[U-Boot] [PATCH v5 0/6] Add ARMv8 PSCI framework
v4-v5 changes: - rebased to latest u-boot version to ease conflict. - added mutually exclusive from FSL_PPA.
v3-v4 changes: - Re-added the 1/6 from v2, and move the newly re-named macro into Kconfig - Add "Reviewed-by: Tom Rini trini@konsulko.com" for patch 4/6 ~ 6/6.
v2-v3 changes: - Drop the previous 1/6, since the previous CONFIG_ARMV8_PSCI in common parts of codes also work for generic PSCI framework, so there are 5 patches in this iteration. - Add "Reviewed-by: Tom Rini trini@konsulko.com" for patches 1/5 and 2/5, which were 2/6 and 3/6. - Move config values for ls1043 from armv8/Kconfig to s1043ardb_defconfig.
v1-v2 changes: - The new config options are introduced in Kconfig when used for first time - Introduce new config options in armv8/Kconfig instead of LS1043 platform - Move previous patch 5/6 to current 2/6 place
v1 notes:
This patch set introduces ARMv8 PSCI framework, all the PSCI functions are implemented a default dummy one, it is up to each platform to implement their own specific ones.
The first 1/6 patch is a prepare clean up for adding ARMv8 PSCI. Patches 2/6 to 5/6 introduce new ARMv8 framework and set it up. The last 6/6 adds a most simple implementation on NXP LS1043 platform, to verify this framework.
This patch set mainly introduces ARMv8 PSCI framework, for easier review and merge, further PSCI implementation on LS1043 is coming later.
Hongbo Zhang (6): ARMv8: LS1043A: change macro CONFIG_ARMV8_PSCI definition ARMv8: Add secure sections for PSCI text and data ARMv8: Enable SMC instruction ARMv8: Add basic PSCI framework ARMv8: Setup PSCI memory and device tree ARMv8: LS1043A: Enable LS1043A default PSCI support
arch/arm/config.mk | 3 +- arch/arm/cpu/armv8/Kconfig | 41 ++++ arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/cpu-dt.c | 11 +- arch/arm/cpu/armv8/cpu.c | 22 ++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 21 ++ arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 3 +- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 3 +- arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S | 20 ++ arch/arm/cpu/armv8/psci.S | 286 +++++++++++++++++++++++ arch/arm/cpu/armv8/sec_firmware.c | 2 +- arch/arm/cpu/armv8/sec_firmware_asm.S | 2 +- arch/arm/cpu/armv8/u-boot.lds | 57 +++++ arch/arm/include/asm/armv8/sec_firmware.h | 2 +- arch/arm/include/asm/macro.h | 8 +- arch/arm/include/asm/psci.h | 15 ++ arch/arm/include/asm/secure.h | 2 +- arch/arm/include/asm/system.h | 11 + arch/arm/lib/bootm-fdt.c | 3 +- arch/arm/lib/bootm.c | 3 + arch/arm/lib/psci-dt.c | 5 +- board/freescale/ls1043ardb/Kconfig | 9 + include/configs/ls1043ardb.h | 1 - 24 files changed, 519 insertions(+), 13 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S create mode 100644 arch/arm/cpu/armv8/psci.S
NXP/Freescale uses macro CONFIG_ARMV8_PSCI to enable their private PSCI implementation in PPA firmware, but this macro naming too generic, so this patch replaces it with a specic one CONFIG_FSL_PPA_ARMV8_PSCI. And this macro CONFIG_ARMV8_PSCI will be used for a generic PSCI for ARMv8 which will be added in following patchs.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com --- arch/arm/cpu/armv8/cpu-dt.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 20 ++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 3 ++- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 3 ++- arch/arm/cpu/armv8/sec_firmware.c | 2 +- arch/arm/cpu/armv8/sec_firmware_asm.S | 2 +- arch/arm/include/asm/armv8/sec_firmware.h | 2 +- arch/arm/lib/bootm-fdt.c | 2 +- arch/arm/lib/psci-dt.c | 2 +- include/configs/ls1043ardb.h | 1 - 10 files changed, 30 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv8/cpu-dt.c b/arch/arm/cpu/armv8/cpu-dt.c index 9ffb49c..659ec27 100644 --- a/arch/arm/cpu/armv8/cpu-dt.c +++ b/arch/arm/cpu/armv8/cpu-dt.c @@ -13,7 +13,7 @@ int psci_update_dt(void *fdt) { #ifdef CONFIG_MP -#if defined(CONFIG_ARMV8_PSCI) +#if defined(CONFIG_FSL_PPA_ARMV8_PSCI) #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT /* * If the PSCI in SEC Firmware didn't work, avoid to update the diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 6772584..d28a422 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -44,6 +44,26 @@ config FSL_LSCH3 menu "Layerscape architecture" depends on FSL_LSCH2 || FSL_LSCH3
