[PATCH v6 00/13] Raspberry Pi 400/Compute Module 4 support
This series could be split into at least two or even three parts, but I kept it as is for now as it contains all the changes needed in order to have u-boot working on the new Raspberry Pi 400 and Raspberry Pi Compute Module 4.
There are core changes, specifically with regard to cpu to bus address space translations. So far we had relied on hard-coded values but RPi needs per device translations as it has at least three distinct bus address spaces with different offsets. So it's a good opportunity to implement bus translations the right way by parsing DT's dma-ranges.
Here's a more concrete example of what we're dealing with:
- On a RPi4, SoC version BCM2711C0 with 8GB of memory
[0x0 0x200000000] [0x200000000 0x400000000] [0xc0000000 0x100000000] [0x00000000 0x100000000] phys/cpu address PCIe bus address Legacy peripheral emmc2 address space space address space space
- On a RPi4, SoC version BCM2711C0 with 4GB of memory
[0x0 0x100000000] [0x100000000 0x200000000] [0xc0000000 0x100000000] [0x00000000 0x100000000] phys/cpu address PCIe bus address Legacy peripheral emmc2 address space space address space space
- On a RPi4, SoC version BCM2711B0 with 8GB of memory (bus can only access the lower 3GB of memory because of a SoC routing bug)
[0x0 0x200000000] [0x00000000 0xC0000000] [0xc0000000 0x100000000] phys/cpu address PCIe bus address Legacy peripheral space space address space
Changes since v5: - Fix xhci patch - Rebase fixes
Changes since v4: - Get rid of #ifs all over the place
Changes since v3: - Add commit "video: arm: rpi: Add brcm,bcm2711-hdmi0 compatible", it's pretty harmless - Get rid of non-device based phys2bus call in xhci & mmc - Simon's review changes in tests - Comment some of the APIs
Changes since v2: - Test builds not broken with buildman - Add tests to all DM changes - Make code conditional with config option - Correct OF refcount - Add config changes - Address small changes as per reviews
Changes since v1: - Fix some issues in 'dm: Introduce xxx_get_dma_range()' - Fix some typos in commit messages - Change DTB file name for RPi400 - Address Matthias' comments
Nicolas Saenz Julienne (13): rpi: Add identifier for the new RPi400 rpi: Add identifier for the new CM4 pci: pcie-brcmstb: Fix inbound window configurations dm: Introduce xxx_get_dma_range() dm: test: Add test case for dev_get_dma_ranges() dm: Introduce DMA constraints into the core device model dm: test: Add test case for dev->dma_offset dm: Introduce dev_phys_to_bus()/dev_bus_to_phys() dm: test: Add test case for dev_phys_to_bus()/dev_bus_to_phys() xhci: translate virtual addresses into the bus's address space mmc: Introduce mmc_phys_to_bus()/mmc_bus_to_phys() configs: rpi4: Enable DM_DMA across all RPi4 configurations video: arm: rpi: Add brcm,bcm2711-hdmi0 compatible
arch/sandbox/dts/test.dts | 21 ++++++++ board/raspberrypi/rpi/rpi.c | 10 ++++ common/fdt_support.c | 73 ++++++++++++++++++++++++++++ configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + drivers/core/Kconfig | 10 ++++ drivers/core/device.c | 41 ++++++++++++++++ drivers/core/of_addr.c | 78 ++++++++++++++++++++++++++++++ drivers/core/ofnode.c | 9 ++++ drivers/core/read.c | 6 +++ drivers/mmc/sdhci.c | 12 +++-- drivers/pci/pcie_brcmstb.c | 12 ++--- drivers/usb/host/xhci-mem.c | 45 +++++++++-------- drivers/usb/host/xhci-ring.c | 13 +++-- drivers/usb/host/xhci.c | 4 +- drivers/video/bcm2835.c | 1 + include/dm/device.h | 13 +++++ include/dm/of_addr.h | 17 +++++++ include/dm/ofnode.h | 16 ++++++ include/dm/read.h | 21 ++++++++ include/fdt_support.h | 14 ++++++ include/mmc.h | 6 +++ include/phys2bus.h | 17 +++++++ include/usb/xhci.h | 20 +++++++- test/dm/Makefile | 2 + test/dm/core.c | 30 ++++++++++++ test/dm/phys2bus.c | 37 ++++++++++++++ test/dm/read.c | 49 +++++++++++++++++++ 33 files changed, 543 insertions(+), 41 deletions(-) create mode 100644 test/dm/phys2bus.c create mode 100644 test/dm/read.c
The Raspberry Pi Foundation released the new RPi400 which we want to detect, so we can enable Ethernet on it and know the correct device tree file name.
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Reviewed-by: Peter Robinson pbrobinson@gmail.com Tested-by: Peter Robinson pbrobinson@gmail.com --- board/raspberrypi/rpi/rpi.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 6b1fa5fc14..b66698e4a9 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -157,6 +157,11 @@ static const struct rpi_model rpi_models_new_scheme[] = { DTB_DIR "bcm2711-rpi-4-b.dtb", true, }, + [0x13] = { + "400", + DTB_DIR "bcm2711-rpi-400.dtb", + true, + }, };
static const struct rpi_model rpi_models_old_scheme[] = {
The Raspberry Pi Foundation released the new Compute Module 4 which we want to detect, so we can enable Ethernet on it and know the correct device tree file name.
Note that this sets the Ethernet option to true since the official CM4 IO board has an Ethernet port. But that might not be the case when using custom ones.
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index b66698e4a9..abcf41a5a8 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -162,6 +162,11 @@ static const struct rpi_model rpi_models_new_scheme[] = { DTB_DIR "bcm2711-rpi-400.dtb", true, }, + [0x14] = { + "Compute Module 4", + DTB_DIR "bcm2711-rpi-cm4.dtb", + true, + }, };
So far we've assumed a fixed configuration for inbound windows as we had a single user for this controller. But the controller's DMA constraints were improved starting with BCM2711's B1 revision of the SoC, notably available in CM4 and Pi400. They allow for wider inbound windows. We can now cover the whole address space, whereas before we where limited to the lower 3GB.
This information is passed to us through DT's 'dma-ranges' property and it's specially important for us to honor it since some interactions with the board's co-processor assume we're doing so (specifically the XHCI firmware load operation, which is handled by the co-processor after u-boot has correctly configured the PCIe controller).
