[U-Boot] [PATCH 1/5] arm, omap3: Add support for TechNexion modules
Add support for TechNexion TAO3530 SoM
This patch has been posted quite a long time ago. I ported it to the latest mainline U-Boot version. With some additional cleanup and enhancements.
Signed-off-by: Tapani Utriainen tapani@technexion.com CC: Sandeep Paulraj s-paulraj@ti.com Signed-off-by: Stefan Roese sr@denx.de Cc: Thorsten Eisbein thorsten.eisbein@head-acoustics.de Cc: Tom Rini trini@ti.com --- arch/arm/include/asm/mach-types.h | 1 + board/technexion/tao3530/Makefile | 5 + board/technexion/tao3530/tao3530.c | 170 +++++++++++++++++ board/technexion/tao3530/tao3530.h | 364 +++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/tao3530.h | 310 +++++++++++++++++++++++++++++++ 6 files changed, 851 insertions(+) create mode 100644 board/technexion/tao3530/Makefile create mode 100644 board/technexion/tao3530/tao3530.c create mode 100644 board/technexion/tao3530/tao3530.h create mode 100644 include/configs/tao3530.h
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index 440b041..cb7604a 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -470,6 +470,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_EUKREA_CPUIMX35SD 2821 #define MACH_TYPE_EUKREA_CPUIMX51SD 2822 #define MACH_TYPE_EUKREA_CPUIMX51 2823 +#define MACH_TYPE_OMAP3_TAO3530 2836 #define MACH_TYPE_SMDKC210 2838 #define MACH_TYPE_OMAP3_BRAILLO 2839 #define MACH_TYPE_SPYPLUG 2840 diff --git a/board/technexion/tao3530/Makefile b/board/technexion/tao3530/Makefile new file mode 100644 index 0000000..2aff383 --- /dev/null +++ b/board/technexion/tao3530/Makefile @@ -0,0 +1,5 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := tao3530.o diff --git a/board/technexion/tao3530/tao3530.c b/board/technexion/tao3530/tao3530.c new file mode 100644 index 0000000..9482f35 --- /dev/null +++ b/board/technexion/tao3530/tao3530.c @@ -0,0 +1,170 @@ +/* + * Maintainer : + * Tapani Utriainen linuxfae@technexion.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <netdev.h> +#include <twl4030.h> +#include <asm/io.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/mem.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/gpio.h> +#include <asm/gpio.h> +#include <asm/mach-types.h> + +#include <usb.h> +#include <asm/ehci-omap.h> + +#include "tao3530.h" + +DECLARE_GLOBAL_DATA_PTR; + +int tao3530_revision(void) +{ + int ret = 0; + + /* char *label argument is unused in gpio_request() */ + ret = gpio_request(65, ""); + if (ret) { + printf("Error? GPIO 65 not available\n"); + goto out; + } + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M4)); + + ret = gpio_request(1, ""); + if (ret) { + printf("Error? GPIO 1 not available\n"); + goto out2; + } + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTU | EN | M4)); + + ret = gpio_direction_input(65); + if (ret) { + printf("Error? GPIO 65 not available for input\n"); + goto out3; + } + + ret = gpio_direction_input(1); + if (ret) { + printf("Error? GPIO 1 not available for input\n"); + goto out3; + } + + ret = gpio_get_value(65) << 1 | gpio_get_value(1); + +out3: + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTU | EN | M0)); + gpio_free(1); +out2: + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M0)); + gpio_free(65); +out: + + return ret; +} + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + /* board id for Linux */ + gd->bd->bi_arch_number = MACH_TYPE_OMAP3_TAO3530; + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +/* + * Routine: misc_init_r + * Description: Configure board specific parts + */ +int misc_init_r(void) +{ + struct gpio *gpio5_base = (struct gpio *)OMAP34XX_GPIO5_BASE; + struct gpio *gpio6_base = (struct gpio *)OMAP34XX_GPIO6_BASE; + + twl4030_power_init(); + twl4030_led_init(TWL4030_LED_LEDEN_LEDAON | TWL4030_LED_LEDEN_LEDBON); + + /* Configure GPIOs to output */ + /* GPIO23 */ + writel(~(GPIO10 | GPIO8 | GPIO2 | GPIO1), &gpio6_base->oe); + writel(~(GPIO31 | GPIO30 | GPIO22 | GPIO21 | + GPIO15 | GPIO14 | GPIO13 | GPIO12), &gpio5_base->oe); + + /* Set GPIOs */ + writel(GPIO10 | GPIO8 | GPIO2 | GPIO1, + &gpio6_base->setdataout); + writel(GPIO31 | GPIO30 | GPIO29 | GPIO28 | GPIO22 | GPIO21 | + GPIO15 | GPIO14 | GPIO13 | GPIO12, &gpio5_base->setdataout); + + dieid_num_r(); + + /* Set memory size environment variable, depending on revision */ + switch (tao3530_revision()) { + case 0x2: /* Rev C1 -- 256MB */ + setenv("mem_size", "mem=256M"); + break; + case 0x3: /* Rev A2/B2 -- 128MB */ + setenv("mem_size", "mem=128M"); + break; + default: + printf("Warning: Unknown TAO3530 rev, setting mem=128M\n"); + } + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_TAO3530(); +} + +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0, 