[PATCH] board: xilinx: Remove conditional check for Microblaze
U-Boot is not picking boot.scr script address from device tree rather it's using default address for Microblaze platform, and it's picking for other platforms. Remove conditional check for Microblaze platform, so that u-boot pick up boot.scr script address for all platforms from device tree.
Signed-off-by: Padmarao Begari padmarao.begari@amd.com --- board/xilinx/common/board.c | 39 +++++++++++++++++-------------------- 1 file changed, 18 insertions(+), 21 deletions(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 0b43407b9e..a217b39df6 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -426,28 +426,25 @@ int board_late_init_xilinx(void) struct xilinx_board_description *desc; phys_size_t bootm_size = gd->ram_top - gd->ram_base; u64 bootscr_flash_offset, bootscr_flash_size; - - if (!IS_ENABLED(CONFIG_MICROBLAZE)) { - ulong scriptaddr; - u64 bootscr_address; - u64 bootscr_offset; - - /* Fetch bootscr_address/bootscr_offset from DT and update */ - if (!ofnode_read_bootscript_address(&bootscr_address, - &bootscr_offset)) { - if (bootscr_offset) - ret |= env_set_hex("scriptaddr", - gd->ram_base + - bootscr_offset); - else - ret |= env_set_hex("scriptaddr", - bootscr_address); - } else { - /* Update scriptaddr(bootscr offset) from env */ - scriptaddr = env_get_hex("scriptaddr", 0); + ulong scriptaddr; + u64 bootscr_address; + u64 bootscr_offset; + + /* Fetch bootscr_address/bootscr_offset from DT and update */ + if (!ofnode_read_bootscript_address(&bootscr_address, + &bootscr_offset)) { + if (bootscr_offset) ret |= env_set_hex("scriptaddr", - gd->ram_base + scriptaddr); - } + gd->ram_base + + bootscr_offset); + else + ret |= env_set_hex("scriptaddr", + bootscr_address); + } else { + /* Update scriptaddr(bootscr offset) from env */ + scriptaddr = env_get_hex("scriptaddr", 0); + ret |= env_set_hex("scriptaddr", + gd->ram_base + scriptaddr); }
if (!ofnode_read_bootscript_flash(&bootscr_flash_offset,
ulong scriptaddr;
u64 bootscr_offset;
&bootscr_offset)) {
if (bootscr_offset)
gd->ram_base +
bootscr_offset);
else
bootscr_address);
} else {
- ulong scriptaddr;
&bootscr_offset)) {
gd->ram_base +
bootscr_offset);
else
bootscr_address);
} else {
Applied. M
Michal Simek
Padmarao Begari