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Tested-by: Peter Robinson pbrobinson@gmail.com --- drivers/pci/pcie_brcmstb.c | 12 +++++------- 1 file changed, 5 insertions(+), 7 deletions(-)
diff --git a/drivers/pci/pcie_brcmstb.c b/drivers/pci/pcie_brcmstb.c index dd2a4ef629..bd645d7896 100644 --- a/drivers/pci/pcie_brcmstb.c +++ b/drivers/pci/pcie_brcmstb.c @@ -432,6 +432,7 @@ static int brcm_pcie_probe(struct udevice *dev) struct pci_controller *hose = dev_get_uclass_priv(ctlr); struct brcm_pcie *pcie = dev_get_priv(dev); void __iomem *base = pcie->base; + struct pci_region region; bool ssc_good = false; int num_out_wins = 0; u64 rc_bar2_offset, rc_bar2_size; @@ -468,13 +469,10 @@ static int brcm_pcie_probe(struct udevice *dev) MISC_CTRL_SCB_ACCESS_EN_MASK | MISC_CTRL_CFG_READ_UR_MODE_MASK | MISC_CTRL_MAX_BURST_SIZE_128); - /* - * TODO: When support for other SoCs than BCM2711 is added we may - * need to use the base address and size(s) provided in the dma-ranges - * property. - */ - rc_bar2_offset = 0; - rc_bar2_size = 0xc0000000; + + pci_get_dma_regions(dev, ®ion, 0); + rc_bar2_offset = region.bus_start - region.phys_start; + rc_bar2_size = 1ULL << fls64(region.size - 1);
tmp = lower_32_bits(rc_bar2_offset); u32p_replace_bits(&tmp, brcm_pcie_encode_ibar_size(rc_bar2_size),
Add the following functions to get a specific device's DMA ranges: - dev_get_dma_range() - ofnode_get_dma_range() - of_get_dma_range() - fdt_get_dma_range() They are specially useful in oder to be able validate a physical address space range into a bus's and to convert addresses from and to address spaces.
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com --- common/fdt_support.c | 73 +++++++++++++++++++++++++++++++++++++++ drivers/core/of_addr.c | 78 ++++++++++++++++++++++++++++++++++++++++++ drivers/core/ofnode.c | 9 +++++ drivers/core/read.c | 6 ++++ include/dm/of_addr.h | 17 +++++++++ include/dm/ofnode.h | 16 +++++++++ include/dm/read.h | 21 ++++++++++++ include/fdt_support.h | 14 ++++++++ 8 files changed, 234 insertions(+)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 5ae75df3c6..bf855d26c8 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1342,6 +1342,79 @@ u64 fdt_translate_dma_address(const void *blob, int node_offset, return __of_translate_address(blob, node_offset, in_addr, "dma-ranges"); }
+int fdt_get_dma_range(const void *blob, int node, phys_addr_t *cpu, + dma_addr_t *bus, u64 *size) +{ + bool found_dma_ranges = false; + struct of_bus *bus_node; + const fdt32_t *ranges; + int na, ns, pna, pns; + int parent = node; + int ret = 0; + int len; + + /* Find the closest dma-ranges property */ + while (parent >= 0) { + ranges = fdt_getprop(blob, parent, "dma-ranges", &len); + + /* Ignore empty ranges, they imply no translation required */ + if (ranges && len > 0) + break; + + /* Once we find 'dma-ranges', then a missing one is an error */ + if (found_dma_ranges && !ranges) { + ret = -EINVAL; + goto out; + } + + if (ranges) + found_dma_ranges = true; + + parent = fdt_parent_offset(blob, parent); + } + + if (!ranges || parent < 0) { + debug("no dma-ranges found for node %s\n", + fdt_get_name(blob, node, NULL)); + ret = -ENOENT; + goto out; + } + + /* switch to that node */ + node = parent; + parent = fdt_parent_offset(blob, node); + if (parent < 0) { + printf("Found dma-ranges in root node, shoudln't happen\n"); + ret = -EINVAL; + goto out; + } + + /* Get the address sizes both for the bus and its parent */ + bus_node = of_match_bus(blob, node); + bus_node->count_cells(blob, node, &na, &ns); + if (!OF_CHECK_COUNTS(na, ns)) { + printf("%s: Bad cell count for %s\n", __FUNCTION__, + fdt_get_name(blob, node, NULL)); + return -EINVAL; + goto out; + } + + bus_node = of_match_bus(blob, parent); + bus_node->count_cells(blob, parent, &pna, &pns); + if (!OF_CHECK_COUNTS(pna, pns)) { + printf("%s: Bad cell count for %s\n", __FUNCTION__, + fdt_get_name(blob, parent, NULL)); + return -EINVAL; + goto out; + } + + *bus = fdt_read_number(ranges, na); + *cpu = fdt_translate_dma_address(blob, node, ranges + na); + *size = fdt_read_number(ranges + na + pna, ns); +out: + return ret; +} + /** * fdt_node_offset_by_compat_reg: Find a node that matches compatiable and * who's reg property matches a physical cpu address diff --git a/drivers/core/of_addr.c b/drivers/core/of_addr.c index ca34d84922..703bc3e3f5 100644 --- a/drivers/core/of_addr.c +++ b/drivers/core/of_addr.c @@ -325,6 +325,84 @@ u64 of_translate_dma_address(const struct device_node *dev, const __be32 *in_add return __of_translate_address(dev, in_addr, "dma-ranges"); }
+int of_get_dma_range(const struct device_node *dev, phys_addr_t *cpu, + dma_addr_t *bus, u64 *size) +{ + bool found_dma_ranges = false; + struct device_node *parent; + struct of_bus *bus_node; + int na, ns, pna, pns; + const __be32 *ranges; + int ret = 0; + int len; + + /* Find the closest dma-ranges property */ + dev = of_node_get(dev); + while (dev) { + ranges = of_get_property(dev, "dma-ranges", &len); + + /* Ignore empty ranges, they imply no translation required */ + if (ranges && len > 0) + break; + + /* Once we find 'dma-ranges', then a missing one is an error */ + if (found_dma_ranges && !ranges) { + ret = -EINVAL; + goto out; + } + + if (ranges) + found_dma_ranges = true; + + parent = of_get_parent(dev); + of_node_put(dev); + dev = parent; + } + + if (!dev || !ranges) { + debug("no dma-ranges found for node %s\n", + of_node_full_name(dev)); + ret = -ENOENT; + goto out; + } + + /* switch to that node */ + parent = of_get_parent(dev); + if (!parent) { + printf("Found dma-ranges in root node, shoudln't happen\n"); + ret = -EINVAL; + goto out; + } + + /* Get the address sizes both for the bus and its parent */ + bus_node = of_match_bus((struct device_node*)dev); + bus_node->count_cells(dev, &na, &ns); + if (!OF_CHECK_COUNTS(na, ns)) { + printf("Bad cell count for %s\n", of_node_full_name(dev)); + return -EINVAL; + goto out_parent; + } + + bus_node = of_match_bus(parent); + bus_node->count_cells(parent, &pna, &pns); + if (!OF_CHECK_COUNTS(pna, pns)) { + printf("Bad cell count for %s\n", of_node_full_name(parent)); + return -EINVAL; + goto out_parent; + } + + *bus = of_read_number(ranges, na); + *cpu = of_translate_dma_address(dev, ranges + na); + *size = of_read_number(ranges + na + pna, ns); + +out_parent: + of_node_put(parent); +out: + of_node_put(dev); + return ret; +} + + static int __of_address_to_resource(const struct device_node *dev, const __be32 *addrp, u64 size, unsigned int flags, const char *name, struct resource *r) diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 2a6e43ddc6..18bb375f19 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -923,6 +923,15 @@ u64 ofnode_translate_dma_address(ofnode node, const fdt32_t *in_addr) return fdt_translate_dma_address(gd->fdt_blob, ofnode_to_offset(node), in_addr); }
