[U-Boot] [PATCH 3/5] x86: i8042: Clean up the driver
This commit cleans up the existing i8042 driver by: - Reorder those static function so that their declarations can be removed - Remove unused routines i8042_flush() and i8042_disable() - Remove unused CONFIG_USE_CPCIDVI wrapped codes - Remove __weak board_i8042_skip() - Rename CamelCase variables to conform U-Boot coding convention - Rename wait_until_kbd_output_full() to kbd_output_full() - Change to use macros for i8042 command and control register bits
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/input/i8042.c | 633 +++++++++++++++++++++----------------------------- include/i8042.h | 112 +++++---- 2 files changed, 317 insertions(+), 428 deletions(-)
diff --git a/drivers/input/i8042.c b/drivers/input/i8042.c index 3799580..3812733 100644 --- a/drivers/input/i8042.c +++ b/drivers/input/i8042.c @@ -10,49 +10,30 @@ /* includes */
#include <common.h> -#include <linux/compiler.h> - -#ifdef CONFIG_USE_CPCIDVI -extern u8 gt_cpcidvi_in8(u32 offset); -extern void gt_cpcidvi_out8(u32 offset, u8 data); - -#define in8(a) gt_cpcidvi_in8(a) -#define out8(a, b) gt_cpcidvi_out8(a, b) -#endif - +#include <asm/io.h> #include <i8042.h>
/* defines */ +#define in8(p) inb(p) +#define out8(p, v) outb(v, p)
#ifdef CONFIG_CONSOLE_CURSOR extern void console_cursor(int state); -static int blinkCount = CONFIG_SYS_CONSOLE_BLINK_COUNT; +static int blink_count = CONFIG_SYS_CONSOLE_BLINK_COUNT; static int cursor_state; #endif
/* locals */
-static int kbd_input = -1; /* no input yet */ -static int kbd_mapping = KBD_US; /* default US keyboard */ -static int kbd_flags = NORMAL; /* after reset */ -static int kbd_state; /* unshift code */ - -static void kbd_conv_char(unsigned char scan_code); -static void kbd_led_set(void); -static void kbd_normal(unsigned char scan_code); -static void kbd_shift(unsigned char scan_code); -static void kbd_ctrl(unsigned char scan_code); -static void kbd_num(unsigned char scan_code); -static void kbd_caps(unsigned char scan_code); -static void kbd_scroll(unsigned char scan_code); -static void kbd_alt(unsigned char scan_code); -static int kbd_input_empty(void); -static int kbd_reset(void); +static int kbd_input = -1; /* no input yet */ +static int kbd_mapping = KBD_US; /* default US keyboard */ +static int kbd_flags = NORMAL; /* after reset */ +static int kbd_state; /* unshift code */
static unsigned char kbd_fct_map[144] = { /* kbd_fct_map table for scan code */ - 0, AS, AS, AS, AS, AS, AS, AS, /* scan 0- 7 */ - AS, AS, AS, AS, AS, AS, AS, AS, /* scan 8- F */ + 0, AS, AS, AS, AS, AS, AS, AS, /* scan 00-07 */ + AS, AS, AS, AS, AS, AS, AS, AS, /* scan 08-0F */ AS, AS, AS, AS, AS, AS, AS, AS, /* scan 10-17 */ AS, AS, AS, AS, AS, CN, AS, AS, /* scan 18-1F */ AS, AS, AS, AS, AS, AS, AS, AS, /* scan 20-27 */ @@ -74,8 +55,8 @@ static unsigned char kbd_fct_map[144] = { static unsigned char kbd_key_map[2][5][144] = { { /* US keyboard */ { /* unshift code */ - 0, 0x1b, '1', '2', '3', '4', '5', '6', /* scan 0- 7 */ - '7', '8', '9', '0', '-', '=', 0x08, '\t', /* scan 8- F */ + 0, 0x1b, '1', '2', '3', '4', '5', '6', /* scan 00-07 */ + '7', '8', '9', '0', '-', '=', 0x08, '\t', /* scan 08-0F */ 'q', 'w', 'e', 'r', 't', 'y', 'u', 'i', /* scan 10-17 */ 'o', 'p', '[', ']', '\r', CN, 'a', 's', /* scan 18-1F */ 'd', 'f', 'g', 'h', 'j', 'k', 'l', ';', /* scan 20-27 */ @@ -94,8 +75,8 @@ static unsigned char kbd_key_map[2][5][144] = { 0, 'D', 'C', 0, 'B', 0, '@', 'P' /* extended */ }, { /* shift code */ - 0, 