[U-Boot-Users] [PATCH] Fix offset calculation for multi-type legacy images.
Calculation of tail was incorrect when size % 4 == 0.
New code removes the conditional and does the same thing but with arithmetic
Signed-off-by: Nick Spence nick.spence@freescale.com ---
The minimum change is to re-insert the original check:
if ((uimage_to_cpu (size[i]) % 4) != 0) tail += (4 - uimage_to_cpu (size[i]) % 4);
or a variation on this.
The proposed patch cleans up the code a little further by removing the condition entirely and achieving the same rounding-up effect a little more cleanly and clearly.
common/image.c | 13 ++++--------- 1 files changed, 4 insertions(+), 9 deletions(-)
diff --git a/common/image.c b/common/image.c index f7faf50..9e9e023 100644 --- a/common/image.c +++ b/common/image.c @@ -23,7 +23,6 @@ * MA 02111-1307 USA */
- #ifndef USE_HOSTCC #include <common.h> #include <watchdog.h> @@ -242,7 +241,7 @@ void image_multi_getimg (image_header_t *hdr, ulong idx, { int i; uint32_t *size; - ulong offset, tail, count, img_data; + ulong offset, count, img_data;
/* get number of component */ count = image_multi_count (hdr); @@ -258,19 +257,15 @@ void image_multi_getimg (image_header_t *hdr, ulong idx, if (idx < count) { *len = uimage_to_cpu (size[idx]); offset = 0; - tail = 0;
/* go over all indices preceding requested component idx */ for (i = 0; i < idx; i++) { - /* add up i-th component size */ - offset += uimage_to_cpu (size[i]); - - /* add up alignment for i-th component */ - tail += (4 - uimage_to_cpu (size[i]) % 4); + /* add up i-th component size, rounding up to 4 bytes */ + offset += (uimage_to_cpu (size[i]) + 3) & ~3 ; }
/* calculate idx-th component data address */ - *data = img_data + offset + tail; + *data = img_data + offset; } else { *len = 0; *data = 0;
Applied, thanks.
Nick Spence
