[U-Boot] [PATCH 1/2] efikamx: refine USB support
Because of the way USB pad settings are handled it doesn't make sense to be able to build the Efika MX board support without CONFIG_CMD_USB turned on. So, we change the build to always compile in USB support.
We do not need to check for CONFIG_CMD_USB like we do with CONFIG_MXC_SPI since the USB subsystem will error out of the compile for us.
Additionally, the following behaviors have changed;
* Smartbook "preboot" should not set input and output to USB keyboard as there is no display support * board_eth_init is implemented such that it does not cause U-Boot to report an explicit failure ("CPU Net Initialization Failed").
Since Ethernet is implemented via USB (fixed on Smarttop, pluggable on Smartbook, and handled by "usb start") - the warning that is left ("No ethernet found") is perfectly reasonable at the point it is printed since the USB system hasn't been started and nothing has been probed yet.
Signed-off-by: Matt Sealey matt@genesi-usa.com Cc: Stefano Babic sbabic@denx.de Cc: Marek Vasut marex@denx.de --- board/genesi/mx51_efikamx/Makefile | 6 +----- board/genesi/mx51_efikamx/efikamx-usb.c | 12 ++++++++++++ board/genesi/mx51_efikamx/efikamx.c | 3 --- 3 files changed, 13 insertions(+), 8 deletions(-)
diff --git a/board/genesi/mx51_efikamx/Makefile b/board/genesi/mx51_efikamx/Makefile index bd2174f..f95356f 100644 --- a/board/genesi/mx51_efikamx/Makefile +++ b/board/genesi/mx51_efikamx/Makefile @@ -27,11 +27,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS := efikamx.o - -ifdef CONFIG_CMD_USB -COBJS += efikamx-usb.o -endif +COBJS := efikamx.o efikamx-usb.o
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/genesi/mx51_efikamx/efikamx-usb.c b/board/genesi/mx51_efikamx/efikamx-usb.c index abd358a..ae6d1be 100644 --- a/board/genesi/mx51_efikamx/efikamx-usb.c +++ b/board/genesi/mx51_efikamx/efikamx-usb.c @@ -201,3 +201,15 @@ void board_ehci_hcd_postinit(struct usb_ehci *ehci, int port) IMX_GPIO_NR(2, 20)); } } + +/* + * Ethernet on the Smarttop is on the USB bus. Rather than give an error about + * "CPU Net Initialization Failed", just pass this test since no other settings + * are required. Smartbook doesn't have built-in Ethernet but we will let it + * pass anyway considering someone may have plugged in a USB stick and all + * they need to do is run "usb start". + */ +int board_eth_init(bd_t *bis) +{ + return 0; +} diff --git a/board/genesi/mx51_efikamx/efikamx.c b/board/genesi/mx51_efikamx/efikamx.c index b9064fb..d9c499d 100644 --- a/board/genesi/mx51_efikamx/efikamx.c +++ b/board/genesi/mx51_efikamx/efikamx.c @@ -484,9 +484,6 @@ int board_late_init(void) imx_iomux_v3_setup_multiple_pads(efikamx_pata_pads, ARRAY_SIZE(efikamx_pata_pads)); efikamx_usb_setup_pads();
- if (machine_is_efikasb()) - setenv("preboot", "usb reset ; setenv stdin usbkbd\0"); - return 0; }
Rewrite and refine the configuration for the Efika MX to support the board features effectively.
In summary:
* Reorder configuration so it is more readable * Bring the configuration up to a production-compatible boot process by implementing scanning of bootable partitions on MMC and ATA media, and the environment required to support this. * Refine configuration settings to save space and disable arguably unused features like gzip support (not required for booting). * Add CONFIG_EFI_PARTITION, CONFIG_OF_FDT and CONFIG_CMD_BOOTZ support. * Refine memtest ranges * Remove SPI flash environment saving since modifying the environment can stop boot, and in any case can be modified or supplemented from any supported boot media via the "boot.scr" script or through the serial console each boot. * USB default to port 0 which is the Smarttop USBDR port (Ethernet) * Make CONFIG_CMD_NET 'depend' on CONFIG_CMD_USB (CONFIG_CMD_USB is not currently optional, though, but it makes more sense this way) * Remove CONFIG_PREBOOT and CONFIG_USB_KEYBOARD
Requires the patch "Add U_BOOT_TIMESTAMP definition."
