[U-Boot] [PATCH v2 31/35] dts: zynq: Add basic fdt support
This patch provides a basic fdt support for zynq u-boot.
zynq-7000.dtsi-> initial arch dts file zynq-zed.dts -> initial zed board dts file more devices should be added in subsequent patches.
u-boot build: once configuring of a board done for building dtb with zynq-zed.dts as an input zynq-uboot> make DEVICE_TREE=zynq-zed
Enabled CONFIG_OF_SEPARATE for building dtb separately. There is a new binary called u-boot-dtb.bin which is a u-boot with devicetree supported.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- V2: none
arch/arm/dts/zynq-7000.dtsi | 13 +++++++++++++ board/xilinx/dts/zynq-zed.dts | 14 ++++++++++++++ include/configs/zynq-common.h | 5 +++++ 3 files changed, 32 insertions(+) create mode 100644 arch/arm/dts/zynq-7000.dtsi create mode 100644 board/xilinx/dts/zynq-zed.dts
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi new file mode 100644 index 0000000..f20b8bd --- /dev/null +++ b/arch/arm/dts/zynq-7000.dtsi @@ -0,0 +1,13 @@ +/* + * Xilinx Zynq 7000 DTSI + * Describes the hardware common to all Zynq 7000-based boards. + * + * Copyright (C) 2013 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/include/ "skeleton.dtsi" + +/ { + compatible = "xlnx,zynq-7000"; +}; diff --git a/board/xilinx/dts/zynq-zed.dts b/board/xilinx/dts/zynq-zed.dts new file mode 100644 index 0000000..91a5deb --- /dev/null +++ b/board/xilinx/dts/zynq-zed.dts @@ -0,0 +1,14 @@ +/* + * Xilinx ZED board DTS + * + * Copyright (C) 2013 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/dts-v1/; +#include "zynq-7000.dtsi" + +/ { + model = "Zynq ZED Board"; + compatible = "xlnx,zynq-zed", "xlnx,zynq-7000"; +}; diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 6e2b062..c7e9b76 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -244,6 +244,11 @@ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */
+/* FDT support */ +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE +#define CONFIG_DISPLAY_BOARDINFO_LATE + /* Boot FreeBSD/vxWorks from an ELF image */ #if defined(CONFIG_ZYNQ_BOOT_FREEBSD) # define CONFIG_API