+menu "Layerscape PPA" +config FSL_LS_PPA + bool "FSL Layerscape PPA firmware support" + depends on ARCH_LS1043A || ARCH_LS1046A + select FSL_PPA_ARMV8_PSCI + help + The FSL Primary Protected Application (PPA) is a software component + which is loaded during boot stage, and then remains resident in RAM + and runs in the TrustZone after boot. + Say y to enable it. + +config FSL_PPA_ARMV8_PSCI + bool "PSCI implementation in PPA firmware" + depends on FSL_LS_PPA + help + This config enables the ARMv8 PSCI implementation in PPA firmware. + This is a private PSCI implementation and different from those + implemented under the common ARMv8 PSCI framework. +endmenu + config SYS_FSL_MMDC bool
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index ffbbd72..467d9af 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -410,7 +410,8 @@ int arch_early_init_r(void) erratum_a009942_check_cpo(); #endif #ifdef CONFIG_MP -#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && defined(CONFIG_ARMV8_PSCI) +#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && \ + defined(CONFIG_FSL_PPA_ARMV8_PSCI) /* Check the psci version to determine if the psci is supported */ psci_ver = sec_firmware_support_psci_version(); #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 0dae5fa..c10ccf9 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -42,7 +42,8 @@ void ft_fixup_cpu(void *blob) int addr_cells; u64 val, core_id; size_t *boot_code_size = &(__secondary_boot_code_size); -#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && defined(CONFIG_ARMV8_PSCI) +#if defined(CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT) && \ + defined(CONFIG_FSL_PPA_ARMV8_PSCI) int node; u32 psci_ver;
diff --git a/arch/arm/cpu/armv8/sec_firmware.c b/arch/arm/cpu/armv8/sec_firmware.c index 2ddd67e..0b973f0 100644 --- a/arch/arm/cpu/armv8/sec_firmware.c +++ b/arch/arm/cpu/armv8/sec_firmware.c @@ -209,7 +209,7 @@ __weak bool sec_firmware_is_valid(const void *sec_firmware_img) return true; }
-#ifdef CONFIG_ARMV8_PSCI +#ifdef CONFIG_FSL_PPA_ARMV8_PSCI /* * The PSCI_VERSION function is added from PSCI v0.2. When the PSCI * v0.1 received this function, the NOT_SUPPORTED (0xffff_ffff) error diff --git a/arch/arm/cpu/armv8/sec_firmware_asm.S b/arch/arm/cpu/armv8/sec_firmware_asm.S index 1b39f1d..903195d 100644 --- a/arch/arm/cpu/armv8/sec_firmware_asm.S +++ b/arch/arm/cpu/armv8/sec_firmware_asm.S @@ -41,7 +41,7 @@ WEAK(_sec_firmware_entry) ret ENDPROC(_sec_firmware_entry)
-#ifdef CONFIG_ARMV8_PSCI +#ifdef CONFIG_FSL_PPA_ARMV8_PSCI ENTRY(_sec_firmware_support_psci_version) mov x0, 0x84000000 mov x1, 0x0 diff --git a/arch/arm/include/asm/armv8/sec_firmware.h b/arch/arm/include/asm/armv8/sec_firmware.h index eb68185..a4e144b 100644 --- a/arch/arm/include/asm/armv8/sec_firmware.h +++ b/arch/arm/include/asm/armv8/sec_firmware.h @@ -14,7 +14,7 @@ int sec_firmware_init(const void *, u32 *, u32 *); int _sec_firmware_entry(const void *, u32 *, u32 *); bool sec_firmware_is_valid(const void *); -#ifdef CONFIG_ARMV8_PSCI +#ifdef CONFIG_FSL_PPA_ARMV8_PSCI unsigned int sec_firmware_support_psci_version(void); unsigned int _sec_firmware_support_psci_version(void); #endif diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index 4481f9e..1615756 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -52,7 +52,7 @@ int arch_fixup_fdt(void *blob) return ret; #endif
-#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_ARMV8_PSCI) +#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_FSL_PPA_ARMV8_PSCI) ret = psci_update_dt(blob); if (ret) return ret; diff --git a/arch/arm/lib/psci-dt.c b/arch/arm/lib/psci-dt.c index baf6d70..41e139e 100644 --- a/arch/arm/lib/psci-dt.c +++ b/arch/arm/lib/psci-dt.c @@ -16,7 +16,7 @@
int fdt_psci(void *fdt) { -#if defined(CONFIG_ARMV8_PSCI) || defined(CONFIG_ARMV7_PSCI) +#if defined(CONFIG_FSL_PPA_ARMV8_PSCI) || defined(CONFIG_ARMV7_PSCI) int nodeoff; unsigned int psci_ver = 0; int tmp; diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 849a6cb..71c26bd 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -12,7 +12,6 @@ #if defined(CONFIG_FSL_LS_PPA) #define CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT #define SEC_FIRMWARE_ERET_ADDR_REVERT -#define CONFIG_ARMV8_PSCI
#define CONFIG_SYS_LS_PPA_FW_IN_XIP #ifdef CONFIG_SYS_LS_PPA_FW_IN_XIP
This patch adds secure_text, secure_data and secure_stack sections for ARMv8 to hold PSCI text and data, and it is based on the legacy implementation of ARMv7.