Signed-off-by: Matt Sealey matt@genesi-usa.com Cc: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- include/configs/mx51_efikamx.h | 486 ++++++++++++++++++++++++---------------- 1 file changed, 291 insertions(+), 195 deletions(-)
diff --git a/include/configs/mx51_efikamx.h b/include/configs/mx51_efikamx.h index 143b0f0..449f61b 100644 --- a/include/configs/mx51_efikamx.h +++ b/include/configs/mx51_efikamx.h @@ -1,9 +1,11 @@ /* * Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de + * Copyright (C) 2009 Freescale Semiconductor, Inc. + * Copyright (C) 2009 Pegatron Corporation + * Copyright (C) 2009-2012, Genesi USA, Inc. * - * (C) Copyright 2009 Freescale Semiconductor, Inc. - * - * Configuration settings for the MX51EVK Board + * Configuration settings for the Genesi Efika MX Smarttop & Smartbook + * based on MX51EVK settings * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -25,250 +27,344 @@ #define __CONFIG_H
#include <config_cmd_default.h> +#include <timestamp.h>
/* - * High Level Board Configuration Options + * U-Boot on the Efika MX is limited in some ways to a 256KiB binary (assuming + * we stick with the config in the legacy kernels which gives U-Boot a 256KiB + * MTD partition). With a lot of boot device support and full system configuration + * we manage to break this limit with some toolchains or miscellaneous settings, + * so we do some damage limitation by making sure the build is as fine-tuned as + * possible. + * + * We don't support compressing scripts, kernels, ramdisks or device trees + * because Linux will decompress itself at runtime, ramdisks stay compressed, + * scripts and device trees have minimal space saving anyway. Therefore we + * don't need zlib, gzip etc. + * + * We also don't really care about NetBSD or RTEMS, PCMCIA or weirder load + * methods right now which saves a little more space. */ -/* An i.MX51 CPU */ -#define CONFIG_MX51 +#undef CONFIG_ZLIB +#undef CONFIG_GZIP +#undef CONFIG_BOOTM_NETBSD +#undef CONFIG_BOOTM_RTEMS +#undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_PCMCIA +#undef CONFIG_PCMCIA +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADY +#undef CONFIG_CMD_IMLS
-#define machine_is_efikamx() (CONFIG_MACH_TYPE == MACH_TYPE_MX51_EFIKAMX) -#define machine_is_efikasb() (CONFIG_MACH_TYPE == MACH_TYPE_MX51_EFIKASB) +/* + * We will need to undefine this to save even more space if we break the 256KiB + * limit.. but for now we just squeak in and it would be nicer to users if + * space was optimized elsewhere first. + */ +#define CONFIG_SYS_LONGHELP
-#include <asm/arch/imx-regs.h> +/* + * We want to explicitly enable these in case they're not. + */ +#define CONFIG_CMD_DATE +#define CONFIG_CMD_CACHE +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ
+#define CONFIG_MX51 #define CONFIG_SYS_MX5_HCLK 24000000 #define CONFIG_SYS_MX5_CLK32 32768 #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
-#define CONFIG_SYS_TEXT_BASE 0x97800000 +#define machine_is_efikamx() (CONFIG_MACH_TYPE == MACH_TYPE_MX51_EFIKAMX) +#define machine_is_efikasb() (CONFIG_MACH_TYPE == MACH_TYPE_MX51_EFIKASB) + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_REVISION_TAG + +#define CONFIG_MXC_GPIO
-#define CONFIG_L2_OFF -#define CONFIG_SYS_ICACHE_OFF -#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200
