[U-Boot] [PATCH] cmd: mmc: Make Mode: printout consistent
The "Mode :" line is the only one in "mmc info" output that has a space in front of the colon. Drop the space to make it consistent with the rest of the output, e.g.:
=> mmc dev 1 ; mmc info switch to partitions #0, OK mmc1 is current device Device: sd@ee160000 Manufacturer ID: 3 OEM: 5344 Name: SL08G Bus Speed: 50000000 Mode : SD High Speed (50MHz) ^------------------------------ Remove this space Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 7.4 GiB Bus Width: 1-bit Erase Group Size: 512 Bytes
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Jaehoon Chung jh80.chung@samsung.com CC: Tom Rini trini@konsulko.com --- cmd/mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/mmc.c b/cmd/mmc.c index 8bc3648193..6f3cb85cc0 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -26,7 +26,7 @@ static void print_mmcinfo(struct mmc *mmc)
printf("Bus Speed: %d\n", mmc->clock); #if CONFIG_IS_ENABLED(MMC_VERBOSE) - printf("Mode : %s\n", mmc_mode_name(mmc->selected_mode)); + printf("Mode: %s\n", mmc_mode_name(mmc->selected_mode)); mmc_dump_capabilities("card capabilities", mmc->card_caps); mmc_dump_capabilities("host capabilities", mmc->host_caps); #endif
