[U-Boot] [PATCH v2 0/6] handle compression buffer overflows
v2: added acks, various suggested cleanups
This series fixes gzip, lzma, and lzo to not overflow when writing to output buffers. Without this, it might be possible for untrusted compressed input to overflow the buffers used to hold the decompressed image.
To catch these conditions, I added a series of compression tests available in the sandbox build. Without the fixes in patches 3, 4, and 5, the overflows are visible.
Thanks,
-Kees
Kees Cook (6): sandbox: add compression tests documentation: add more compression configs gzip: correctly bounds-check output buffer lzma: correctly bounds-check output buffer lzo: correctly bounds-check output buffer bootm: allow correct bounds-check of destination
README | 9 ++ common/cmd_bootm.c | 2 +- include/configs/sandbox.h | 5 + lib/gunzip.c | 4 +- lib/lzma/LzmaTools.c | 8 +- lib/lzo/lzo1x_decompress.c | 8 +- test/Makefile | 1 + test/compression.c | 335 ++++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 366 insertions(+), 6 deletions(-) create mode 100644 test/compression.c
This adds the "test_compression" command when building the sandbox. This tests the existing compression and decompression routines for simple sanity and for buffer overflow conditions.
Signed-off-by: Kees Cook keescook@chromium.org --- v2: - updates, suggested by Simon Glass: - replace license text with correct stub - drop redundant #ifdefs --- include/configs/sandbox.h | 5 + test/Makefile | 1 + test/compression.c | 335 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 341 insertions(+) create mode 100644 test/compression.c
diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index af3d6ad..4027030 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -109,4 +109,9 @@ "stdout=serial\0" \ "stderr=serial\0"
+#define CONFIG_GZIP_COMPRESSED +#define CONFIG_BZIP2 +#define CONFIG_LZO +#define CONFIG_LZMA + #endif diff --git a/test/Makefile b/test/Makefile index 99ce890..a68613d 100644 --- a/test/Makefile +++ b/test/Makefile @@ -9,6 +9,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)libtest.o
COBJS-$(CONFIG_SANDBOX) += command_ut.o +COBJS-$(CONFIG_SANDBOX) += compression.o
COBJS := $(sort $(COBJS-y)) SRCS := $(COBJS:.o=.c) diff --git a/test/compression.c b/test/compression.c new file mode 100644 index 0000000..8834d5e --- /dev/null +++ b/test/compression.c @@ -0,0 +1,335 @@ +/* + * Copyright (c) 2013, The Chromium Authors + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define DEBUG + +#include <common.h> +#include <command.h> +#include <malloc.h> + +#include <u-boot/zlib.h> +#include <bzlib.h> + +#include <lzma/LzmaTypes.h> +#include <lzma/LzmaDec.h> +#include <lzma/LzmaTools.h> + +#include <linux/lzo.h> + +static const char plain[] = + "I am a highly compressable bit of text.\n" + "I am a highly compressable bit of text.\n" + "I am a highly compressable bit of text.\n" + "There are many like me, but this one is mine.\n" + "If I were any shorter, there wouldn't be much sense in\n" + "compressing me in the first place. At least with lzo, anyway,\n" + "which appears to behave poorly in the face of short text\n" + "messages.