ADDR0_LOW); + writel((enetaddr[5] << 8 | enetaddr[4]), priv->mac_reg + ADDR0_HIGH); + + v = readl(priv->mac_reg + TX_CTL1); + /* TX_MD Transmission starts after a full frame located in TX DMA FIFO*/ + v |= BIT(1); + writel(v, priv->mac_reg + TX_CTL1); + + v = readl(priv->mac_reg + RX_CTL1); + /* RX_MD RX DMA reads data from RX DMA FIFO to host memory after a + * complete frame has been written to RX DMA FIFO + */ + v |= BIT(1); + writel(v, priv->mac_reg + RX_CTL1); + + /* DMA */ + writel(8 << 24 , priv->mac_reg + CTL1); + + /* Enable recieve and trasnmit interupt */ + writel(RX_INT | TX_INT | TX_UNF_INT, (priv->mac_reg + INT_EN)); + + /* Intialize rx/tx descriptors */ + rx_descs_init(priv); + tx_descs_init(priv); + + /*Start up the PHY */ + if (phy_startup(priv->phydev)) { + printf("Could not initialize PHY %s\n", + priv->phydev->dev->name); + return -1; + } + + sun8i_adjust_link(priv, priv->phydev); + + /* start RX DMA */ + v = readl(priv->mac_reg + RX_CTL1); + v |= BIT(30); + writel(v, priv->mac_reg + RX_CTL1); + + v = readl(priv->mac_reg + TX_CTL1); + v |= BIT(30); + writel(v, priv->mac_reg + TX_CTL1); + + /* Enable RX/TX */ + setbits_le32(priv->mac_reg + RX_CTL0, 0x1 << 31); + setbits_le32(priv->mac_reg + TX_CTL0, 0x1 << 31); + + writel(0x3FFF, priv->mac_reg + INT_STA); + + return 0; +} + +static void sun8i_emac_board_setup(struct emac_eth_dev *priv) +{ + priv->ccu_reg = (void *)SUN8I_CCU_BASE; + priv->sysctl_reg = (void *)SUN8I_SCTL_BASE; + int pin; + + /* Set clock gating for emac */ + setbits_le32((priv->ccu_reg + CLK_GATING_REG0), + 0x1 << AHB_GATE_OFFSET_GMAC); + + /* Set clock gating for ephy */ + setbits_le32((priv->ccu_reg + CLK_GATING_REG4), + 0x1 << AHB_GATE_OFFSET_EPHY); + + /* Set Tx clock source as MII with rate 25MZ */ + clrbits_le32((priv->sysctl_reg + EMAC_CLK_REG), + SCTL_EMAC_TX_CLK_SRC_MII | + SCTL_EMAC_EPIT_MII | SCTL_EMAC_CLK_SEL); + + /* Set EMAC clock */ + setbits_le32((priv->ccu_reg + AHB2_CFG_REG), (0x1 << 1) | (0x1 << 0)); + + /* Deassert EPHY */ + setbits_le32((priv->ccu_reg + BUS_SOFT_RST_REG2), EPHY_RST); + + /* Deassert EMAC */ + setbits_le32((priv->ccu_reg + BUS_SOFT_RST_REG0), EMAC_RST); + + /* Pin mux setting for emac */ + for (pin = SUNXI_GPD(8); pin <= SUNXI_GPD(22); pin++) + sunxi_gpio_set_cfgpin(pin, SUN8I_GPD8_GMAC); +} + +static int _sun8i_eth_recv(struct emac_eth_dev *priv, uchar **packetp) +{ + u32 status, desc_num = priv->rx_currdescnum; + struct emac_dma_desc *desc_p = &priv->rx_chain[desc_num]; + int length = -EAGAIN; + uint32_t desc_start = (uint32_t)desc_p; + uint32_t desc_end = desc_start + + roundup(sizeof(*desc_p), ARCH_DMA_MINALIGN); + + uint32_t data_start = (uint32_t)desc_p->buf_addr; + uint32_t data_end; + + /* Invalidate entire buffer descriptor */ + invalidate_dcache_range(desc_start, desc_end); + + status = desc_p->status; + + length = (desc_p->status >> 16) & 0x3FFF; + + data_end = data_start + roundup(length, ARCH_DMA_MINALIGN); + invalidate_dcache_range(data_start, data_end); + *packetp = desc_p->buf_addr; + + return length; +} + +static int _sun8i_emac_eth_send(struct emac_eth_dev *priv, void *packet, + int len) +{ + u32 v, status, desc_num = priv->tx_currdescnum; + struct emac_dma_desc *desc_p = &priv->tx_chain[desc_num]; + + int length = -EAGAIN; + uint32_t desc_start = (uint32_t)desc_p; + uint32_t desc_end = desc_start + + roundup(sizeof(*desc_p), ARCH_DMA_MINALIGN); + + uint32_t data_start = (uint32_t)desc_p->buf_addr; + uint32_t data_end; + + /* Invalidate entire buffer descriptor */ + invalidate_dcache_range(desc_start, desc_end); + + desc_p->st = len; + desc_p->st |= 1<<24; + desc_p->st |= 1<<29; + + memcpy((unsigned *)desc_p->buf_addr, packet, len); + + flush_dcache_range(data_start, data_end); + + desc_p->st |= BIT(31); + desc_p->st |= BIT(30); + + desc_p->st |= 1<<29; + desc_p->status = 1<<31; + + /* Start the DMA */ + v = readl(priv->mac_reg + TX_CTL1); + v |= BIT(31);/* mandatory */ + v |= BIT(30);/* mandatory */ + writel(v, priv->mac_reg + TX_CTL1); + + return 0; +} + +static int sun8i_emac_eth_send(struct udevice *dev, void *packet, int length) +{ + struct emac_eth_dev *priv = dev_get_priv(dev); + return _sun8i_emac_eth_send(priv, packet, length); +} + + +static int sun8i_write_hwaddr(struct emac_eth_dev *priv, u8 *mac_id) +{ + u32 macid_lo, macid_hi; + + macid_lo = mac_id[0] + (mac_id[1] << 8) + (mac_id[2] << 16) + + (mac_id[3] << 24); + macid_hi = mac_id[4] + (mac_id[5] << 8); + + writel(macid_hi, priv->mac_reg + ADDR0_HIGH); + writel(macid_lo, priv->mac_reg + ADDR0_LOW); + + return 0; +} + +static void sun8i_emac_eth_stop(struct udevice *dev) +{ + /* printf("Do nothin here\n"); */ +} + + +static int sun8i_emac_eth_start(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + return _sun8i_emac_eth_init(dev->priv, pdata->enetaddr); +} + +static int sun8i_mdio_init(const char *name, struct emac_eth_dev *priv) +{ + int ret; + + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate MDIO bus\n"); + return -ENOMEM; + } + + bus->read = sun8i_mdio_read; + bus->write = sun8i_mdio_write; + snprintf(bus->name, sizeof(bus->name), name); + bus->priv = (void *)priv; + + return mdio_register(bus); +} + +static int sun8i_emac_eth_probe(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct emac_eth_dev *priv = dev_get_priv(dev); + + priv->mac_reg = (void *)pdata->iobase; + priv->interface = PHY_INTERFACE_MODE_MII; + sun8i_emac_board_setup(priv); + + + sun8i_mdio_init(dev->name, priv); + priv->bus = miiphy_get_dev_by_name(dev->name); + + return sun8i_phy_init(priv, dev); +} + +static int sun8i_eth_write_hwaddr(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct emac_eth_dev *priv = dev_get_priv(dev); + return sun8i_write_hwaddr(priv, pdata->enetaddr); +} + +static int sun8i_emac_eth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct emac_eth_dev *priv = dev_get_priv(dev); + + return _sun8i_eth_recv(priv, packetp); +} + +static const struct eth_ops sun8i_emac_eth_ops = { + .start = sun8i_emac_eth_start, + .write_hwaddr = sun8i_eth_write_hwaddr, + .send = sun8i_emac_eth_send, + .recv = sun8i_emac_eth_recv, + .stop = sun8i_emac_eth_stop, +}; + +static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + pdata->iobase = dev_get_addr(dev); + + return 0; +} + +static const struct udevice_id sun8i_emac_eth_ids[] = { + { .compatible = "allwinner,sun8i-h3-emac" }, + { } +}; + +U_BOOT_DRIVER(eth_sun8i_emac) = { + .name = "eth_sun8i_emac", + .id = UCLASS_ETH, + .of_match = sun8i_emac_eth_ids, + .ofdata_to_platdata = sun8i_emac_eth_ofdata_to_platdata, + .probe = sun8i_emac_eth_probe, + .ops = &sun8i_emac_eth_ops, + .priv_auto_alloc_size = sizeof(struct emac_eth_dev), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
On Mon, Apr 25, 2016 at 12:34:06AM +0530, Amit Singh Tomar wrote:
Hello
Hello
I have some comments below
I do not think you will doing Jumbo frame, so 2048 is too much Anyway, I have got strange reaction from hw with this value (Even BSP use 2047)
Unused, and if used, use the proper define (CONFIG_RX_DESCR_NUM/CONFIG_ETH_BUFSIZE)
