Hi Tom,
please pull MIPS updates for 2019.07
https://travis-ci.org/danielschwierzeck/u-boot/builds/527853668
The following changes since commit b4ee6daad7a2604ca9466b2ba48de86cc27d381f:
Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imx (2019-05-01 07:25:51 -0400)
git://git.denx.de/u-boot-mips.git tags/mips-pull-2019-05-03
for you to fetch changes up to 5c629b1b69f780540e6e3bcc57d29438749f97c5:
net: mscc: ocelot: Update DTS for Luton pcb90 (2019-05-03 16:46:36 +0200)
---------------------------------------------------------------- - mscc: small fixes, enhance network support for Serval, Luton amd Ocelot - mt7620: rename arch to more generic name mtmips - mips: pass initrd addresses via DT as physical addresses
---------------------------------------------------------------- Horatiu Vultur (13): mips: mscc: serval: Fix reset board: mscc: serval: Fix board detect net: Add MSCC Serval network driver. board: mscc: serval: Update MSCC Serval boards net: mscc: serval: Add ethernet nodes for Serval configs: mscc_serval: Add network support arch: mips: Update initrd_start and initrd_end net: mscc: ocelot: Update network driver for pcb120 board: mscc: ocelot: Update MSCC Ocelot board. net: mscc: ocelot: Update DTS for Ocelot pcb120. net: mscc: luton: Update network driver for pcb90 board: mscc: luton: Update MSCC Luton board net: mscc: ocelot: Update DTS for Luton pcb90
Robert P. J. Day (1): MSCC: delete obsolete reference to MSCC_BITBANG_SPI_GPIO
Weijie Gao (1): mips: rename mach-mt7620 to mach-mtmips
MAINTAINERS | 1 + arch/mips/Kconfig | 6 +- arch/mips/Makefile | 2 +- arch/mips/dts/Makefile | 2 +- arch/mips/dts/luton_pcb090.dts | 228 +++++-- arch/mips/dts/luton_pcb091.dts | 132 ++-- arch/mips/dts/mscc,luton.dtsi | 126 +--- arch/mips/dts/mscc,ocelot.dtsi | 109 ++-- arch/mips/dts/mscc,serval.dtsi | 58 ++ arch/mips/dts/ocelot_pcb120.dts | 75 +++ arch/mips/dts/ocelot_pcb123.dts | 44 +- arch/mips/dts/serval_pcb105.dts | 44 ++ arch/mips/dts/serval_pcb106.dts | 44 ++ arch/mips/lib/bootm.c | 2 + arch/mips/mach-mscc/Kconfig | 1 - arch/mips/mach-mscc/include/mach/ddr.h | 55 +- .../include/mach/ocelot/ocelot_devcpu_gcb.h | 1 + arch/mips/mach-mscc/reset.c | 2 +- arch/mips/{mach-mt7620 => mach-mtmips}/Kconfig | 14 +- arch/mips/{mach-mt7620 => mach-mtmips}/Makefile | 0 arch/mips/{mach-mt7620 => mach-mtmips}/cpu.c | 0 .../{mach-mt7620 => mach-mtmips}/ddr_calibrate.c | 0 .../{mach-mt7620 => mach-mtmips}/lowlevel_init.S | 0 arch/mips/{mach-mt7620 => mach-mtmips}/mt76xx.h | 0 board/mscc/luton/luton.c | 13 +- board/mscc/ocelot/ocelot.c | 15 + board/mscc/serval/serval.c | 14 +- configs/gardena-smart-gateway-mt7688-ram_defconfig | 2 +- configs/gardena-smart-gateway-mt7688_defconfig | 2 +- configs/linkit-smart-7688-ram_defconfig | 2 +- configs/linkit-smart-7688_defconfig | 2 +- configs/mscc_serval_defconfig | 6 +- drivers/gpio/Kconfig | 2 +- drivers/net/Kconfig | 2 +- drivers/net/mscc_eswitch/Kconfig | 7 + drivers/net/mscc_eswitch/Makefile | 5 +- drivers/net/mscc_eswitch/luton_switch.c | 415 +++++++----- drivers/net/mscc_eswitch/ocelot_switch.c | 434 ++++++++++--- drivers/net/mscc_eswitch/serval_switch.c | 703 +++++++++++++++++++++ drivers/spi/Kconfig | 2 +- drivers/watchdog/Kconfig | 2 +- include/dt-bindings/mscc/luton_data.h | 17 + include/dt-bindings/mscc/ocelot_data.h | 19 + include/dt-bindings/mscc/serval_data.h | 19 + 44 files changed, 2043 insertions(+), 586 deletions(-) rename arch/mips/{mach-mt7620 => mach-mtmips}/Kconfig (93%) rename arch/mips/{mach-mt7620 => mach-mtmips}/Makefile (100%) rename arch/mips/{mach-mt7620 => mach-mtmips}/cpu.c (100%) rename arch/mips/{mach-mt7620 => mach-mtmips}/ddr_calibrate.c (100%) rename arch/mips/{mach-mt7620 => mach-mtmips}/lowlevel_init.S (100%) rename arch/mips/{mach-mt7620 => mach-mtmips}/mt76xx.h (100%) create mode 100644 drivers/net/mscc_eswitch/serval_switch.c create mode 100644 include/dt-bindings/mscc/luton_data.h create mode 100644 include/dt-bindings/mscc/ocelot_data.h create mode 100644 include/dt-bindings/mscc/serval_data.h
On Sat, May 04, 2019 at 03:26:18PM +0200, Daniel Schwierzeck wrote:
Hi Tom,
Daniel Schwierzeck