0, 0, -1, -1); + + return 0; +} +#endif + +#if defined(CONFIG_USB_EHCI) && !defined(CONFIG_SPL_BUILD) +/* Call usb_stop() before starting the kernel */ +void show_boot_progress(int val) +{ + if (val == BOOTSTAGE_ID_RUN_OS) + usb_stop(); +} + +static struct omap_usbhs_board_data usbhs_bdata = { + .port_mode[0] = OMAP_USBHS_PORT_MODE_UNUSED, + .port_mode[1] = OMAP_EHCI_PORT_MODE_PHY, + .port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED +}; + +int ehci_hcd_init(int index, enum usb_init_type init, + struct ehci_hccr **hccr, struct ehci_hcor **hcor) +{ + return omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor); +} + +int ehci_hcd_stop(int index) +{ + return omap_ehci_hcd_stop(); +} +#endif /* CONFIG_USB_EHCI */ diff --git a/board/technexion/tao3530/tao3530.h b/board/technexion/tao3530/tao3530.h new file mode 100644 index 0000000..1ea767d --- /dev/null +++ b/board/technexion/tao3530/tao3530.h @@ -0,0 +1,364 @@ +/* + * (C) Copyright TechNexion 2010 + * Edward Lin linuxfae@technexion.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _TAO3530_H_ +#define _TAO3530_H_ + +const omap3_sysinfo sysinfo = { + DDR_STACKED, + "OMAP3 TAO-3530 board", + "NAND", +}; + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_TAO3530() \ + /*SDRC*/\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) \ + /*GPMC*/\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A2), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A6), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A8), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A9), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_A10), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS3), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS4), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS6), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(GPMC_NCS7), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M0)) \ + /*DSS*/\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) \ + /*CAMERA*/\ + MUX_VAL(CP(CAM_HS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_PCLK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4)) \ + /* - CAM_RESET*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) \ + /*Audio Interface */\ + MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP2_DX), (IDIS | PTD | DIS | M0)) \ + /*Expansion card */\ + MUX_VAL(CP(MMC1_CLK), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M0)) \ + /* MMC2 WLAN */\ + MUX_VAL(CP(MMC2_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MMC2_CMD), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MMC2_DAT4), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT5), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT6), (IDIS | PTD | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT7), (IDIS | PTU | EN | M4)) \ + /*Bluetooth*/\ + MUX_VAL(CP(MCBSP3_DX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP3_DR), (IEN | PTD | DIS | M0)) \ + /*LocalBus LAN Reset*/\ + MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTD | DIS | M4)) \ + /*LocalBus LAN IRQ*/\ + MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M0)) \ + /*Modem Interface */\ + MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART1_RTS), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART1_CTS), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(MCBSP4_DR), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(MCBSP4_DX), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MCBSP1_DX), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M1)) \ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) \ + MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | EN | M1)) \ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTU | EN | M4)) \ + /*Serial Interface*/\ + MUX_VAL(CP(UART3_CTS_RCTX), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_NXT), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(HDQ_SIO), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(MCSPI1_CS1), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | EN | M4)) \ + /* USB EHCI (port 2) */\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTU | DIS | M3)) \ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTU | DIS | M3)) \ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTU | DIS | M3)) \ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTU | DIS | M3)) \ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTU | DIS | M3)) \ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTU | DIS | M3)) \ + /*Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) \ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) \ + /* - VIO_1V8*/\ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_EMU0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_EMU1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(ETK_CLK_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_CTL_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_D0_ES2), (IEN | PTU | DIS | M1)) \ + MUX_VAL(CP(ETK_D1_ES2), (IEN | PTU | DIS | M1)) \ + MUX_VAL(CP(ETK_D2_ES2), (IEN | PTU | DIS | M1)) \ + MUX_VAL(CP(ETK_D3_ES2), (IEN | PTU | DIS | M1)) \ + MUX_VAL(CP(ETK_D4_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_D5_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_D6_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_D7_ES2), (IEN | PTU | DIS | M1)) \ + MUX_VAL(CP(ETK_D8_ES2), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(ETK_D9_ES2), (IEN | PTD | EN | M4)) \ + MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTU | DIS | M3)) \ + MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTU | DIS | M3)) \ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTU | DIS | M3)) \ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTU | DIS | M3)) \ + MUX_VAL(CP(ETK_D14_ES2), (IEN|PTU|DIS|M3)) \ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTU | DIS | M3)) \ + MUX_VAL(CP(D2D_MCAD1), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD2), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD3), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD4), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD5), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD6), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD7), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD8), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD9), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD10), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD11), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD12), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD13), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD14), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD15), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD16), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD17), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD18), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD19), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD20), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD21), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD22), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD23), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD24), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD25), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD26), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD27), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD28), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD29), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD30), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD31), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD32), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD33), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) \ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) \ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) \ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) + +#endif diff --git a/boards.cfg b/boards.cfg index caba64e..d72be99 100644 --- a/boards.cfg +++ b/boards.cfg @@ -325,6 +325,7 @@ Active arm armv7 omap3 logicpd zoom1 Active arm armv7 omap3 logicpd zoom2 omap3_zoom2 - Tom Rix Tom.Rix@windriver.com Active arm armv7 omap3 matrix_vision mvblx omap3_mvblx - Michael Jones michael.jones@matrix-vision.de Active arm armv7 omap3 nokia rx51 nokia_rx51 - Pali Rohár pali.rohar@gmail.com +Active arm armv7 omap3 technexion tao3530 tao3530 - Tapani Utriainen linuxfae@technexion.com Active arm armv7 omap3 technexion twister twister - Stefano Babic sbabic@denx.de Active arm armv7 omap3 teejet mt_ventoux mt_ventoux - Stefano Babic sbabic@denx.de Active arm armv7 omap3 ti am3517crane am3517_crane - Nagendra T S nagendra@mistralsolutions.com diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h new file mode 100644 index 0000000..6327161 --- /dev/null +++ b/include/configs/tao3530.h @@ -0,0 +1,310 @@ +/* + * Configuration settings for the TechNexion TAO-3530 SOM + * equipped on Thunder baseboard. + * + * Edward Lin linuxfae@technexion.com + * Tapani Utriainen linuxfae@technexion.