\n"; + +/* bzip2 -c /tmp/plain.txt > /tmp/plain.bz2 */ +static const char bzip2_compressed[] = + "\x42\x5a\x68\x39\x31\x41\x59\x26\x53\x59\xe5\x63\xdd\x09\x00\x00" + "\x28\x57\x80\x00\x10\x40\x85\x20\x20\x04\x00\x3f\xef\xdf\xf0\x30" + "\x00\xd6\xd0\x34\x91\x89\xa6\xf5\x4d\x19\x1a\x19\x0d\x02\x34\xd4" + "\xc9\x00\x34\x34\x00\x02\x48\x41\x35\x4f\xd4\xc6\x88\xd3\x50\x3d" + "\x4f\x51\x82\x4f\x88\xc3\x0d\x05\x62\x4f\x91\xa3\x52\x1b\xd0\x52" + "\x41\x4a\xa3\x98\xc2\x6b\xca\xa3\x82\xa5\xac\x8b\x15\x99\x68\xad" + "\xdf\x29\xd6\xf1\xf7\x5a\x10\xcd\x8c\x26\x61\x94\x95\xfe\x9e\x16" + "\x18\x28\x69\xd4\x23\x64\xcc\x2b\xe5\xe8\x5f\x00\xa4\x70\x26\x2c" + "\xee\xbd\x59\x6d\x6a\xec\xfc\x31\xda\x59\x0a\x14\x2a\x60\x1c\xf0" + "\x04\x86\x73\x9a\xc5\x5b\x87\x3f\x5b\x4c\x93\xe6\xb5\x35\x0d\xa6" + "\xb1\x2e\x62\x7b\xab\x67\xe7\x99\x2a\x14\x5e\x9f\x64\xcb\x96\xf4" + "\x0d\x65\xd4\x39\xe6\x8b\x7e\xea\x1c\x03\x69\x97\x83\x58\x91\x96" + "\xe1\xf0\x9d\xa4\x15\x8b\xb8\xc6\x93\xdc\x3d\xd9\x3c\x22\x55\xef" + "\xfb\xbb\x2a\xd3\x87\xa2\x8b\x04\xd9\x19\xf8\xe2\xfd\x4f\xdb\x1a" + "\x07\xc8\x60\xa3\x3f\xf8\xbb\x92\x29\xc2\x84\x87\x2b\x1e\xe8\x48"; +static const unsigned long bzip2_compressed_size = 240; + +/* lzma -z -c /tmp/plain.txt > /tmp/plain.lzma */ +static const char lzma_compressed[] = + "\x5d\x00\x00\x80\x00\xff\xff\xff\xff\xff\xff\xff\xff\x00\x24\x88" + "\x08\x26\xd8\x41\xff\x99\xc8\xcf\x66\x3d\x80\xac\xba\x17\xf1\xc8" + "\xb9\xdf\x49\x37\xb1\x68\xa0\x2a\xdd\x63\xd1\xa7\xa3\x66\xf8\x15" + "\xef\xa6\x67\x8a\x14\x18\x80\xcb\xc7\xb1\xcb\x84\x6a\xb2\x51\x16" + "\xa1\x45\xa0\xd6\x3e\x55\x44\x8a\x5c\xa0\x7c\xe5\xa8\xbd\x04\x57" + "\x8f\x24\xfd\xb9\x34\x50\x83\x2f\xf3\x46\x3e\xb9\xb0\x00\x1a\xf5" + "\xd3\x86\x7e\x8f\x77\xd1\x5d\x0e\x7c\xe1\xac\xde\xf8\x65\x1f\x4d" + "\xce\x7f\xa7\x3d\xaa\xcf\x26\xa7\x58\x69\x1e\x4c\xea\x68\x8a\xe5" + "\x89\xd1\xdc\x4d\xc7\xe0\x07\x42\xbf\x0c\x9d\x06\xd7\x51\xa2\x0b" + "\x7c\x83\x35\xe1\x85\xdf\xee\xfb\xa3\xee\x2f\x47\x5f\x8b\x70\x2b" + "\xe1\x37\xf3\x16\xf6\x27\x54\x8a\x33\x72\x49\xea\x53\x7d\x60\x0b" + "\x21\x90\x66\xe7\x9e\x56\x61\x5d\xd8\xdc\x59\xf0\xac\x2f\xd6\x49" + "\x6b\x85\x40\x08\x1f\xdf\x26\x25\x3b\x72\x44\xb0\xb8\x21\x2f\xb3" + "\xd7\x9b\x24\x30\x78\x26\x44\x07\xc3\x33\xd1\x4d\x03\x1b\xe1\xff" + "\xfd\xf5\x50\x8d\xca"; +static const unsigned long lzma_compressed_size = 229; + +/* lzop -c /tmp/plain.txt > /tmp/plain.lzo */ +static const char lzo_compressed[] = + "\x89\x4c\x5a\x4f\x00\x0d\x0a\x1a\x0a\x10\x30\x20\x60\x09\x40\x01" + "\x05\x03\x00\x00\x09\x00\x00\x81\xb4\x52\x09\x54\xf1\x00\x00\x00" + "\x00\x09\x70\x6c\x61\x69\x6e\x2e\x74\x78\x74\x65\xb1\x07\x9c\x00" + "\x00\x01\x5e\x00\x00\x01\x0f\xc3\xc7\x7a\xe0\x00\x16\x49\x20\x61" + "\x6d\x20\x61\x20\x68\x69\x67\x68\x6c\x79\x20\x63\x6f\x6d\x70\x72" + "\x65\x73\x73\x61\x62\x6c\x65\x20\x62\x69\x74\x20\x6f\x66\x20\x74" + "\x65\x78\x74\x2e\x0a\x20\x2f\x9c\x00\x00\x22\x54\x68\x65\x72\x65" + "\x20\x61\x72\x65\x20\x6d\x61\x6e\x79\x20\x6c\x69\x6b\x65\x20\x6d" + "\x65\x2c\x20\x62\x75\x74\x20\x74\x68\x69\x73\x20\x6f\x6e\x65\x20" + "\x69\x73\x20\x6d\x69\x6e\x65\x2e\x0a\x49\x66\x20\x49\x20\x77\x84" + "\x06\x0a\x6e\x79\x20\x73\x68\x6f\x72\x74\x65\x72\x2c\x20\x74\x90" + "\x08\x00\x08\x77\x6f\x75\x6c\x64\x6e\x27\x74\x20\x62\x65\x20\x6d" + "\x75\x63\x68\x20\x73\x65\x6e\x73\x65\x20\x69\x6e\x0a\xf8\x19\x02" + "\x69\x6e\x67\x20\x6d\x64\x02\x64\x06\x00\x5a\x20\x66\x69\x72\x73" + "\x74\x20\x70\x6c\x61\x63\x65\x2e\x20\x41\x74\x20\x6c\x65\x61\x73" + "\x74\x20\x77\x69\x74\x68\x20\x6c\x7a\x6f\x2c\x20\x61\x6e\x79\x77" + "\x61\x79\x2c\x0a\x77\x68\x69\x63\x68\x20\x61\x70\x70\x65\x61\x72" + "\x73\x20\x74\x6f\x20\x62\x65\x68\x61\x76\x65\x20\x70\x6f\x6f\x72" + "\x6c\x79\x20\x69\x6e\x20\x74\x68\x65\x20\x66\x61\x63\x65\x20\x6f" + "\x66\x20\x73\x68\x6f\x72\x74\x20\x74\x65\x78\x74\x0a\x6d\x65\x73" + "\x73\x61\x67\x65\x73\x2e\x0a\x11\x00\x00\x00\x00\x00\x00"; +static