typo your patch have some typos, run aspell on it
- u32 status;
- u32 st;
- void *buf_addr;
- struct emac_dma_desc *next;
+} __aligned(4);
- struct emac_dma_desc rx_chain[CONFIG_TX_DESCR_NUM];
- struct emac_dma_desc tx_chain[CONFIG_RX_DESCR_NUM];
- char rxbuffer[RX_TOTAL_BUFSIZE] __aligned(ARCH_DMA_MINALIGN);
- char txbuffer[TX_TOTAL_BUFSIZE] __aligned(ARCH_DMA_MINALIGN);
- u32 interface;
- u32 link;
- u32 speed;
- u32 duplex;
- u32 phy_configured;
- u32 tx_currdescnum;
- u32 rx_currdescnum;
- u32 addr;
- u32 tx_slot;
- void *mac_reg;
- void *sysctl_reg;
- void *ccu_reg;
- struct phy_device *phydev;
- struct mii_dev *bus;
- struct emac_eth_dev *priv = bus->priv;
- ulong start;
- u32 miiaddr;
- int timeout = CONFIG_MDIO_TIMEOUT;
- /*miiaddr = ((addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) & MDIO_CMD_MII_PHY_ADDR_MASK ) |
- miiaddr &= ~MDIO_CMD_MII_WRITE;
- miiaddr &= ~MDIO_CMD_MII_PHY_REG_ADDR_MASK;
- miiaddr |= (reg << MDIO_CMD_MII_PHY_REG_ADDR_SHIFT) &
- miiaddr &= ~MDIO_CMD_MII_PHY_ADDR_MASK;
- miiaddr |= (addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) &
- miiaddr |= MDIO_CMD_MII_BUSY;
- writel(miiaddr, priv->mac_reg + MII_CMD);
- start = get_timer(0);
- while (get_timer(start) < timeout) {
udelay(10);
- return -1;
u16 val)
- ulong start;
- u32 miiaddr;
- int ret = -1, timeout = CONFIG_MDIO_TIMEOUT;
- /*writel(val, &mac_p->miidata);
- miiaddr |= MDIO_CMD_MII_WRITE;
- writel(val, priv->mac_reg + MII_DATA);
ret = 0;
break;
udelay(10);
- return ret;
- u32 val;
- int mask = 0xffffffff;
- mask = 1 << CONFIG_PHY_ADDR;
- /* H3 based SoC has an Internal PHY that needs
- val = readl(priv->sysctl_reg + EMAC_CLK_REG);
- val = (val & ~REG_DEFAULT_MASK) | REG_DEFAULT_VALUE;
- val |= CONFIG_PHY_ADDR << REG_PHY_ADDR_SHIFT;
- val &= ~REG_SHUTDOWN;
- val |= REG_PHY_SELECT;
- setbits_le32((priv->sysctl_reg + EMAC_CLK_REG), (1 << 13));
- writel(val, (priv->sysctl_reg + EMAC_CLK_REG));
- phydev = phy_find_by_mask(priv->bus, mask,
- if (!phydev)
return -ENODEV;
- phy_connect_dev(phydev, dev);
- priv->phydev = phydev;
- phy_config(phydev);
- u32 v;
- v = readl(priv->mac_reg + CTL0);
- if (phydev->duplex)
v |= BIT(0);
- else
v &= ~BIT(0);
- v &= ~0x0C;
- switch (phydev->speed) {
- case 1000:
break;
- case 100:
v |= BIT(2);
v |= BIT(3);
break;
- case 10:
v |= BIT(3);
break;
- writel(v, priv->mac_reg + CTL0);
- struct emac_dma_desc *desc_table_p = &priv->rx_chain[0];
- char *rxbuffs = &priv->rxbuffer[0];
- struct emac_dma_desc *desc_p;
- u32 idx;
- flush_dcache_range((unsigned int)rxbuffs, (unsigned int)rxbuffs +
RX_TOTAL_BUFSIZE);
- for (idx = 0; idx < CONFIG_RX_DESCR_NUM; idx++) {
- /* Correcting the last pointer of the chain */
- desc_p->next = &desc_table_p[0];
- flush_dcache_range((unsigned int)priv->rx_chain,
- writel((ulong)&desc_table_p[0], (priv->mac_reg + RX_DMA_DESC));
- priv->rx_currdescnum = 0;
- struct emac_dma_desc *desc_table_p = &priv->tx_chain[0];
- char *txbuffs = &priv->txbuffer[0];
- u32 idx;
- for (idx = 0; idx < CONFIG_TX_DESCR_NUM; idx++) {
desc_p->status = 0;
desc_p->st = 0;
- flush_dcache_range((unsigned int)priv->tx_chain,
- writel((ulong)&desc_table_p[0], priv->mac_reg + TX_DMA_DESC);
- priv->tx_currdescnum = 0;
- u32 reg, v;
- priv->tx_slot = 0;
- reg = readl((priv->mac_reg + CTL1));
- if (!(reg & 0x1)) {
do {
You need to setup a timeout
- /* Rewrite mac addres after reset */
- writel((enetaddr[3] << 24 | enetaddr[2] << 16 | enetaddr[1] << 8
- writel((enetaddr[5] << 8 | enetaddr[4]), priv->mac_reg + ADDR0_HIGH);
Why not using sun8i_write_hwaddr ?
