[U-Boot] [PATCH 1/6] rockchip: clk: rk3036: convert to use live dt
Use live dt api to get cru base addr.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
drivers/clk/rockchip/clk_rk3036.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3036.c b/drivers/clk/rockchip/clk_rk3036.c index 510a00a..560222b 100644 --- a/drivers/clk/rockchip/clk_rk3036.c +++ b/drivers/clk/rockchip/clk_rk3036.c @@ -321,7 +321,7 @@ static int rk3036_clk_probe(struct udevice *dev) { struct rk3036_clk_priv *priv = dev_get_priv(dev);
- priv->cru = (struct rk3036_cru *)devfdt_get_addr(dev); + priv->cru = dev_read_addr_ptr(dev); rkclk_init(priv->cru);
drivers/clk/rockchip/clk_rk3188.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index 6451c95..ad8df5a 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -541,7 +541,7 @@ static int rk3188_clk_ofdata_to_platdata(struct udevice *dev) #if !CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3188_clk_priv *priv = dev_get_priv(dev);
- priv->cru = (struct rk3188_cru *)devfdt_get_addr(dev); + priv->cru = dev_read_addr_ptr(dev); #endif
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip/next, thanks!
drivers/clk/rockchip/clk_rk322x.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk322x.c b/drivers/clk/rockchip/clk_rk322x.c index 4e6d2f0..ebcab73 100644 --- a/drivers/clk/rockchip/clk_rk322x.c +++ b/drivers/clk/rockchip/clk_rk322x.c @@ -475,7 +475,7 @@ static int rk322x_clk_ofdata_to_platdata(struct udevice *dev) { struct rk322x_clk_priv *priv = dev_get_priv(dev);
- priv->cru = (struct rk322x_cru *)devfdt_get_addr(dev); + priv->cru = dev_read_addr_ptr(dev);
return 0; }
drivers/clk/rockchip/clk_rk3288.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 552a71a..3a36d04 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -906,7 +906,7 @@ static int rk3288_clk_ofdata_to_platdata(struct udevice *dev) #if !CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3288_clk_priv *priv = dev_get_priv(dev);
- priv->cru = (struct rk3288_cru *)devfdt_get_addr(dev); + priv->cru = dev_read_addr_ptr(dev); #endif
drivers/clk/rockchip/clk_rk3328.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index 2ccc798..046b4e4 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -767,7 +767,7 @@ static int rk3328_clk_ofdata_to_platdata(struct udevice *dev) { struct rk3328_clk_priv *priv = dev_get_priv(dev);
- priv->cru = (struct rk3328_cru *)devfdt_get_addr(dev); + priv->cru = dev_read_addr_ptr(dev);
return 0; }
drivers/clk/rockchip/clk_rv1108.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index 224c813..958fc78 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -213,7 +213,7 @@ static int rv1108_clk_probe(struct udevice *dev) { struct rv1108_clk_priv *priv = dev_get_priv(dev);
- priv->cru = (struct rv1108_cru *)devfdt_get_addr(dev); + priv->cru = dev_read_addr_ptr(dev);
Kever Yang
Philipp Tomsich
