[U-Boot] [PATCH] MIPS: tb0229: fix GCC 4.6 compile errors and warnings
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- This patch fixes the last broken board when running MAKEALL -a mips. This board was added by Wolfgang in 2004 and never had a real maintainer. If no one care about this board, I think it could be dropped.
board/tb0229/flash.c | 3 -- board/tb0229/tb0229.c | 10 ++++--- board/tb0229/vr4131-pci.c | 65 +++++++++++++++++++++++--------------------- 3 files changed, 40 insertions(+), 38 deletions(-)
diff --git a/board/tb0229/flash.c b/board/tb0229/flash.c index 75d7769..ec64e5c 100644 --- a/board/tb0229/flash.c +++ b/board/tb0229/flash.c @@ -24,7 +24,6 @@ */
#include <common.h> -#include <asm/ppc4xx.h> #include <asm/processor.h>
flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ @@ -59,8 +58,6 @@ unsigned long flash_init (void) { unsigned long size_b0, size_b1; int i; - uint pbcr; - unsigned long base_b0, base_b1;
/* Init: no FLASHes known */ for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { diff --git a/board/tb0229/tb0229.c b/board/tb0229/tb0229.c index d3f05b2..9c284f0 100644 --- a/board/tb0229/tb0229.c +++ b/board/tb0229/tb0229.c @@ -11,6 +11,7 @@
#include <common.h> #include <command.h> +#include <netdev.h> #include <asm/addrspace.h> #include <asm/io.h> #include <asm/reboot.h> @@ -26,21 +27,22 @@ void _machine_restart(void) #if defined(CONFIG_PCI) static struct pci_controller hose;
-void pci_init_board (void) +void pci_init_board(void) { + extern void init_vr4131_pci(struct pci_controller *hose); init_vr4131_pci(&hose); } #endif
phys_size_t initdram(int board_type) { - return get_ram_size (CONFIG_SYS_SDRAM_BASE, 0x8000000); + return get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x8000000); }
-int checkboard (void) +int checkboard(void) { printf("Board: TANBAC TB0229 "); - printf("(CPU Speed %d MHz)\n", (int)CPU_CLOCK_RATE/1000000); + printf("(CPU Speed %d MHz)\n", (int) CPU_CLOCK_RATE / 1000000);
set_io_port_base(0);
diff --git a/board/tb0229/vr4131-pci.c b/board/tb0229/vr4131-pci.c index 6ff4293..a011391 100644 --- a/board/tb0229/vr4131-pci.c +++ b/board/tb0229/vr4131-pci.c @@ -56,8 +56,8 @@ volatile unsigned int *pciconfigdata; * Access PCI Configuration Register for VR4131 */
-static int vr4131_pci_config_access (u8 access_type, u32 dev, u32 reg, - u32 * data) +static int vr4131_pci_config_access(u8 access_type, pci_dev_t dev, int reg, + u32 *data) { u32 bus; u32 device; @@ -73,20 +73,20 @@ static int vr4131_pci_config_access (u8 access_type, u32 dev, u32 reg, *VR4131_PCICONFAREG = (u32) (dev | ((reg / 4) << 2) | 1); }
- if (access_type == PCI_ACCESS_WRITE) { + if (access_type == PCI_ACCESS_WRITE) *VR4131_PCICONFDREG = *data; - } else { + else *data = *VR4131_PCICONFDREG; - }
return (0); }
-static int vr4131_pci_read_config_byte (u32 hose, u32 dev, u32 reg, u8 * val) +static int vr4131_pci_read_config_byte(struct pci_controller *hose, + pci_dev_t dev, int reg, u8 *val) { u32 data;
- if (vr4131_pci_config_access (PCI_ACCESS_READ, dev, reg, &data)) + if (vr4131_pci_config_access(PCI_ACCESS_READ, dev, reg, &data)) return -1;
*val = (data >> ((reg & 3) << 3)) & 0xff; @@ -95,14 +95,15 @@ static int vr4131_pci_read_config_byte (u32 hose, u32 dev, u32 reg, u8 * val) }
-static int vr4131_pci_read_config_word (u32 hose, u32 dev, u32 reg, u16 * val) +static int vr4131_pci_read_config_word(struct pci_controller *hose, + pci_dev_t dev, int reg, u16 *val) { u32 data;
if (reg & 1) return -1;
*val = (data >> ((reg & 3) << 3)) & 0xffff; @@ -111,15 +112,15 @@ static int vr4131_pci_read_config_word (u32 hose, u32 dev, u32 reg, u16 * val) }
-static int vr4131_pci_read_config_dword (u32 hose, u32 dev, u32 reg, - u32 * val) +static int vr4131_pci_read_config_dword(struct pci_controller *hose, + pci_dev_t dev, int reg, u32 *val) { u32 data = 0;
if (reg & 3) return -1;
*val = data; @@ -127,53 +128,55 @@ static int vr4131_pci_read_config_dword (u32 hose, u32 dev, u32 reg, return (0); }
-static int vr4131_pci_write_config_byte (u32 hose, u32 dev, u32 reg, u8 val) +static int vr4131_pci_write_config_byte(struct pci_controller *hose, + pci_dev_t dev, int reg, u8 val) { u32 data = 0;
data = (data & ~(0xff << ((reg & 3) << 3))) | (val << ((reg & 3) << 3));
- if (vr4131_pci_config_access (PCI_ACCESS_WRITE, dev, reg, &data)) + if (vr4131_pci_config_access(PCI_ACCESS_WRITE, dev, reg, &data)) return -1;
return 0; }
-static int vr4131_pci_write_config_word (u32 hose, u32 dev, u32 reg, u16 val) +static int vr4131_pci_write_config_word(struct pci_controller *hose, + pci_dev_t dev, int reg, u16 val) { u32 data = 0;
data = (data & ~(0xffff << ((reg & 3) << 3))) | (val << ((reg & 3) << 3));
return 0; }
-static int vr4131_pci_write_config_dword (u32 hose, u32 dev, u32 reg, u32 val) +static int vr4131_pci_write_config_dword(struct pci_controller *hose, + pci_dev_t dev, int reg, u32 val) { u32 data;
- if (reg & 3) { + if (reg & 3) return -1; - }
data = val;
return (0); @@ -184,7 +187,7 @@ static int vr4131_pci_write_config_dword (u32 hose, u32 dev, u32 reg, u32 val) * Initialize VR4131 PCIU */
-vr4131_pciu_init () +static void vr4131_pciu_init(void) { /* PCI clock */ *VR4131_PCICLKSELREG = 0x00000002; @@ -211,28 +214,28 @@ vr4131_pciu_init () * Initialize Module */
-void init_vr4131_pci (struct pci_controller *hose) +void init_vr4131_pci(struct pci_controller *hose) { hose->first_busno = 0; hose->last_busno = 0xff;
- vr4131_pciu_init (); /* Initialize VR4131 PCIU */ + vr4131_pciu_init(); /* Initialize VR4131 PCIU */
/* PCI memory space #1 */ - pci_set_region (hose->regions + 0, + pci_set_region(hose->regions + 0, 0x10000000, 0xb0000000, 0x04000000, PCI_REGION_MEM);
/* PCI memory space #2 */ - pci_set_region (hose->regions + 1, + pci_set_region(hose->regions + 1, 0x14000000, 0xb4000000, 0x02000000, PCI_REGION_MEM);
/* PCI I/O space */ - pci_set_region (hose->regions + 2, + pci_set_region(hose->regions + 2, 0x16000000, 0xb6000000, 0x02000000, PCI_REGION_IO);
/* System memory space */ - pci_set_region (hose->regions + 3, + pci_set_region(hose->regions + 3, 0x00000000, 0x80000000, 0x04000000, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); @@ -246,9 +249,9 @@ void init_vr4131_pci (struct pci_controller *hose) hose->write_word = vr4131_pci_write_config_word; hose->write_dword = vr4131_pci_write_config_dword;
- pci_register_hose (hose); + pci_register_hose(hose);
- hose->last_busno = pci_hose_scan (hose); + hose->last_busno = pci_hose_scan(hose);
return; }
Dear Daniel Schwierzeck,
In message 1323442731-12017-1-git-send-email-daniel.schwierzeck@googlemail.com you wrote:
Can you please split thisi nto two patches, one performing just the coding style cleanup, and the second one adding all the rest?
