[U-Boot] [PATCH v6 0/5] spi: cadence_qspi: optimize & fix indirect rd-writes
This patchset: - fixes trigger base & transfer start address register programming. This fix superseeds the previous patch "spi: cadence_qspi: Fix the indirect ahb trigger address setting". - adds support to get fifo width from device tree
Changes in v6: - fixed binding for trigger-address.
Changes in v5: - fixed compilation warnings.
Changes in v4: - fifo-width & trigger address alligned to linux device tree binding. - removed un-necessary casting. - renaming of one parameter splitted to separate patch. - trigger address of socfpga reverted back to 0x0. - code formatting done to avoid checkpatch CHECKS.
Changes in v3: - removed two patches which were bypassing the sram level check. - format string in patch corrected 3/4 - added commit message in patch 1/4
Changes in v2: - rebased to master. - removed patch "spi: cadence_qspi: read can be independent of fifo width", it was implemented in other patchset, in mainline now.
Vikas Manocha (5): spi: cadence_qspi: move trigger base configuration in init spi: cadence_qspi: fix indirect read/write start address spi: cadence_qspi: fix base trigger address & transfer start address spi: cadence_qspi: rename ahbbase to flashbase for clarity spi: cadence_qspi: get fifo width from device tree
arch/arm/dts/socfpga.dtsi | 2 ++ arch/arm/dts/stv0991.dts | 2 ++ drivers/spi/cadence_qspi.c | 14 ++++++++------ drivers/spi/cadence_qspi.h | 6 ++++-- drivers/spi/cadence_qspi_apb.c | 42 ++++++++++++++++------------------------ 5 files changed, 33 insertions(+), 33 deletions(-)
No need to configure indirect trigger address for every read/write.
Signed-off-by: Vikas Manocha vikas.manocha@st.com ---
Changes in v6: None Changes in v5: fixed type cast compilation warnings. Changes in v4: removed extra type casts. Changes in v3: added commit message & removed extra bracket. Changes in v2: Rebased to master
drivers/spi/cadence_qspi_apb.c | 9 ++------- 1 file changed, 2 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index d053407..d377ad1 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -534,6 +534,8 @@ void cadence_qspi_apb_controller_init(struct cadence_spi_platdata *plat)
/* Indirect mode configurations */ writel((plat->sram_size/2), plat->regbase + CQSPI_REG_SRAMPARTITION); + writel((u32)plat->ahbbase & CQSPI_INDIRECTTRIGGER_ADDR_MASK, + plat->regbase + CQSPI_REG_INDIRECTTRIGGER);
/* Disable all interrupts */ writel(0, plat->regbase + CQSPI_REG_IRQMASK); @@ -693,10 +695,6 @@ int cadence_qspi_apb_indirect_read_setup(struct cadence_spi_platdata *plat, /* for normal read (only ramtron as of now) */ addr_bytes = cmdlen - 1;
- /* Setup the indirect trigger address */ - writel(((u32)plat->ahbbase & CQSPI_INDIRECTTRIGGER_ADDR_MASK), - plat->regbase + CQSPI_REG_INDIRECTTRIGGER); - /* Configure the opcode */ rd_reg = cmdbuf[0] << CQSPI_REG_RD_INSTR_OPCODE_LSB;
@@ -790,9 +788,6 @@ int cadence_qspi_apb_indirect_write_setup(struct cadence_spi_platdata *plat, cmdlen, (unsigned int)cmdbuf); return -EINVAL; } - /* Setup the indirect trigger address */ - writel(((u32)plat->ahbbase & CQSPI_INDIRECTTRIGGER_ADDR_MASK), - plat->regbase + CQSPI_REG_INDIRECTTRIGGER);
/* Configure the opcode */ reg = cmdbuf[0] << CQSPI_REG_WR_INSTR_OPCODE_LSB;
plat->regbase + CQSPI_REG_INDIRECTTRIGGER); /* Disable all interrupts */ writel(0, plat->regbase + CQSPI_REG_IRQMASK);
plat->regbase + CQSPI_REG_INDIRECTTRIGGER); /* Configure the opcode */ reg = cmdbuf[0] << CQSPI_REG_WR_INSTR_OPCODE_LSB;
-- 1.7.9.5
Reviewed-by: Jagan Teki jteki@openedev.com
thanks!