ARMV8_SECURE_BASE defines the address for PSCI secure sections, ARMV8_PSCI and ARMV8_PSCI_NR_CPUS are firstly used in this patch, so they are introduce here in Kconfig too.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/config.mk | 3 +- arch/arm/cpu/armv8/Kconfig | 31 +++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + arch/arm/cpu/armv8/u-boot.lds | 57 +++++++++++++++++++++++++++++++ 4 files changed, 91 insertions(+), 1 deletion(-)
diff --git a/arch/arm/config.mk b/arch/arm/config.mk index 008da39..3a81f13 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -121,7 +121,8 @@ endif
# limit ourselves to the sections we want in the .bin. ifdef CONFIG_ARM64 -OBJCOPYFLAGS += -j .text -j .rodata -j .data -j .u_boot_list -j .rela.dyn +OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .data \ + -j .u_boot_list -j .rela.dyn else OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .hash \ -j .data -j .got -j .got.plt -j .u_boot_list -j .rel.dyn diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 965a8d1..edae43d 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -40,4 +40,35 @@ config PSCI_RESET
Select Y here to make use of PSCI calls for system reset
+config ARMV8_PSCI + bool "Enable PSCI support" if EXPERT + default n + help + PSCI is Power State Coordination Interface defined by ARM. + The PSCI in U-boot provides a general framework and each platform + can implement their own specific PSCI functions. + Say Y here to enable PSCI support on ARMv8 platform. + +config ARMV8_PSCI_NR_CPUS + int "Maximum supported CPUs for PSCI" + depends on ARMV8_PSCI + default 4 + help + The maximum number of CPUs supported in the PSCI firmware. + It is no problem to set a larger value than the number of CPUs in + the actual hardware implementation. + +if SYS_HAS_ARMV8_SECURE_BASE + +config ARMV8_SECURE_BASE + hex "Secure address for PSCI image" + depends on ARMV8_PSCI + help + Address for placing the PSCI text, data and stack sections. + If not defined, the PSCI sections are placed together with the u-boot + but platform can choose to place PSCI code image separately in other + places such as some secure RAM built-in SOC etc. + +endif + endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index d28a422..cc0dc88 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -47,6 +47,7 @@ menu "Layerscape architecture" menu "Layerscape PPA" config FSL_LS_PPA bool "FSL Layerscape PPA firmware support" + depends on !ARMV8_PSCI depends on ARCH_LS1043A || ARCH_LS1046A select FSL_PPA_ARMV8_PSCI help diff --git a/arch/arm/cpu/armv8/u-boot.lds b/arch/arm/cpu/armv8/u-boot.lds index fd15ad5..22195b8 100644 --- a/arch/arm/cpu/armv8/u-boot.lds +++ b/arch/arm/cpu/armv8/u-boot.lds @@ -8,11 +8,17 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <config.h> +#include <asm/psci.h> + OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") OUTPUT_ARCH(aarch64) ENTRY(_start) SECTIONS { +#ifdef CONFIG_ARMV8_SECURE_BASE + /DISCARD/ : { *(.rela._secure*) } +#endif . = 0x00000000;
. = ALIGN(8); @@ -23,6 +29,57 @@ SECTIONS *(.text*) }
+#ifdef CONFIG_ARMV8_PSCI + .__secure_start : +#ifndef CONFIG_ARMV8_SECURE_BASE + ALIGN(CONSTANT(COMMONPAGESIZE)) +#endif + { + KEEP(*(.__secure_start)) + } + +#ifndef CONFIG_ARMV8_SECURE_BASE +#define CONFIG_ARMV8_SECURE_BASE +#define __ARMV8_PSCI_STACK_IN_RAM +#endif + .secure_text CONFIG_ARMV8_SECURE_BASE : + AT(ADDR(.__secure_start) + SIZEOF(.__secure_start)) + { + *(._secure.text) + } + + .secure_data : AT(LOADADDR(.secure_text) + SIZEOF(.secure_text)) + { + *(._secure.data) + } + + .secure_stack ALIGN(ADDR(.secure_data) + SIZEOF(.secure_data), + CONSTANT(COMMONPAGESIZE)) (NOLOAD) : +#ifdef __ARMV8_PSCI_STACK_IN_RAM + AT(ADDR(.secure_stack)) +#else + AT(LOADADDR(.secure_data) + SIZEOF(.secure_data)) +#endif + { + KEEP(*(.__secure_stack_start)) + + . = . + CONFIG_ARMV8_PSCI_NR_CPUS * ARM_PSCI_STACK_SIZE; + + . = ALIGN(CONSTANT(COMMONPAGESIZE)); + + KEEP(*(.__secure_stack_end)) + } + +#ifndef __ARMV8_PSCI_STACK_IN_RAM + . = LOADADDR(.secure_stack); +#endif + + .__secure_end : AT(ADDR(.__secure_end)) { + KEEP(*(.__secure_end)) + LONG(0x1d1071c); /* Must output something to reset LMA */ + } +#endif + . = ALIGN(8); .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) }
PSCI implementation needs the SMC instruction to be enabled.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/macro.h | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/macro.h b/arch/arm/include/asm/macro.h index 2553e3e..e1916f7 100644 --- a/arch/arm/include/asm/macro.h +++ b/arch/arm/include/asm/macro.h @@ -182,11 +182,17 @@ lr .req x30
/* * The next lower exception level is AArch64, 64bit EL2 | HCE | - * SMD | RES1 (Bits[5:4]) | Non-secure EL0/EL1. + * RES1 (Bits[5:4]) | Non-secure EL0/EL1. + * and the SMD depends on requirements. */ +#ifdef CONFIG_ARMV8_PSCI + ldr \tmp, =(SCR_EL3_RW_AARCH64 | SCR_EL3_HCE_EN |\ + SCR_EL3_RES1 | SCR_EL3_NS_EN) +#else ldr \tmp, =(SCR_EL3_RW_AARCH64 | SCR_EL3_HCE_EN |\ SCR_EL3_SMD_DIS | SCR_EL3_RES1 |\ SCR_EL3_NS_EN) +#endif msr scr_el3, \tmp
/* Return to the EL2_SP2 mode from EL3 */
This patch introduces a generic ARMv8 PSCI framework, with all functions returning a dummy ARM_PSCI_RET_NI (Not Implemented), then it is up to each platform to implement their own functions based on this framework.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv8/Kconfig | 10 ++ arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/psci.S | 286 ++++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/psci.h | 15 +++ 4 files changed, 312 insertions(+) create mode 100644 arch/arm/cpu/armv8/psci.S
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index edae43d..22dce88 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -58,6 +58,16 @@ config ARMV8_PSCI_NR_CPUS It is no problem to set a larger value than the number of CPUs in the actual hardware implementation.