- printf("(CPU Speed %d MHz)\n", (int) CPU_CLOCK_RATE / 1000000);
When we touch this, would it then not make sense to switch to using print_mhz() instead?
- if (access_type == PCI_ACCESS_WRITE) *VR4131_PCICONFDREG = *data;
- } else {
- else *data = *VR4131_PCICONFDREG;
You are sure that we don;t need any I/O accessors / memory barriers here (and elsewhere) ?
This board breaks MAKEALL -a mips due to compile errors. This patch fixes only the parts causing the errors to get MAKEALL working.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- Changes for v2: - removed fixes for coding style cleanup and compiler warnings
Note: minimal patch to get MAKEALL -a mips working. This board is broken and has no maintainer so it should be dropped.
board/tb0229/flash.c | 1 - board/tb0229/tb0229.c | 1 + board/tb0229/vr4131-pci.c | 2 +- 3 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/tb0229/flash.c b/board/tb0229/flash.c index 75d7769..4cb5968 100644 --- a/board/tb0229/flash.c +++ b/board/tb0229/flash.c @@ -24,7 +24,6 @@ */
flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ diff --git a/board/tb0229/tb0229.c b/board/tb0229/tb0229.c index d3f05b2..8e374a1 100644 --- a/board/tb0229/tb0229.c +++ b/board/tb0229/tb0229.c @@ -11,6 +11,7 @@
#include <common.h> #include <command.h> +#include <netdev.h> #include <asm/addrspace.h> #include <asm/io.h> #include <asm/reboot.h> diff --git a/board/tb0229/vr4131-pci.c b/board/tb0229/vr4131-pci.c index 6ff4293..e6fff9d 100644 --- a/board/tb0229/vr4131-pci.c +++ b/board/tb0229/vr4131-pci.c @@ -184,7 +184,7 @@ static int vr4131_pci_write_config_dword (u32 hose, u32 dev, u32 reg, u32 val) * Initialize VR4131 PCIU */
In message 1323621577-13010-1-git-send-email-daniel.schwierzeck@googlemail.com you wrote:
Changes for v2:
Applied, thanks.
Changes for v2:
I suggest we drop it. You patch does not really fix it. With GCC 4.6 I get anothe rton of warnings / errors:
Configuring for tb0229 board... pci_indirect.c: In function 'indirect_read_config_byte': pci_indirect.c:101:1: warning: implicit declaration of function 'out_le32' [-Wimplicit-function-declaration] pci_indirect.c:101:1: warning: implicit declaration of function 'in_8' [-Wimplicit-function-declaration] pci_indirect.c: In function 'indirect_read_config_word': pci_indirect.c:102:1: warning: implicit declaration of function 'in_le16' [-Wimplicit-function-declaration] pci_indirect.c: In function 'indirect_read_config_dword': pci_indirect.c:103:1: warning: implicit declaration of function 'in_le32' [-Wimplicit-function-declaration] pci_indirect.c: In function 'indirect_write_config_byte': pci_indirect.c:109:1: warning: implicit declaration of function 'out_8' [-Wimplicit-function-declaration] pci_indirect.c: In function 'indirect_write_config_word': pci_indirect.c:110:1: warning: implicit declaration of function 'out_le16' [-Wimplicit-function-declaration] flash.c: In function 'flash_init': flash.c:62:25: warning: unused variable 'base_b1' [-Wunused-variable] flash.c:62:16: warning: unused variable 'base_b0' [-Wunused-variable] flash.c:61:7: warning: unused variable 'pbcr' [-Wunused-variable] vr4131-pci.c: In function 'init_vr4131_pci': vr4131-pci.c:242:18: warning: assignment from incompatible pointer type [enabled by default] vr4131-pci.c:243:18: warning: assignment from incompatible pointer type [enabled by default] vr4131-pci.c:244:19: warning: assignment from incompatible pointer type [enabled by default] vr4131-pci.c:245:19: warning: assignment from incompatible pointer type [enabled by default] vr4131-pci.c:246:19: warning: assignment from incompatible pointer type [enabled by default] vr4131-pci.c:247:20: warning: assignment from incompatible pointer type [enabled by default] tb0229.c: In function 'pci_init_board': tb0229.c:32:2: warning: implicit declaration of function 'init_vr4131_pci' [-Wimplicit-function-declaration] tb0229.c: In function 'initdram': tb0229.c:38:2: warning: passing argument 1 of 'get_ram_size' makes pointer from integer without a cast [enabled by default] /home/wd/git/u-boot/work/include/common.h:383:6: note: expected 'long int *' but argument is of type 'unsigned int' mips-linux-ld: Warning: size of symbol `_machine_restart' changed from 8 in arch/mips/cpu/mips32/libmips32.o to 12 in board/tb0229/libtb0229.o mips-linux-ld: Warning: size of symbol `board_eth_init' changed from 8 in net/libnet.o to 88 in board/tb0229/libtb0229.o mips-linux-ld: arch/mips/cpu/mips32/start.o: compiled for a big endian system and target is little endian mips-linux-ld: arch/mips/cpu/mips32/start.o: endianness incompatible with that of the selected emulation mips-linux-ld: failed to merge target specific data of file arch/mips/cpu/mips32/start.o mips-linux-ld: arch/mips/cpu/mips32/libmips32.o: compiled for a big endian system and target is little endian mips-linux-ld: arch/mips/cpu/mips32/libmips32.o: endianness incompatible with that of the selected emulation mips-linux-ld: failed to merge target specific data of file arch/mips/cpu/mips32/libmips32.o mips-linux-ld: arch/mips/lib/libmips.o: compiled for a big endian system and target is little endian mips-linux-ld: arch/mips/lib/libmips.o: endianness incompatible with that of the selected emulation mips-linux-ld: failed to merge target specific data of file arch/mips/lib/libmips.o mips-linux-ld: common/libcommon.o: compiled for a big endian system and target is little endian mips-linux-ld: common/libcommon.o: endianness incompatible with that of the selected emulation mips-linux-ld: failed to merge target specific data of file common/libcommon.o mips-linux-ld: disk/libdisk.o: compiled for a big endian system and target is little endian mips-linux-ld: disk/libdisk.o: endianness incompatible with that of the selected emulation ...
