[U-Boot] [PATCH] arm64: zynqmp: Add comment about level shifter mode v1
Silicon v1 didn't support SD boot mode with level shifter. Because system can't boot any error message is not shown that's why comment is just a record if someone tries to debug it.
arch/arm/cpu/armv8/zynqmp/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/spl.c b/arch/arm/cpu/armv8/zynqmp/spl.c index e5a413954a5b..779497ca6d0b 100644 --- a/arch/arm/cpu/armv8/zynqmp/spl.c +++ b/arch/arm/cpu/armv8/zynqmp/spl.c @@ -84,7 +84,7 @@ u32 spl_boot_device(void) return BOOT_DEVICE_RAM; #ifdef CONFIG_SPL_MMC_SUPPORT case SD_MODE1: - case SD1_LSHFT_MODE: + case SD1_LSHFT_MODE: /* not working on silicon v1 */ /* if both controllers enabled, then these two are the second controller */ #if defined(CONFIG_ZYNQ_SDHCI0) && defined(CONFIG_ZYNQ_SDHCI1) return BOOT_DEVICE_MMC2;
Michal Simek