Indirect read/write start addresses are flash start addresses for indirect read or write transfers. These should be absolute flash addresses instead of offsets.
Changes in v6: none Changes in v5: fixed type cast compilation warnings. Changes in v4: removed extra type casts. Changes in v3: none Changes in v2: Rebased to master
drivers/spi/cadence_qspi_apb.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index d377ad1..c5b14c5 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -705,7 +705,8 @@ int cadence_qspi_apb_indirect_read_setup(struct cadence_spi_platdata *plat,
/* Get address */ addr_value = cadence_qspi_apb_cmd2addr(&cmdbuf[1], addr_bytes); - writel(addr_value, plat->regbase + CQSPI_REG_INDIRECTRDSTARTADDR); + writel((u32)plat->ahbbase + addr_value, + plat->regbase + CQSPI_REG_INDIRECTRDSTARTADDR);
/* The remaining lenght is dummy bytes. */ dummy_bytes = cmdlen - addr_bytes - 1; @@ -795,7 +796,8 @@ int cadence_qspi_apb_indirect_write_setup(struct cadence_spi_platdata *plat,
/* Setup write address. */ reg = cadence_qspi_apb_cmd2addr(&cmdbuf[1], addr_bytes); - writel(reg, plat->regbase + CQSPI_REG_INDIRECTWRSTARTADDR); + writel((u32)plat->ahbbase + reg, + plat->regbase + CQSPI_REG_INDIRECTWRSTARTADDR);
reg = readl(plat->regbase + CQSPI_REG_SIZE); reg &= ~CQSPI_REG_SIZE_ADDRESS_MASK;
plat->regbase + CQSPI_REG_INDIRECTRDSTARTADDR); /* The remaining lenght is dummy bytes. */ dummy_bytes = cmdlen - addr_bytes - 1;
plat->regbase + CQSPI_REG_INDIRECTWRSTARTADDR); reg = readl(plat->regbase + CQSPI_REG_SIZE); reg &= ~CQSPI_REG_SIZE_ADDRESS_MASK;
-- 1.7.9.5
Jagan, is introducing ad-hoc typecasts to suppress warnings OK with you ?
Best regards, Marek Vasut
I think there are few ad-hoc typecasts similar to were there in the driver, do you have any other thoughts?
thanks!
Yes, for example -- fix the few, then add new features. Adding more just because there were some before is a totally shitty approach.
Hi Vikas,
Can you fix this?
thanks!
This patch is to separate the base trigger from the read/write transfer start addresses.
Base trigger register address (0x1c register) corresponds to the address which should be put on AHB bus to handle indirect transfer triggered before.
To handle indirect transfer we need to issue addresses from (value of 0x1c) to (value of 0x1c) + 15*4 ("4" corresponds to size of SRAM location). There are no obstacles in issuing const address just equal to 0x1c. Important thing to note is that indirect trigger address has nothing in common with your physical or mapped NOR Flash address.
Transfer read/write start addresses (offset 0x68/0x78)should be programmed with the absolute flash address to be read/written.
plat->triggerbase is added in device tree for mapped spi flash address.
Changes in v6: fixed binding for trigger-address. Changes in v5: None. Changes in v4: - fifo-width & trigger address alligned to linux device tree binding. - renaming of one parameter moved to separate patch. - trigger address of socfpga reverted back to 0x0.