I'll prepare a patch...
Thanks.
The "tb0229" board has long been unmaintained, and is broken. Remove it.
Signed-off-by: Wolfgang Denk wd@denx.de --- board/tb0229/Makefile | 47 -- board/tb0229/config.mk | 30 - board/tb0229/flash.c | 1197 ------------------------------------------ board/tb0229/lowlevel_init.S | 70 --- board/tb0229/tb0229.c | 54 -- board/tb0229/u-boot.lds | 70 --- board/tb0229/vr4131-pci.c | 254 --------- boards.cfg | 1 - doc/README.scrapyard | 7 +- 9 files changed, 4 insertions(+), 1726 deletions(-) delete mode 100644 board/tb0229/Makefile delete mode 100644 board/tb0229/config.mk delete mode 100644 board/tb0229/flash.c delete mode 100644 board/tb0229/lowlevel_init.S delete mode 100644 board/tb0229/tb0229.c delete mode 100644 board/tb0229/u-boot.lds delete mode 100644 board/tb0229/vr4131-pci.c
diff --git a/board/tb0229/Makefile b/board/tb0229/Makefile deleted file mode 100644 index 76f1664..0000000 --- a/board/tb0229/Makefile +++ /dev/null @@ -1,47 +0,0 @@ -# -# (C) Masami Komiya mkomiya@sonare.it 2004 -# -# (C) Copyright 2003-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o vr4131-pci.o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/tb0229/config.mk b/board/tb0229/config.mk deleted file mode 100644 index 017511d..0000000 --- a/board/tb0229/config.mk +++ /dev/null @@ -1,30 +0,0 @@ -# -# (C) Masami Komiya mkomiya@sonare.it 2004 -# -# (C) Copyright 2003 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -# ROM version -CONFIG_SYS_TEXT_BASE = 0xBFC00000 - -# RAM version -#CONFIG_SYS_TEXT_BASE = 0x80400000 diff --git a/board/tb0229/flash.c b/board/tb0229/flash.c deleted file mode 100644 index 4cb5968..0000000 --- a/board/tb0229/flash.c +++ /dev/null @@ -1,1197 +0,0 @@ -/* - * (C) Masami Komiya mkomiya@sonare.it 2004 - * - * (C) Copyright 2001-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/processor.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - - -#ifdef CONFIG_SYS_FLASH_16BIT -#define FLASH_WORD_SIZE unsigned short -#define FLASH_ID_MASK 0xFFFF -#else -#define FLASH_WORD_SIZE unsigned long -#define FLASH_ID_MASK 0xFFFFFFFF -#endif - -/*----------------------------------------------------------------------- - * Functions - */ -/* stolen from esteem192e/flash.c */ -ulong flash_get_size (volatile FLASH_WORD_SIZE * addr, flash_info_t * info); - -#ifndef CONFIG_SYS_FLASH_16BIT -static int write_word (flash_info_t * info, ulong dest, ulong data); -#else -static int write_short (flash_info_t * info, ulong dest, ushort data); -#endif -static void flash_get_offsets (ulong base, flash_info_t * info); - - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - unsigned long size_b0, size_b1; - int i; - uint pbcr; - unsigned long base_b0, base_b1; - - /* Init: no FLASHes known */ - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size_b0 = - flash_get_size ((volatile FLASH_WORD_SIZE *) CONFIG_SYS_FLASH_BASE, - &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", size_b0, size_b0 << 20); - } - - /* Only one bank */ - if (CONFIG_SYS_MAX_FLASH_BANKS == 1) { - /* Setup offsets */ - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - /* Monitor protection ON by default */ -#if 0 /* sand: */ - (void) flash_protect (FLAG_PROTECT_SET, - FLASH_BASE0_PRELIM - monitor_flash_len + - size_b0, - FLASH_BASE0_PRELIM - 1 + size_b0, - &flash_info[0]); -#else - (void) flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - - 1, &flash_info[0]); -#endif - size_b1 = 0; - flash_info[0].size = size_b0; - } -#ifdef CONFIG_SYS_FLASH_BASE_2 - /* 2 banks */ - else { - size_b1 = - flash_get_size ((volatile FLASH_WORD_SIZE *) - CONFIG_SYS_FLASH_BASE_2, &flash_info[1]); - - /* Re-do sizing to get full correct info */ - - if (size_b1) { - mtdcr (EBC0_CFGADDR, PB0CR); - pbcr = mfdcr (EBC0_CFGDATA); - mtdcr (EBC0_CFGADDR, PB0CR); - base_b1 = -size_b1; - pbcr = (pbcr & 0x0001ffff) | base_b1 | - (((size_b1 / 1024 / 1024) - 1) << 17); - mtdcr (EBC0_CFGDATA, pbcr); - /* printf("PB1CR = %x\n", pbcr); */ - } - - if (size_b0) { - mtdcr (EBC0_CFGADDR, PB1CR); - pbcr = mfdcr (EBC0_CFGDATA); - mtdcr (EBC0_CFGADDR, PB1CR); - base_b0 = base_b1 - size_b0; - pbcr = (pbcr & 0x0001ffff) | base_b0 | - (((size_b0 / 1024 / 1024) - 1) << 17); - mtdcr (EBC0_CFGDATA, pbcr); - /* printf("PB0CR = %x\n", pbcr); */ - } - - size_b0 = - flash_get_size ((volatile FLASH_WORD_SIZE *) base_b0, - &flash_info[0]); - - flash_get_offsets (base_b0, &flash_info[0]); - - /* monitor protection ON by default */ -#if 0 /* sand: */ - (void) flash_protect (FLAG_PROTECT_SET, - FLASH_BASE0_PRELIM - monitor_flash_len + - size_b0, - FLASH_BASE0_PRELIM - 1 + size_b0, - &flash_info[0]); -#else - (void) flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - - 1, &flash_info[0]); -#endif - - if (size_b1) { - /* Re-do sizing to get full correct info */ - size_b1 = - flash_get_size ((volatile FLASH_WORD_SIZE *) - base_b1, &flash_info[1]); - - flash_get_offsets (base_b1, &flash_info[1]); - - /* monitor protection ON by default */ - (void) flash_protect (FLAG_PROTECT_SET, - base_b1 + size_b1 - - monitor_flash_len, - base_b1 + size_b1 - 1, - &flash_info[1]); - /* monitor protection OFF by default (one is enough) */ - (void) flash_protect (FLAG_PROTECT_CLEAR, - base_b0 + size_b0 - - monitor_flash_len, - base_b0 + size_b0 - 1, - &flash_info[0]); - } else { - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[1].sector_count = -1; - } - - flash_info[0].size = size_b0; - flash_info[1].size = size_b1; - } /* else 2 banks */ -#endif - return (size_b0 + size_b1); -} - - -/*----------------------------------------------------------------------- - */ - -static void flash_get_offsets (ulong base, flash_info_t * info) -{ - int i; - - /* set up sector start adress table */ - if ((info->flash_id & FLASH_TYPEMASK) == FLASH_28F320J3A || - (info->flash_id & FLASH_TYPEMASK) == FLASH_28F640J3A || - (info->flash_id & FLASH_TYPEMASK) == FLASH_28F128J3A) { - for (i = 0; i < info->sector_count; i++) { - info->start[i] = - base + (i * info->size / info->sector_count); - } - } else if (info->flash_id & FLASH_BTYPE) { - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - -#ifndef CONFIG_SYS_FLASH_16BIT - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00008000; - info->start[3] = base + 0x0000C000; - info->start[4] = base + 0x00010000; - info->start[5] = base + 0x00014000; - info->start[6] = base + 0x00018000; - info->start[7] = base + 0x0001C000; - for (i = 8; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00020000) - 0x000E0000; - } - } else { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00008000; - info->start[2] = base + 0x0000C000; - info->start[3] = base + 0x00010000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00020000) - 0x00060000; - } - } -#else - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00002000; - info->start[2] = base + 0x00004000; - info->start[3] = base + 0x00006000; - info->start[4] = base + 0x00008000; - info->start[5] = base + 0x0000A000; - info->start[6] = base + 0x0000C000; - info->start[7] = base + 0x0000E000; - for (i = 8; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00010000) - 0x00070000; - } - } else { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = - base + (i * 0x00010000) - 0x00030000; - } - } -#endif - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - -#ifndef CONFIG_SYS_FLASH_16BIT - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - info->start[i--] = base + info->size - 0x00014000; - info->start[i--] = base + info->size - 0x00018000; - info->start[i--] = base + info->size - 0x0001C000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - - } else { - - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - } -#else - info->start[i--] = base + info->size - 0x00002000; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000A000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x0000E000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - - } else { - - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } -#endif - } - - -} - -/*----------------------------------------------------------------------- - */ - -void flash_print_info (flash_info_t * info) -{ - int i; - uchar *boottype; - uchar botboot[] = ", bottom boot sect)\n"; - uchar topboot[] = ", top boot sector)\n"; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: - printf ("AMD "); - break; - case FLASH_MAN_FUJ: - printf ("FUJITSU "); - break; - case FLASH_MAN_SST: - printf ("SST "); - break; - case FLASH_MAN_STM: - printf ("STM "); - break; - case FLASH_MAN_INTEL: - printf ("INTEL "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - if (info->flash_id & 0x0001) { - boottype = botboot; - } else { - boottype = topboot; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM400B: - printf ("AM29LV400B (4 Mbit%s", boottype); - break; - case FLASH_AM400T: - printf ("AM29LV400T (4 Mbit%s", boottype); - break; - case FLASH_AM800B: - printf ("AM29LV800B (8 Mbit%s", boottype); - break; - case FLASH_AM800T: - printf ("AM29LV800T (8 Mbit%s", boottype); - break; - case FLASH_AM160B: - printf ("AM29LV160B (16 Mbit%s", boottype); - break; - case FLASH_AM160T: - printf ("AM29LV160T (16 Mbit%s", boottype); - break; - case FLASH_AM320B: - printf ("AM29LV320B (32 Mbit%s", boottype); - break; - case FLASH_AM320T: - printf ("AM29LV320T (32 Mbit%s", boottype); - break; - case FLASH_INTEL800B: - printf ("INTEL28F800B (8 Mbit%s", boottype); - break; - case FLASH_INTEL800T: - printf ("INTEL28F800T (8 Mbit%s", boottype); - break; - case FLASH_INTEL160B: - printf ("INTEL28F160B (16 Mbit%s", boottype); - break; - case FLASH_INTEL160T: - printf ("INTEL28F160T (16 Mbit%s", boottype); - break; - case FLASH_INTEL320B: - printf ("INTEL28F320B (32 Mbit%s", boottype); - break; - case FLASH_INTEL320T: - printf ("INTEL28F320T (32 Mbit%s", boottype); - break; - -#if 0 /* enable when devices are available */ - - case FLASH_INTEL640B: - printf ("INTEL28F640B (64 Mbit%s", boottype); - break; - case FLASH_INTEL640T: - printf ("INTEL28F640T (64 Mbit%s", boottype); - break; -#endif - case FLASH_28F320J3A: - printf ("INTEL28F320J3A (32 Mbit%s", boottype); - break; - case FLASH_28F640J3A: - printf ("INTEL28F640J3A (64 Mbit%s", boottype); - break; - case FLASH_28F128J3A: - printf ("INTEL28F128J3A (128 Mbit%s", boottype); - break; - - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); - return; -} - - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ -ulong flash_get_size (volatile FLASH_WORD_SIZE * addr, flash_info_t * info) -{ - short i; - ulong base = (ulong) addr; - FLASH_WORD_SIZE value; - - /* Write auto select command: read Manufacturer ID */ - - -#ifndef CONFIG_SYS_FLASH_16BIT - - /* - * Note: if it is an AMD flash and the word at addr[0000] - * is 0x00890089 this routine will think it is an Intel - * flash device and may(most likely) cause trouble. - */ - - addr[0x0000] = 0x00900090; - if (addr[0x0000] != 0x00890089) { - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00900090; -#else - - /* - * Note: if it is an AMD flash and the word at addr[0000] - * is 0x0089 this routine will think it is an Intel - * flash device and may(most likely) cause trouble. - */ - - addr[0x0000] = 0x0090; - - if (addr[0x0000] != 0x0089) { - addr[0x0555] = 0x00AA; - addr[0x02AA] = 0x0055; - addr[0x0555] = 0x0090; -#endif - } - value = addr[0]; - - switch (value) { - case (AMD_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_AMD; - break; - case (FUJ_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_FUJ; - break; - case (STM_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_STM; - break; - case (SST_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_SST; - break; - case (INTEL_MANUFACT & FLASH_ID_MASK): - info->flash_id = FLASH_MAN_INTEL; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - - } - - value = addr[1]; /* device ID */ - - switch (value) { - - case (AMD_ID_LV400T & FLASH_ID_MASK): - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV400B & FLASH_ID_MASK): - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV800T & FLASH_ID_MASK): - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV800B & FLASH_ID_MASK): - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV160T & FLASH_ID_MASK): - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (AMD_ID_LV160B & FLASH_ID_MASK): - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ -#if 0 /* enable when device IDs are available */ - case (AMD_ID_LV320T & FLASH_ID_MASK): - info->flash_id += FLASH_AM320T; - info->sector_count = 67; - info->size = 0x00800000; - break; /* => 8 MB */ - - case (AMD_ID_LV320B & FLASH_ID_MASK): - info->flash_id += FLASH_AM320B; - info->sector_count = 67; - info->size = 0x00800000; - break; /* => 8 MB */ -#endif - - case (INTEL_ID_28F800B3T & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL800T; - info->sector_count = 23; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (INTEL_ID_28F800B3B & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL800B; - info->sector_count = 23; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (INTEL_ID_28F160B3T & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL160T; - info->sector_count = 39; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (INTEL_ID_28F160B3B & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL160B; - info->sector_count = 39; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (INTEL_ID_28F320B3T & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL320T; - info->sector_count = 71; - info->size = 0x00800000; - break; /* => 8 MB */ - - case (INTEL_ID_28F320B3B & FLASH_ID_MASK): - info->flash_id += FLASH_AM320B; - info->sector_count = 71; - info->size = 0x00800000; - break; /* => 8 MB */ - -#if 0 /* enable when devices are available */ - case (INTEL_ID_28F320B3T & FLASH_ID_MASK): - info->flash_id += FLASH_INTEL320T; - info->sector_count = 135; - info->size = 0x01000000; - break; /* => 16 MB */ - - case (INTEL_ID_28F320B3B & FLASH_ID_MASK): - info->flash_id += FLASH_AM320B; - info->sector_count = 135; - info->size = 0x01000000; - break; /* => 16 MB */ -#endif - case (INTEL_ID_28F320J3A & FLASH_ID_MASK): - info->flash_id += FLASH_28F320J3A; - info->sector_count = 32; - info->size = 0x00400000; - break; /* => 32 MBit */ - case (INTEL_ID_28F640J3A & FLASH_ID_MASK): - info->flash_id += FLASH_28F640J3A; - info->sector_count = 64; - info->size = 0x00800000; - break; /* => 64 MBit */ - case (INTEL_ID_28F128J3A & FLASH_ID_MASK): - info->flash_id += FLASH_28F128J3A; - info->sector_count = 128; - info->size = 0x01000000; - break; /* => 128 MBit */ - - default: - /* FIXME */ - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - } - - flash_get_offsets (base, info); - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile FLASH_WORD_SIZE *) (info->start[i]); - info->protect[i] = addr[2] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (volatile FLASH_WORD_SIZE *) info->start[0]; - if ((info->flash_id & 0xFF00) == FLASH_MAN_INTEL) { - *addr = (0x00F000F0 & FLASH_ID_MASK); /* reset bank */ - } else { - *addr = (0x00FF00FF & FLASH_ID_MASK); /* reset bank */ - } - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - - volatile FLASH_WORD_SIZE *addr = - (volatile FLASH_WORD_SIZE *) (info->start[0]); - int flag, prot, sect, l_sect, barf; - ulong start, now, last; - int rcode = 0; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || - ((info->flash_id > FLASH_AMD_COMP) && - ((info->flash_id & FLASH_VENDMASK) != FLASH_MAN_INTEL))) { - printf ("Can't erase unknown flash type - aborted\n"); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - if (info->flash_id < FLASH_AMD_COMP) { -#ifndef CONFIG_SYS_FLASH_16BIT - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00800080; - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; -#else - addr[0x0555] = 0x00AA; - addr[0x02AA] = 0x0055; - addr[0x0555] = 0x0080; - addr[0x0555] = 0x00AA; - addr[0x02AA] = 0x0055; -#endif - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (volatile FLASH_WORD_SIZE *) (info-> - start - [sect]); - addr[0] = (0x00300030 & FLASH_ID_MASK); - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = (volatile FLASH_WORD_SIZE *) (info->start[l_sect]); - while ((addr[0] & (0x00800080 & FLASH_ID_MASK)) != - (0x00800080 & FLASH_ID_MASK)) { - if ((now = get_timer (start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000000) { /* every second */ - serial_putc ('.'); - last = now; - } - } - - DONE: - /* reset to read mode */ - addr = (volatile FLASH_WORD_SIZE *) info->start[0]; - addr[0] = (0x00F000F0 & FLASH_ID_MASK); /* reset bank */ - } else { - - - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - barf = 0; -#ifndef CONFIG_SYS_FLASH_16BIT - addr = (vu_long *) (info->start[sect]); - addr[0] = 0x00500050; - addr[0] = 0x00200020; - addr[0] = 0x00D000D0; - while (!(addr[0] & 0x00800080)); /* wait for error or finish */ - if (addr[0] & 0x003A003A) { /* check for error */ - barf = addr[0] & 0x003A0000; - if (barf) { - barf >>= 16; - } else { - barf = addr[0] & 0x0000003A; - } - } -#else - addr = (vu_short *) (info->start[sect]); - addr[0] = 0x0050; /* clear status register */ - addr[0] = 0x0020; - addr[0] = 0x00D0; - while (!(addr[0] & 0x0080)); /* wait for error or finish */ - if (addr[0] & 0x003A) /* check for error */ - barf = addr[0] & 0x003A; -#endif - if (barf) { - printf ("\nFlash error in sector at %lx\n", (unsigned long) addr); - if (barf & 0x0002) - printf ("Block locked, not erased.\n"); - if ((barf & 0x0030) == 0x0030) - printf ("Command Sequence error.\n"); - if ((barf & 0x0030) == 0x0020) - printf ("Block Erase error.\n"); - if (barf & 0x0008) - printf ("Vpp Low error.