+int ofnode_get_dma_range(ofnode node, phys_addr_t *cpu, dma_addr_t *bus, u64 *size) +{ + if (ofnode_is_np(node)) + return of_get_dma_range(ofnode_to_np(node), cpu, bus, size); + else + return fdt_get_dma_range(gd->fdt_blob, ofnode_to_offset(node), + cpu, bus, size); +} + int ofnode_device_is_compatible(ofnode node, const char *compat) { if (ofnode_is_np(node)) diff --git a/drivers/core/read.c b/drivers/core/read.c index fc74d64814..e86c4b6740 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -340,6 +340,12 @@ u64 dev_translate_dma_address(const struct udevice *dev, const fdt32_t *in_addr) return ofnode_translate_dma_address(dev_ofnode(dev), in_addr); }
+int dev_get_dma_range(const struct udevice *dev, phys_addr_t *cpu, + dma_addr_t *bus, u64 *size) +{ + return ofnode_get_dma_range(dev_ofnode(dev), cpu, bus, size); +} + int dev_read_alias_highest_id(const char *stem) { if (of_live_active()) diff --git a/include/dm/of_addr.h b/include/dm/of_addr.h index 3fa1ffce81..ee21d5cf4f 100644 --- a/include/dm/of_addr.h +++ b/include/dm/of_addr.h @@ -44,6 +44,23 @@ u64 of_translate_address(const struct device_node *no, const __be32 *in_addr); */ u64 of_translate_dma_address(const struct device_node *no, const __be32 *in_addr);
+ +/** + * of_get_dma_range() - get dma-ranges for a specific DT node + * + * Get DMA ranges for a specifc node, this is useful to perform bus->cpu and + * cpu->bus address translations + * + * @param blob Pointer to device tree blob + * @param node_offset Node DT offset + * @param cpu Pointer to variable storing the range's cpu address + * @param bus Pointer to variable storing the range's bus address + * @param size Pointer to variable storing the range's size + * @return translated DMA address or OF_BAD_ADDR on error + */ +int of_get_dma_range(const struct device_node *dev, phys_addr_t *cpu, + dma_addr_t *bus, u64 *size); + /** * of_get_address() - obtain an address from a node * diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 5b088650d3..c4680fbbaa 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -996,6 +996,22 @@ u64 ofnode_translate_address(ofnode node, const fdt32_t *in_addr); */ u64 ofnode_translate_dma_address(ofnode node, const fdt32_t *in_addr);
+/** + * ofnode_get_dma_range() - get dma-ranges for a specific DT node + * + * Get DMA ranges for a specifc node, this is useful to perform bus->cpu and + * cpu->bus address translations + * + * @param blob Pointer to device tree blob + * @param node_offset Node DT offset + * @param cpu Pointer to variable storing the range's cpu address + * @param bus Pointer to variable storing the range's bus address + * @param size Pointer to variable storing the range's size + * @return translated DMA address or OF_BAD_ADDR on error + */ +int ofnode_get_dma_range(ofnode node, phys_addr_t *cpu, dma_addr_t *bus, + u64 *size); + /** * ofnode_device_is_compatible() - check if the node is compatible with compat * diff --git a/include/dm/read.h b/include/dm/read.h index fc987f7759..e0e3da0bae 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -648,6 +648,21 @@ u64 dev_translate_address(const struct udevice *dev, const fdt32_t *in_addr); u64 dev_translate_dma_address(const struct udevice *dev, const fdt32_t *in_addr);
+/** + * dev_get_dma_range() - Get a device's DMA constraints + * + * Provide the address bases and size of the linear mapping between the CPU and + * a device's BUS address space. + * + * @dev: device giving the context in which to translate the DMA address + * @cpu: base address for CPU's view of memory + * @bus: base address for BUS's view of memory + * @size: size of the address space + * @return 0 if ok, negative on error + */ +int dev_get_dma_range(const struct udevice *dev, phys_addr_t *cpu, + dma_addr_t *bus, u64 *size); + /** * dev_read_alias_highest_id - Get highest alias id for the given stem * @stem: Alias stem to be examined @@ -988,6 +1003,12 @@ static inline u64 dev_translate_dma_address(const struct udevice *dev, return ofnode_translate_dma_address(dev_ofnode(dev), in_addr); }
+static inline int dev_get_dma_range(const struct udevice *dev, phys_addr_t *cpu, + dma_addr_t *bus, u64 *size) +{ + return ofnode_get_dma_range(dev_ofnode(dev), cpu, bus, size); +} + static inline int dev_read_alias_highest_id(const char *stem) { if (!CONFIG_IS_ENABLED(OF_LIBFDT)) diff --git a/include/fdt_support.h b/include/fdt_support.h index dbbac0fb6a..46eb1dbbb2 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -260,6 +260,20 @@ u64 fdt_translate_address(const void *blob, int node_offset, u64 fdt_translate_dma_address(const void *blob, int node_offset, const __be32 *in_addr);
+/** + * Get DMA ranges for a specifc node, this is useful to perform bus->cpu and + * cpu->bus address translations + * + * @param blob Pointer to device tree blob + * @param node_offset Node DT offset + * @param cpu Pointer to variable storing the range's cpu address + * @param bus Pointer to variable storing the range's bus address + * @param size Pointer to variable storing the range's size + * @return translated DMA address or OF_BAD_ADDR on error + */ +int fdt_get_dma_range(const void *blob, int node_offset, phys_addr_t *cpu, + dma_addr_t *bus, u64 *size); + int fdt_node_offset_by_compat_reg(void *blob, const char *compat, phys_addr_t compat_off); int fdt_alloc_phandle(void *blob);
Introduce some new nodes in sandbox's test device-tree and dm tests in order to validate dev_get_dma_range().