Changes in v3: formatted string breaking fixed. Changes in v2: Rebased to master
arch/arm/dts/socfpga.dtsi | 1 + arch/arm/dts/stv0991.dts | 1 + drivers/spi/cadence_qspi.c | 9 +++++---- drivers/spi/cadence_qspi.h | 1 + drivers/spi/cadence_qspi_apb.c | 7 +++---- 5 files changed, 11 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index 9b12420..9756544 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -639,6 +639,7 @@ ext-decoder = <0>; /* external decoder */ num-cs = <4>; fifo-depth = <128>; + cdns,trigger-address = <0x00000000>; sram-size = <128>; bus-num = <2>; status = "disabled"; diff --git a/arch/arm/dts/stv0991.dts b/arch/arm/dts/stv0991.dts index fa3fd64..6bc5372 100644 --- a/arch/arm/dts/stv0991.dts +++ b/arch/arm/dts/stv0991.dts @@ -33,6 +33,7 @@ <0x40000000 0x1000000>; clocks = <3750000>; sram-size = <256>; + cdns,trigger-address = <0x40000000>; status = "okay";
flash0: n25q32@0 { diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 34a0f46..0d1abc8 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -290,6 +290,8 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus)
plat->regbase = (void *)data[0]; plat->ahbbase = (void *)data[2]; + plat->trigger_base = (u32 *)fdtdec_get_addr(blob, node, + "cdns,trigger-address");
/* Use 500KHz as a suitable default */ plat->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", @@ -311,10 +313,9 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20); plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128);
- debug("%s: regbase=%p ahbbase=%p max-frequency=%d page-size=%d\n", - __func__, plat->regbase, plat->ahbbase, plat->max_hz, - plat->page_size); - + debug("%s: regbase=%p ahbbase=%p trigger_base=%p max-frequency=%d page-size=%d\n", + __func__, plat->regbase, plat->ahbbase, plat->trigger_base, + plat->max_hz, plat->page_size); return 0; }
diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index 98e57aa..2f1bd92 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -18,6 +18,7 @@ struct cadence_spi_platdata { unsigned int max_hz; void *regbase; void *ahbbase; + void *trigger_base;
u32 page_size; u32 block_size; diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index c5b14c5..8156b2b 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -44,7 +44,6 @@ #define CQSPI_INST_TYPE_QUAD (2)
#define CQSPI_STIG_DATA_LEN_MAX (8) -#define CQSPI_INDIRECTTRIGGER_ADDR_MASK (0xFFFFF)
#define CQSPI_DUMMY_CLKS_PER_BYTE (8) #define CQSPI_DUMMY_BYTES_MAX (4) @@ -281,7 +280,7 @@ static int qpsi_write_sram_fifo_push(struct cadence_spi_platdata *plat, const void *src_addr, unsigned int num_bytes) { const void *reg_base = plat->regbase; - void *dest_addr = plat->ahbbase; + void *dest_addr = plat->trigger_base; unsigned int retry = CQSPI_REG_RETRY; unsigned int sram_level; unsigned int wr_bytes; @@ -534,7 +533,7 @@ void cadence_qspi_apb_controller_init(struct cadence_spi_platdata *plat)
/* Indirect mode configurations */ writel((plat->sram_size/2), plat->regbase + CQSPI_REG_SRAMPARTITION); - writel((u32)plat->ahbbase & CQSPI_INDIRECTTRIGGER_ADDR_MASK, + writel((u32)plat->trigger_base, plat->regbase + CQSPI_REG_INDIRECTTRIGGER);
/* Disable all interrupts */ @@ -753,7 +752,7 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, plat->regbase + CQSPI_REG_INDIRECTRD);
if (qspi_read_sram_fifo_poll(plat->regbase, (void *)rxbuf, - (const void *)plat->ahbbase, rxlen)) + (const void *)plat->trigger_base, rxlen)) goto failrd;
/* Check flash indirect controller */
cdns,trigger-address = <0x40000000>; status = "okay"; flash0: n25q32@0 {
"cdns,trigger-address"); /* Use 500KHz as a suitable default */ plat->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency",
plat->page_size);
void *trigger_base; u32 page_size; u32 block_size;
writel((u32)plat->trigger_base, plat->regbase + CQSPI_REG_INDIRECTTRIGGER); /* Disable all interrupts */
(const void *)plat->trigger_base, rxlen)) goto failrd; /* Check flash indirect controller */
-- 1.7.9.5
plat->ahbbase renamed to plat->flashbase for better clarity.