/* - * Bootloader Components Configuration + * Genesi do not support saving the U-Boot environment at runtime. If you + * need new environment, write a boot.scr that changes the variables before + * you boot. This reduces the amount of odd behavior possible from misconfigured + * U-Boots, corrupted SPI NOR, since every boot it will always be reset to the + * compiled-in configuration. + */ +#define CONFIG_ENV_IS_NOWHERE + +/* + * SPI is essential in that the PMIC needs some setup and we wholeheartedly + * support the need to update U-Boot from within U-Boot (see above). */ #define CONFIG_CMD_SPI -#define CONFIG_CMD_SF +#ifdef CONFIG_CMD_SPI +# define CONFIG_HARD_SPI +# define CONFIG_MXC_SPI +# define CONFIG_DEFAULT_SPI_BUS 1 +# define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH) + +# define CONFIG_CMD_SF +# ifdef CONFIG_CMD_SF +# define CONFIG_SPI_FLASH +# define CONFIG_SPI_FLASH_SST +# define CONFIG_SF_DEFAULT_CS (1 | IMX_GPIO_NR(4, 25) << 8) +# define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) +# define CONFIG_SF_DEFAULT_SPEED 25000000 +# define CONFIG_SYS_NO_FLASH +# endif /* CONFIG_CMD_SF */ + +# define CONFIG_PMIC +# define CONFIG_PMIC_SPI +# define CONFIG_PMIC_FSL +# define CONFIG_FSL_PMIC_BUS 0 +# define CONFIG_FSL_PMIC_CS (0 | IMX_GPIO_NR(4, 24) << 8) +# define CONFIG_FSL_PMIC_CLK 25000000 +# define CONFIG_FSL_PMIC_MODE (SPI_MODE_0 | SPI_CS_HIGH) +# define CONFIG_FSL_PMIC_BITLEN 32 +# define CONFIG_RTC_MC13XXX +#endif /* CONFIG_CMD_SPI */ + #define CONFIG_CMD_MMC -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 +#ifdef CONFIG_CMD_MMC +# define CONFIG_MMC +# define CONFIG_GENERIC_MMC +# define CONFIG_FSL_ESDHC +# define CONFIG_SYS_FSL_ESDHC_ADDR 0 +# define CONFIG_SYS_FSL_ESDHC_NUM 2 +#endif /* CONFIG_CMD_MMC */ + #define CONFIG_CMD_IDE -#define CONFIG_CMD_NET -#define CONFIG_CMD_DATE -#undef CONFIG_CMD_IMLS +#ifdef CONFIG_CMD_IDE +# define CONFIG_LBA48 +# undef CONFIG_IDE_RESET +# undef CONFIG_IDE_LED +# define CONFIG_MX51_PATA + +# define __io + +# define CONFIG_SYS_IDE_MAXBUS 1 +# define CONFIG_SYS_IDE_MAXDEVICE 1 +# define CONFIG_SYS_ATA_BASE_ADDR 0x83fe0000 +# define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 +# define CONFIG_SYS_ATA_DATA_OFFSET 0xa0 +# define CONFIG_SYS_ATA_REG_OFFSET 0xa0 +# define CONFIG_SYS_ATA_ALT_OFFSET 0xd8 +# define CONFIG_SYS_ATA_STRIDE 4 + +# define CONFIG_IDE_PREINIT +# define CONFIG_MXC_ATA_PIO_MODE 4 +# define CONFIG_SYS_PIO_MODE 4 +#endif /* CONFIG_CMD_IDE */
+#define CONFIG_CMD_USB +#ifdef CONFIG_CMD_USB +# define CONFIG_USB_EHCI /* Enable EHCI USB support */ +# define CONFIG_USB_EHCI_MX5 +# define CONFIG_USB_ULPI +# define CONFIG_USB_ULPI_VIEWPORT +# define CONFIG_USB_STORAGE +# undef CONFIG_USB_KEYBOARD /* - * Environmental settings + * USB port numbers: DR=0, H1=1, H2=2 + * + * This could be modified to know the difference between + * Smarttop and Smartbook */ - -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) -#define CONFIG_ENV_SECT_SIZE (1 * 64 * 1024) -#define CONFIG_ENV_SIZE (4 * 1024) - +# define CONFIG_MXC_USB_PORT 0 +# if (CONFIG_MXC_USB_PORT == 0) +# define CONFIG_MXC_USB_PORTSC (1 << 28) +# define CONFIG_MXC_USB_FLAGS MXC_EHCI_INTERNAL_PHY +# else /* USBH1 or USBH2 */ +# define CONFIG_MXC_USB_PORTSC (2 << 30) +# define CONFIG_MXC_USB_FLAGS 0 +# endif /* (CONFIG_MXC_USB_PORT == 0) */ /* - * ATAG setup + * Networking kind of depends on USB for the Efika MX, so we put + * the network configuration in here for readability's sake. */ -#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ -#define CONFIG_REVISION_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG +# define CONFIG_CMD_NET +# ifdef CONFIG_CMD_NET +# define CONFIG_USB_HOST_ETHER +# define CONFIG_USB_ETHER_ASIX /* Efika MX Smarttop built-in */ +# define CONFIG_USB_ETHER_SMSC95XX +# define CONFIG_CMD_PING +# define CONFIG_CMD_DHCP +# define CONFIG_CMD_NFS +# endif /* CONFIG_CMD_NET */ + +# define CONFIG_EHCI_IS_TDI +# define CONFIG_USB_HOST_ETHER +# define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP +#endif /* CONFIG_CMD_USB */
