[PATCH v5] arch: arm: mach-rockchip: Kconfig: Enable BOOTSTD_FULL for RK3399 and RK3588
Rockchip RK3399 and RK3588 SoCs can support wide range of bootflows. Without full bootflow commands, it can be difficult to figure out issues if any, hence enable by default.
Signed-off-by: Shantur Rathore i@shantur.com ---
Changes in v5: - Only enable it for RK3399 and RK3588 as suggested by Kever
Changes in v4: - Replace BOOTSTD_DEFAULT with BOOTSTD_FULL as previous version didn't apply on next
arch/arm/mach-rockchip/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 6ff0aa6911..5a46c986ef 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -265,6 +265,7 @@ config ROCKCHIP_RK3399 imply TPL_TINY_MEMSET imply TPL_ROCKCHIP_COMMON_BOARD imply SYS_BOOTCOUNT_SINGLEWORD if BOOTCOUNT_LIMIT + imply BOOTSTD_FULL imply CMD_BOOTCOUNT if BOOTCOUNT_LIMIT help The Rockchip RK3399 is a ARM-based SoC with a dual-core Cortex-A72 @@ -319,6 +320,7 @@ config ROCKCHIP_RK3588 imply MISC_INIT_R imply CLK_SCMI imply SCMI_FIRMWARE + imply BOOTSTD_FULL help The Rockchip RK3588 is a ARM-based SoC with quad-core Cortex-A76 and quad-core Cortex-A55 including NEON and GPU, 6TOPS NPU, Mali-G610 MP4,
Shantur Rathore