+config ARMV8_PSCI_CPUS_PER_CLUSTER + int "Number of CPUs per cluster" + depends on ARMV8_PSCI + default 0 + help + The number of CPUs per cluster, suppose each cluster has same number + of CPU cores, platforms with asymmetric clusters don't apply here. + A value 0 or no definition of it works for single cluster system. + System with multi-cluster should difine their own exact value. + if SYS_HAS_ARMV8_SECURE_BASE
config ARMV8_SECURE_BASE diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index dea1465..28ba786 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -25,3 +25,4 @@ obj-$(CONFIG_FSL_LAYERSCAPE) += fsl-layerscape/ obj-$(CONFIG_S32V234) += s32v234/ obj-$(CONFIG_ARCH_ZYNQMP) += zynqmp/ obj-$(CONFIG_TARGET_HIKEY) += hisilicon/ +obj-$(CONFIG_ARMV8_PSCI) += psci.o diff --git a/arch/arm/cpu/armv8/psci.S b/arch/arm/cpu/armv8/psci.S new file mode 100644 index 0000000..43d5d6b --- /dev/null +++ b/arch/arm/cpu/armv8/psci.S @@ -0,0 +1,286 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * Author: Hongbo Zhang hongbo.zhang@nxp.com + * + * SPDX-License-Identifier: GPL-2.0+ + * This file implements LS102X platform PSCI SYSTEM-SUSPEND function + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/psci.h> + +/* Default PSCI function, return -1, Not Implemented */ +#define PSCI_DEFAULT(__fn) \ + ENTRY(__fn); \ + mov w0, #ARM_PSCI_RET_NI; \ + ret; \ + ENDPROC(__fn); \ + .weak __fn + +/* PSCI function and ID table definition*/ +#define PSCI_TABLE(__id, __fn) \ + .word __id; \ + .word __fn + +.pushsection ._secure.text, "ax" + +/* 32 bits PSCI default functions */ +PSCI_DEFAULT(psci_version) +PSCI_DEFAULT(psci_cpu_suspend) +PSCI_DEFAULT(psci_cpu_off) +PSCI_DEFAULT(psci_cpu_on) +PSCI_DEFAULT(psci_affinity_info) +PSCI_DEFAULT(psci_migrate) +PSCI_DEFAULT(psci_migrate_info_type) +PSCI_DEFAULT(psci_migrate_info_up_cpu) +PSCI_DEFAULT(psci_system_off) +PSCI_DEFAULT(psci_system_reset) +PSCI_DEFAULT(psci_features) +PSCI_DEFAULT(psci_cpu_freeze) +PSCI_DEFAULT(psci_cpu_default_suspend) +PSCI_DEFAULT(psci_node_hw_state) +PSCI_DEFAULT(psci_system_suspend) +PSCI_DEFAULT(psci_set_suspend_mode) +PSCI_DEFAULT(psi_stat_residency) +PSCI_DEFAULT(psci_stat_count) + +.align 3 +_psci_32_table: +PSCI_TABLE(ARM_PSCI_FN_CPU_SUSPEND, psci_cpu_suspend) +PSCI_TABLE(ARM_PSCI_FN_CPU_OFF, psci_cpu_off) +PSCI_TABLE(ARM_PSCI_FN_CPU_ON, psci_cpu_on) +PSCI_TABLE(ARM_PSCI_FN_MIGRATE, psci_migrate) +PSCI_TABLE(ARM_PSCI_0_2_FN_PSCI_VERSION, psci_version) +PSCI_TABLE(ARM_PSCI_0_2_FN_CPU_SUSPEND, psci_cpu_suspend) +PSCI_TABLE(ARM_PSCI_0_2_FN_CPU_OFF, psci_cpu_off) +PSCI_TABLE(ARM_PSCI_0_2_FN_CPU_ON, psci_cpu_on) +PSCI_TABLE(ARM_PSCI_0_2_FN_AFFINITY_INFO, psci_affinity_info) +PSCI_TABLE(ARM_PSCI_0_2_FN_MIGRATE, psci_migrate) +PSCI_TABLE(ARM_PSCI_0_2_FN_MIGRATE_INFO_TYPE, psci_migrate_info_type) +PSCI_TABLE(ARM_PSCI_0_2_FN_MIGRATE_INFO_UP_CPU, psci_migrate_info_up_cpu) +PSCI_TABLE(ARM_PSCI_0_2_FN_SYSTEM_OFF, psci_system_off) +PSCI_TABLE(ARM_PSCI_0_2_FN_SYSTEM_RESET, psci_system_reset) +PSCI_TABLE(ARM_PSCI_1_0_FN_PSCI_FEATURES, psci_features) +PSCI_TABLE(ARM_PSCI_1_0_FN_CPU_FREEZE, psci_cpu_freeze) +PSCI_TABLE(ARM_PSCI_1_0_FN_CPU_DEFAULT_SUSPEND, psci_cpu_default_suspend) +PSCI_TABLE(ARM_PSCI_1_0_FN_NODE_HW_STATE, psci_node_hw_state) +PSCI_TABLE(ARM_PSCI_1_0_FN_SYSTEM_SUSPEND, psci_system_suspend) +PSCI_TABLE(ARM_PSCI_1_0_FN_SET_SUSPEND_MODE, psci_set_suspend_mode) +PSCI_TABLE(ARM_PSCI_1_0_FN_STAT_RESIDENCY, psi_stat_residency) +PSCI_TABLE(ARM_PSCI_1_0_FN_STAT_COUNT, psci_stat_count) +PSCI_TABLE(0, 0) + +/* 64 bits PSCI default functions */ +PSCI_DEFAULT(psci_cpu_suspend_64) +PSCI_DEFAULT(psci_cpu_on_64) +PSCI_DEFAULT(psci_affinity_info_64) +PSCI_DEFAULT(psci_migrate_64) +PSCI_DEFAULT(psci_migrate_info_up_cpu_64) +PSCI_DEFAULT(psci_cpu_default_suspend_64) +PSCI_DEFAULT(psci_node_hw_state_64) +PSCI_DEFAULT(psci_system_suspend_64) +PSCI_DEFAULT(psci_stat_residency_64) +PSCI_DEFAULT(psci_stat_count_64) + +.align 3 +_psci_64_table: +PSCI_TABLE(ARM_PSCI_0_2_FN64_CPU_SUSPEND, psci_cpu_suspend_64) +PSCI_TABLE(ARM_PSCI_0_2_FN64_CPU_ON, psci_cpu_on_64) +PSCI_TABLE(ARM_PSCI_0_2_FN64_AFFINITY_INFO, psci_affinity_info_64) +PSCI_TABLE(ARM_PSCI_0_2_FN64_MIGRATE, psci_migrate_64) +PSCI_TABLE(ARM_PSCI_0_2_FN64_MIGRATE_INFO_UP_CPU, psci_migrate_info_up_cpu_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_CPU_DEFAULT_SUSPEND, psci_cpu_default_suspend_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_NODE_HW_STATE, psci_node_hw_state_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_SYSTEM_SUSPEND, psci_system_suspend_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_STAT_RESIDENCY, psci_stat_residency_64) +PSCI_TABLE(ARM_PSCI_1_0_FN64_STAT_COUNT, psci_stat_count_64) +PSCI_TABLE(0, 0) + +.macro psci_enter + /* PSCI call is Fast Call(atomic), so mask DAIF */ + mrs x15, DAIF + stp x15, xzr, [sp, #-16]! + ldr x15, =0x3C0 + msr DAIF, x15 + /* SMC convention, x18 ~ x30 should be saved by callee */ + stp x29, x30, [sp, #-16]! + stp x27, x28, [sp, #-16]! + stp x25, x26, [sp, #-16]! + stp x23, x24, [sp, #-16]! + stp x21, x22, [sp, #-16]! + stp x19, x20, [sp, #-16]! + mrs x15, elr_el3 + stp x18, x15, [sp, #-16]! +.endm + +.macro psci_return + /* restore registers */ + ldp x18, x15, [sp], #16 + msr elr_el3, x15 + ldp x19, x20, [sp], #16 + ldp x21, x22, [sp], #16 + ldp x23, x24, [sp], #16 + ldp x25, x26, [sp], #16 + ldp x27, x28, [sp], #16 + ldp x29, x30, [sp], #16 + /* restore DAIF */ + ldp x15, xzr, [sp], #16 + msr DAIF, x15 + eret +.endm + +/* Caller must put PSCI function-ID table base in x9 */ +handle_psci: + psci_enter +1: ldr x10, [x9] /* Load PSCI function table */ + ubfx x11, x10, #32, #32 + ubfx x10, x10, #0, #32 + cbz x10, 3f /* If reach the end, bail out */ + cmp x10, x0 + b.eq 2f /* PSCI function found */ + add x9, x9, #8 /* If not match, try next entry */ + b 1b + +2: blr x11 /* Call PSCI function */ + psci_return + +3: mov x0, #ARM_PSCI_RET_NI + psci_return + +unknown_smc_id: + ldr x0, =0xFFFFFFFF + eret + +handle_smc32: + /* SMC function ID 0x84000000-0x8400001F: 32 bits PSCI */ + ldr w9, =0x8400001F + cmp w0, w9 + b.gt unknown_smc_id + ldr w9, =0x84000000 + cmp w0, w9 + b.lt unknown_smc_id + + adr x9, _psci_32_table + b handle_psci + +handle_smc64: + /* check SMC32 or SMC64 calls */ + ubfx x9, x0, #30, #1 + cbz x9, handle_smc32 + + /* SMC function ID 0xC4000000-0xC400001F: 64 bits PSCI */ + ldr x9, =0xC400001F + cmp x0, x9 + b.gt unknown_smc_id + ldr x9, =0xC4000000 + cmp x0, x9 + b.lt unknown_smc_id + + adr x9, _psci_64_table + b handle_psci + +/* + * Get CPU ID from MPIDR, suppose every cluster has same number of CPU cores, + * Platform with asymmetric clusters should implement their own interface. + * In case this function being called by other platform's C code, the ARM + * Architecture Procedure Call Standard is considered, e.g. register X0 is + * used for the return value, while in this PSCI environment, X0 usually holds + * the SMC function identifier, so X0 should be saved by caller function. + */ +ENTRY(psci_get_cpu_id) +#ifdef CONFIG_ARMV8_PSCI_CPUS_PER_CLUSTER + mrs x9, MPIDR_EL1 + ubfx x9, x9, #8, #8 + ldr