-#define CONFIG_OF_LIBFDT 1 +#if defined(CONFIG_CMD_IDE) || defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) +# define CONFIG_DOS_PARTITION +# define CONFIG_EFI_PARTITION +# define CONFIG_CMD_FAT +# define CONFIG_CMD_EXT2 +#endif /* CONFIG_CMD_IDE || CONFIG_CMD_USB || CONFIG_CMD_MMC */
-/* - * Size of malloc() pool +/*----------------------------------------------------------------------- + * Physical Memory Map */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CSD0_BASE_ADDR +#define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024)
-#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_BOARD_LATE_INIT +#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) +#define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE)
-/* - * Hardware drivers - */ -#define CONFIG_MXC_UART -#define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-#define CONFIG_MXC_GPIO +#define CONFIG_SYS_DDR_CLKSEL 0 +#define CONFIG_SYS_CLKTL_CBCDR 0x59E35145
/* - * SPI Interface + * ENVIRONMENT + * + * layout of load addresses; + * 0x90000000 = START OF MEMORY + * 0x90007FC0 = load address for uImage (32704 bytes from start) + * Yes, this is a curious address, designed to compensate for the + * kernel load address encoded in the uImage we have to load + * it at 0x90008000 minus the 64 bytes for the original uImage + * header to put the first instruction at the right address. + * We have 10453056 (10MiB-32704) bytes to store a kernel + * 0x90A00000 = boot script address (boot.scr), 65536 bytes reserved + * 0x90A10000 = device tree address (board.dtb), 65536 bytes reserved + * 0x90A20000 = ramdisk address */ -#ifdef CONFIG_CMD_SPI
-#define CONFIG_HARD_SPI -#define CONFIG_MXC_SPI -#define CONFIG_DEFAULT_SPI_BUS 1 -#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH) - -/* SPI FLASH */ -#ifdef CONFIG_CMD_SF - -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_SST -#define CONFIG_SF_DEFAULT_CS (1 | 121 << 8) -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) -#define CONFIG_SF_DEFAULT_SPEED 25000000 - -#define CONFIG_ENV_SPI_CS (1 | 121 << 8) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_MAX_HZ 25000000 -#define CONFIG_ENV_SPI_MODE (SPI_MODE_0) -#define CONFIG_FSL_ENV_IN_SF -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_SYS_NO_FLASH - -#else -#define CONFIG_ENV_IS_NOWHERE -#endif +#define CONFIG_KERNEL_ADDR 0x90007FC0 +#define CONFIG_LOADADDR CONFIG_KERNEL_ADDR +#define CONFIG_SCRIPT_ADDR 0x90A00000 +#define CONFIG_DT_ADDR 0x90A10000 +#define CONFIG_RD_ADDR 0x90A20000
-/* SPI PMIC */ -#define CONFIG_PMIC -#define CONFIG_PMIC_SPI -#define CONFIG_PMIC_FSL -#define CONFIG_FSL_PMIC_BUS 0 -#define CONFIG_FSL_PMIC_CS (0 | 120 << 8) -#define CONFIG_FSL_PMIC_CLK 25000000 -#define CONFIG_FSL_PMIC_MODE (SPI_MODE_0 | SPI_CS_HIGH) -#define CONFIG_FSL_PMIC_BITLEN 32 -#define CONFIG_RTC_MC13XXX -#endif +#define CONFIG_STACKSIZE (128 * 1024) +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
/* - * MMC Configs + * Ideally we would want the load address define to be different to the kernel + * address. This will allow errant scripting defaults to run (i.e. fatload filename) + * without trashing specially-defined memory areas as above. However, we have a + * legacy of users and Linux images to support, so we just suck it up and deal with it */ -#ifdef CONFIG_CMD_MMC -#define CONFIG_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_FSL_ESDHC -#define CONFIG_SYS_FSL_ESDHC_ADDR 0 -#define CONFIG_SYS_FSL_ESDHC_NUM 2 -#endif - +#define CONFIG_SYS_TEXT_BASE 0x97800000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_KERNEL_ADDR /* - * ATA/IDE + * Memory test range: from where ATAGs get put, to 64MiB above the ramdisk load + * address. If any of this range fails it's a good indicator of serious breakage */ -#ifdef CONFIG_CMD_IDE -#define CONFIG_LBA48 -#undef CONFIG_IDE_LED -#undef CONFIG_IDE_RESET - -#define CONFIG_MX51_PATA +#define CONFIG_SYS_MEMTEST_START 0x90000100 +#define CONFIG_SYS_MEMTEST_END 0x94A20000