\n"); - rcode = 1; - } else - printf ("."); - l_sect = sect; - } - addr = (volatile FLASH_WORD_SIZE *) info->start[0]; -#ifndef CONFIG_SYS_FLASH_16BIT - addr[0] = (0x00FF00FF & FLASH_ID_MASK); /* reset bank */ -#else - addr[0] = (0x00FF & FLASH_ID_MASK); /* reset bank */ -#endif - } - - } - printf (" done\n"); - return rcode; -} - -/*----------------------------------------------------------------------- - */ - -/*flash_info_t *addr2info (ulong addr) -{ - flash_info_t *info; - int i; - - for (i=0, info=&flash_info[0]; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) { - if ((addr >= info->start[0]) && - (addr < (info->start[0] + info->size)) ) { - return (info); - } - } - - return (NULL); -} -*/ -/*----------------------------------------------------------------------- - * Copy memory to flash. - * Make sure all target addresses are within Flash bounds, - * and no protected sectors are hit. - * Returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - target range includes protected sectors - * 8 - target address not in Flash memory - */ - -/*int flash_write (uchar *src, ulong addr, ulong cnt) -{ - int i; - ulong end = addr + cnt - 1; - flash_info_t *info_first = addr2info (addr); - flash_info_t *info_last = addr2info (end ); - flash_info_t *info; - - if (cnt == 0) { - return (0); - } - - if (!info_first || !info_last) { - return (8); - } - - for (info = info_first; info <= info_last; ++info) { - ulong b_end = info->start[0] + info->size;*/ /* bank end addr */ -/* short s_end = info->sector_count - 1; - for (i=0; i<info->sector_count; ++i) { - ulong e_addr = (i == s_end) ? b_end : info->start[i + 1]; - - if ((end >= info->start[i]) && (addr < e_addr) && - (info->protect[i] != 0) ) { - return (4); - } - } - } - -*/ /* finally write data to flash */ -/* for (info = info_first; info <= info_last && cnt>0; ++info) { - ulong len; - - len = info->start[0] + info->size - addr; - if (len > cnt) - len = cnt; - if ((i = write_buff(info, src, addr, len)) != 0) { - return (i); - } - cnt -= len; - addr += len; - src += len; - } - return (0); -} -*/ -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ -#ifndef CONFIG_SYS_FLASH_16BIT - ulong cp, wp, data; - int l; -#else - ulong cp, wp; - ushort data; -#endif - int i, rc; - -#ifndef CONFIG_SYS_FLASH_16BIT - - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i = 0, cp = wp; i < l; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - for (; i < 4 && cnt > 0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt == 0 && i < 4; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - if ((rc = write_word (info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i = 0; i < 4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word (info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; i < 4 && cnt > 0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i < 4; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - return (write_word (info, wp, data)); - -#else - wp = (addr & ~1); /* get lower word aligned address */ - - /* - * handle unaligned start byte - */ - if (addr - wp) { - data = 0; - data = (data << 8) | *src++; - --cnt; - if ((rc = write_short (info, wp, data)) != 0) { - return (rc); - } - wp += 2; - } - - /* - * handle word aligned part - */ -/* l = 0; used for debuging */ - while (cnt >= 2) { - data = 0; - for (i = 0; i < 2; ++i) { - data = (data << 8) | *src++; - } - -/* if(!l){ - printf("%x",data); - l = 1; - } used for debuging */ - - if ((rc = write_short (info, wp, data)) != 0) { - return (rc); - } - wp += 2; - cnt -= 2; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; i < 2 && cnt > 0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i < 2; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - return (write_short (info, wp, data)); - - -#endif -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -#ifndef CONFIG_SYS_FLASH_16BIT -static int write_word (flash_info_t * info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long *) (info->start[0]); - ulong start, barf; - int flag; - -#if defined (__MIPSEL__) - data = cpu_to_be32 (data); -#endif - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_long *) dest) & data) != data) { - return (2); - } - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - - if (info->flash_id < FLASH_AMD_COMP) { - /* AMD stuff */ - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00A000A0; - } else { - /* intel stuff */ - *addr = 0x00400040; - } - - *((vu_long *) dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - /* data polling for D7 */ - start = get_timer (0); - - if (info->flash_id < FLASH_AMD_COMP) { - - while ((*((vu_long *) dest) & 0x00800080) != - (data & 0x00800080)) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - printf ("timeout\n"); - return (1); - } - } - - } else { - - while (!(addr[0] & 0x00800080)) { /* wait for error or finish */ - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - printf ("timeout\n"); - return (1); - } - } - - if (addr[0] & 0x003A003A) { /* check for error */ - barf = addr[0] & 0x003A0000; - if (barf) { - barf >>= 16; - } else { - barf = addr[0] & 0x0000003A; - } - printf ("\nFlash write error at address %lx\n", - (unsigned long) dest); - if (barf & 0x0002) - printf ("Block locked, not erased.\n"); - if (barf & 0x0010) - printf ("Programming error.\n"); - if (barf & 0x0008) - printf ("Vpp Low error.\n"); - return (2); - } - - - } - - return (0); -} - -#else - -static int write_short (flash_info_t * info, ulong dest, ushort data) -{ - vu_short *addr = (vu_short *) (info->start[0]); - ulong start, barf; - int flag; - -#if defined (__MIPSEL__) - data = cpu_to_be16 (data); -#endif - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_short *) dest) & data) != data) { - return (2); - } - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - - if (info->flash_id < FLASH_AMD_COMP) { - /* AMD stuff */ - addr[0x0555] = 0x00AA; - addr[0x02AA] = 0x0055; - addr[0x0555] = 0x00A0; - } else { - /* intel stuff */ - *addr = 0x00D0; - *addr = 0x0040; - } - *((vu_short *) dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts (); - - /* data polling for D7 */ - start = get_timer (0); - - if (info->flash_id < FLASH_AMD_COMP) { - /* AMD stuff */ - while ((*((vu_short *) dest) & 0x0080) != (data & 0x0080)) { - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - - } else { - /* intel stuff */ - while (!(addr[0] & 0x0080)) { /* wait for error or finish */ - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) - return (1); - } - - if (addr[0] & 0x003A) { /* check for error */ - barf = addr[0] & 0x003A; - printf ("\nFlash write error at address %lx\n", - (unsigned long) dest); - if (barf & 0x0002) - printf ("Block locked, not erased.