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com --- arch/sandbox/dts/test.dts | 17 ++++++++++++++ test/dm/Makefile | 1 + test/dm/read.c | 49 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 67 insertions(+) create mode 100644 test/dm/read.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index c9b9b7b75e..b279903d2a 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -293,6 +293,23 @@ test5-gpios = <&gpio_a 19>; };
+ mmio-bus@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "denx,u-boot-test-bus"; + dma-ranges = <0x10000000 0x00000000 0x00040000>; + + subnode@0 { + compatible = "denx,u-boot-fdt-test"; + }; + }; + + mmio-bus@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "denx,u-boot-test-bus"; + }; + acpi_test1: acpi-test { compatible = "denx,u-boot-acpi-test"; acpi-ssdt-test-data = "ab"; diff --git a/test/dm/Makefile b/test/dm/Makefile index 46e076ed09..5c52d8b6ea 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -15,6 +15,7 @@ obj-$(CONFIG_UT_DM) += test-fdt.o obj-$(CONFIG_UT_DM) += test-uclass.o
obj-$(CONFIG_UT_DM) += core.o +obj-$(CONFIG_UT_DM) += read.o ifneq ($(CONFIG_SANDBOX),) obj-$(CONFIG_ACPIGEN) += acpi.o obj-$(CONFIG_ACPIGEN) += acpigen.o diff --git a/test/dm/read.c b/test/dm/read.c new file mode 100644 index 0000000000..7768aa2968 --- /dev/null +++ b/test/dm/read.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020 Nicolas Saenz Julienne nsaenzjulienne@suse.de + */ + +#include <common.h> +#include <dm.h> +#include <dm/device.h> +#include <dm/ofnode.h> +#include <dm/root.h> +#include <dm/test.h> +#include <dm/uclass-internal.h> +#include <test/ut.h> + +static int dm_test_dma_ranges(struct unit_test_state *uts) +{ + struct udevice *dev; + phys_addr_t cpu; + dma_addr_t bus; + ofnode node; + u64 size; + + /* dma-ranges are on the device's node */ + node = ofnode_path("/mmio-bus@0"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_BUS, node, &dev)); + ut_assertok(dev_get_dma_range(dev, &cpu, &bus, &size)); + ut_asserteq_64(0x40000, size); + ut_asserteq_64(0x0, cpu); + ut_asserteq_64(0x10000000, bus); + + /* dma-ranges are on the bus' node */ + node = ofnode_path("/mmio-bus@0/subnode@0"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_FDT, node, &dev)); + ut_assertok(dev_get_dma_range(dev, &cpu, &bus, &size)); + ut_asserteq_64(0x40000, size); + ut_asserteq_64(0x0, cpu); + ut_asserteq_64(0x10000000, bus); + + /* No dma-ranges available */ + node = ofnode_path("/mmio-bus@1"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_BUS, node, &dev)); + ut_asserteq(-ENOENT, dev_get_dma_range(dev, &cpu, &bus, &size)); + + return 0; +} +DM_TEST(dm_test_dma_ranges, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
Calculating the DMA offset between a bus address space and CPU's every time we call phys_to_bus() and bus_to_phys() isn't ideal performance wise, as it implies traversing the device tree from the device's node up to the root. Since this information is static and available before the device's initialization, parse it before the probe call an provide the DMA offset in 'struct udevice' for the address translation code to use it.
Changes since v5: - Use dev_has_ofnode()
drivers/core/Kconfig | 10 ++++++++++ drivers/core/device.c | 41 +++++++++++++++++++++++++++++++++++++++++ include/dm/device.h | 13 +++++++++++++ 3 files changed, 64 insertions(+)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 65a503e76d..0932ee23a7 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -129,6 +129,16 @@ config TPL_DM_INLINE_OFNODE This applies to several ofnode functions (see ofnode.h) which are seldom used. Inlining them can help reduce code size.
+config DM_DMA + bool "Support per-device DMA constraints" + depends on DM + default n + help + Enable this to extract per-device DMA constraints, only supported on + device-tree systems for now. This is needed in order translate + addresses on systems where different buses have different views of + the physical address space. + config REGMAP bool "Support register maps" depends on DM diff --git a/drivers/core/device.c b/drivers/core/device.c index aeab3836ed..57424abf99 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -421,6 +421,43 @@ fail: return ret; }
+/** + * device_get_dma_constraints() - Populate device's DMA constraints + * + * Gets a device's DMA constraints from firmware. This information is later + * used by drivers to translate physcal addresses to the device's bus address + * space. For now only device-tree is supported. + * + * @dev: Pointer to target device + * Return: 0 if OK or if no DMA constraints were found, error otherwise + */ +static int device_get_dma_constraints(struct udevice *dev) +{ + struct udevice *parent = dev->parent; + phys_addr_t cpu = 0; + dma_addr_t bus = 0; + u64 size = 0; + int ret; + + if (!CONFIG_IS_ENABLED(DM_DMA) || !parent || !dev_has_ofnode(parent)) + return 0; + + /* + * We start parsing for dma-ranges from the device's bus node. This is + * specially important on nested buses. + */ + ret = dev_get_dma_range(parent, &cpu, &bus, &size); + /* Don't return an error if no 'dma-ranges' were found */ + if (ret && ret != -ENOENT) { + dm_warn("%s: failed to get DMA range, %d\n", dev->name, ret); + return ret; + } + + dev_set_dma_offset(dev, cpu - bus); + + return 0; +} + int device_probe(struct udevice *dev) { const struct driver *drv; @@ -474,6 +511,10 @@ int device_probe(struct udevice *dev) goto fail; }
+ ret = device_get_dma_constraints(dev); + if (ret) + goto fail; + ret = uclass_pre_probe_device(dev); if (ret) goto fail; diff --git a/include/dm/device.h b/include/dm/device.h index f5b4cd6876..9ac96fa28d 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -148,6 +148,8 @@ enum { * When CONFIG_DEVRES is enabled, devm_kmalloc() and friends will * add to this list. Memory so-allocated will be freed * automatically when the device is removed / unbound + * @dma_offset: Offset between the physical address space (CPU's) and the + * device's bus address space */ struct udevice { const struct driver *driver; @@ -172,6 +174,9 @@ struct udevice { #ifdef CONFIG_DEVRES struct list_head devres_head; #endif +#if CONFIG_IS_ENABLED(DM_DMA) + ulong dma_offset; +#endif };
/* Maximum sequence number supported */ @@ -213,6 +218,14 @@ static inline ofnode dev_ofnode(const struct udevice *dev) /* Returns non-zero if the device is active (probed and not removed) */ #define device_active(dev) (dev_get_flags(dev) & DM_FLAG_ACTIVATED)
+#if CONFIG_IS_ENABLED(DM_DMA) +#define dev_set_dma_offset(_dev, _offset) _dev->dma_offset = _offset +#define dev_get_dma_offset(_dev) _dev->dma_offset +#else +#define dev_set_dma_offset(_dev, _offset) +#define dev_get_dma_offset(_dev) 0 +#endif + static inline int dev_of_offset(const struct udevice *dev) { #if !CONFIG_IS_ENABLED(OF_PLATDATA)
Add test to validate dev->dma_offset is properly set on devices.