-#define __io +#define CONFIG_BOOTDELAY 3
-#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 1 - -#define CONFIG_SYS_ATA_BASE_ADDR 0x83fe0000 -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 - -#define CONFIG_SYS_ATA_DATA_OFFSET 0xa0 -#define CONFIG_SYS_ATA_REG_OFFSET 0xa0 -#define CONFIG_SYS_ATA_ALT_OFFSET 0xd8 +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT
-#define CONFIG_SYS_ATA_STRIDE 4 +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "Efika MX> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#define CONFIG_IDE_PREINIT -#define CONFIG_MXC_ATA_PIO_MODE 4 -#endif +#define CONFIG_SYS_HZ 1000
/* - * USB + * Reproduce environment from production Efika MX systems */ -#define CONFIG_CMD_USB -#ifdef CONFIG_CMD_USB -#define CONFIG_USB_EHCI /* Enable EHCI USB support */ -#define CONFIG_USB_EHCI_MX5 -#define CONFIG_USB_ULPI -#define CONFIG_USB_ULPI_VIEWPORT -#define CONFIG_MXC_USB_PORT 1 -#if (CONFIG_MXC_USB_PORT == 0) -#define CONFIG_MXC_USB_PORTSC (1 << 28) -#define CONFIG_MXC_USB_FLAGS MXC_EHCI_INTERNAL_PHY -#else -#define CONFIG_MXC_USB_PORTSC (2 << 30) -#define CONFIG_MXC_USB_FLAGS 0 +#if (CONFIG_MACH_TYPE == MACH_TYPE_MX51_EFIKAMX) +# define CONFIG_EFIKAMX_MODEL "mx" +#elif (CONFIG_MACH_TYPE == MACH_TYPE_MX51_EFIKASB) +# define CONFIG_EFIAKMX_MODEL "sb" #endif -#define CONFIG_EHCI_IS_TDI -#define CONFIG_USB_STORAGE -#define CONFIG_USB_HOST_ETHER -#define CONFIG_USB_KEYBOARD -#define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP -#define CONFIG_PREBOOT -/* USB NET */ -#ifdef CONFIG_CMD_NET -#define CONFIG_USB_ETHER_ASIX -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#endif -#endif /* CONFIG_CMD_USB */
-/* - * Filesystems - */ -#ifdef CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#ifdef CONFIG_CMD_NET -#define CONFIG_CMD_NFS -#endif -#endif + +#define XADDR(a) #a +#define ADDR(a) XADDR(a) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "model=" CONFIG_EFIKAMX_MODEL "\0" \ + "firmware_version=" U_BOOT_TIMESTAMP "\0" \ + "script=boot.scr\0" \ + "kerneladdr=" ADDR(CONFIG_KERNEL_ADDR) "\0" \ + "scriptaddr=" ADDR(CONFIG_SCRIPT_ADDR) "\0" \ + "ramdiskaddr=" ADDR(CONFIG_RD_ADDR) "\0" \ + "dtbaddr=" ADDR(CONFIG_DT_ADDR) "\0" \ + "bootdevices=mmc ide usb\0" \ + "units=0\0" \ + "console=ttymxc0,115200n8\0" \ + "bootargs=console=${console}"
/* - * Miscellaneous configurable options + * Note: make sure the last EXTRA_ENV_SETTINGS item has no null terminator! */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_BOOTDELAY 3 -#define CONFIG_LOADADDR 0x90800000 - -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "Efika> " -#define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x90000000 -#define CONFIG_SYS_MEMTEST_END 0x90010000 - -#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR - -#define CONFIG_SYS_HZ 1000 -#define CONFIG_CMDLINE_EDITING