x10, =CONFIG_ARMV8_PSCI_CPUS_PER_CLUSTER + mul x9, x10, x9 +#else + mov x9, xzr +#endif + mrs x10, MPIDR_EL1 + ubfx x10, x10, #0, #8 + add x0, x10, x9 + ret +ENDPROC(psci_get_cpu_id) +.weak psci_get_cpu_id + +/* CPU ID input in x0, stack top output in x0*/ +LENTRY(psci_get_cpu_stack_top) + adr x9, __secure_stack_end + lsl x0, x0, #ARM_PSCI_STACK_SHIFT + sub x0, x9, x0 + ret +ENDPROC(psci_get_cpu_stack_top) + +unhandled_exception: + b unhandled_exception /* simply dead loop */ + +handle_sync: + mov x15, x30 + mov x14, x0 + + bl psci_get_cpu_id + bl psci_get_cpu_stack_top + mov x9, #1 + msr spsel, x9 + mov sp, x0 + + mov x0, x14 + mov x30, x15 + + mrs x9, esr_el3 + ubfx x9, x9, #26, #6 + cmp x9, #0x13 + b.eq handle_smc32 + cmp x9, #0x17 + b.eq handle_smc64 + + b unhandled_exception + + .align 11 + .globl el3_exception_vectors +el3_exception_vectors: + b unhandled_exception /* Sync, Current EL using SP0 */ + .align 7 + b unhandled_exception /* IRQ, Current EL using SP0 */ + .align 7 + b unhandled_exception /* FIQ, Current EL using SP0 */ + .align 7 + b unhandled_exception /* SError, Current EL using SP0 */ + .align 7 + b unhandled_exception /* Sync, Current EL using SPx */ + .align 7 + b unhandled_exception /* IRQ, Current EL using SPx */ + .align 7 + b unhandled_exception /* FIQ, Current EL using SPx */ + .align 7 + b unhandled_exception /* SError, Current EL using SPx */ + .align 7 + b handle_sync /* Sync, Lower EL using AArch64 */ + .align 7 + b unhandled_exception /* IRQ, Lower EL using AArch64 */ + .align 7 + b unhandled_exception /* FIQ, Lower EL using AArch64 */ + .align 7 + b unhandled_exception /* SError, Lower EL using AArch64 */ + .align 7 + b unhandled_exception /* Sync, Lower EL using AArch32 */ + .align 7 + b unhandled_exception /* IRQ, Lower EL using AArch32 */ + .align 7 + b unhandled_exception /* FIQ, Lower EL using AArch32 */ + .align 7 + b unhandled_exception /* SError, Lower EL using AArch32 */ + +ENTRY(psci_setup_vectors) + adr x0, el3_exception_vectors + msr vbar_el3, x0 + ret +ENDPROC(psci_setup_vectors) + +ENTRY(psci_arch_init) + ret +ENDPROC(psci_arch_init) +.weak psci_arch_init + +.popsection diff --git a/arch/arm/include/asm/psci.h b/arch/arm/include/asm/psci.h index 9f1f779..ac8b00d 100644 --- a/arch/arm/include/asm/psci.h +++ b/arch/arm/include/asm/psci.h @@ -45,6 +45,9 @@ #define ARM_PSCI_0_2_FN_BASE 0x84000000 #define ARM_PSCI_0_2_FN(n) (ARM_PSCI_0_2_FN_BASE + (n))
+#define ARM_PSCI_0_2_FN64_BASE 0xC4000000 +#define ARM_PSCI_0_2_FN64(n) (ARM_PSCI_0_2_FN64_BASE + (n)) + #define ARM_PSCI_0_2_FN_PSCI_VERSION ARM_PSCI_0_2_FN(0) #define ARM_PSCI_0_2_FN_CPU_SUSPEND ARM_PSCI_0_2_FN(1) #define ARM_PSCI_0_2_FN_CPU_OFF ARM_PSCI_0_2_FN(2) @@ -56,6 +59,12 @@ #define ARM_PSCI_0_2_FN_SYSTEM_OFF ARM_PSCI_0_2_FN(8) #define ARM_PSCI_0_2_FN_SYSTEM_RESET ARM_PSCI_0_2_FN(9)
+#define ARM_PSCI_0_2_FN64_CPU_SUSPEND ARM_PSCI_0_2_FN64(1) +#define ARM_PSCI_0_2_FN64_CPU_ON ARM_PSCI_0_2_FN64(3) +#define ARM_PSCI_0_2_FN64_AFFINITY_INFO ARM_PSCI_0_2_FN64(4) +#define ARM_PSCI_0_2_FN64_MIGRATE ARM_PSCI_0_2_FN64(5) +#define ARM_PSCI_0_2_FN64_MIGRATE_INFO_UP_CPU ARM_PSCI_0_2_FN64(7) + /* PSCI 1.0 interface */ #define ARM_PSCI_1_0_FN_PSCI_FEATURES ARM_PSCI_0_2_FN(10) #define ARM_PSCI_1_0_FN_CPU_FREEZE ARM_PSCI_0_2_FN(11) @@ -66,6 +75,12 @@ #define ARM_PSCI_1_0_FN_STAT_RESIDENCY ARM_PSCI_0_2_FN(16) #define ARM_PSCI_1_0_FN_STAT_COUNT ARM_PSCI_0_2_FN(17)