Changes in v6: none Changes in v5: none Changes in v4: new
drivers/spi/cadence_qspi.c | 8 ++++---- drivers/spi/cadence_qspi.h | 4 ++-- drivers/spi/cadence_qspi_apb.c | 4 ++-- 3 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 0d1abc8..c63f583 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -150,7 +150,7 @@ static int cadence_spi_probe(struct udevice *bus) struct cadence_spi_priv *priv = dev_get_priv(bus);
priv->regbase = plat->regbase; - priv->ahbbase = plat->ahbbase; + priv->flashbase = plat->flashbase;
if (!priv->qspi_is_init) { cadence_qspi_apb_controller_init(plat); @@ -289,7 +289,7 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) }
plat->regbase = (void *)data[0]; - plat->ahbbase = (void *)data[2]; + plat->flashbase = (void *)data[2]; plat->trigger_base = (u32 *)fdtdec_get_addr(blob, node, "cdns,trigger-address");
@@ -313,8 +313,8 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20); plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128);
- debug("%s: regbase=%p ahbbase=%p trigger_base=%p max-frequency=%d page-size=%d\n", - __func__, plat->regbase, plat->ahbbase, plat->trigger_base, + debug("%s: regbase=%p flashbase=%p trigger_base=%p max-frequency=%d page-size=%d\n", + __func__, plat->regbase, plat->flashbase, plat->trigger_base, plat->max_hz, plat->page_size); return 0; } diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index 2f1bd92..7341339 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -17,7 +17,7 @@ struct cadence_spi_platdata { unsigned int max_hz; void *regbase; - void *ahbbase; + void *flashbase; void *trigger_base;
u32 page_size; @@ -31,7 +31,7 @@ struct cadence_spi_platdata {
struct cadence_spi_priv { void *regbase; - void *ahbbase; + void *flashbase; size_t cmd_len; u8 cmd_buf[32]; size_t data_len; diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 8156b2b..2638f00 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -704,7 +704,7 @@ int cadence_qspi_apb_indirect_read_setup(struct cadence_spi_platdata *plat,
/* Get address */ addr_value = cadence_qspi_apb_cmd2addr(&cmdbuf[1], addr_bytes); - writel((u32)plat->ahbbase + addr_value, + writel((u32)plat->flashbase + addr_value, plat->regbase + CQSPI_REG_INDIRECTRDSTARTADDR);
/* The remaining lenght is dummy bytes. */ @@ -795,7 +795,7 @@ int cadence_qspi_apb_indirect_write_setup(struct cadence_spi_platdata *plat,
/* Setup write address. */ reg = cadence_qspi_apb_cmd2addr(&cmdbuf[1], addr_bytes); - writel((u32)plat->ahbbase + reg, + writel((u32)plat->flashbase + reg, plat->regbase + CQSPI_REG_INDIRECTWRSTARTADDR);
Can you give short description about this rename.
priv->flashbase = plat->flashbase; if (!priv->qspi_is_init) { cadence_qspi_apb_controller_init(plat);
void *ahbbase;
void *flashbase; void *trigger_base; u32 page_size;
void *ahbbase;
writel((u32)plat->flashbase + addr_value, plat->regbase + CQSPI_REG_INDIRECTRDSTARTADDR); /* The remaining lenght is dummy bytes. */
writel((u32)plat->flashbase + reg, plat->regbase + CQSPI_REG_INDIRECTWRSTARTADDR); reg = readl(plat->regbase + CQSPI_REG_SIZE);
-- 1.7.9.5
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jteki@openedev.com] Sent: Wednesday, September 23, 2015 3:15 AM To: Vikas MANOCHA Cc: u-boot@lists.denx.de; Stefan Roese; Graham Moore; Marek Vašut Subject: Re: [U-Boot] [PATCH v6 4/5] spi: cadence_qspi: rename ahbbase to flashbase for clarity
With ahbbase it was not clear which base address it is, flashbase makes it clear that it is mapped flash memory base address. I will add this info & send the next version.
Rgds, Vikas
udevice *bus)
} plat->regbase = (void *)data[0];
udevice *bus)
128);
- plat->trigger_base, plat->max_hz, plat->page_size); return 0;
void *ahbbase;
void *ahbbase;
writel((u32)plat->flashbase + addr_value, plat->regbase + CQSPI_REG_INDIRECTRDSTARTADDR); /* The remaining lenght is dummy bytes. */ @@ -795,7 +795,7 @@
-- 1.7.9.5
-- Jagan | openedev.
