[PATCH 05/15] net-lwip: add ping command
Add CONFIG_CMD_PING_LWIP depending on CONFIG_NET_LWIP to provide the ping command using lwIP.
The implementation is derived from lwIP's contrib/apps/ping/ping.c.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- boot/Kconfig | 1 + cmd/Kconfig | 6 ++ cmd/net-lwip.c | 8 +++ include/net-lwip.h | 3 + net-lwip/Makefile | 1 + net-lwip/ping.c | 171 +++++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 190 insertions(+) create mode 100644 net-lwip/ping.c
diff --git a/boot/Kconfig b/boot/Kconfig index 649fd454a2..9f220fa75c 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -382,6 +382,7 @@ config BOOT_DEFAULTS_CMDS select CMD_PING if CMD_NET select CMD_PXE if CMD_NET select CMD_DHCP_LWIP if CMD_NET_LWIP + select CMD_PING_LWIP if CMD_NET_LWIP select CMD_BOOTI if ARM64 select CMD_BOOTZ if ARM && !ARM64 imply CMD_MII if NET diff --git a/cmd/Kconfig b/cmd/Kconfig index 7bb6269b7a..6840f7319b 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2098,6 +2098,12 @@ config CMD_DHCP_LWIP help Boot image via network using DHCP/TFTP protocol
+config CMD_PING_LWIP + bool "ping" + select PROT_RAW_LWIP + help + Send ICMP ECHO_REQUEST to network host + config CMD_TFTPBOOT_LWIP bool "tftp" select PROT_UDP_LWIP diff --git a/cmd/net-lwip.c b/cmd/net-lwip.c index 30b396f2d0..fbe04048cd 100644 --- a/cmd/net-lwip.c +++ b/cmd/net-lwip.c @@ -12,6 +12,14 @@ U_BOOT_CMD( ); #endif
+#if defined(CONFIG_CMD_PING_LWIP) +U_BOOT_CMD( + ping, 2, 1, do_ping, + "send ICMP ECHO_REQUEST to network host", + "pingAddress" +); +#endif + #if defined(CONFIG_CMD_TFTPBOOT_LWIP) U_BOOT_CMD( tftpboot, 3, 0, do_tftpb, diff --git a/include/net-lwip.h b/include/net-lwip.h index 2308703e46..2abaaa3b4e 100644 --- a/include/net-lwip.h +++ b/include/net-lwip.h @@ -5,6 +5,7 @@
#include <asm/cache.h> #include <linux/types.h> +#include <lwip/ip_addr.h> #include <lwip/netif.h> #include <time.h>
@@ -50,6 +51,7 @@ int eth_env_get_enetaddr_by_index(const char *base_name, int index, int eth_init(void); /* Initialize the device */ int eth_send(void *packet, int length); /* Send a packet */ int eth_rx(void); +const char *eth_get_name(void); int eth_get_dev_index(void); int eth_init_state_only(void); /* Set active state */ void eth_set_current(void); /* set nterface to ethcur var */ @@ -80,6 +82,7 @@ int net_lwip_init(void); struct netif *net_lwip_get_netif(void);
int do_dhcp(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); +int do_ping(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_tftpb(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
#endif /* __NET_LWIP_H__ */ diff --git a/net-lwip/Makefile b/net-lwip/Makefile index 79bdaecee5..676615fe17 100644 --- a/net-lwip/Makefile +++ b/net-lwip/Makefile @@ -7,6 +7,7 @@ obj-$(CONFIG_$(SPL_)DM_ETH) += ../net/eth_common.o obj-$(CONFIG_$(SPL_)DM_ETH) += ../net/eth-uclass.o obj-$(CONFIG_$(SPL_)DM_ETH) += net-lwip.o obj-$(CONFIG_CMD_DHCP_LWIP) += dhcp.o +obj-$(CONFIG_CMD_PING_LWIP) += ping.o obj-$(CONFIG_CMD_TFTPBOOT_LWIP) += tftp.o
