[U-Boot] [RFC] colibri_imx7: Do not hardcode the memory size
Instead of hardcoding the memory size, use the generic imx_ddr_size() function, which extracts the memory size in runtime by reading the DDR controller registers.
This helps in supporting 512MB and 1GB modules.
Signed-off-by: Fabio Estevam festevam@gmail.com --- Hi Stefan,
I don't have the hardware to test, but I think we should be good by using imx_ddr_size() here.
board/toradex/colibri_imx7/colibri_imx7.c | 2 +- include/configs/colibri_imx7.h | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/board/toradex/colibri_imx7/colibri_imx7.c b/board/toradex/colibri_imx7/colibri_imx7.c index 2b7591e..9029c0b 100644 --- a/board/toradex/colibri_imx7/colibri_imx7.c +++ b/board/toradex/colibri_imx7/colibri_imx7.c @@ -52,7 +52,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + gd->ram_size = imx_ddr_size();
return 0; } diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index ff6bd67..02849ba 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -14,7 +14,6 @@ #include "mx7_common.h"
/*#define CONFIG_DBG_MONITOR*/ -#define PHYS_SDRAM_SIZE SZ_1G
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M)
Hi Fabio
Stefan is currently at Linaro Connect and may not have access to hardware.
In theory that sounds fine. However, in practise that function seems to return zero on our modules which leads to it freezing during boot.
I am currently looking more closely into it and will keep you posted.
Hi Stefan,
PHYS_SDRAM_SIZE);
BTW: Notice the generic get_ram_size() function which actually already did/does figure out the RAM size across all our modules regardless of being NXP/imx based or not. The size given there is just some kind of upper bound maxsize:
https://git.denx.de/?p=u-boot.git;a=blob;f=common/memsize.c#l21
Cheers
Marcel
Hi Fabio
I had a closer look at it. It turns out we kind of over provision the DDR controller in order to be able to actually use various kinds and sizes of chips without any need to change anything. So while this really works the imx_ddr_size() function currently seems to overflow in which case it just returns zero. I suggest fixing this by capping the function which I will send out a patch for shortly.
No, due to us over provisioning the DDR controller and using the generic get_ram_size() function we already do automatically detecting 256MB, 512MB or 1GB modules.
Hi Stefan,
PHYS_SDRAM_SIZE);
I suggest we keep using the generic get_ram_size() function which works very well but rather than passing a hardcoded maxsize we use the i.MX 7 specific imx_ddr_size() function. I will send out an updated patch.
Cheers
Marcel
Fabio Estevam
Marcel Ziswiler