const unsigned long lzo_compressed_size = 334; + + +#define TEST_BUFFER_SIZE 512 + +typedef int (*mutate_func)(void *, unsigned long, void *, unsigned long, + unsigned long *); + +static int compress_using_gzip(void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + int ret; + unsigned long inout_size = out_max; + + ret = gzip(out, &inout_size, in, in_size); + if (out_size) + *out_size = inout_size; + + return ret; +} + +static int uncompress_using_gzip(void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + int ret; + unsigned long inout_size = in_size; + + ret = gunzip(out, out_max, in, &inout_size); + if (out_size) + *out_size = inout_size; + + return ret; +} + +static int compress_using_bzip2(void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + /* There is no bzip2 compression in u-boot, so fake it. */ + assert(in_size == strlen(plain)); + assert(memcmp(plain, in, in_size) == 0); + + if (bzip2_compressed_size > out_max) + return -1; + + memcpy(out, bzip2_compressed, bzip2_compressed_size); + if (out_size) + *out_size = bzip2_compressed_size; + + return 0; +} + +static int uncompress_using_bzip2(void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + int ret; + unsigned int inout_size = out_max; + + ret = BZ2_bzBuffToBuffDecompress(out, &inout_size, in, in_size, + CONFIG_SYS_MALLOC_LEN < (4096 * 1024), 0); + if (out_size) + *out_size = inout_size; + + return (ret != BZ_OK); +} + +static int compress_using_lzma(void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + /* There is no lzma compression in u-boot, so fake it. */ + assert(in_size == strlen(plain)); + assert(memcmp(plain, in, in_size) == 0); + + if (lzma_compressed_size > out_max) + return -1; + + memcpy(out, lzma_compressed, lzma_compressed_size); + if (out_size) + *out_size = lzma_compressed_size; + + return 0; +} + +static int uncompress_using_lzma(void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + int ret; + SizeT inout_size = out_max; + + ret = lzmaBuffToBuffDecompress(out, &inout_size, in, in_size); + if (out_size) + *out_size = inout_size; + + return (ret != SZ_OK); +} + +static int compress_using_lzo(void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + /* There is no lzo compression in u-boot, so fake it. */ + assert(in_size == strlen(plain)); + assert(memcmp(plain, in, in_size) == 0); + + if (lzo_compressed_size > out_max) + return -1; + + memcpy(out, lzo_compressed, lzo_compressed_size); + if (out_size) + *out_size = lzo_compressed_size; + + return 0; +} + +static int uncompress_using_lzo(void *in, unsigned long in_size, + void *out, unsigned long out_max, + unsigned long *out_size) +{ + int ret; + size_t input_size = in_size; + size_t output_size = out_max; + + ret = lzop_decompress(in, input_size, out, &output_size); + if (out_size) + *out_size = output_size; + + return (ret != LZO_E_OK); +} + +#define errcheck(statement) if (!