+#define ARM_PSCI_1_0_FN64_CPU_DEFAULT_SUSPEND ARM_PSCI_0_2_FN64(12) +#define ARM_PSCI_1_0_FN64_NODE_HW_STATE ARM_PSCI_0_2_FN64(13) +#define ARM_PSCI_1_0_FN64_SYSTEM_SUSPEND ARM_PSCI_0_2_FN64(14) +#define ARM_PSCI_1_0_FN64_STAT_RESIDENCY ARM_PSCI_0_2_FN64(16) +#define ARM_PSCI_1_0_FN64_STAT_COUNT ARM_PSCI_0_2_FN64(17) + /* 1KB stack per core */ #define ARM_PSCI_STACK_SHIFT 10 #define ARM_PSCI_STACK_SIZE (1 << ARM_PSCI_STACK_SHIFT)
Newly add ARMv8 PSCI needs to be initialized, be copied or reserved in right place, this patch does all the setup steps.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv8/cpu-dt.c | 11 ++++++++++- arch/arm/cpu/armv8/cpu.c | 22 ++++++++++++++++++++++ arch/arm/include/asm/secure.h | 2 +- arch/arm/include/asm/system.h | 11 +++++++++++ arch/arm/lib/bootm-fdt.c | 3 ++- arch/arm/lib/bootm.c | 3 +++ arch/arm/lib/psci-dt.c | 5 +++-- 7 files changed, 52 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv8/cpu-dt.c b/arch/arm/cpu/armv8/cpu-dt.c index 659ec27..3a5afe8 100644 --- a/arch/arm/cpu/armv8/cpu-dt.c +++ b/arch/arm/cpu/armv8/cpu-dt.c @@ -6,6 +6,7 @@
#include <common.h> #include <asm/psci.h> +#include <asm/system.h> #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT #include <asm/armv8/sec_firmware.h> #endif @@ -13,7 +14,8 @@ int psci_update_dt(void *fdt) { #ifdef CONFIG_MP -#if defined(CONFIG_FSL_PPA_ARMV8_PSCI) +#if defined(CONFIG_ARMV8_PSCI) || defined(CONFIG_FSL_PPA_ARMV8_PSCI) + #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT /* * If the PSCI in SEC Firmware didn't work, avoid to update the @@ -25,6 +27,13 @@ int psci_update_dt(void *fdt) return 0; #endif fdt_psci(fdt); + +#if defined(CONFIG_ARMV8_PSCI) && !defined(CONFIG_ARMV8_SECURE_BASE) + /* secure code lives in RAM, keep it alive */ + fdt_add_mem_rsv(fdt, (unsigned long)__secure_start, + __secure_end - __secure_start); +#endif + #endif #endif return 0; diff --git a/arch/arm/cpu/armv8/cpu.c b/arch/arm/cpu/armv8/cpu.c index e06c3cc..5dcb5e2 100644 --- a/arch/arm/cpu/armv8/cpu.c +++ b/arch/arm/cpu/armv8/cpu.c @@ -14,6 +14,7 @@ #include <common.h> #include <command.h> #include <asm/system.h> +#include <asm/secure.h> #include <linux/compiler.h>
int cleanup_before_linux(void) @@ -41,3 +42,24 @@ int cleanup_before_linux(void)
return 0; } + +#ifdef CONFIG_ARMV8_PSCI +static void relocate_secure_section(void) +{ +#ifdef CONFIG_ARMV8_SECURE_BASE + size_t sz = __secure_end - __secure_start; + + memcpy((void *)CONFIG_ARMV8_SECURE_BASE, __secure_start, sz); + flush_dcache_range(CONFIG_ARMV8_SECURE_BASE, + CONFIG_ARMV8_SECURE_BASE + sz + 1); + invalidate_icache_all(); +#endif +} + +void armv8_setup_psci(void) +{ + relocate_secure_section(); + secure_ram_addr(psci_setup_vectors)(); + secure_ram_addr(psci_arch_init)(); +} +#endif diff --git a/arch/arm/include/asm/secure.h b/arch/arm/include/asm/secure.h index 5a403bc..d23044a 100644 --- a/arch/arm/include/asm/secure.h +++ b/arch/arm/include/asm/secure.h @@ -6,7 +6,7 @@ #define __secure __attribute__ ((section ("._secure.text"))) #define __secure_data __attribute__ ((section ("._secure.data")))
-#ifdef CONFIG_ARMV7_SECURE_BASE +#if defined(CONFIG_ARMV7_SECURE_BASE) || defined(CONFIG_ARMV8_SECURE_BASE) /* * Warning, horror ahead. * diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index 01efc43..dc4c991 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -237,6 +237,17 @@ void smc_call(struct pt_regs *args); void __noreturn psci_system_reset(void); void __noreturn psci_system_off(void);
+#ifdef CONFIG_ARMV8_PSCI +extern char __secure_start[]; +extern char __secure_end[]; +extern char __secure_stack_start[]; +extern char __secure_stack_end[]; + +void armv8_setup_psci(void); +void psci_setup_vectors(void); +void psci_arch_init(void); +#endif + #endif /* __ASSEMBLY__ */