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com --- arch/sandbox/dts/test.dts | 4 ++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + test/dm/core.c | 30 ++++++++++++++++++++++++++++++ 6 files changed, 38 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index b279903d2a..39efeaa5a7 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -308,6 +308,10 @@ #address-cells = <1>; #size-cells = <1>; compatible = "denx,u-boot-test-bus"; + + subnode@0 { + compatible = "denx,u-boot-fdt-test"; + }; };
acpi_test1: acpi-test { diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 2066d0a292..d63e22c2bc 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -95,6 +95,7 @@ CONFIG_ENV_EXT4_DEVICE_AND_PART="0:0" CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NETCONSOLE=y CONFIG_IP_DEFRAG=y +CONFIG_DM_DMA=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_DEVRES=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 58d4ef18c3..a96641a6d6 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -108,6 +108,7 @@ CONFIG_ENV_EXT4_DEVICE_AND_PART="0:0" CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NETCONSOLE=y CONFIG_IP_DEFRAG=y +CONFIG_DM_DMA=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_DEVRES=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index efd99a92f1..00a4329537 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -76,6 +76,7 @@ CONFIG_ENV_EXT4_DEVICE_AND_PART="0:0" CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NETCONSOLE=y CONFIG_IP_DEFRAG=y +CONFIG_DM_DMA=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_DEVRES=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index d193b18f47..fbb138805a 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -95,6 +95,7 @@ CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NETCONSOLE=y CONFIG_IP_DEFRAG=y CONFIG_SPL_DM=y +CONFIG_DM_DMA=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/test/dm/core.c b/test/dm/core.c index 1f5ca570dc..855449aac2 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -1085,3 +1085,33 @@ static int dm_test_all_have_seq(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_all_have_seq, UT_TESTF_SCAN_PDATA); + +static int dm_test_dma_offset(struct unit_test_state *uts) +{ + struct udevice *dev; + ofnode node; + + /* Make sure the bus's dma-ranges aren't taken into account here */ + node = ofnode_path("/mmio-bus@0"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_BUS, node, &dev)); + ut_asserteq_64(0, dev->dma_offset); + + /* Device behind a bus with dma-ranges */ + node = ofnode_path("/mmio-bus@0/subnode@0"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_FDT, node, &dev)); + ut_asserteq_64(-0x10000000ULL, dev->dma_offset); + + /* This one has no dma-ranges */ + node = ofnode_path("/mmio-bus@1"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_BUS, node, &dev)); + node = ofnode_path("/mmio-bus@1/subnode@0"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_FDT, node, &dev)); + ut_asserteq_64(0, dev->dma_offset); + + return 0; +} +DM_TEST(dm_test_dma_offset, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
These functions, instead of relying on hard-coded platform-specific address translations, make use of the DMA constraints provided by the DM core. This allows for per-device translations.
We can't yet get rid of the legacy phys_to_bus()/bus_to_phys() implementations as some of its users are not integrated into the device model.
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Tested-by: Peter Robinson pbrobinson@gmail.com --- include/phys2bus.h | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/include/phys2bus.h b/include/phys2bus.h index dc9b8e5a25..866b8b51a8 100644 --- a/include/phys2bus.h +++ b/include/phys2bus.h @@ -21,4 +21,21 @@ static inline unsigned long bus_to_phys(unsigned long bus) } #endif
+#if CONFIG_IS_ENABLED(DM) +#include <dm/device.h> + +static inline dma_addr_t dev_phys_to_bus(struct udevice *dev, phys_addr_t phys) +{ + return phys - dev_get_dma_offset(dev); +} + +static inline phys_addr_t dev_bus_to_phys(struct udevice *dev, dma_addr_t bus) +{ + return bus + dev_get_dma_offset(dev); +} +#else +#define dev_phys_to_bus(_, _addr) _addr +#define dev_bus_to_phys(_, _addr) _addr +#endif + #endif
By reusing DT nodes already available in sandbox's test DT introduce a test to validate dev_phys_to_bus()/dev_bus_to_phys().
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com --- test/dm/Makefile | 1 + test/dm/phys2bus.c | 37 +++++++++++++++++++++++++++++++++++++ 2 files changed, 38 insertions(+) create mode 100644 test/dm/phys2bus.c
diff --git a/test/dm/Makefile b/test/dm/Makefile index 5c52d8b6ea..ac86abaa88 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -16,6 +16,7 @@ obj-$(CONFIG_UT_DM) += test-uclass.o
obj-$(CONFIG_UT_DM) += core.o obj-$(CONFIG_UT_DM) += read.o +obj-$(CONFIG_UT_DM) += phys2bus.o ifneq ($(CONFIG_SANDBOX),) obj-$(CONFIG_ACPIGEN) += acpi.o obj-$(CONFIG_ACPIGEN) += acpigen.o diff --git a/test/dm/phys2bus.c b/test/dm/phys2bus.c new file mode 100644 index 0000000000..342f2fa8eb --- /dev/null +++ b/test/dm/phys2bus.c @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020 Nicolas Saenz Julienne nsaenzjulienne@suse.de + */ + +#include <common.h> +#include <dm.h> +#include <mapmem.h> +#include <phys2bus.h> +#include <dm/device.h> +#include <dm/ofnode.h> +#include <dm/root.h> +#include <dm/test.h> +#include <dm/uclass-internal.h> +#include <test/ut.h> + +static int dm_test_phys_to_bus(struct unit_test_state *uts) +{ + struct udevice *dev; + ofnode node; + + node = ofnode_path("/mmio-bus@0"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_BUS, node, &dev)); + /* In this case it should be transparent, no dma-ranges in parent bus */ + ut_asserteq_addr((void*)0xfffffULL, (void*)dev_phys_to_bus(dev, 0xfffff)); + ut_asserteq_addr((void*)0xfffffULL, (void*)(ulong)dev_bus_to_phys(dev, 0xfffff)); + + node = ofnode_path("/mmio-bus@0/subnode@0"); + ut_assert(ofnode_valid(node)); + ut_assertok(uclass_get_device_by_ofnode(UCLASS_TEST_FDT, node, &dev)); + ut_asserteq_addr((void*)0x100fffffULL, (void*)dev_phys_to_bus(dev, 0xfffff)); + ut_asserteq_addr((void*)0xfffffULL, (void*)(ulong)dev_bus_to_phys(dev, 0x100fffff)); + + return 0; +} +DM_TEST(dm_test_phys_to_bus, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
So far we've been content with passing physical addresses when configuring memory addresses into XHCI controllers, but not all platforms have buses with transparent mappings. Specifically the Raspberry Pi 4 might introduce an offset to memory accesses incoming from its PCIe port.