(statement)) { \ + fprintf(stderr, "\tFailed: %s\n", #statement); \ + ret = 1; \ + goto out; \ +} + +static int run_test(char *name, mutate_func compress, mutate_func uncompress) +{ + ulong orig_size, compressed_size, uncompressed_size; + void *orig_buf; + void *compressed_buf = NULL; + void *uncompressed_buf = NULL; + void *compare_buf = NULL; + int ret; + + printf(" testing %s ...\n", name); + + orig_buf = (void *)plain; + orig_size = strlen(orig_buf); /* Trailing NULL not included. */ + errcheck(orig_size > 0); + + compressed_size = uncompressed_size = TEST_BUFFER_SIZE; + compressed_buf = malloc(compressed_size); + errcheck(compressed_buf != NULL); + uncompressed_buf = malloc(uncompressed_size); + errcheck(uncompressed_buf != NULL); + compare_buf = malloc(uncompressed_size); + errcheck(compare_buf != NULL); + + /* Compress works as expected. */ + printf("\torig_size:%lu\n", orig_size); + memset(compressed_buf, 'A', TEST_BUFFER_SIZE); + errcheck(compress(orig_buf, orig_size, + compressed_buf, compressed_size, + &compressed_size) == 0); + printf("\tcompressed_size:%lu\n", compressed_size); + errcheck(compressed_size > 0); + errcheck(compressed_size < orig_size); + errcheck(((char *)compressed_buf)[compressed_size-1] != 'A'); + errcheck(((char *)compressed_buf)[compressed_size] == 'A'); + + /* Uncompresses with space remaining. */ + errcheck(uncompress(compressed_buf, compressed_size, + uncompressed_buf, uncompressed_size, + &uncompressed_size) == 0); + printf("\tuncompressed_size:%lu\n", uncompressed_size); + errcheck(uncompressed_size == orig_size); + errcheck(memcmp(orig_buf, uncompressed_buf, orig_size) == 0); + + /* Uncompresses with exactly the right size output buffer. */ + memset(uncompressed_buf, 'A', TEST_BUFFER_SIZE); + errcheck(uncompress(compressed_buf, compressed_size, + uncompressed_buf, orig_size, + &uncompressed_size) == 0); + errcheck(uncompressed_size == orig_size); + errcheck(memcmp(orig_buf, uncompressed_buf, orig_size) == 0); + errcheck(((char *)uncompressed_buf)[orig_size] == 'A'); + + /* Make sure compression does not over-run. */ + memset(compare_buf, 'A', TEST_BUFFER_SIZE); + ret = compress(orig_buf, orig_size, + compare_buf, compressed_size - 1, + NULL); + errcheck(((char *)compare_buf)[compressed_size] == 'A'); + errcheck(ret != 0); + printf("\tcompress does not overrun\n"); + + /* Make sure decompression does not over-run. */ + memset(compare_buf, 'A', TEST_BUFFER_SIZE); + ret = uncompress(compressed_buf, compressed_size, + compare_buf, uncompressed_size - 1, + NULL); + errcheck(((char *)compare_buf)[uncompressed_size - 1] == 'A'); + errcheck(ret != 0); + printf("\tuncompress does not overrun\n"); + + /* Got here, everything is fine. */ + ret = 0; + +out: + printf(" %s: %s\n", name, ret == 0 ? "ok" : "FAILED"); + + free(compare_buf); + free(uncompressed_buf); + free(compressed_buf); + + return ret; +} + + +static int do_test_compression(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + int err = 0; + + err += run_test("gzip", compress_using_gzip, uncompress_using_gzip); + err += run_test("bzip2", compress_using_bzip2, uncompress_using_bzip2); + err += run_test("lzma", compress_using_lzma, uncompress_using_lzma); + err += run_test("lzo", compress_using_lzo, uncompress_using_lzo); + + printf("test_compression %s\n", err == 0 ? "ok" : "FAILED"); + + return err; +} + +U_BOOT_CMD( + test_compression, 5, 1, do_test_compression, + "Basic test of compressors: gzip bzip2 lzma lzo", "" +);
This adds the missing compression config items to the README.