\n"); - if (barf & 0x0010) - printf ("Programming error.\n"); - if (barf & 0x0008) - printf ("Vpp Low error.\n"); - return (2); - } - *addr = 0x00B0; - *addr = 0x0070; - while (!(addr[0] & 0x0080)) { /* wait for error or finish */ - if (get_timer (start) > CONFIG_SYS_FLASH_WRITE_TOUT) - return (1); - } - - *addr = 0x00FF; - - } - - return (0); - -} -#endif diff --git a/board/tb0229/lowlevel_init.S b/board/tb0229/lowlevel_init.S deleted file mode 100644 index 5fce856..0000000 --- a/board/tb0229/lowlevel_init.S +++ /dev/null @@ -1,70 +0,0 @@ -/* - * Memory sub-system initialization code for TANBAC Evaluation board TB0229. - * - * Copyright (c) 2003 Masami Komiya mkomiya@sonare.it - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2, or (at - * your option) any later version. - */ - -#include <config.h> -#include <asm/regdef.h> - - - .globl lowlevel_init -lowlevel_init: - - /* BCUCNTREG1 = 0x0040 */ - la t0, 0xaf000000 - li t1, 0x0040 - sh t1, 0(t0) - - /* ROMSIZEREG = 0x3333 */ - la t0, 0xaf000004 - li t1, 0x3333 - sh t1, 0(t0) - - /* ROMSPEEDREG = 0x3003 */ - la t0, 0xaf000006 - li t1, 0x3003 - sh t1, 0(t0) - - /* BCUCNTREG3 = 0 */ - la t0, 0xaf000016 - li t1, 0x0000 - sh t1, 0(t0) - - /* CMUCLKMSK */ - la t0, 0xaf000060 - li t1, 0x39a2 - sh t1, 0(t0) - - /* PMUCNTREG */ - la t0, 0xaf0000c2 - li t1, 0x0006 - sh t1, 0(t0) - - /* SDRAMMODEREG = 0x8029 */ - la t0, 0xaf000400 - li t1, 0x8029 - sh t1, 0(t0) - - /* SDRAMCNTREG = 0x2322 */ - la t0, 0xaf000402 - li t1, 0x2322 - sh t1, 0(t0) - - /* BCURFCNTREG = 0x0106 */ - la t0, 0xaf000404 - li t1, 0x0106 - sh t1, 0(t0) - - /* RAMSZEREG = 0x5555 (64MB Bank) */ - la t0, 0xaf000408 - li t1, 0x5555 - sh t1, 0(t0) - - j ra - nop diff --git a/board/tb0229/tb0229.c b/board/tb0229/tb0229.c deleted file mode 100644 index 8e374a1..0000000 --- a/board/tb0229/tb0229.c +++ /dev/null @@ -1,54 +0,0 @@ -/* - * Board initialize code for TANBAC Evaluation board TB0229. - * - * (C) Masami Komiya mkomiya@sonare.it 2004 - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2, or (at - * your option) any later version. - */ - -#include <common.h> -#include <command.h> -#include <netdev.h> -#include <asm/addrspace.h> -#include <asm/io.h> -#include <asm/reboot.h> -#include <pci.h> - -void _machine_restart(void) -{ - void (*f)(void) = (void *) 0xbfc00000; - - f(); -} - -#if defined(CONFIG_PCI) -static struct pci_controller hose; - -void pci_init_board (void) -{ - init_vr4131_pci(&hose); -} -#endif - -phys_size_t initdram(int board_type) -{ - return get_ram_size (CONFIG_SYS_SDRAM_BASE, 0x8000000); -} - -int checkboard (void) -{ - printf("Board: TANBAC TB0229 "); - printf("(CPU Speed %d MHz)\n", (int)CPU_CLOCK_RATE/1000000); - - set_io_port_base(0); - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/tb0229/u-boot.lds b/board/tb0229/u-boot.lds deleted file mode 100644 index 5ea1094..0000000 --- a/board/tb0229/u-boot.lds +++ /dev/null @@ -1,70 +0,0 @@ -/* - * (C) Masami Komiya mkomiya@sonare.it 2004 - * - * (C) Copyright 2003 - * Wolfgang Denk Engineering, wd@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-tradlittlemips", "elf32-tradlittlemips", "elf32-tradlittlemips") - -OUTPUT_ARCH(mips) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - *(.text*) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data*) } - - . = .; - _gp = ALIGN(16) + 0x7ff0; - - .got : { - __got_start = .; - *(.got) - __got_end = .; - } - - .sdata : { *(.sdata*) } - - .u_boot_cmd : { - __u_boot_cmd_start = .; - *(.u_boot_cmd) - __u_boot_cmd_end = .; - } - - uboot_end_data = .; - num_got_entries = (__got_end - __got_start) >> 2; - - . = ALIGN(4); - .sbss (NOLOAD) : { *(.sbss*) } - .bss (NOLOAD) : { *(.bss*) . = ALIGN(4); } - uboot_end = .; -} diff --git a/board/tb0229/vr4131-pci.c b/board/tb0229/vr4131-pci.c deleted file mode 100644 index e6fff9d..0000000 --- a/board/tb0229/vr4131-pci.c +++ /dev/null @@ -1,254 +0,0 @@ -/* - * VR4131 PCIU support code for TANBAC Evaluation board TB0229. - * - * (C) Masami Komiya mkomiya@sonare.it 2004 - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2, or (at - * your option) any later version. - */ - -#include <common.h> -#include <pci.h> -#include <asm/addrspace.h> - -#define VR4131_PCIMMAW1REG (volatile unsigned int *)(CKSEG1 + 0x0f000c00) -#define VR4131_PCIMMAW2REG (volatile unsigned int *)(CKSEG1 + 0x0f000c04) -#define VR4131_PCITAW1REG (volatile unsigned int *)(CKSEG1 + 0x0f000c08) -#define VR4131_PCITAW2REG (volatile unsigned int *)(CKSEG1 + 0x0f000c0c) -#define VR4131_PCIMIOAWREG (volatile unsigned int *)(CKSEG1 + 0x0f000c10) -#define VR4131_PCICONFDREG (volatile unsigned int *)(CKSEG1 + 0x0f000c14) -#define VR4131_PCICONFAREG (volatile unsigned int *)(CKSEG1 + 0x0f000c18) -#define VR4131_PCIMAILREG (volatile unsigned int *)(CKSEG1 + 0x0f000c1c) -#define VR4131_BUSERRADREG (volatile unsigned int *)(CKSEG1 + 0x0f000c24) -#define VR4131_INTCNTSTAREG (volatile unsigned int *)(CKSEG1 + 0x0f000c28) -#define VR4131_PCIEXACCREG (volatile unsigned int *)(CKSEG1 + 0x0f000c2c) -#define VR4131_PCIRECONTREG (volatile unsigned int *)(CKSEG1 + 0x0f000c30) -#define VR4131_PCIENREG (volatile unsigned int *)(CKSEG1 + 0x0f000c34) -#define VR4131_PCICLKSELREG (volatile unsigned int *)(CKSEG1 + 0x0f000c38) -#define VR4131_PCITRDYREG (volatile unsigned int *)(CKSEG1 + 0x0f000c3c) -#define VR4131_PCICLKRUNREG (volatile unsigned int *)(CKSEG1 + 0x0f000c60) -#define VR4131_PCIHOSTCONFIG (volatile unsigned int *)(CKSEG1 + 0x0f000d00) -#define VR4131_VENDORIDREG (volatile unsigned int *)(CKSEG1 + 0x0f000d00) -#define VR4131_DEVICEIDREG (volatile unsigned int *)(CKSEG1 + 0x0f000d00) -#define VR4131_COMMANDREG (volatile unsigned int *)(CKSEG1 + 0x0f000d04) -#define VR4131_STATUSREG (volatile unsigned int *)(CKSEG1 + 0x0f000d04) -#define VR4131_REVREG (volatile unsigned int *)(CKSEG1 + 0x0f000d08) -#define VR4131_CLASSREG (volatile unsigned int *)(CKSEG1 + 0x0f000d08) -#define VR4131_CACHELSREG (volatile unsigned int *)(CKSEG1 + 0x0f000d0c) -#define VR4131_LATTIMERRG (volatile unsigned int *)(CKSEG1 + 