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ +#define CONFIG_ARMV7 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP /* in a TI OMAP core */ +#define CONFIG_OMAP34XX /* which is a 34XX */ +#define CONFIG_OMAP3430 /* which is in a 3430 */ +#define CONFIG_OMAP3_TAO3530 /* working with TAO-3530 */ +#define CONFIG_OMAP_GPIO +#define CONFIG_OMAP_COMMON + +#define CONFIG_SDRC /* Has an SDRC controller */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* + * Display CPU and Board information + */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_OF_LIBFDT + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ + /* Sector */ +#define CONFIG_SYS_MALLOC_LEN (4 << 20) + +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* + * select serial console configuration + */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_DOS_PARTITION + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:512k(x-loader),"\ + "1920k(u-boot),128k(u-boot-env),"\ + "4m(kernel),-(fs)" + +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING + +#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#undef CONFIG_CMD_FPGA /* FPGA configuration Support */ +#undef CONFIG_CMD_IMI /* iminfo */ +#undef CONFIG_CMD_IMLS /* List all found images */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_DRIVER_OMAP34XX_I2C + +/* + * TWL4030 + */ +#define CONFIG_TWL4030_POWER +#define CONFIG_TWL4030_LED + +/* + * Board NAND Info. + */ +#define CONFIG_SYS_NAND_QUIET_TEST +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ + /* to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access nand at */ + /* CS0 */ +#define GPMC_NAND_ECC_LP_x16_LAYOUT + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ + /* devices */ +/* Environment information */ +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyO2,115200n8\0" \ + "mpurate=600\0" \ + "dvi_mode=omapfb.mode=dvi:1280x720-24@60\0" \ + "tv_mode=omapfb.mode=tv:ntsc\0" \ + "video_mode=omapdss.def_disp=lcd vram=6M omapfb.vram=0:2M,1:2M,2:2M\0" \ + "lcd_mode=omapfb.mode=lcd:800x480@60 \0" \ + "extra_options= \0" \ + "mem_size=mem=128M \0" \ + "mmcdev=0\0" \ + "mmcroot=/dev/mmcblk0p2 rw\0" \ + "mmcrootfstype=ext3 rootwait\0" \ + "nandroot=ubi0:rootfs ubi.mtd=4\0" \ + "nandrootfstype=ubifs\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "${mem_size} " \ + "mpurate=${mpurate} " \ + "${video_mode} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype} " \ + "${extra_options}\0" \ + "nandargs=setenv bootargs console=${console} " \ + "${mem_size} " \ + "mpurate=${mpurate} " \ + "${video_mode} " \ + "${network_setting} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype} "\ + "${extra_options}\0" \ + "loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source ${loadaddr}\0" \ + "loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmc rescan ${mmcdev}; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi" + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "TAO-3530 # " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ + +/* turn on command-line edit/hist/auto */ +#define CONFIG_CMDLINE_EDITING +#define CONFIG_COMMAND_HISTORY +#define CONFIG_AUTO_COMPLETE +#define CONFIG_AUTOCOMPLETE + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) /* memtest */ + /* works on */ +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ + 0x01F00000) /* 31MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default */ + /* load address */ +#define CONFIG_SYS_TEXT_BASE 0x80008000 + +/* + * OMAP3 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ + +/* + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 MiB */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* + * FLASH and environment organization + */ + +/* **** PISMO SUPPORT *** */ + +/* Configure the PISMO */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ +#define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE + +/* Monitor at start of flash */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP + +#define CONFIG_ENV_IS_IN_NAND 1 +#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) +#define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET +#define CONFIG_ENV_ADDR CONFIG_ENV_OFFSET + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) + +#define CONFIG_OMAP3_SPI + +/* + * USB + * + * Currently only EHCI is enabled, the MUSB OTG controller + * is not enabled. + */ + +/* USB EHCI */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_OMAP +#define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 162 + +#define CONFIG_USB_ULPI +#define CONFIG_USB_ULPI_VIEWPORT_OMAP + +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_SMSC95XX + +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETHER_RNDIS +#define CONFIG_USB_STORAGE +#define CONGIG_CMD_STORAGE + +#endif /* __CONFIG_H */
Add SPL support for the Technexion TAO3530 SOM to replace x-loader. Tested with the Thunder baseboard. Currently this is only tested with the TAO3530 SOM revision (Ax/Bx).
Tested by booting via MMC and NAND.