# Disable this warning as it is triggered by: diff --git a/net-lwip/ping.c b/net-lwip/ping.c new file mode 100644 index 0000000000..763a9bb1e3 --- /dev/null +++ b/net-lwip/ping.c @@ -0,0 +1,171 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* Copyright (C) 2024 Linaro Ltd. */ + +#include <command.h> +#include <console.h> +#include <linux/delay.h> +#include <linux/errno.h> +#include <lwip/icmp.h> +#include <lwip/inet_chksum.h> +#include <lwip/raw.h> +#include <lwip/timeouts.h> +#include <net-lwip.h> +#include <time.h> + +#define PING_DELAY_MS 1000 +#define PING_TIMEOUT_MS 10000 +/* Additional data size to include in the packet */ +#define PING_DATA_SIZE 32 +/* Ping identifier - must fit on a u16_t */ +#define PING_ID 0xAFAF + +static const ip_addr_t *ping_target; +static struct raw_pcb *ping_pcb; +static u16_t ping_seq_num; +static bool ping_target_alive; + +static u8_t ping_recv(void *arg, struct raw_pcb *pcb, struct pbuf *p, + const ip_addr_t *addr) +{ + struct icmp_echo_hdr *iecho; + + if (addr->addr != ping_target->addr) + return 0; + + if ((p->tot_len >= (IP_HLEN + sizeof(struct icmp_echo_hdr))) && + pbuf_remove_header(p, IP_HLEN) == 0) { + iecho = (struct icmp_echo_hdr *)p->payload; + + if ((iecho->id == PING_ID) && + (iecho->seqno == lwip_htons(ping_seq_num))) { + ping_target_alive = true; + printf("host %s is alive\n", ipaddr_ntoa(addr)); + pbuf_free(p); + return 1; /* eat the packet */ + } + /* not eaten, restore original packet */ + pbuf_add_header(p, IP_HLEN); + } + + return 0; /* don't eat the packet */ +} + +static int ping_raw_init(void) +{ + ping_pcb = raw_new(IP_PROTO_ICMP); + if (!ping_pcb) + return -ENOMEM; + + raw_recv(ping_pcb, ping_recv, NULL); + raw_bind(ping_pcb, IP_ADDR_ANY); + + return 0; +} + +static void ping_raw_stop(void) +{ + if (ping_pcb != NULL) { + raw_remove(ping_pcb); + ping_pcb = NULL; + } +} + +static void ping_prepare_echo(struct icmp_echo_hdr *iecho, u16_t len) +{ + size_t i; + size_t data_len = len - sizeof(struct icmp_echo_hdr); + + ICMPH_TYPE_SET(iecho, ICMP_ECHO); + ICMPH_CODE_SET(iecho, 0); + iecho->chksum = 0; + iecho->id = PING_ID; + iecho->seqno = lwip_htons(++ping_seq_num); + + /* Fill the additional data buffer with some data */ + for(i = 0; i < data_len; i++) { + ((char *)iecho)[sizeof(struct icmp_echo_hdr) + i] = (char)i; + } + + iecho->chksum = inet_chksum(iecho, len); +} + +static void ping_send_icmp(struct raw_pcb *raw, const ip_addr_t *addr) +{ + struct pbuf *p; + struct icmp_echo_hdr *iecho; + size_t ping_size = sizeof(struct icmp_echo_hdr) + PING_DATA_SIZE; + + p = pbuf_alloc(PBUF_IP, (u16_t)ping_size, PBUF_RAM); + if (!p) + return; + + if ((p->len == p->tot_len) && (p->next == NULL)) { + iecho = (struct icmp_echo_hdr *)p->payload; + ping_prepare_echo(iecho, (u16_t)ping_size); + raw_sendto(raw, p, addr); + } + + pbuf_free(p); +} + +static void ping_send(void *arg) +{ + struct raw_pcb *pcb = (struct raw_pcb *)arg; + + ping_send_icmp(pcb, ping_target); + sys_timeout(PING_DELAY_MS, ping_send, ping_pcb); +} + +static int ping_loop(const ip_addr_t* addr) +{ + ulong start; + int ret; + + printf("Using %s device\n", eth_get_name()); + + ret = ping_raw_init(); + if (ret < 0) + return ret; + ping_target = addr; + + start = get_timer(0); + ping_send(ping_pcb); + + do { + eth_rx(); + if (ping_target_alive) + break; + sys_check_timeouts(); + if (ctrlc()) { + printf("\nAbort\n"); + break; + } + } while (get_timer(start) < PING_TIMEOUT_MS); + + sys_untimeout(ping_send, ping_pcb); + ping_raw_stop(); + ping_target = NULL; + + if (ping_target_alive) { + ping_target_alive = false; + return 0; + } + printf("ping failed; host %s is not alive\n", ipaddr_ntoa(addr)); + return -1; +} + +int do_ping(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + ip_addr_t addr; + + if (argc < 2) + return CMD_RET_USAGE; + + if (!ipaddr_aton(argv[1], &addr)) + return CMD_RET_USAGE; + + if (ping_loop(&addr) < 0) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +}
Jerome Forissier
