[U-Boot-Users] [PATCH] PPC4xx: Add MII mode support to the EMAC RGMII Bridge
This patch adds support for placing the RGMII bridge on the PPC405EX(r) into MII/GMII mode and allows a board-specific configuration to specify the bridge mode at compile-time.
Signed-off-by: Grant Erickson gerickson@nuovations.com --- cpu/ppc4xx/4xx_enet.c | 80 ++++++++++++++++++++++++++++++++++++++------ include/configs/kilauea.h | 1 + include/configs/makalu.h | 1 + include/ppc4xx_enet.h | 16 ++++++++- 4 files changed, 86 insertions(+), 12 deletions(-)
diff --git a/cpu/ppc4xx/4xx_enet.c b/cpu/ppc4xx/4xx_enet.c index c40e0ca..638e155 100644 --- a/cpu/ppc4xx/4xx_enet.c +++ b/cpu/ppc4xx/4xx_enet.c @@ -465,30 +465,88 @@ int ppc_4xx_eth_setup_bridge(int devnum, bd_t * bis) #if defined(CONFIG_405EX) int ppc_4xx_eth_setup_bridge(int devnum, bd_t * bis) { - u32 gmiifer = 0; + u32 rgmiifer = 0;
/* - * Right now only 2*RGMII is supported. Please extend when needed. - * sr - 2007-09-19 + * The 405EX(r)'s RGMII bridge can operate in one of several + * modes, only one of which (2 x RGMII) allows the + * simultaneous use of both EMACs on the 405EX. */ - switch (1) { - case 1: + + switch (CONFIG_EMAC_PHY_MODE) { + + case EMAC_PHY_MODE_NONE: + /* No ports */ + rgmiifer |= RGMII_FER_DIS << 0; + rgmiifer |= RGMII_FER_DIS << 4; + out_be32((void *)RGMII_FER, rgmiifer); + bis->bi_phymode[0] = BI_PHYMODE_NONE; + bis->bi_phymode[1] = BI_PHYMODE_NONE; + break; + case EMAC_PHY_MODE_NONE_RGMII: + /* 1 x RGMII port on channel 0 */ + rgmiifer |= RGMII_FER_RGMII << 0; + rgmiifer |= RGMII_FER_DIS << 4; + out_be32((void *)RGMII_FER, rgmiifer); + bis->bi_phymode[0] = BI_PHYMODE_RGMII; + bis->bi_phymode[1] = BI_PHYMODE_NONE; + break; + case EMAC_PHY_MODE_RGMII_NONE: + /* 1 x RGMII port on channel 1 */ + rgmiifer |= RGMII_FER_DIS << 0; + rgmiifer |= RGMII_FER_RGMII << 4; + out_be32((void *)RGMII_FER, rgmiifer); + bis->bi_phymode[0] = BI_PHYMODE_NONE; + bis->bi_phymode[1] = BI_PHYMODE_RGMII; + break; + case EMAC_PHY_MODE_RGMII_RGMII: /* 2 x RGMII ports */ - out_be32((void *)RGMII_FER, 0x00000055); + rgmiifer |= RGMII_FER_RGMII << 0; + rgmiifer |= RGMII_FER_RGMII << 4; + out_be32((void *)RGMII_FER, rgmiifer); bis->bi_phymode[0] = BI_PHYMODE_RGMII; bis->bi_phymode[1] = BI_PHYMODE_RGMII; break; - case 2: - /* 2 x SMII ports */ + case EMAC_PHY_MODE_NONE_GMII: + /* 1 x GMII port on channel 0 */ + rgmiifer |= RGMII_FER_GMII << 0; + rgmiifer |= RGMII_FER_DIS << 4; + out_be32((void *)RGMII_FER, rgmiifer); + bis->bi_phymode[0] = BI_PHYMODE_GMII; + bis->bi_phymode[1] = BI_PHYMODE_NONE; + break; + case EMAC_PHY_MODE_NONE_MII: + /* 1 x MII port on channel 0 */ + rgmiifer |= RGMII_FER_MII << 0; + rgmiifer |= RGMII_FER_DIS << 4; + out_be32((void *)RGMII_FER, rgmiifer); + bis->bi_phymode[0] = BI_PHYMODE_MII; + bis->bi_phymode[1] = BI_PHYMODE_NONE; + break; + case EMAC_PHY_MODE_GMII_NONE: + /* 1 x GMII port on channel 1 */ + rgmiifer |= RGMII_FER_DIS << 0; + rgmiifer |= RGMII_FER_GMII << 4; + out_be32((void *)RGMII_FER, rgmiifer); + bis->bi_phymode[0] = BI_PHYMODE_NONE; + bis->bi_phymode[1] = BI_PHYMODE_GMII; + break; + case EMAC_PHY_MODE_MII_NONE: + /* 1 x MII port on channel 1 */ + rgmiifer |= RGMII_FER_DIS << 0; + rgmiifer |= RGMII_FER_MII << 4; + out_be32((void *)RGMII_FER, rgmiifer); + bis->bi_phymode[0] = BI_PHYMODE_NONE; + bis->bi_phymode[1] = BI_PHYMODE_MII; break; default: break; }