Signed-off-by: Kees Cook keescook@chromium.org --- v2: - adjusted language slightly, thanks to Simon Glass --- README | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/README b/README index 3918807..6485350 100644 --- a/README +++ b/README @@ -1680,6 +1680,10 @@ CBFS (Coreboot Filesystem) support to compress the specified memory at its best effort.
- Compression support: + CONFIG_GZIP + + Enabled by default to support gzip compressed images. + CONFIG_BZIP2
If this option is set, support for bzip2 compressed @@ -1713,6 +1717,11 @@ CBFS (Coreboot Filesystem) support then calculate the amount of needed dynamic memory (ensuring the appropriate CONFIG_SYS_MALLOC_LEN value).
+ CONFIG_LZO + + If this option is set, support for LZO compressed images + is included. + - MII/PHY support: CONFIG_PHY_ADDR
The output buffer size must not be reset by the gzip decoder or there is a risk of overflowing memory during decompression.
Signed-off-by: Kees Cook keescook@chromium.org Acked-by: Simon Glass sjg@chromium.org --- lib/gunzip.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/gunzip.c b/lib/gunzip.c index 9959781..35abfb3 100644 --- a/lib/gunzip.c +++ b/lib/gunzip.c @@ -89,13 +89,13 @@ int zunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp, s.avail_out = dstlen; do { r = inflate(&s, Z_FINISH); - if (r != Z_STREAM_END && r != Z_BUF_ERROR && stoponerr == 1) { + if (stoponerr == 1 && r != Z_STREAM_END && + (s.avail_out == 0 || r != Z_BUF_ERROR)) { printf("Error: inflate() returned %d\n", r); inflateEnd(&s); return -1; } s.avail_in = *lenp - offset - (int)(s.next_out - (unsigned char*)dst); - s.avail_out = dstlen; } while (r == Z_BUF_ERROR); *lenp = s.next_out - (unsigned char *) dst; inflateEnd(&s);
Hi Kees,
} s.avail_in = *lenp - offset - (int)(s.next_out - (unsigned char*)dst);(s.avail_out == 0 || r != Z_BUF_ERROR)) { printf("Error: inflate() returned %d\n", r); inflateEnd(&s); return -1;
} while (r == Z_BUF_ERROR); *lenp = s.next_out - (unsigned char *) dst; inflateEnd(&s);s.avail_out = dstlen;
I have done u-boot upgrade to v2013.10 version and I see the problem with this patch when I am trying to boot my zynq image.
After reverting this patch everything works as expected.
Here is the image I am using. http://www.monstr.eu/20131108-image.ub
Below is the bootlog.
Do you have any idea what can be wrong?
Thanks, Michal
U-Boot 2013.10 (Nov 08 2013 - 13:02:26)
Memory: ECC disabled DRAM: 1 GiB WARNING: Caches not enabled MMC: zynq_sdhci: 0 SF: Detected N25Q128A with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Net: Gem.e000b000 U-BOOT for zynq-zc702
Gem.e000b000 Waiting for PHY auto negotiation to complete.... done BOOTP broadcast 1 DHCP client bound to address 192.168.0.90 Hit any key to stop autoboot: 0 U-Boot-PetaLinux> run netboot Gem.e000b000:7 is connected to Gem.e000b000. Reconnecting to Gem.e000b000 Gem.e000b000 Waiting for PHY auto negotiation to complete.... done Using Gem.e000b000 device TFTP from server 192.168.0.100; our IP address is 192.168.0.90 Filename 'image.ub'. Load address: 0x1000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ####################################### 2 MiB/s done Bytes transferred = 12964752 (c5d390 hex) ## Loading kernel from FIT Image at 01000000 ... Using 'conf@1' configuration Trying 'kernel@1' kernel subimage Description: PetaLinux Kernel Type: Kernel Image Compression: gzip compressed Data Start: 0x010000f0 Data Size: 12949283 Bytes = 12.3 MiB Architecture: ARM OS: Linux Load Address: 0x10008000 Entry Point: 0x10008000 Hash algo: crc32 Hash value: 39564940 Verifying Hash Integrity ... crc32+ OK ## Loading fdt from FIT Image at 01000000 ... Using 'conf@1' configuration Trying 'fdt@1' fdt subimage Description: Flattened Device Tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x01c598f8 Data Size: 14133 Bytes = 13.8 KiB Architecture: ARM Hash algo: crc32 Hash value: be457cb0 Hash algo: sha1 Hash value: 206ffdb413e297d4a143a47fa8598cee4527a63a Verifying Hash Integrity ... crc32+ sha1+ OK Booting using the fdt blob at 0x1c598f8 Uncompressing Kernel Image ... Error: inflate() returned -5 GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover resetting ...