Introduce xhci_virt_to_bus() and xhci_bus_to_virt() to cater with these limitations, and make sure we don't break non DM users.
Changes since v5: - Add missing address tranlation
drivers/usb/host/xhci-mem.c | 45 +++++++++++++++++++----------------- drivers/usb/host/xhci-ring.c | 13 +++++++---- drivers/usb/host/xhci.c | 4 ++-- include/usb/xhci.h | 20 +++++++++++++++- 4 files changed, 53 insertions(+), 29 deletions(-)
diff --git a/drivers/usb/host/xhci-mem.c b/drivers/usb/host/xhci-mem.c index b002d6f166..83147d51b5 100644 --- a/drivers/usb/host/xhci-mem.c +++ b/drivers/usb/host/xhci-mem.c @@ -110,7 +110,7 @@ static void xhci_scratchpad_free(struct xhci_ctrl *ctrl)
ctrl->dcbaa->dev_context_ptrs[0] = 0;
- free((void *)(uintptr_t)le64_to_cpu(ctrl->scratchpad->sp_array[0])); + free(xhci_bus_to_virt(ctrl, le64_to_cpu(ctrl->scratchpad->sp_array[0]))); free(ctrl->scratchpad->sp_array); free(ctrl->scratchpad); ctrl->scratchpad = NULL; @@ -216,8 +216,8 @@ static void *xhci_malloc(unsigned int size) * @param link_trbs flag to indicate whether to link the trbs or NOT * @return none */ -static void xhci_link_segments(struct xhci_segment *prev, - struct xhci_segment *next, bool link_trbs) +static void xhci_link_segments(struct xhci_ctrl *ctrl, struct xhci_segment *prev, + struct xhci_segment *next, bool link_trbs) { u32 val; u64 val_64 = 0; @@ -226,7 +226,7 @@ static void xhci_link_segments(struct xhci_segment *prev, return; prev->next = next; if (link_trbs) { - val_64 = virt_to_phys(next->trbs); + val_64 = xhci_virt_to_bus(ctrl, next->trbs); prev->trbs[TRBS_PER_SEGMENT-1].link.segment_ptr = cpu_to_le64(val_64);
@@ -304,7 +304,8 @@ static struct xhci_segment *xhci_segment_alloc(void) * @param link_trbs flag to indicate whether to link the trbs or NOT * @return pointer to the newly created RING */ -struct xhci_ring *xhci_ring_alloc(unsigned int num_segs, bool link_trbs) +struct xhci_ring *xhci_ring_alloc(struct xhci_ctrl *ctrl, unsigned int num_segs, + bool link_trbs) { struct xhci_ring *ring; struct xhci_segment *prev; @@ -327,12 +328,12 @@ struct xhci_ring *xhci_ring_alloc(unsigned int num_segs, bool link_trbs) next = xhci_segment_alloc(); BUG_ON(!next);
- xhci_link_segments(prev, next, link_trbs); + xhci_link_segments(ctrl, prev, next, link_trbs);
prev = next; num_segs--; } - xhci_link_segments(prev, ring->first_seg, link_trbs); + xhci_link_segments(ctrl, prev, ring->first_seg, link_trbs); if (link_trbs) { /* See section 4.9.2.1 and 6.4.4.1 */ prev->trbs[TRBS_PER_SEGMENT-1].link.control |= @@ -354,6 +355,7 @@ static int xhci_scratchpad_alloc(struct xhci_ctrl *ctrl) struct xhci_hccr *hccr = ctrl->hccr; struct xhci_hcor *hcor = ctrl->hcor; struct xhci_scratchpad *scratchpad; + uint64_t val_64; int num_sp; uint32_t page_size; void *buf; @@ -371,8 +373,9 @@ static int xhci_scratchpad_alloc(struct xhci_ctrl *ctrl) scratchpad->sp_array = xhci_malloc(num_sp * sizeof(u64)); if (!scratchpad->sp_array) goto fail_sp2; - ctrl->dcbaa->dev_context_ptrs[0] = - cpu_to_le64((uintptr_t)scratchpad->sp_array); + + val_64 = xhci_virt_to_bus(ctrl, scratchpad->sp_array); + ctrl->dcbaa->dev_context_ptrs[0] = cpu_to_le64(val_64);
xhci_flush_cache((uintptr_t)&ctrl->dcbaa->dev_context_ptrs[0], sizeof(ctrl->dcbaa->dev_context_ptrs[0])); @@ -393,8 +396,8 @@ static int xhci_scratchpad_alloc(struct xhci_ctrl *ctrl) xhci_flush_cache((uintptr_t)buf, num_sp * page_size);
for (i = 0; i < num_sp; i++) { - uintptr_t ptr = (uintptr_t)buf + i * page_size; - scratchpad->sp_array[i] = cpu_to_le64(ptr); + val_64 = xhci_virt_to_bus(ctrl, buf + i * page_size); + scratchpad->sp_array[i] = cpu_to_le64(val_64); }
xhci_flush_cache((uintptr_t)scratchpad->sp_array, @@ -484,9 +487,9 @@ int xhci_alloc_virt_device(struct xhci_ctrl *ctrl, unsigned int slot_id) }
/* Allocate endpoint 0 ring */ - virt_dev->eps[0].ring = xhci_ring_alloc(1, true); + virt_dev->eps[0].ring = xhci_ring_alloc(ctrl, 1, true);
- byte_64 = virt_to_phys(virt_dev->out_ctx->bytes); + byte_64 = xhci_virt_to_bus(ctrl, virt_dev->out_ctx->bytes);
/* Point to output device context in dcbaa. */ ctrl->dcbaa->dev_context_ptrs[slot_id] = cpu_to_le64(byte_64); @@ -522,15 +525,15 @@ int xhci_mem_init(struct xhci_ctrl *ctrl, struct xhci_hccr *hccr, return -ENOMEM; }
- val_64 = virt_to_phys(ctrl->dcbaa); + val_64 = xhci_virt_to_bus(ctrl, ctrl->dcbaa); /* Set the pointer in DCBAA register */ xhci_writeq(&hcor->or_dcbaap, val_64);
/* Command ring control pointer register initialization */ - ctrl->cmd_ring = xhci_ring_alloc(1, true); + ctrl->cmd_ring = xhci_ring_alloc(ctrl, 1, true);
/* Set the address in the Command Ring Control register */ - trb_64 = virt_to_phys(ctrl->cmd_ring->first_seg->trbs); + trb_64 = xhci_virt_to_bus(ctrl, ctrl->cmd_ring->first_seg->trbs); val_64 = xhci_readq(&hcor->or_crcr); val_64 = (val_64 & (u64) CMD_RING_RSVD_BITS) | (trb_64 & (u64) ~CMD_RING_RSVD_BITS) | @@ -551,7 +554,7 @@ int xhci_mem_init(struct xhci_ctrl *ctrl, struct xhci_hccr *hccr, ctrl->ir_set = &ctrl->run_regs->ir_set[0];