/* Ensure we setup mdio for this devnum and ONLY this devnum */ - gmiifer = in_be32((void *)RGMII_FER); - gmiifer |= (1 << (19-devnum)); - out_be32((void *)RGMII_FER, gmiifer); + rgmiifer = in_be32((void *)RGMII_FER); + rgmiifer |= (1 << (19-devnum)); + out_be32((void *)RGMII_FER, rgmiifer);
return ((int)0x0); } diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index f3d048c..dc246fd 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -375,6 +375,7 @@ *----------------------------------------------------------------------*/ #define CONFIG_M88E1111_PHY 1 #define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_EMAC_PHY_MODE EMAC_PHY_MODE_RGMII_RGMII #define CONFIG_PHY_ADDR 1 /* PHY address, See schematics */
#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ diff --git a/include/configs/makalu.h b/include/configs/makalu.h index 65b240e..ab92ae4 100644 --- a/include/configs/makalu.h +++ b/include/configs/makalu.h @@ -223,6 +223,7 @@ *----------------------------------------------------------------------*/ #define CONFIG_M88E1111_PHY 1 #define CONFIG_IBM_EMAC4_V4 1 +#define CONFIG_EMAC_PHY_MODE EMAC_PHY_MODE_RGMII_RGMII #define CONFIG_PHY_ADDR 6 /* PHY address, See schematics */
#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ diff --git a/include/ppc4xx_enet.h b/include/ppc4xx_enet.h index 4c97b36..b74c6fc 100644 --- a/include/ppc4xx_enet.h +++ b/include/ppc4xx_enet.h @@ -153,6 +153,20 @@ typedef struct emac_4xx_hw_st { #define SDR0_PFC1_EM_1000 (0x00200000) #endif
+/* + * XMII bridge configurations for those systems (e.g. 405EX(r)) that do + * not have a pin function control (PFC) register to otherwise determine + * the bridge configuration. + */ +#define EMAC_PHY_MODE_NONE 0 +#define EMAC_PHY_MODE_NONE_RGMII 1 +#define EMAC_PHY_MODE_RGMII_NONE 2 +#define EMAC_PHY_MODE_RGMII_RGMII 3 +#define EMAC_PHY_MODE_NONE_GMII 4 +#define EMAC_PHY_MODE_GMII_NONE 5 +#define EMAC_PHY_MODE_NONE_MII 6 +#define EMAC_PHY_MODE_MII_NONE 7 + /* ZMII Bridge Register addresses */ #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ @@ -218,12 +232,12 @@ typedef struct emac_4xx_hw_st { #endif
/* RGMII Function Enable (FER) Register Bit Definitions */ -/* Note: for EMAC 2 and 3 only, 440GX only */ #define RGMII_FER_DIS (0x00) #define RGMII_FER_RTBI (0x04) #define RGMII_FER_RGMII (0x05) #define RGMII_FER_TBI (0x06) #define RGMII_FER_GMII (0x07) +#define RGMII_FER_MII (RGMII_FER_GMII)
#define RGMII_FER_V(__x) ((__x - 2) * 4)
Applied to "next" branch in u-boot-ppc4xx repository. Thanks.
Best regards, Stefan
Grant Erickson
Stefan Roese