Fifo width could be different on different socs, e.g. stv0991 & altera soc have different fifo width.
Changes in v6: none Changes in v5: none Changes in v4: alligned to linux device tree binding. Changes in v3: none Changes in v2: Rebased to master
arch/arm/dts/socfpga.dtsi | 1 + arch/arm/dts/stv0991.dts | 1 + drivers/spi/cadence_qspi.c | 1 + drivers/spi/cadence_qspi.h | 1 + drivers/spi/cadence_qspi_apb.c | 24 ++++++++++-------------- 5 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index 9756544..5f0b0fa 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -640,6 +640,7 @@ num-cs = <4>; fifo-depth = <128>; cdns,trigger-address = <0x00000000>; + cdns,fifo-width = <4>; sram-size = <128>; bus-num = <2>; status = "disabled"; diff --git a/arch/arm/dts/stv0991.dts b/arch/arm/dts/stv0991.dts index 6bc5372..0a88b69 100644 --- a/arch/arm/dts/stv0991.dts +++ b/arch/arm/dts/stv0991.dts @@ -34,6 +34,7 @@ clocks = <3750000>; sram-size = <256>; cdns,trigger-address = <0x40000000>; + cdns,fifo-width = <8>; status = "okay";
flash0: n25q32@0 { diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index c63f583..0430218 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -312,6 +312,7 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) plat->tchsh_ns = fdtdec_get_int(blob, subnode, "tchsh-ns", 20); plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20); plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128); + plat->fifo_width = fdtdec_get_int(blob, node, "cdns,fifo-width", 4);
debug("%s: regbase=%p flashbase=%p trigger_base=%p max-frequency=%d page-size=%d\n", __func__, plat->regbase, plat->flashbase, plat->trigger_base, diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index 7341339..91f38f1 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -27,6 +27,7 @@ struct cadence_spi_platdata { u32 tchsh_ns; u32 tslch_ns; u32 sram_size; + u32 fifo_width; };
struct cadence_spi_priv { diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 2638f00..478b5a0 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -34,8 +34,6 @@ #define CQSPI_REG_RETRY (10000) #define CQSPI_POLL_IDLE_RETRY (3)
-#define CQSPI_FIFO_WIDTH (4) - #define CQSPI_REG_SRAM_THRESHOLD_WORDS (50)
/* Transfer mode */ @@ -48,9 +46,6 @@ #define CQSPI_DUMMY_CLKS_PER_BYTE (8) #define CQSPI_DUMMY_BYTES_MAX (4)
- -#define CQSPI_REG_SRAM_FILL_THRESHOLD \ - ((CQSPI_REG_SRAM_SIZE_WORD / 2) * CQSPI_FIFO_WIDTH) /**************************************************************************** * Controller's configuration and status register (offset from QSPI_BASE) ****************************************************************************/ @@ -214,7 +209,7 @@ static void cadence_qspi_apb_read_fifo_data(void *dest, }
static void cadence_qspi_apb_write_fifo_data(const void *dest_ahb_addr, - const void *src, unsigned int bytes) + const void *src, unsigned int fifo_width, unsigned int bytes) { unsigned int temp = 0; int i; @@ -222,11 +217,11 @@ static void cadence_qspi_apb_write_fifo_data(const void *dest_ahb_addr, unsigned int *dest_ptr = (unsigned int *)dest_ahb_addr; unsigned int *src_ptr = (unsigned int *)src;