/* Event ring does not maintain link TRB */ - ctrl->event_ring = xhci_ring_alloc(ERST_NUM_SEGS, false); + ctrl->event_ring = xhci_ring_alloc(ctrl, ERST_NUM_SEGS, false); ctrl->erst.entries = xhci_malloc(sizeof(struct xhci_erst_entry) * ERST_NUM_SEGS);
@@ -560,8 +563,8 @@ int xhci_mem_init(struct xhci_ctrl *ctrl, struct xhci_hccr *hccr, for (val = 0, seg = ctrl->event_ring->first_seg; val < ERST_NUM_SEGS; val++) { - trb_64 = virt_to_phys(seg->trbs); struct xhci_erst_entry *entry = &ctrl->erst.entries[val]; + trb_64 = xhci_virt_to_bus(ctrl, seg->trbs); entry->seg_addr = cpu_to_le64(trb_64); entry->seg_size = cpu_to_le32(TRBS_PER_SEGMENT); entry->rsvd = 0; @@ -570,7 +573,7 @@ int xhci_mem_init(struct xhci_ctrl *ctrl, struct xhci_hccr *hccr, xhci_flush_cache((uintptr_t)ctrl->erst.entries, ERST_NUM_SEGS * sizeof(struct xhci_erst_entry));
- deq = virt_to_phys(ctrl->event_ring->dequeue); + deq = xhci_virt_to_bus(ctrl, ctrl->event_ring->dequeue);
/* Update HC event ring dequeue pointer */ xhci_writeq(&ctrl->ir_set->erst_dequeue, @@ -585,7 +588,7 @@ int xhci_mem_init(struct xhci_ctrl *ctrl, struct xhci_hccr *hccr, /* this is the event ring segment table pointer */ val_64 = xhci_readq(&ctrl->ir_set->erst_base); val_64 &= ERST_PTR_MASK; - val_64 |= virt_to_phys(ctrl->erst.entries) & ~ERST_PTR_MASK; + val_64 |= xhci_virt_to_bus(ctrl, ctrl->erst.entries) & ~ERST_PTR_MASK;
xhci_writeq(&ctrl->ir_set->erst_base, val_64);
@@ -848,7 +851,7 @@ void xhci_setup_addressable_virt_dev(struct xhci_ctrl *ctrl, /* EP 0 can handle "burst" sizes of 1, so Max Burst Size field is 0 */ ep0_ctx->ep_info2 |= cpu_to_le32(MAX_BURST(0) | ERROR_COUNT(3));
- trb_64 = virt_to_phys(virt_dev->eps[0].ring->first_seg->trbs); + trb_64 = xhci_virt_to_bus(ctrl, virt_dev->eps[0].ring->first_seg->trbs); ep0_ctx->deq = cpu_to_le64(trb_64 | virt_dev->eps[0].ring->cycle_state);
/* diff --git a/drivers/usb/host/xhci-ring.c b/drivers/usb/host/xhci-ring.c index d708fc928b..6b31ad4398 100644 --- a/drivers/usb/host/xhci-ring.c +++ b/drivers/usb/host/xhci-ring.c @@ -275,10 +275,13 @@ void xhci_queue_command(struct xhci_ctrl *ctrl, u8 *ptr, u32 slot_id, u32 ep_index, trb_type cmd) { u32 fields[4]; - u64 val_64 = virt_to_phys(ptr); + u64 val_64 = 0;
BUG_ON(prepare_ring(ctrl, ctrl->cmd_ring, EP_STATE_RUNNING));
+ if (ptr) + val_64 = xhci_virt_to_bus(ctrl, ptr); + fields[0] = lower_32_bits(val_64); fields[1] = upper_32_bits(val_64); fields[2] = 0; @@ -401,7 +404,7 @@ void xhci_acknowledge_event(struct xhci_ctrl *ctrl)
/* Inform the hardware */ xhci_writeq(&ctrl->ir_set->erst_dequeue, - virt_to_phys(ctrl->event_ring->dequeue) | ERST_EHB); + xhci_virt_to_bus(ctrl, ctrl->event_ring->dequeue) | ERST_EHB); }
/** @@ -579,7 +582,7 @@ int xhci_bulk_tx(struct usb_device *udev, unsigned long pipe, u64 addr; int ret; u32 trb_fields[4]; - u64 val_64 = virt_to_phys(buffer); + u64 val_64 = xhci_virt_to_bus(ctrl, buffer); void *last_transfer_trb_addr; int available_length;
@@ -723,7 +726,7 @@ again: return -ETIMEDOUT; }
- if ((uintptr_t)(le64_to_cpu(event->trans_event.buffer)) + if ((uintptr_t)(le64_to_cpu(xhci_bus_to_virt(ctrl, event->trans_event.buffer))) != (uintptr_t)last_transfer_trb_addr) { available_length -= (int)EVENT_TRB_LEN(le32_to_cpu(event->trans_event.transfer_len)); @@ -884,7 +887,7 @@ int xhci_ctrl_tx(struct usb_device *udev, unsigned long pipe, if (length > 0) { if (req->requesttype & USB_DIR_IN) field |= TRB_DIR_IN; - buf_64 = virt_to_phys(buffer); + buf_64 = xhci_virt_to_bus(ctrl, buffer);
trb_fields[0] = lower_32_bits(buf_64); trb_fields[1] = upper_32_bits(buf_64); diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 7080f8fabe..d27ac01c83 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -604,7 +604,7 @@ static int xhci_set_configuration(struct usb_device *udev) ep_ctx[ep_index] = xhci_get_ep_ctx(ctrl, in_ctx, ep_index);
/* Allocate the ep rings */ - virt_dev->eps[ep_index].ring = xhci_ring_alloc(1, true); + virt_dev->eps[ep_index].ring = xhci_ring_alloc(ctrl, 1, true); if (!virt_dev->eps[ep_index].ring) return -ENOMEM;
@@ -628,7 +628,7 @@ static int xhci_set_configuration(struct usb_device *udev) cpu_to_le32(MAX_BURST(max_burst) | ERROR_COUNT(err_count));
- trb_64 = virt_to_phys(virt_dev->eps[ep_index].ring->enqueue); + trb_64 = xhci_virt_to_bus(ctrl, virt_dev->eps[ep_index].ring->enqueue); ep_ctx[ep_index]->deq = cpu_to_le64(trb_64 | virt_dev->eps[ep_index].ring->cycle_state);
diff --git a/include/usb/xhci.h b/include/usb/xhci.h index e1d382369a..8d95e213b0 100644 --- a/include/usb/xhci.h +++ b/include/usb/xhci.h @@ -16,6 +16,7 @@ #ifndef HOST_XHCI_H_ #define HOST_XHCI_H_
+#include <phys2bus.h> #include <reset.h> #include <asm/types.h> #include <asm/cache.h> @@ -1221,6 +1222,12 @@ struct xhci_ctrl { #define XHCI_MTK_HOST BIT(0) };