0x0f000d0c) -#define VR4131_MAILBAREG (volatile unsigned int *)(CKSEG1 + 0x0f000d10) -#define VR4131_PCIMBA1REG (volatile unsigned int *)(CKSEG1 + 0x0f000d14) -#define VR4131_PCIMBA2REG (volatile unsigned int *)(CKSEG1 + 0x0f000d18) - -/*#define VR41XX_PCIIRQ_OFFSET (VR41XX_IRQ_MAX + 1) */ -/*#define VR41XX_PCIIRQ_MAX (VR41XX_IRQ_MAX + 12) */ -/*#define VR4122_PCI_HOST_BASE 0xa0000000 */ - -volatile unsigned int *pciconfigaddr; -volatile unsigned int *pciconfigdata; - -#define PCI_ACCESS_READ 0 -#define PCI_ACCESS_WRITE 1 - -/* - * Access PCI Configuration Register for VR4131 - */ - -static int vr4131_pci_config_access (u8 access_type, u32 dev, u32 reg, - u32 * data) -{ - u32 bus; - u32 device; - - bus = ((dev & 0xff0000) >> 16); - device = ((dev & 0xf800) >> 11); - - if (bus == 0) { - /* Type 0 Configuration */ - *VR4131_PCICONFAREG = (u32) (1UL << device | (reg & 0xfc)); - } else { - /* Type 1 Configuration */ - *VR4131_PCICONFAREG = (u32) (dev | ((reg / 4) << 2) | 1); - } - - if (access_type == PCI_ACCESS_WRITE) { - *VR4131_PCICONFDREG = *data; - } else { - *data = *VR4131_PCICONFDREG; - } - - return (0); -} - -static int vr4131_pci_read_config_byte (u32 hose, u32 dev, u32 reg, u8 * val) -{ - u32 data; - - if (vr4131_pci_config_access (PCI_ACCESS_READ, dev, reg, &data)) - return -1; - - *val = (data >> ((reg & 3) << 3)) & 0xff; - - return 0; -} - - -static int vr4131_pci_read_config_word (u32 hose, u32 dev, u32 reg, u16 * val) -{ - u32 data; - - if (reg & 1) - return -1; - - if (vr4131_pci_config_access (PCI_ACCESS_READ, dev, reg, &data)) - return -1; - - *val = (data >> ((reg & 3) << 3)) & 0xffff; - - return 0; -} - - -static int vr4131_pci_read_config_dword (u32 hose, u32 dev, u32 reg, - u32 * val) -{ - u32 data = 0; - - if (reg & 3) - return -1; - - if (vr4131_pci_config_access (PCI_ACCESS_READ, dev, reg, &data)) - return -1; - - *val = data; - - return (0); -} - -static int vr4131_pci_write_config_byte (u32 hose, u32 dev, u32 reg, u8 val) -{ - u32 data = 0; - - if (vr4131_pci_config_access (PCI_ACCESS_READ, dev, reg, &data)) - return -1; - - data = (data & ~(0xff << ((reg & 3) << 3))) | (val << - ((reg & 3) << 3)); - - if (vr4131_pci_config_access (PCI_ACCESS_WRITE, dev, reg, &data)) - return -1; - - return 0; -} - - -static int vr4131_pci_write_config_word (u32 hose, u32 dev, u32 reg, u16 val) -{ - u32 data = 0; - - if (reg & 1) - return -1; - - if (vr4131_pci_config_access (PCI_ACCESS_READ, dev, reg, &data)) - return -1; - - data = (data & ~(0xffff << ((reg & 3) << 3))) | (val << - ((reg & 3) << 3)); - - if (vr4131_pci_config_access (PCI_ACCESS_WRITE, dev, reg, &data)) - return -1; - - return 0; -} - -static int vr4131_pci_write_config_dword (u32 hose, u32 dev, u32 reg, u32 val) -{ - u32 data; - - if (reg & 3) { - return -1; - } - - data = val; - - if (vr4131_pci_config_access (PCI_ACCESS_WRITE, dev, reg, &data)) - return -1; - - return (0); -} - - -/* - * Initialize VR4131 PCIU - */ - -static void vr4131_pciu_init(void) -{ - /* PCI clock */ - *VR4131_PCICLKSELREG = 0x00000002; - - /* PCI memory and I/O space */ - *VR4131_PCIMMAW1REG = 0x100F9010; - *VR4131_PCIMMAW2REG = 0x140FD014; - *VR4131_PCIMIOAWREG = 0x160FD000; - - /* Target memory window */ - *VR4131_PCITAW1REG = 0x00081000; /* 64MB */ - *VR4131_PCITAW2REG = 0x00000000; - - *VR4131_MAILBAREG = 0UL; - *VR4131_PCIMBA1REG = 0UL; - - *VR4131_PCITRDYREG = 0x00008004; - - *VR4131_PCIENREG = 0x00000004; /* PCI enable */ - *VR4131_COMMANDREG = 0x02000007; -} - -/* - * Initialize Module - */ - -void init_vr4131_pci (struct pci_controller *hose) -{ - hose->first_busno = 0; - hose->last_busno = 0xff; - - vr4131_pciu_init (); /* Initialize VR4131 PCIU */ - - /* PCI memory space #1 */ - pci_set_region (hose->regions + 0, - 0x10000000, 0xb0000000, 0x04000000, PCI_REGION_MEM); - - /* PCI memory space #2 */ - pci_set_region (hose->regions + 1, - 0x14000000, 0xb4000000, 0x02000000, PCI_REGION_MEM); - - - /* PCI I/O space */ - pci_set_region (hose->regions + 2, - 0x16000000, 0xb6000000, 0x02000000, PCI_REGION_IO); - - /* System memory space */ - pci_set_region (hose->regions + 3, - 0x00000000, - 0x80000000, - 0x04000000, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - hose->region_count = 4; - - hose->read_byte = vr4131_pci_read_config_byte; - hose->read_word = vr4131_pci_read_config_word; - hose->read_dword = vr4131_pci_read_config_dword; - hose->write_byte = vr4131_pci_write_config_byte; - hose->write_word = vr4131_pci_write_config_word; - hose->write_dword = vr4131_pci_write_config_dword; - - pci_register_hose (hose); - - hose->last_busno = pci_hose_scan (hose); - - return; -} diff --git a/boards.cfg b/boards.cfg index a0a2bba..1e5b3e0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -331,7 +331,6 @@ M5485GFE m68k mcf547x_8x m548xevb freescale - M5485HFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO microblaze-generic microblaze microblaze microblaze-generic xilinx qemu_mips mips mips32 qemu-mips - - qemu-mips -tb0229 mips mips32 vct_platinum mips mips32 vct micronas - vct:VCT_PLATINUM vct_platinumavc mips mips32 vct micronas - vct:VCT_PLATINUMAVC vct_platinumavc_onenand mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 08e5a9e..4b5558d 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -11,9 +11,10 @@ easily if here is something they might want to dig for...
Board Arch CPU removed Commit last known maintainer/contact ============================================================================= -rmu powerpc MPC850 - 2011-12-07 Wolfgang Denk wd@denx.de -OXC powerpc MPC8240 - 2011-12-07 -BAB7xx powerpc MPC740/MPC750 - 2011-12-07 Frank Gottschling fgottschling@eltec.de +tb0229 mips mips32 - 2011-12-12 +rmu powerpc MPC850 fb82fd7 2011-12-07 Wolfgang Denk wd@denx.de +OXC powerpc MPC8240 309a292 2011-12-07 +BAB7xx powerpc MPC740/MPC750 c53043b 2011-12-07 Frank Gottschling fgottschling@eltec.de xm250 arm pxa c746cdd 2011-25-11 pleb2 arm pxa b185a1c 2011-25-11 cradle arm pxa 4e24f8a 2011-25-11 Kyle Harris kharris@nexus-tech.net
Dear Wolfgang Denk,
Applied, thanks.
Daniel Schwierzeck