Signed-off-by: Stefan Roese sr@denx.de Cc: Tapani Utriainen tapani@technexion.com Cc: Thorsten Eisbein thorsten.eisbein@head-acoustics.de Cc: Tom Rini trini@ti.com --- board/technexion/tao3530/tao3530.c | 27 +++++++++++++++- include/configs/tao3530.h | 64 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 90 insertions(+), 1 deletion(-)
diff --git a/board/technexion/tao3530/tao3530.c b/board/technexion/tao3530/tao3530.c index 9482f35..7cf5aa6 100644 --- a/board/technexion/tao3530/tao3530.c +++ b/board/technexion/tao3530/tao3530.c @@ -67,6 +67,31 @@ out: return ret; }
+#ifdef CONFIG_SPL_BUILD +/* + * Routine: get_board_mem_timings + * Description: If we use SPL then there is no x-loader nor config header + * so we have to setup the DDR timings ourself on both banks. + */ +void get_board_mem_timings(struct board_sdrc_timings *timings) +{ + if (tao3530_revision() < 3) { + /* 256MB / Bank */ + timings->mcfg = MCFG(256 << 20, 14); /* RAS-width 14 */ + timings->ctrla = HYNIX_V_ACTIMA_165; + timings->ctrlb = HYNIX_V_ACTIMB_165; + } else { + /* 128MB / Bank */ + timings->mcfg = MCFG(128 << 20, 13); /* RAS-width 13 */ + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + } + + timings->mr = MICRON_V_MR_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; +} +#endif + /* * Routine: board_init * Description: Early hardware init. @@ -134,7 +159,7 @@ void set_muxconf_regs(void) MUX_TAO3530(); }
-#ifdef CONFIG_GENERIC_MMC +#if defined(CONFIG_GENERIC_MMC) && !defined(CONFIG_SPL_BUILD) int board_mmc_init(bd_t *bis) { omap_mmc_init(0, 0, 0, -1, -1); diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 6327161..03eb85e 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -5,6 +5,8 @@ * Edward Lin linuxfae@technexion.com * Tapani Utriainen linuxfae@technexion.com * + * Copyright (C) 2013 Stefan Roese sr@denx.de + * * SPDX-License-Identifier: GPL-2.0+ */
@@ -307,4 +309,66 @@ #define CONFIG_USB_STORAGE #define CONGIG_CMD_STORAGE
+/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_NAND_SIMPLE + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_OMAP3_ID_NAND +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +/* NAND boot config */ +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +/* + * Use the ECC/OOB layout from omap_gpmc.h that matches your chip: + * SP vs LP, 8bit vs 16bit: GPMC_NAND_HW_ECC_LAYOUT + */ +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13 } +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 3 + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 + +#define CONFIG_SPL_TEXT_BASE 0x40200800 +#define CONFIG_SPL_MAX_SIZE (54 * 1024) /* 8 KB for stack */ +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +/* + * Use 0x80008000 as TEXT_BASE here for compatibility reasons with the + * older x-loader implementations. And move the BSS area so that it + * doesn't overlap with TEXT_BASE. + */ +#define CONFIG_SYS_TEXT_BASE 0x80008000 +#define CONFIG_SPL_BSS_START_ADDR 0x80100000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + #endif /* __CONFIG_H */
SPL works also on TAO-3530 rev Cx (using mmc and Tsunami baseboard).
Tested-by: Tapani Utriainen tapani@technexion.com
- Routine: get_board_mem_timings
- Description: If we use SPL then there is no x-loader nor config header
- so we have to setup the DDR timings ourself on both banks.
- if (tao3530_revision() < 3) {
/* 256MB / Bank */
- } else {
/* 128MB / Bank */
- timings->mr = MICRON_V_MR_165;
- timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz;
+} +#endif
- Routine: board_init
- Description: Early hardware init.
- Edward Lin linuxfae@technexion.com
- Copyright (C) 2013 Stefan Roese sr@denx.de
- Use the ECC/OOB layout from omap_gpmc.h that matches your chip:
- SP vs LP, 8bit vs 16bit: GPMC_NAND_HW_ECC_LAYOUT
10, 11, 12, 13 }
- Use 0x80008000 as TEXT_BASE here for compatibility reasons with the
- older x-loader implementations. And move the BSS area so that it
- doesn't overlap with TEXT_BASE.
Do we no longer have stack issues that this exposed?
Hi Tom,
No. Work fine without any further patches applied. I have to admit, that I have no idea why this problem with the re-assignment of r8 seems to be solved. Some for CM_T35 btw.
Thanks, Stefan
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 11/14/2013 12:47 PM, Stefan Roese wrote:
Hi Tom,
OK, can you please repost any other older patches from then that need to be applied still? I think I see them all, but I suspect they need Makefile changes anyhow.
- -- Tom
Yes, they definitely need some massaging. I'll repost the CM_T35 related patches tomorrow as well.