0x1b, '!', '@', '#', '$', '%', '^', /* scan 0- 7 */ - '&', '*', '(', ')', '_', '+', 0x08, '\t', /* scan 8- F */ + 0, 0x1b, '!', '@', '#', '$', '%', '^', /* scan 00-07 */ + '&', '*', '(', ')', '_', '+', 0x08, '\t', /* scan 08-0F */ 'Q', 'W', 'E', 'R', 'T', 'Y', 'U', 'I', /* scan 10-17 */ 'O', 'P', '{', '}', '\r', CN, 'A', 'S', /* scan 18-1F */ 'D', 'F', 'G', 'H', 'J', 'K', 'L', ':', /* scan 20-27 */ @@ -114,8 +95,8 @@ static unsigned char kbd_key_map[2][5][144] = { 0, 'D', 'C', 0, 'B', 0, '@', 'P' /* extended */ }, { /* control code */ - 0xff, 0x1b, 0xff, 0x00, 0xff, 0xff, 0xff, 0xff, /* scan 0- 7 */ - 0x1e, 0xff, 0xff, 0xff, 0x1f, 0xff, 0xff, '\t', /* scan 8- F */ + 0xff, 0x1b, 0xff, 0x00, 0xff, 0xff, 0xff, 0xff, /* scan 00-07 */ + 0x1e, 0xff, 0xff, 0xff, 0x1f, 0xff, 0xff, '\t', /* scan 08-0F */ 0x11, 0x17, 0x05, 0x12, 0x14, 0x19, 0x15, 0x09, /* scan 10-17 */ 0x0f, 0x10, 0x1b, 0x1d, '\r', CN, 0x01, 0x13, /* scan 18-1F */ 0x04, 0x06, 0x07, 0x08, 0x0a, 0x0b, 0x0c, 0xff, /* scan 20-27 */ @@ -134,8 +115,8 @@ static unsigned char kbd_key_map[2][5][144] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff /* extended */ }, { /* non numeric code */ - 0, 0x1b, '1', '2', '3', '4', '5', '6', /* scan 0- 7 */ - '7', '8', '9', '0', '-', '=', 0x08, '\t', /* scan 8- F */ + 0, 0x1b, '1', '2', '3', '4', '5', '6', /* scan 00-07 */ + '7', '8', '9', '0', '-', '=', 0x08, '\t', /* scan 08-0F */ 'q', 'w', 'e', 'r', 't', 'y', 'u', 'i', /* scan 10-17 */ 'o', 'p', '[', ']', '\r', CN, 'a', 's', /* scan 18-1F */ 'd', 'f', 'g', 'h', 'j', 'k', 'l', ';', /* scan 20-27 */ @@ -154,30 +135,30 @@ static unsigned char kbd_key_map[2][5][144] = { 0, 'D', 'C', 0, 'B', 0, '@', 'P' /* extended */ }, { /* right alt mode - not used in US keyboard */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 0 - 7 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 8 - F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 10 -17 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 18 -1F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 20 -27 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 28 -2F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 30 -37 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 38 -3F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 40 -47 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 48 -4F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 50 -57 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 58 -5F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 60 -67 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 68 -6F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 70 -77 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 78 -7F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 00-07 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 08-0F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 10-17 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 18-1F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 20-27 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 28-2F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 30-37 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 38-3F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 40-47 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 48-4F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 50-57 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 58-5F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 60-67 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 