#else /* CONFIG_ARM64 */ diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index 1615756..e261d4f 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -52,7 +52,8 @@ int arch_fixup_fdt(void *blob) return ret; #endif
-#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_FSL_PPA_ARMV8_PSCI) +#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_ARMV8_PSCI) || \ + defined(CONFIG_FSL_PPA_ARMV8_PSCI) ret = psci_update_dt(blob); if (ret) return ret; diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 4eee13a..43cc83e 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -316,6 +316,9 @@ static void boot_jump_linux(bootm_headers_t *images, int flag) announce_and_cleanup(fake);
if (!fake) { +#ifdef CONFIG_ARMV8_PSCI + armv8_setup_psci(); +#endif do_nonsec_virt_switch();
update_os_arch_secondary_cores(images->os.arch); diff --git a/arch/arm/lib/psci-dt.c b/arch/arm/lib/psci-dt.c index 41e139e..45af037 100644 --- a/arch/arm/lib/psci-dt.c +++ b/arch/arm/lib/psci-dt.c @@ -16,7 +16,8 @@
int fdt_psci(void *fdt) { -#if defined(CONFIG_FSL_PPA_ARMV8_PSCI) || defined(CONFIG_ARMV7_PSCI) +#if defined(CONFIG_ARMV7_PSCI) || defined(CONFIG_ARMV8_PSCI) || \ + defined(CONFIG_FSL_PPA_ARMV8_PSCI) int nodeoff; unsigned int psci_ver = 0; int tmp; @@ -65,7 +66,7 @@ int fdt_psci(void *fdt) init_psci_node: #ifdef CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT psci_ver = sec_firmware_support_psci_version(); -#elif defined(CONFIG_ARMV7_PSCI_1_0) +#elif defined(CONFIG_ARMV7_PSCI_1_0) || defined(CONFIG_ARMV8_PSCI) psci_ver = ARM_PSCI_VER_1_0; #endif switch (psci_ver) {
A most basic PSCI implementation with only one psci_version is added for LS1043A, this can verify the generic PSCI framework, and more platform specific implementation will be added later.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S | 20 ++++++++++++++++++++ board/freescale/ls1043ardb/Kconfig | 9 +++++++++ 3 files changed, 30 insertions(+) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 51c1cee..423b4b3 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -28,6 +28,7 @@ endif
ifneq ($(CONFIG_LS1043A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1043a_serdes.o +obj-$(CONFIG_ARMV8_PSCI) += ls1043a_psci.o endif
ifneq ($(CONFIG_ARCH_LS1012A),) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S b/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S new file mode 100644 index 0000000..86045ac --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_psci.S @@ -0,0 +1,20 @@ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * Author: Hongbo Zhang hongbo.zhang@nxp.com + * + * SPDX-License-Identifier: GPL-2.0+ + * This file implements LS102X platform PSCI SYSTEM-SUSPEND function + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/psci.h> + + .pushsection ._secure.text, "ax" + +.globl psci_version +psci_version: + ldr w0, =0x00010000 /* PSCI v1.0 */ + ret + + .popsection diff --git a/board/freescale/ls1043ardb/Kconfig b/board/freescale/ls1043ardb/Kconfig index 51818ec..80203a4 100644 --- a/board/freescale/ls1043ardb/Kconfig +++ b/board/freescale/ls1043ardb/Kconfig @@ -13,4 +13,13 @@ config SYS_SOC config SYS_CONFIG_NAME default "ls1043ardb"
+config SYS_HAS_ARMV8_SECURE_BASE + bool "Enable secure address for PSCI image" + depends on ARMV8_PSCI + default n + help + PSCI image can be re-located to secure RAM. + If enabled, please also define the value for ARMV8_SECURE_BASE, + for LS1043ARDB, it could be some address in OCRAM. + endif
Hongbo Zhang
york sun