On Fri, Nov 8, 2013 at 4:04 AM, Michal Simek monstr@monstr.eu wrote:
Hi Kees,
Eek, sorry this is causing you trouble!
Is there any way you can extract just the gzipped kernel from this image? I'm not sure how to get at it from this .ub file.
Do you have any idea what can be wrong? [...] Uncompressing Kernel Image ... Error: inflate() returned -5 GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover resetting ...
Either my change is failing to detect end-of-buffer correctly, or it _is_, in which case this has uncovered an unsafe caller of gunzip. This is after the "Uncompressing" message, so it's this caller:
case IH_COMP_GZIP: printf(" Uncompressing %s ... ", type_name); if (gunzip(load_buf, unc_len, image_buf, &image_len) != 0) { puts("GUNZIP: uncompress, out-of-mem or overwrite " "error - must RESET board to recover\n"); if (boot_progress) bootstage_error(BOOTSTAGE_ID_DECOMP_IMAGE); return BOOTM_ERR_RESET; }
*load_end = load + image_len; break;
If the uncompressed length of the kernel image is larger than "unc_len", then this is catching a legitimate memory overflow. This is entirely controlled by CONFIG_SYS_BOOTM_LEN. Is it possible this is set too low for your build?
-Kees
Hi Kees,
no worries. Problem is on my side. Look below.
Sure just run imi. Then you will get data start address and length. And you can use unzip command.
case IH_COMP_GZIP: printf(" Uncompressing %s ... ", type_name); if (gunzip(load_buf, unc_len, image_buf, &image_len) != 0) { puts("GUNZIP: uncompress, out-of-mem or overwrite " "error - must RESET board to recover\n"); if (boot_progress) bootstage_error(BOOTSTAGE_ID_DECOMP_IMAGE); return BOOTM_ERR_RESET; } *load_end = load + image_len; break;
Ah yes, that's the issue. My image is 14MB and have just 16MB BOOTM_LEN.
Thanks for pointing to this. Michal
Hi Kees,
I have read README about BOOTM_LEN and it cares just about compressed images but macro is generic enough to also handle uncompressed images and this checking should be probably done too.
Thanks, Michal
The output buffer size must be correctly passed to the lzma decoder or there is a risk of overflowing memory during decompression. Switching to the LZMA_FINISH_END mode means nothing is left in an unknown state once the buffer becomes full.
Signed-off-by: Kees Cook keescook@chromium.org Acked-by: Simon Glass sjg@chromium.org --- lib/lzma/LzmaTools.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/lib/lzma/LzmaTools.c b/lib/lzma/LzmaTools.c index 8d1165e11b..0aec2f9 100644 --- a/lib/lzma/LzmaTools.c +++ b/lib/lzma/LzmaTools.c @@ -97,15 +97,19 @@ int lzmaBuffToBuffDecompress (unsigned char *outStream, SizeT *uncompressedSize, g_Alloc.Alloc = SzAlloc; g_Alloc.Free = SzFree;
+ /* Short-circuit early if we know the buffer can't hold the results. */ + if (outSizeFull != (SizeT)-1 && *uncompressedSize < outSizeFull) + return SZ_ERROR_OUTPUT_EOF; + /* Decompress */ - outProcessed = outSizeFull; + outProcessed = *uncompressedSize;
WATCHDOG_RESET();
res = LzmaDecode( outStream, &outProcessed, inStream + LZMA_DATA_OFFSET, &compressedSize, - inStream, LZMA_PROPS_SIZE, LZMA_FINISH_ANY, &state, &g_Alloc); + inStream, LZMA_PROPS_SIZE, LZMA_FINISH_END, &state, &g_Alloc); *uncompressedSize = outProcessed; if (res != SZ_OK) { return res;
This checks the size of the output buffer and fails if it was going to overflow the buffer during lzo decompression.