68-6F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 70-77 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 78-7F */ 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* extended */ 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff /* extended */ } }, - { /* german keyboard */ + { /* German keyboard */ { /* unshift code */ - 0, 0x1b, '1', '2', '3', '4', '5', '6', /* scan 0- 7 */ - '7', '8', '9', '0', 0xe1, ''', 0x08, '\t', /* scan 8- F */ + 0, 0x1b, '1', '2', '3', '4', '5', '6', /* scan 00-07 */ + '7', '8', '9', '0', 0xe1, ''', 0x08, '\t', /* scan 08-0F */ 'q', 'w', 'e', 'r', 't', 'z', 'u', 'i', /* scan 10-17 */ 'o', 'p', 0x81, '+', '\r', CN, 'a', 's', /* scan 18-1F */ 'd', 'f', 'g', 'h', 'j', 'k', 'l', 0x94, /* scan 20-27 */ @@ -196,8 +177,8 @@ static unsigned char kbd_key_map[2][5][144] = { 0, 'D', 'C', 0, 'B', 0, '@', 'P' /* extended */ }, { /* shift code */ - 0, 0x1b, '!', '"', 0x15, '$', '%', '&', /* scan 0- 7 */ - '/', '(', ')', '=', '?', '`', 0x08, '\t', /* scan 8- F */ + 0, 0x1b, '!', '"', 0x15, '$', '%', '&', /* scan 00-07 */ + '/', '(', ')', '=', '?', '`', 0x08, '\t', /* scan 08-0F */ 'Q', 'W', 'E', 'R', 'T', 'Z', 'U', 'I', /* scan 10-17 */ 'O', 'P', 0x9a, '*', '\r', CN, 'A', 'S', /* scan 18-1F */ 'D', 'F', 'G', 'H', 'J', 'K', 'L', 0x99, /* scan 20-27 */ @@ -216,8 +197,8 @@ static unsigned char kbd_key_map[2][5][144] = { 0, 'D', 'C', 0, 'B', 0, '@', 'P' /* extended */ }, { /* control code */ - 0xff, 0x1b, 0xff, 0x00, 0xff, 0xff, 0xff, 0xff, /* scan 0- 7 */ - 0x1e, 0xff, 0xff, 0xff, 0x1f, 0xff, 0xff, '\t', /* scan 8- F */ + 0xff, 0x1b, 0xff, 0x00, 0xff, 0xff, 0xff, 0xff, /* scan 00-07 */ + 0x1e, 0xff, 0xff, 0xff, 0x1f, 0xff, 0xff, '\t', /* scan 08-0F */ 0x11, 0x17, 0x05, 0x12, 0x14, 0x19, 0x15, 0x09, /* scan 10-17 */ 0x0f, 0x10, 0x1b, 0x1d, '\r', CN, 0x01, 0x13, /* scan 18-1F */ 0x04, 0x06, 0x07, 0x08, 0x0a, 0x0b, 0x0c, 0xff, /* scan 20-27 */ @@ -236,8 +217,8 @@ static unsigned char kbd_key_map[2][5][144] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff /* extended */ }, { /* non numeric code */ - 0, 0x1b, '1', '2', '3', '4', '5', '6', /* scan 0- 7 */ - '7', '8', '9', '0', 0xe1, ''', 0x08, '\t', /* scan 8- F */ + 0, 0x1b, '1', '2', '3', '4', '5', '6', /* scan 00-07 */ + '7', '8', '9', '0', 0xe1, ''', 0x08, '\t', /* scan 08-0F */ 'q', 'w', 'e', 'r', 't', 'z', 'u', 'i', /* scan 10-17 */ 'o', 'p', 0x81, '+', '\r', CN, 'a', 's', /* scan 18-1F */ 'd', 'f', 'g', 'h', 'j', 'k', 'l', 0x94, /* scan 20-27 */ @@ -255,23 +236,23 @@ static unsigned char kbd_key_map[2][5][144] = { '\r', CN, '/', '*', ' ', ST, 'F', 'A', /* extended */ 0, 'D', 'C', 0, 'B', 0, '@', 'P' /* extended */ }, - { /* Right alt mode - is used in German keyboard */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 0 - 7 */ - '{', '[', ']', '}', '\', 0xff, 0xff, 0xff, /* scan 8 - F */ - '@', 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 10 -17 */ - 0xff, 0xff, 0xff, '~', 0xff, 0xff, 0xff, 0xff, /* scan 18 -1F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 20 -27 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 28 -2F */ - 0xff, 0xff, 0xe6, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 30 -37 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 38 -3F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 40 -47 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 48 -4F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, '|', 0xff, /* scan 50 -57 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 58 -5F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 60 -67 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 68 -6F */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 70 -77 */ - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 78 -7F */ + { /* right alt mode - is used in German keyboard */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 00-07 */ + '{', '[', ']', '}', '\', 0xff, 0xff, 0xff, /* scan 08-0F */ + '@', 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 10-17 */ + 0xff, 0xff, 0xff, '~', 0xff, 0xff, 0xff, 0xff, /* scan 18-1F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 20-27 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 28-2F */ + 0xff, 0xff, 0xe6, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 30-37 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 38-3F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 40-47 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 48-4F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, '|', 0xff, /* scan 50-57 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 58-5F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 60-67 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 68-6F */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 70-77 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* scan 78-7F */ 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* extended */ 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff /* extended */ } @@ -298,167 +279,113 @@ static unsigned char ext_key_map[] = { 0x00 /* map end */ };
-/******************************************************************************/ - -static int kbd_controller_present(void) -{ - return in8(I8042_STATUS_REG) != 0xff; -} - -/* - * Implement a weak default function for boards that optionally - * need to skip the i8042 initialization. - */ -int __weak board_i8042_skip(void) +static int kbd_input_empty(void) { - /* As default, don't skip */ - return 0; -} + int kbd_timeout = KBD_TIMEOUT * 1000;
-void i8042_flush(void) -{ - int timeout; - - /* - * The delay is to give the keyboard controller some time to fill the - * next byte. - */ - while (1) { - timeout = 100; /* wait for no longer than 100us */ - while (timeout > 0 && !(in8(I8042_STATUS_REG) & 0x01)) { - udelay(1); - timeout--; - } + while ((in8(I8042_STS_REG) & STATUS_IBF) && kbd_timeout--) + udelay(1);
- /* Try to pull next byte if not timeout. */ - if (in8(I8042_STATUS_REG) & 0x01) - in8(I8042_DATA_REG); - else - break; - } + return kbd_timeout != -1; }
-int i8042_disable(void) +static int kbd_output_full(void) { - if (kbd_input_empty() == 0) - return -1; - - /* Disable keyboard */ - out8(I8042_COMMAND_REG, 0xad); + int kbd_timeout = KBD_TIMEOUT * 1000;
- if (kbd_input_empty() == 0) - return -1; + while (((in8(I8042_STS_REG) & STATUS_OBF) == 0) && kbd_timeout--) + udelay(1);
- return 0; + return kbd_timeout != -1; }
- -/******************************************************************************* - * - * i8042_kbd_init - reset keyboard and init state flags - */ -int i8042_kbd_init(void) +static void kbd_led_set(void) { - int keymap, try; - char *penv; + kbd_input_empty(); + out8(I8042_DATA_REG, CMD_SET_KBD_LED); + kbd_input_empty(); + out8(I8042_DATA_REG, (kbd_flags & 0x7)); +}
- if (!kbd_controller_present() || board_i8042_skip()) - return -1; +static void kbd_normal(unsigned char scan_code) +{ + unsigned char chr;