- while (remaining >= CQSPI_FIFO_WIDTH) { - for (i = CQSPI_FIFO_WIDTH/sizeof(src_ptr) - 1; i >= 0; i--) + while (remaining >= fifo_width) { + for (i = fifo_width/sizeof(src_ptr) - 1; i >= 0; i--) writel(*(src_ptr+i), dest_ptr+i); - src_ptr += CQSPI_FIFO_WIDTH/sizeof(src_ptr); - remaining -= CQSPI_FIFO_WIDTH; + src_ptr += fifo_width/sizeof(src_ptr); + remaining -= fifo_width; } if (remaining) { /* dangling bytes */ @@ -241,7 +236,7 @@ static void cadence_qspi_apb_write_fifo_data(const void *dest_ahb_addr,
/* Read from SRAM FIFO with polling SRAM fill level. */ static int qspi_read_sram_fifo_poll(const void *reg_base, void *dest_addr, - const void *src_addr, unsigned int num_bytes) + const void *src_addr, unsigned int fifo_width, unsigned int num_bytes) { unsigned int remaining = num_bytes; unsigned int retry; @@ -263,7 +258,7 @@ static int qspi_read_sram_fifo_poll(const void *reg_base, void *dest_addr, return -1; }
- sram_level *= CQSPI_FIFO_WIDTH; + sram_level *= fifo_width; sram_level = sram_level > remaining ? remaining : sram_level;
/* Read data from FIFO. */ @@ -305,7 +300,8 @@ static int qpsi_write_sram_fifo_push(struct cadence_spi_platdata *plat, wr_bytes = (remaining > page_size) ? page_size : remaining;
- cadence_qspi_apb_write_fifo_data(dest_addr, src, wr_bytes); + cadence_qspi_apb_write_fifo_data(dest_addr, src, + plat->fifo_width, wr_bytes); src += wr_bytes; remaining -= wr_bytes; } @@ -752,7 +748,7 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, plat->regbase + CQSPI_REG_INDIRECTRD);
if (qspi_read_sram_fifo_poll(plat->regbase, (void *)rxbuf, - (const void *)plat->trigger_base, rxlen)) + (const void *)plat->trigger_base, plat->fifo_width, rxlen)) goto failrd;
Hi Vikas,
cdns,fifo-width = <8>; status = "okay"; flash0: n25q32@0 {
plat->fifo_width = fdtdec_get_int(blob, node, "cdns,fifo-width", 4); debug("%s: regbase=%p flashbase=%p trigger_base=%p max-frequency=%d page-size=%d\n", __func__, plat->regbase, plat->flashbase, plat->trigger_base,
u32 fifo_width;
This removal is out-of-scope wrt this patch, create one more patch for this.
- Controller's configuration and status register (offset from QSPI_BASE)
sram_level *= fifo_width; sram_level = sram_level > remaining ? remaining : sram_level; /* Read data from FIFO. */
(const void *)plat->trigger_base, plat->fifo_width, rxlen)) goto failrd; /* Check flash indirect controller */
-- 1.7.9.5
Thanks Jagan,
-----Original Message----- From: Jagan Teki [mailto:jteki@openedev.com] Sent: Wednesday, September 23, 2015 4:00 AM To: Vikas MANOCHA Cc: u-boot@lists.denx.de; Stefan Roese; Graham Moore; Marek Vašut Subject: Re: [U-Boot] [PATCH v6 5/5] spi: cadence_qspi: get fifo width from device tree
Hi Vikas,
cdns,fifo-width = <8>; status = "okay"; flash0: n25q32@0 { diff --git
udevice *bus)
128);
u32 fifo_width;
Agreed, I will create another patch in next version.
Rgds, Vikas
*dest_ahb_addr,
- num_bytes)
return -1; }
sram_level;
plat->fifo_width,
- wr_bytes); src += wr_bytes; remaining -= wr_bytes; }
plat->regbase + CQSPI_REG_INDIRECTRD); if (qspi_read_sram_fifo_poll(plat->regbase, (void *)rxbuf,
-- 1.7.9.5
Reminder... let me know if there is any comment.
Rgds, Vikas
-----Original Message----- From: Vikas MANOCHA Sent: Friday, September 11, 2015 11:28 AM To: u-boot@lists.denx.de; sr@denx.de; grmoore@opensource.altera.com; jteki@openedev.com; marex@denx.de Cc: Vikas MANOCHA Subject: [PATCH v6 0/5] spi: cadence_qspi: optimize & fix indirect rd-writes
This patchset:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
-- 1.7.9.5
Jagan Teki
Vikas MANOCHA
Vikas Manocha
