[PATCH] dtoc: add coverage test for unicode error
Add an additional test to dtoc in order improve the coverage, specifically to take into account the case of unicode error when scanning drivers.
Signed-off-by: Walter Lozano walter.lozano@collabora.com ---
tools/dtoc/dtb_platdata.py | 14 +++++++++++--- tools/dtoc/test_dtoc.py | 18 ++++++++++++++++++ 2 files changed, 29 insertions(+), 3 deletions(-)
diff --git a/tools/dtoc/dtb_platdata.py b/tools/dtoc/dtb_platdata.py index c28768f4a2..c37db5b86e 100644 --- a/tools/dtoc/dtb_platdata.py +++ b/tools/dtoc/dtb_platdata.py @@ -145,8 +145,10 @@ class DtbPlatdata(object): U_BOOT_DRIVER_ALIAS(driver_alias, driver_name) value: Driver name declared with U_BOOT_DRIVER(driver_name) _links: List of links to be included in dm_populate_phandle_data() + _drivers_additional: List of additional drivers to use during scanning """ - def __init__(self, dtb_fname, include_disabled, warning_disabled): + def __init__(self, dtb_fname, include_disabled, warning_disabled, + drivers_additional=[]): self._fdt = None self._dtb_fname = dtb_fname self._valid_nodes = None @@ -157,6 +159,7 @@ class DtbPlatdata(object): self._drivers = [] self._driver_aliases = {} self._links = [] + self._drivers_additional = drivers_additional
def get_normalized_compat_name(self, node): """Get a node's normalized compat name @@ -338,6 +341,10 @@ class DtbPlatdata(object): continue self.scan_driver(dirpath + '/' + fn)
+ for fn in self._drivers_additional: + print('Checking %s/%s' % (basedir, fn)) + self.scan_driver(basedir + '/' + fn) + def scan_dtb(self): """Scan the device tree to obtain a tree of nodes and properties
@@ -654,7 +661,8 @@ class DtbPlatdata(object):
self.out(''.join(self.get_buf()))
-def run_steps(args, dtb_file, include_disabled, output, warning_disabled=False): +def run_steps(args, dtb_file, include_disabled, output, warning_disabled=False, + drivers_additional=[]): """Run all the steps of the dtoc tool
Args: @@ -666,7 +674,7 @@ def run_steps(args, dtb_file, include_disabled, output, warning_disabled=False): if not args: raise ValueError('Please specify a command: struct, platdata')
- plat = DtbPlatdata(dtb_file, include_disabled, warning_disabled) + plat = DtbPlatdata(dtb_file, include_disabled, warning_disabled, drivers_additional) plat.scan_drivers() plat.scan_dtb() plat.scan_tree() diff --git a/tools/dtoc/test_dtoc.py b/tools/dtoc/test_dtoc.py index 169ecd6e6e..d750e52a34 100755 --- a/tools/dtoc/test_dtoc.py +++ b/tools/dtoc/test_dtoc.py @@ -13,6 +13,7 @@ import collections import os import struct import sys +import tempfile import unittest
from dtoc import dtb_platdata @@ -829,3 +830,20 @@ U_BOOT_DEVICE(spl_test2) = { self.run_test(['invalid-cmd'], dtb_file, output) self.assertIn("Unknown command 'invalid-cmd': (use: struct, platdata)", str(e.exception)) + + def testUnicodeError(self): + """Test running dtoc with an invalid unicode file + + To be able to perform this tests without adding a weird text file which + would produce issues when using checkpatch.pl or patman, generate the + file at runtime and then process it. + """ + dtb_file = get_dtb_file('dtoc_test_simple.dts') + output = tools.GetOutputFilename('output') + driver_fn = '/tmp/' + next(tempfile._get_candidate_names()) + with open(driver_fn, 'wb+') as df: + df.write(b'\x81') + + with test_util.capture_sys_output() as (stdout, stderr): + dtb_platdata.run_steps(['struct'], dtb_file, False, output, True, + ['tools/dtoc/dtoc_test_unicode_error.cxx'])
Hi Walter,
On Mon, 20 Jul 2020 at 12:29, Walter Lozano walter.lozano@collabora.com wrote:
This seems to be missing a .cxx file, so gives a build error.
Regards, Simo
Hi Simon,
On 27/7/20 20:35, Simon Glass wrote:
Hi Walter,
Sorry for the error. I'm sending a new version with some additional improvements.
Regards,
Walter
Walter Lozano