-#ifdef CONFIG_USE_CPCIDVI - penv = getenv("console"); - if (penv != NULL) { - if (strncmp(penv, "serial", 7) == 0) - return -1; - } -#endif - /* Init keyboard device (default US layout) */ - keymap = KBD_US; - penv = getenv("keymap"); - if (penv != NULL) { - if (strncmp(penv, "de", 3) == 0) - keymap = KBD_GER; - } + if ((kbd_flags & BRK) == NORMAL) { + chr = kbd_key_map[kbd_mapping][kbd_state][scan_code]; + if ((chr == 0xff) || (chr == 0x00)) + return;
- for (try = 0; try < KBD_RESET_TRIES; try++) { - if (kbd_reset() == 0) { - kbd_mapping = keymap; - kbd_flags = NORMAL; - kbd_state = 0; - kbd_led_set(); - return 0; + /* if caps lock convert upper to lower */ + if (((kbd_flags & CAPS) == CAPS) && + (chr >= 'a' && chr <= 'z')) { + chr -= 'a' - 'A'; } + kbd_input = chr; } - return -1; }
- -/******************************************************************************* - * - * i8042_tstc - test if keyboard input is available - * option: cursor blinking if called in a loop - */ -int i8042_tstc(struct stdio_dev *dev) +static void kbd_shift(unsigned char scan_code) { - unsigned char scan_code = 0; - -#ifdef CONFIG_CONSOLE_CURSOR - if (--blinkCount == 0) { - cursor_state ^= 1; - console_cursor(cursor_state); - blinkCount = CONFIG_SYS_CONSOLE_BLINK_COUNT; - udelay(10); + if ((kbd_flags & BRK) == BRK) { + kbd_state = AS; + kbd_flags &= (~SHIFT); + } else { + kbd_state = SH; + kbd_flags |= SHIFT; } -#endif +}
- if ((in8(I8042_STATUS_REG) & 0x01) == 0) { - return 0; +static void kbd_ctrl(unsigned char scan_code) +{ + if ((kbd_flags & BRK) == BRK) { + kbd_state = AS; + kbd_flags &= (~CTRL); } else { - scan_code = in8(I8042_DATA_REG); - if (scan_code == 0xfa) - return 0; - - kbd_conv_char(scan_code); - - if (kbd_input != -1) - return 1; + kbd_state = CN; + kbd_flags |= CTRL; } - return 0; }
- -/******************************************************************************* - * - * i8042_getc - wait till keyboard input is available - * option: turn on/off cursor while waiting - */ -int i8042_getc(struct stdio_dev *dev) +static void kbd_num(unsigned char scan_code) { - int ret_chr; - unsigned char scan_code; + if ((kbd_flags & BRK) == NORMAL) { + kbd_flags ^= NUM; + kbd_state = (kbd_flags & NUM) ? AS : NM; + kbd_led_set(); + } +}
- while (kbd_input == -1) { - while ((in8(I8042_STATUS_REG) & 0x01) == 0) { -#ifdef CONFIG_CONSOLE_CURSOR - if (--blinkCount == 0) { - cursor_state ^= 1; - console_cursor(cursor_state); - blinkCount = CONFIG_SYS_CONSOLE_BLINK_COUNT; - } - udelay(10); -#endif - } - scan_code = in8(I8042_DATA_REG); - if (scan_code != 0xfa) - kbd_conv_char (scan_code); +static void kbd_alt(unsigned char scan_code) +{ + if ((kbd_flags & BRK) == BRK) { + kbd_state = AS; + kbd_flags &= (~ALT); + } else { + kbd_state = AK; + kbd_flags &= ALT; } - ret_chr = kbd_input; - kbd_input = -1; - return ret_chr; }
+static void kbd_caps(unsigned char scan_code) +{ + if ((kbd_flags & BRK) == NORMAL) { + kbd_flags ^= CAPS; + kbd_led_set(); + } +}
-/******************************************************************************/ +static void kbd_scroll(unsigned char scan_code) +{ + if ((kbd_flags & BRK) == NORMAL) { + kbd_flags ^= STP; + kbd_led_set(); + if (kbd_flags & STP) + kbd_input = 0x13; + else + kbd_input = 0x11; + } +}
static void kbd_conv_char(unsigned char scan_code) { @@ -475,8 +402,8 @@ static void kbd_conv_char(unsigned char scan_code)