-/*----------------------------------------------------------------------- - * Stack sizes +/* + * Derived from the production-shipped U-Boot from Genesi, and updated to + * support new features. This is somewhat of a standard-in-progress for + * the Linaro Cross-Distro people and attempts to prove a working + * configuration while staying completely compatible with the old config. * - * The stack sizes are set up in start.S using the settings below - */ -#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ - -/*----------------------------------------------------------------------- - * Physical Memory Map + * Note: recommended SD card layout is 3 partitions, configured such that + * the first partition starts at the 1024 byte position on SD. This way an + * SD card can be created to boot U-Boot from SD (with correct DIP settings) + * by simply dd'ing to the first partition without creating strange environments + * with empty space. + * Second partition is /boot - and should be ext2 or ext3 so U-Boot can read it. + * Third partition is / in this case, and could be anything. + * + * However in the event you make a custom SD card with one partition formatted + * as ext2, or plug in a FAT-formatted USB stick on an otherwise empty system, + * it will all still work. We limit it to a single USB stick, but the default + * configuration above does not configure an external USB port right now. */ -#define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM_1 CSD0_BASE_ADDR -#define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024)
-#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) -#define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) -#define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE) - -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) - -#define CONFIG_SYS_DDR_CLKSEL 0 -#define CONFIG_SYS_CLKTL_CBCDR 0x59E35145 - -#endif +#define CONFIG_BOOTCOMMAND \ + "for device in ${bootdevices}; do " \ + "if test ${device} = "ide"; then " \ + "ide reset; setenv units "0"; " \ + "elif test ${device} = "mmc"; then " \ + "mmc rescan; setenv units "1 0"; " \ + "elif test ${device} = "usb"; then " \ + "usb start; setenv units "0"; " \ + "fi; " \ + "for unit in ${units}; do " \ + "${device} dev ${unit}; " \ + "for part in "1 2 3"; do " \ + "for fs in "ext2 fat"; do " \ + "setenv loadcmd "${fs}load ${device} ${unit}:${part}"; " \ + "if ${loadcmd} ${scriptaddr} ${script}; then " \ + "if imi ${scriptaddr}; then " \ + "source ${scriptaddr}; " \ + "fi; " \ + "fi; " \ + "done; " \ + "done; " \ + "done; " \ + "done; " + +#endif /* __CONFIG_H */
In summary:
- Reorder configuration so it is more readable
- Bring the configuration up to a production-compatible boot process by implementing scanning of bootable partitions on MMC and ATA media, and the environment required to support this.
- Refine configuration settings to save space and disable arguably unused features like gzip support (not required for booting).
- Add CONFIG_EFI_PARTITION, CONFIG_OF_FDT and CONFIG_CMD_BOOTZ support.
- Refine memtest ranges
- Remove SPI flash environment saving since modifying the environment can stop boot, and in any case can be modified or supplemented from any supported boot media via the "boot.scr" script or through the serial console each boot.
- USB default to port 0 which is the Smarttop USBDR port (Ethernet)
- Make CONFIG_CMD_NET 'depend' on CONFIG_CMD_USB (CONFIG_CMD_USB is not currently optional, though, but it makes more sense this way)
- Remove CONFIG_PREBOOT and CONFIG_USB_KEYBOARD
Matt,
there are no issue with this patch, but checkpatch reports errors. Can you fix them and resubmit, please ?
Regards, Stefano Babic
- Smartbook "preboot" should not set input and output to USB keyboard as there is no display support
- board_eth_init is implemented such that it does not cause U-Boot to report an explicit failure ("CPU Net Initialization Failed").
Applied (after rebasing) on u-boot-imx, thanks.
Best regards, Stefano Babic
Matt Sealey
Stefano Babic
