[PATCH] efi_loader: capsule: return a corret error code at find_boot_device()
In case of failure at efi_get_variable_int("BootOrder"), we should skip examining boot option variables and return an appropriate error code which is the one the function returned.
Fixes: CID 331153 Code maintainability issues (UNUSED_VALUE) Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_loader/efi_capsule.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index 691eda5e0d14..2d10f47bff24 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -685,7 +685,6 @@ skip: efi_free_pool(boot_dev); boot_dev = NULL; } -out: if (boot_dev) { u16 *path_str;
@@ -703,6 +702,7 @@ out: } else { ret = EFI_NOT_FOUND; } +out: free(boot_order);
return ret;
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
return ret;
AKASHI Takahiro