if ((scan_code == 0xe1) || (kbd_flags & E1)) { if (scan_code == 0xe1) { - kbd_flags ^= BRK; /* reset the break flag */ - kbd_flags ^= E1; /* bitwise EXOR with E1 flag */ + kbd_flags ^= BRK; /* reset the break flag */ + kbd_flags ^= E1; /* bitwise EXOR with E1 flag */ } return; } @@ -511,207 +438,171 @@ static void kbd_conv_char(unsigned char scan_code) case NM: kbd_num(scan_code); break; + case AK: + kbd_alt(scan_code); + break; case CP: kbd_caps(scan_code); break; case ST: kbd_scroll(scan_code); break; - case AK: - kbd_alt(scan_code); - break; } + return; }
- -/******************************************************************************/ - -static void kbd_normal(unsigned char scan_code) +static int kbd_reset(void) { - unsigned char chr; + u8 config;
- if ((kbd_flags & BRK) == NORMAL) { - chr = kbd_key_map[kbd_mapping][kbd_state][scan_code]; - if ((chr == 0xff) || (chr == 0x00)) - return; + /* controller self test */ + if (kbd_input_empty() == 0) + return -1; + out8(I8042_CMD_REG, CMD_SELF_TEST); + if (kbd_output_full() == 0) + return -1; + if (in8(I8042_DATA_REG) != KBC_TEST_OK) + return -1;
- /* if caps lock convert upper to lower */ - if (((kbd_flags & CAPS) == CAPS) && - (chr >= 'a' && chr <= 'z')) { - chr -= 'a' - 'A'; - } - kbd_input = chr; - } -} + /* keyboard reset */ + if (kbd_input_empty() == 0) + return -1; + out8(I8042_DATA_REG, CMD_RESET_KBD); + if (kbd_output_full() == 0) + return -1; + if (in8(I8042_DATA_REG) != KBD_ACK) + return -1; + if (kbd_output_full() == 0) + return -1; + if (in8(I8042_DATA_REG) != KBD_POR) + return -1;
+ /* set AT translation and disable irq */ + if (kbd_input_empty() == 0) + return -1; + out8(I8042_CMD_REG, CMD_RD_CONFIG); + if (kbd_output_full() == 0) + return -1; + config = in8(I8042_DATA_REG); + config |= CONFIG_AT_TRANS; + config &= ~(CONFIG_KIRQ_EN | CONFIG_MIRQ_EN); + if (kbd_input_empty() == 0) + return -1; + out8(I8042_CMD_REG, CMD_WR_CONFIG); + if (kbd_input_empty() == 0) + return -1; + out8(I8042_DATA_REG, config);
-/******************************************************************************/ + /* enable keyboard */ + if (kbd_input_empty() == 0) + return -1; + out8(I8042_CMD_REG, CMD_KBD_EN); + if (kbd_input_empty() == 0) + return -1;
-static void kbd_shift(unsigned char scan_code) -{ - if ((kbd_flags & BRK) == BRK) { - kbd_state = AS; - kbd_flags &= (~SHIFT); - } else { - kbd_state = SH; - kbd_flags |= SHIFT; - } + return 0; }
- -/******************************************************************************/ - -static void kbd_ctrl(unsigned char scan_code) +static int kbd_controller_present(void) { - if ((kbd_flags & BRK) == BRK) { - kbd_state = AS; - kbd_flags &= (~CTRL); - } else { - kbd_state = CN; - kbd_flags |= CTRL; - } + return in8(I8042_STS_REG) != 0xff; }
- -/******************************************************************************/ - -static void kbd_caps(unsigned char scan_code) +/* i8042_kbd_init - reset keyboard and init state flags */ +int i8042_kbd_init(void) { - if ((kbd_flags & BRK) == NORMAL) { - kbd_flags ^= CAPS; - kbd_led_set(); /* update keyboard LED */ - } -} - - -/******************************************************************************/ + int keymap, try; + char *penv;
-static void kbd_num(unsigned char scan_code) -{ - if ((kbd_flags & BRK) == NORMAL) { - kbd_flags ^= NUM; - kbd_state = (kbd_flags & NUM) ? AS : NM; - kbd_led_set(); /* update keyboard LED */ + if (!kbd_controller_present()) { + debug("i8042 keyboard controller is not present\n"); + return -1; } -} - - -/******************************************************************************/