+#if CONFIG_IS_ENABLED(DM_USB) +#define xhci_to_dev(_ctrl) _ctrl->dev +#else +#define xhci_to_dev(_ctrl) NULL +#endif + unsigned long trb_addr(struct xhci_segment *seg, union xhci_trb *trb); struct xhci_input_control_ctx *xhci_get_input_control_ctx(struct xhci_container_ctx *ctx); @@ -1250,7 +1257,8 @@ int xhci_check_maxpacket(struct usb_device *udev); void xhci_flush_cache(uintptr_t addr, u32 type_len); void xhci_inval_cache(uintptr_t addr, u32 type_len); void xhci_cleanup(struct xhci_ctrl *ctrl); -struct xhci_ring *xhci_ring_alloc(unsigned int num_segs, bool link_trbs); +struct xhci_ring *xhci_ring_alloc(struct xhci_ctrl *ctrl, unsigned int num_segs, + bool link_trbs); int xhci_alloc_virt_device(struct xhci_ctrl *ctrl, unsigned int slot_id); int xhci_mem_init(struct xhci_ctrl *ctrl, struct xhci_hccr *hccr, struct xhci_hcor *hcor); @@ -1278,4 +1286,14 @@ extern struct dm_usb_ops xhci_usb_ops;
struct xhci_ctrl *xhci_get_ctrl(struct usb_device *udev);
+static inline dma_addr_t xhci_virt_to_bus(struct xhci_ctrl *ctrl, void *addr) +{ + return dev_phys_to_bus(xhci_to_dev(ctrl), virt_to_phys(addr)); +} + +static inline void *xhci_bus_to_virt(struct xhci_ctrl *ctrl, dma_addr_t addr) +{ + return phys_to_virt(dev_bus_to_phys(xhci_to_dev(ctrl), addr)); +} + #endif /* HOST_XHCI_H_ */
This will allow us to use DM variants of phys_to_bus()/bus_to_phys() when relevant.
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com --- drivers/mmc/sdhci.c | 12 +++++++----- include/mmc.h | 6 ++++++ 2 files changed, 13 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 0628934312..62e4f53b8b 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -14,12 +14,12 @@ #include <log.h> #include <malloc.h> #include <mmc.h> +#include <phys2bus.h> #include <sdhci.h> #include <asm/cache.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/dma-mapping.h> -#include <phys2bus.h>
static void sdhci_reset(struct sdhci_host *host, u8 mask) { @@ -73,6 +73,7 @@ static void sdhci_transfer_pio(struct sdhci_host *host, struct mmc_data *data) static void sdhci_prepare_dma(struct sdhci_host *host, struct mmc_data *data, int *is_aligned, int trans_bytes) { + dma_addr_t dma_addr; unsigned char ctrl; void *buf;
@@ -103,8 +104,8 @@ static void sdhci_prepare_dma(struct sdhci_host *host, struct mmc_data *data, mmc_get_dma_dir(data));
if (host->flags & USE_SDMA) { - sdhci_writel(host, phys_to_bus((ulong)host->start_addr), - SDHCI_DMA_ADDRESS); + dma_addr = dev_phys_to_bus(mmc_to_dev(host->mmc), host->start_addr); + sdhci_writel(host, dma_addr, SDHCI_DMA_ADDRESS); } #if CONFIG_IS_ENABLED(MMC_SDHCI_ADMA) else if (host->flags & (USE_ADMA | USE_ADMA64)) { @@ -162,8 +163,9 @@ static int sdhci_transfer_data(struct sdhci_host *host, struct mmc_data *data) start_addr &= ~(SDHCI_DEFAULT_BOUNDARY_SIZE - 1); start_addr += SDHCI_DEFAULT_BOUNDARY_SIZE; - sdhci_writel(host, phys_to_bus((ulong)start_addr), - SDHCI_DMA_ADDRESS); + start_addr = dev_phys_to_bus(mmc_to_dev(host->mmc), + start_addr); + sdhci_writel(host, start_addr, SDHCI_DMA_ADDRESS); } } if (timeout-- > 0) diff --git a/include/mmc.h b/include/mmc.h index 1d377e0281..c12c7a0b5c 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -736,6 +736,12 @@ struct mmc { u8 hs400_tuning; };
+#if CONFIG_IS_ENABLED(DM_MMC) +#define mmc_to_dev(_mmc) _mmc->dev +#else +#define mmc_to_dev(_mmc) NULL +#endif + struct mmc_hwpart_conf { struct { uint enh_start; /* in 512-byte sectors */
The DM_DMA option is needed in order to translate physical address into bus addresses on a per-device basis.
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com --- configs/rpi_4_32b_defconfig | 1 + configs/rpi_4_defconfig | 1 + configs/rpi_arm64_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index 5ddd838fd5..0a5d3ff8cd 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -22,6 +22,7 @@ CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM_DMA=y CONFIG_DFU_MMC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 2590d0a696..b61cdc05f1 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -22,6 +22,7 @@ CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM_DMA=y CONFIG_DFU_MMC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y diff --git a/configs/rpi_arm64_defconfig b/configs/rpi_arm64_defconfig index 2639219a1a..4125a1feba 100644 --- a/configs/rpi_arm64_defconfig +++ b/configs/rpi_arm64_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FS_UUID=y CONFIG_OF_BOARD=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM_DMA=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y
The 'brcm,bcm2711-hdmi0' compatible string is used on RPi4 instead of 'brcm,bcm2835-hdmi' since the IP core was upgraded (now called VC6 instead of VC4). This has no functional change as far as u-boot driver is concerned. So simply add the compatible string.
Signed-off-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Tested-by: Peter Robinson pbrobinson@gmail.com --- drivers/video/bcm2835.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/video/bcm2835.c b/drivers/video/bcm2835.c index 9326999cd3..c2962932c9 100644 --- a/drivers/video/bcm2835.c +++ b/drivers/video/bcm2835.c @@ -52,6 +52,7 @@ static int bcm2835_video_probe(struct udevice *dev)
static const struct udevice_id bcm2835_video_ids[] = { { .compatible = "brcm,bcm2835-hdmi" }, + { .compatible = "brcm,bcm2711-hdmi0" }, { .compatible = "brcm,bcm2708-fb" }, { } };