Thanks, Stefan
The memory size is autodetected and is passed to the Linux kernel either via ATAGs or device-tree (dtb). So there is no need to pass it via the bootargs.
Signed-off-by: Stefan Roese sr@denx.de Cc: Tapani Utriainen tapani@technexion.com Cc: Thorsten Eisbein thorsten.eisbein@head-acoustics.de Cc: Tom Rini trini@ti.com --- board/technexion/tao3530/tao3530.c | 12 ------------ include/configs/tao3530.h | 3 --- 2 files changed, 15 deletions(-)
diff --git a/board/technexion/tao3530/tao3530.c b/board/technexion/tao3530/tao3530.c index 7cf5aa6..f9ea131 100644 --- a/board/technexion/tao3530/tao3530.c +++ b/board/technexion/tao3530/tao3530.c @@ -133,18 +133,6 @@ int misc_init_r(void)
dieid_num_r();
- /* Set memory size environment variable, depending on revision */ - switch (tao3530_revision()) { - case 0x2: /* Rev C1 -- 256MB */ - setenv("mem_size", "mem=256M"); - break; - case 0x3: /* Rev A2/B2 -- 128MB */ - setenv("mem_size", "mem=128M"); - break; - default: - printf("Warning: Unknown TAO3530 rev, setting mem=128M\n"); - } - return 0; }
diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 03eb85e..9c8e8cf 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -150,21 +150,18 @@ "video_mode=omapdss.def_disp=lcd vram=6M omapfb.vram=0:2M,1:2M,2:2M\0" \ "lcd_mode=omapfb.mode=lcd:800x480@60 \0" \ "extra_options= \0" \ - "mem_size=mem=128M \0" \ "mmcdev=0\0" \ "mmcroot=/dev/mmcblk0p2 rw\0" \ "mmcrootfstype=ext3 rootwait\0" \ "nandroot=ubi0:rootfs ubi.mtd=4\0" \ "nandrootfstype=ubifs\0" \ "mmcargs=setenv bootargs console=${console} " \ - "${mem_size} " \ "mpurate=${mpurate} " \ "${video_mode} " \ "root=${mmcroot} " \ "rootfstype=${mmcrootfstype} " \ "${extra_options}\0" \ "nandargs=setenv bootargs console=${console} " \ - "${mem_size} " \ "mpurate=${mpurate} " \ "${video_mode} " \ "${network_setting} " \
Signed-off-by: Stefan Roese sr@denx.de Cc: Tapani Utriainen tapani@technexion.com Cc: Thorsten Eisbein thorsten.eisbein@head-acoustics.de Cc: Tom Rini trini@ti.com --- board/technexion/tao3530/tao3530.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/board/technexion/tao3530/tao3530.c b/board/technexion/tao3530/tao3530.c index f9ea131..2f3f929 100644 --- a/board/technexion/tao3530/tao3530.c +++ b/board/technexion/tao3530/tao3530.c @@ -131,6 +131,23 @@ int misc_init_r(void) writel(GPIO31 | GPIO30 | GPIO29 | GPIO28 | GPIO22 | GPIO21 | GPIO15 | GPIO14 | GPIO13 | GPIO12, &gpio5_base->setdataout);
+ switch (tao3530_revision()) { + case 0: + printf("TAO-3530 REV Reserve 1\n"); + break; + case 1: + printf("TAO-3530 REV Reserve 2\n"); + break; + case 2: + printf("TAO-3530 REV Cx\n"); + break; + case 3: + printf("TAO-3530 REV Ax/Bx\n"); + break; + default: + printf("Unknown board revision\n"); + } + dieid_num_r();
The Head acoustics (HA) baseboard used the Technexion TAO3530 SOM and has only some minor differences to the Technexion Thunder baseboard. This patch adds support for this HA baseboard / TAO3530 as the "omap3_ha" build target.
