[U-Boot] [PATCH 1/2] i2c: cmd: Relocate subcommands when MANUAL_RELOC
Subcommands contain pointers to functions which are not updated when MANUAL_REALOC is enabled. This patch fix it.
common/cmd_i2c.c | 16 ++++++++++++---- 1 file changed, 12 insertions(+), 4 deletions(-)
diff --git a/common/cmd_i2c.c b/common/cmd_i2c.c index 3d0de81c32f8..552c875f62dd 100644 --- a/common/cmd_i2c.c +++ b/common/cmd_i2c.c @@ -1944,11 +1944,15 @@ static cmd_tbl_t cmd_i2c_sub[] = { U_BOOT_CMD_MKENT(speed, 1, 1, do_i2c_bus_speed, "", ""), };
-#ifdef CONFIG_NEEDS_MANUAL_RELOC -void i2c_reloc(void) { - fixup_cmdtable(cmd_i2c_sub, ARRAY_SIZE(cmd_i2c_sub)); +static __maybe_unused void i2c_reloc(void) +{ + static int relocated; + + if (!relocated) { + fixup_cmdtable(cmd_i2c_sub, ARRAY_SIZE(cmd_i2c_sub)); + relocated = 1; + }; } -#endif
/** * do_i2c() - Handle the "i2c" command-line command @@ -1964,6 +1968,10 @@ static int do_i2c(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) { cmd_tbl_t *c;
+#ifdef CONFIG_NEEDS_MANUAL_RELOC + i2c_reloc(); +#endif + if (argc < 2) return CMD_RET_USAGE;
test/dm/cmd_dm.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/test/dm/cmd_dm.c b/test/dm/cmd_dm.c index caff49aa4f62..b6e71091497c 100644 --- a/test/dm/cmd_dm.c +++ b/test/dm/cmd_dm.c @@ -46,11 +46,25 @@ static cmd_tbl_t test_commands[] = { U_BOOT_CMD_MKENT(devres, 1, 1, do_dm_dump_devres, "", ""), };
+static __maybe_unused void dm_reloc(void) +{ + static int relocated; + + if (!relocated) { + fixup_cmdtable(test_commands, ARRAY_SIZE(test_commands)); + relocated = 1; + } +} + static int do_dm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { cmd_tbl_t *test_cmd; int ret;
+#ifdef CONFIG_NEEDS_MANUAL_RELOC + dm_reloc(); +#endif + if (argc < 2) return CMD_RET_USAGE; test_cmd = find_cmd_tbl(argv[1], test_commands,
Hello Michal,
Am 04.12.2015 um 17:05 schrieb Michal Simek:
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
- static int relocated;
- if (!relocated) {
relocated = 1;
-#endif
- do_i2c() - Handle the "i2c" command-line command
- i2c_reloc();
- if (argc < 2) return CMD_RET_USAGE;
Heiko Schocher
Michal Simek