- v = readl(priv->mac_reg + TX_CTL1);
- /* TX_MD Transmission starts after a full frame located in TX DMA FIFO*/
- v |= BIT(1);
- writel(v, priv->mac_reg + TX_CTL1);
- v = readl(priv->mac_reg + RX_CTL1);
- /* RX_MD RX DMA reads data from RX DMA FIFO to host memory after a
- v |= BIT(1);
- writel(v, priv->mac_reg + RX_CTL1);
- /* DMA */
- writel(8 << 24 , priv->mac_reg + CTL1);
- /* Enable recieve and trasnmit interupt */
Double typo and I do not see any interrupt handling in this file
- writel(RX_INT | TX_INT | TX_UNF_INT, (priv->mac_reg + INT_EN));
- /* Intialize rx/tx descriptors */
- rx_descs_init(priv);
- tx_descs_init(priv);
- /*Start up the PHY */
- if (phy_startup(priv->phydev)) {
return -1;
- sun8i_adjust_link(priv, priv->phydev);
- /* start RX DMA */
- v |= BIT(30);
- v |= BIT(30);
- /* Enable RX/TX */
- setbits_le32(priv->mac_reg + RX_CTL0, 0x1 << 31);
- setbits_le32(priv->mac_reg + TX_CTL0, 0x1 << 31);
- writel(0x3FFF, priv->mac_reg + INT_STA);
- priv->ccu_reg = (void *)SUN8I_CCU_BASE;
- priv->sysctl_reg = (void *)SUN8I_SCTL_BASE;
- int pin;
- /* Set clock gating for emac */
- setbits_le32((priv->ccu_reg + CLK_GATING_REG0),
- /* Set clock gating for ephy */
- setbits_le32((priv->ccu_reg + CLK_GATING_REG4),
- /* Set Tx clock source as MII with rate 25MZ */
- clrbits_le32((priv->sysctl_reg + EMAC_CLK_REG),
- /* Set EMAC clock */
- setbits_le32((priv->ccu_reg + AHB2_CFG_REG), (0x1 << 1) | (0x1 << 0));
- /* Deassert EPHY */
- setbits_le32((priv->ccu_reg + BUS_SOFT_RST_REG2), EPHY_RST);
- /* Deassert EMAC */
- setbits_le32((priv->ccu_reg + BUS_SOFT_RST_REG0), EMAC_RST);
- /* Pin mux setting for emac */
- for (pin = SUNXI_GPD(8); pin <= SUNXI_GPD(22); pin++)
- u32 status, desc_num = priv->rx_currdescnum;
- struct emac_dma_desc *desc_p = &priv->rx_chain[desc_num];
- int length = -EAGAIN;
- uint32_t desc_start = (uint32_t)desc_p;
- uint32_t desc_end = desc_start +
- uint32_t data_start = (uint32_t)desc_p->buf_addr;
- uint32_t data_end;
- /* Invalidate entire buffer descriptor */
- invalidate_dcache_range(desc_start, desc_end);
- status = desc_p->status;
- length = (desc_p->status >> 16) & 0x3FFF;
- data_end = data_start + roundup(length, ARCH_DMA_MINALIGN);
- invalidate_dcache_range(data_start, data_end);
- *packetp = desc_p->buf_addr;
- return length;
I do not understand why you do not check for BIT(31)(DMA own)
int len)
- u32 v, status, desc_num = priv->tx_currdescnum;
- struct emac_dma_desc *desc_p = &priv->tx_chain[desc_num];
not used
- desc_p->st = len;
- desc_p->st |= 1<<24;
- desc_p->st |= 1<<29;
Use BIT()
- memcpy((unsigned *)desc_p->buf_addr, packet, len);
- flush_dcache_range(data_start, data_end);
- desc_p->st |= BIT(31);
- desc_p->st |= BIT(30);
Why setting this twice ?
- desc_p->status = 1<<31;
Use BIT() and put a comment of meaning of thoses bits.
For your send error, try using the same order than my driver (bit 29) Problem with sending I got was about write order and cache.
Regards
Amit Singh Tomar
LABBE Corentin