Signed-off-by: Kees Cook keescook@chromium.org Acked-by: Simon Glass sjg@chromium.org --- lib/lzo/lzo1x_decompress.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/lib/lzo/lzo1x_decompress.c b/lib/lzo/lzo1x_decompress.c index e6ff708..35f3793 100644 --- a/lib/lzo/lzo1x_decompress.c +++ b/lib/lzo/lzo1x_decompress.c @@ -68,13 +68,14 @@ int lzop_decompress(const unsigned char *src, size_t src_len, unsigned char *start = dst; const unsigned char *send = src + src_len; u32 slen, dlen; - size_t tmp; + size_t tmp, remaining; int r;
src = parse_header(src); if (!src) return LZO_E_ERROR;
+ remaining = *dst_len; while (src < send) { /* read uncompressed block size */ dlen = get_unaligned_be32(src); @@ -93,6 +94,10 @@ int lzop_decompress(const unsigned char *src, size_t src_len, if (slen <= 0 || slen > dlen) return LZO_E_ERROR;
+ /* abort if buffer ran out of room */ + if (dlen > remaining) + return LZO_E_OUTPUT_OVERRUN; + /* decompress */ tmp = dlen; r = lzo1x_decompress_safe((u8 *) src, slen, dst, &tmp); @@ -105,6 +110,7 @@ int lzop_decompress(const unsigned char *src, size_t src_len,
src += slen; dst += dlen; + remaining -= dlen; }
return LZO_E_INPUT_OVERRUN;
While nothing presently examines the destination size, it should at least be correct so that future users of sys_mapmem() will not be surprised. Without this, it might be possible to overflow memory.
Signed-off-by: Kees Cook keescook@chromium.org Acked-by: Simon Glass sjg@chromium.org --- common/cmd_bootm.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 046e22f..0f67112 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -368,7 +368,7 @@ static int bootm_load_os(bootm_headers_t *images, unsigned long *load_end,
const char *type_name = genimg_get_type_name(os.type);
- load_buf = map_sysmem(load, image_len); + load_buf = map_sysmem(load, unc_len); image_buf = map_sysmem(image_start, image_len); switch (comp) { case IH_COMP_NONE:
Can someone commit this series? It's been fully acked now...
Thanks,
-Kees
Thanks,
-Kees
Hi Kees,
I'm happy to pull these in for Tom.
I see a few warnings when I run buildman:
$ ./tools/buildman/buildman -b us-kees sandbox -se Summary of 7 commits for 1 boards (1 thread, 32 jobs per thread) 01: omap5: Correct include order, drop CONFIG_SYS_PROMPT define 02: sandbox: add compression tests sandbox: + sandbox +cmd_bootm.c: In function ‘bootm_load_os’: +cmd_bootm.c:443:11: warning: passing argument 4 of ‘lzop_decompress’ from incompatible pointer type [enabled by default] +/usr/local/google/c/cosarm/src/third_party/u-boot/us-kees/.bm-work/00/include/linux/lzo.h:31:5: note: expected ‘size_t *’ but argument is of type ‘uint *’ +cmd_ximg.c: In function ‘do_imgextract’: +cmd_ximg.c:225:6: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] +cmd_ximg.c:225:14: warning: ‘hdr’ may be used uninitialized in this function [-Wuninitialized] 03: documentation: add more compression configs 04: gzip: correctly bounds-check output buffer 05: lzma: correctly bounds-check output buffer 06: lzo: correctly bounds-check output buffer 07: bootm: allow correct bounds-check of destination
I believe these are pre-existing, but didn't happen for sandbox since it was not enabling these options, but could you please create a patch to fix these that we can apply first?
To build for sandbox: 'make sandbox_config; make'
Thanks,
-Kees
Thanks,
-Kees
-- Kees Cook Chrome OS Security
Kees Cook
Michal Simek