Signed-off-by: Stefan Roese sr@denx.de Cc: Tapani Utriainen tapani@technexion.com Cc: Thorsten Eisbein thorsten.eisbein@head-acoustics.de Cc: Tom Rini trini@ti.com --- board/technexion/tao3530/tao3530.c | 15 +++++++++++++++ board/technexion/tao3530/tao3530.h | 7 +++++++ boards.cfg | 1 + 3 files changed, 23 insertions(+)
diff --git a/board/technexion/tao3530/tao3530.c b/board/technexion/tao3530/tao3530.c index 2f3f929..e829d6f 100644 --- a/board/technexion/tao3530/tao3530.c +++ b/board/technexion/tao3530/tao3530.c @@ -75,6 +75,18 @@ out: */ void get_board_mem_timings(struct board_sdrc_timings *timings) { +#if defined(CONFIG_SYS_BOARD_OMAP3_HA) + /* + * Switch baseboard LED to red upon power-on + */ + MUX_OMAP3_HA(); + + /* Request a gpio before using it */ + gpio_request(111, ""); + /* Sets the gpio as output and its value to 1, switch LED to red */ + gpio_direction_output(111, 1); +#endif + if (tao3530_revision() < 3) { /* 256MB / Bank */ timings->mcfg = MCFG(256 << 20, 14); /* RAS-width 14 */ @@ -162,6 +174,9 @@ int misc_init_r(void) void set_muxconf_regs(void) { MUX_TAO3530(); +#if defined(CONFIG_SYS_BOARD_OMAP3_HA) + MUX_OMAP3_HA(); +#endif }
#if defined(CONFIG_GENERIC_MMC) && !defined(CONFIG_SPL_BUILD) diff --git a/board/technexion/tao3530/tao3530.h b/board/technexion/tao3530/tao3530.h index 1ea767d..5c0330c 100644 --- a/board/technexion/tao3530/tao3530.h +++ b/board/technexion/tao3530/tao3530.h @@ -9,7 +9,11 @@
const omap3_sysinfo sysinfo = { DDR_STACKED, +#if defined(CONFIG_SYS_BOARD_OMAP3_HA) + "HEAD acoustics OMAP3-HA\n", +#else "OMAP3 TAO-3530 board", +#endif "NAND", };
@@ -361,4 +365,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) \ MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0))
+#define MUX_OMAP3_HA() \ + MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M4)) /* GPIO_111 */ + #endif diff --git a/boards.cfg b/boards.cfg index d72be99..90923db 100644 --- a/boards.cfg +++ b/boards.cfg @@ -325,6 +325,7 @@ Active arm armv7 omap3 logicpd zoom1 Active arm armv7 omap3 logicpd zoom2 omap3_zoom2 - Tom Rix Tom.Rix@windriver.com Active arm armv7 omap3 matrix_vision mvblx omap3_mvblx - Michael Jones michael.jones@matrix-vision.de Active arm armv7 omap3 nokia rx51 nokia_rx51 - Pali Rohár pali.rohar@gmail.com +Active arm armv7 omap3 technexion tao3530 omap3_ha tao3530:SYS_BOARD_OMAP3_HA Stefan Roese sr@denx.de Active arm armv7 omap3 technexion tao3530 tao3530 - Tapani Utriainen linuxfae@technexion.com Active arm armv7 omap3 technexion twister twister - Stefano Babic sbabic@denx.de Active arm armv7 omap3 teejet mt_ventoux mt_ventoux - Stefano Babic sbabic@denx.de
Sorry for taking so long to get back to this, and I was going to just fixup a few things, until I got farther into the series:
Put this into the config file until we re-sync mach-types.h, IF you need to suppot non-DT booting kernels.
This needs to be re-written now.
Here and elsewhere, printf without formatting chars should be puts.
break;
break;
- default:
This hunk gets dropped in a later patch, just fixup/squash it in. The other patches that do similar things too.
+#define CONFIG_ARMV7 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP34XX /* which is a 34XX */ +#define CONFIG_OMAP3430 /* which is in a 3430 */ +#define CONFIG_OMAP3_TAO3530 /* working with TAO-3530 */
Unused.
... so don't #undef it please, it's never being set.
115200}
Please use the default table then.
No need to set this.
One of these is needed, not both.
/* works on */
Please see doc/README.memory-test
And please compare with omap3_beagle.h and similar, I think there's a few other style things that have changed since when this file was first done. Thanks!
Stefan Roese
Tapani Utriainen
