[PATCH 1/2] hush: Remove default CONFIG_SYS_PROMPT_HUSH_PS2 setting from board files
There is no reason to define default option for this macro which is already done in common/cli_hush.c.
87 #ifndef CONFIG_SYS_PROMPT_HUSH_PS2 88 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " 89 #endif
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
see previous patches:
http://patchwork.ozlabs.org/project/uboot/patch/11b23b65581253f10905bcefc923... https://lists.denx.de/pipermail/u-boot/2012-June/126510.html
include/configs/apalis-imx8.h | 1 - include/configs/colibri-imx8x.h | 1 - include/configs/imx8mm_beacon.h | 1 - include/configs/imx8mm_evk.h | 1 - include/configs/imx8mn_evk.h | 1 - include/configs/imx8mp_evk.h | 1 - include/configs/imx8mq_evk.h | 1 - include/configs/imx8mq_phanbell.h | 1 - include/configs/s5p4418_nanopi2.h | 4 ---- include/configs/verdin-imx8mm.h | 1 - include/configs/xenguest_arm64.h | 1 - 11 files changed, 14 deletions(-)
diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index db4e9011c0..b474b2f522 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -98,7 +98,6 @@ #define PHYS_SDRAM_2_SIZE SZ_2G /* 2 GB */
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index 29a37ed44f..fc2c191594 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -132,7 +132,6 @@ #define PHYS_SDRAM_2_SIZE 0x00000000 /* 0 GB */
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 3c9541187f..9a93dba1c5 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -119,7 +119,6 @@ #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 83521ad401..92eb85553e 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -120,7 +120,6 @@ #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index a6333085fe..cda8fc2ef7 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -124,7 +124,6 @@ #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 8253c6aa2f..92091dfd6b 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -135,7 +135,6 @@ #define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE 2048 #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 3f9a3bc100..96bfff749c 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -175,7 +175,6 @@ /* Monitor Command Prompt */ #undef CONFIG_SYS_PROMPT #define CONFIG_SYS_PROMPT "u-boot=> " -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index e8b65a4ba5..66c2c3a8d8 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -169,7 +169,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE_ADDR
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/s5p4418_nanopi2.h b/include/configs/s5p4418_nanopi2.h index 6dd1f3bc04..1e2180b970 100644 --- a/include/configs/s5p4418_nanopi2.h +++ b/include/configs/s5p4418_nanopi2.h @@ -102,10 +102,6 @@ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#ifdef CONFIG_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#endif - /*----------------------------------------------------------------------- * Etc Command definition */ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index fd8405433d..4751bf5a5a 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -98,7 +98,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE_ADDR
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE diff --git a/include/configs/xenguest_arm64.h b/include/configs/xenguest_arm64.h index c44381e966..d76ce13d14 100644 --- a/include/configs/xenguest_arm64.h +++ b/include/configs/xenguest_arm64.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_MALLOC_LEN (32 * 1024 * 1024)
Move CONFIG_SYS_PROMPT_HUSH_PS2 in Kconfig, depending on CONFIG_HUSH_PARSER, and remove the default value defined in cli_hush.c under __U_BOOT__.
README | 7 ------- cmd/Kconfig | 9 +++++++++ common/cli_hush.c | 3 --- scripts/config_whitelist.txt | 1 - 4 files changed, 9 insertions(+), 11 deletions(-)
diff --git a/README b/README index df824b67e7..8338e5ec21 100644 --- a/README +++ b/README @@ -1927,13 +1927,6 @@ The following options need to be configured: try longer timeout such as #define CONFIG_NFS_TIMEOUT 10000UL
-- Command Interpreter: - CONFIG_SYS_PROMPT_HUSH_PS2 - - This defines the secondary prompt string, which is - printed when the command interpreter needs more input - to complete a command. Usually "> ". - Note:
In the current implementation, the local variables diff --git a/cmd/Kconfig b/cmd/Kconfig index a3166e4f31..2c427d77b8 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -55,6 +55,15 @@ config SYS_PROMPT This string is displayed in the command line to the left of the cursor.
+config SYS_PROMPT_HUSH_PS2 + string "Hush shell secondary prompt" + depends on HUSH_PARSER + default "> " + help + This defines the secondary prompt string, which is + printed when the command interpreter needs more input + to complete a command. Usually "> ". + config SYS_XTRACE string "Command execution tracer" depends on CMDLINE diff --git a/common/cli_hush.c b/common/cli_hush.c index 5b1f119074..79664aad58 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -84,9 +84,6 @@ #include <cli.h> #include <cli_hush.h> #include <command.h> /* find_cmd */ -#ifndef CONFIG_SYS_PROMPT_HUSH_PS2 -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#endif #endif #ifndef __U_BOOT__ #include <ctype.h> /* isalpha, isdigit */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index dc4f0b050c..7b5093fbfd 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3512,7 +3512,6 @@ CONFIG_SYS_POST_WATCHDOG CONFIG_SYS_POST_WORD_ADDR CONFIG_SYS_PPC_DDR_WIMGE CONFIG_SYS_PQSPAR -CONFIG_SYS_PROMPT_HUSH_PS2 CONFIG_SYS_PSDPAR CONFIG_SYS_PSSR_VAL CONFIG_SYS_PTCPAR
On Mon, 26 Oct 2020 at 02:31, Patrick Delaunay patrick.delaunay@st.com wrote:
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Reviewed-by: Simon Glass sjg@chromium.org
For the Xen bits:
Acked-by: Oleksandr Andrushchenko oleksandr_andrushchenko@epam.com
Thank you,
Oleksandr
https://urldefense.com/v3/__http://patchwork.ozlabs.org/project/uboot/patch/... [patchwork[.]ozlabs[.]org] https://urldefense.com/v3/__https://lists.denx.de/pipermail/u-boot/2012-June... [lists[.]denx[.]de]
- Etc Command definition
Patrick Delaunay