-static void kbd_scroll(unsigned char scan_code) -{ - if ((kbd_flags & BRK) == NORMAL) { - kbd_flags ^= STP; - kbd_led_set(); /* update keyboard LED */ - if (kbd_flags & STP) - kbd_input = 0x13; - else - kbd_input = 0x11; + /* Init keyboard device (default US layout) */ + keymap = KBD_US; + penv = getenv("keymap"); + if (penv != NULL) { + if (strncmp(penv, "de", 3) == 0) + keymap = KBD_GER; } -}
-/******************************************************************************/ + for (try = 0; try < KBD_RESET_TRIES; try++) { + if (kbd_reset() == 0) { + kbd_mapping = keymap; + kbd_flags = NORMAL; + kbd_state = 0; + kbd_led_set();
-static void kbd_alt(unsigned char scan_code) -{ - if ((kbd_flags & BRK) == BRK) { - kbd_state = AS; - kbd_flags &= (~ALT); - } else { - kbd_state = AK; - kbd_flags &= ALT; + return 0; + } } -}
- -/******************************************************************************/ - -static void kbd_led_set(void) -{ - kbd_input_empty(); - out8(I8042_DATA_REG, 0xed); /* SET LED command */ - kbd_input_empty(); - out8(I8042_DATA_REG, (kbd_flags & 0x7)); /* LED bits only */ + return -1; }
- -/******************************************************************************/ - -static int kbd_input_empty(void) +/* + * i8042_tstc - test if keyboard input is available + * + * option: cursor blinking if called in a loop + */ +int i8042_tstc(struct stdio_dev *dev) { - int kbdTimeout = KBD_TIMEOUT * 1000; - - while ((in8(I8042_STATUS_REG) & I8042_STATUS_IN_DATA) && kbdTimeout--) - udelay(1); + unsigned char scan_code = 0;
- return kbdTimeout != -1; -} +#ifdef CONFIG_CONSOLE_CURSOR + if (--blink_count == 0) { + cursor_state ^= 1; + console_cursor(cursor_state); + blink_count = CONFIG_SYS_CONSOLE_BLINK_COUNT; + udelay(10); + } +#endif
-/******************************************************************************/ + if ((in8(I8042_STS_REG) & STATUS_OBF) == 0) { + return 0; + } else { + scan_code = in8(I8042_DATA_REG); + if (scan_code == 0xfa) + return 0;
-static int wait_until_kbd_output_full(void) -{ - int kbdTimeout = KBD_TIMEOUT * 1000; + kbd_conv_char(scan_code);
- while (((in8(I8042_STATUS_REG) & 0x01) == 0) && kbdTimeout--) - udelay(1); + if (kbd_input != -1) + return 1; + }
- return kbdTimeout != -1; + return 0; }
-/******************************************************************************/ - -static int kbd_reset(void) +/* + * i8042_getc - wait till keyboard input is available + * + * option: turn on/off cursor while waiting + */ +int i8042_getc(struct stdio_dev *dev) { - /* controller self test */ - if (kbd_input_empty() == 0) - return -1; - - out8(I8042_COMMAND_REG, 0xaa); - - if (wait_until_kbd_output_full() == 0) - return -1; - - if (in8(I8042_DATA_REG) != 0x55) /* success */ - return -1; - - /* KB Reset */ - if (kbd_input_empty() == 0) - return -1; - - out8(I8042_DATA_REG, 0xff); - - if (wait_until_kbd_output_full() == 0) - return -1; - - if (in8(I8042_DATA_REG) != 0xfa) /* ACK */ - return -1; - - if (wait_until_kbd_output_full() == 0) - return -1; - - if (in8(I8042_DATA_REG) != 0xaa) /* Test Pass*/ - return -1; - - if (kbd_input_empty() == 0) - return -1; - - /* Set KBC mode */ - out8(I8042_COMMAND_REG, 0x60); - - if (kbd_input_empty() == 0) - return -1; - - out8(I8042_DATA_REG, 0x44); - - if (kbd_input_empty() == 0) - return -1; + int ret_chr; + unsigned char scan_code;
- /* Enable Keyboard */ - out8(I8042_COMMAND_REG, 0xae); - if (kbd_input_empty() == 0) - return -1; + while (kbd_input == -1) { + while ((in8(I8042_STS_REG) & STATUS_OBF) == 0) { +#ifdef CONFIG_CONSOLE_CURSOR + if (--blink_count == 0) { + cursor_state ^= 1; + console_cursor(cursor_state); + blink_count = CONFIG_SYS_CONSOLE_BLINK_COUNT; + } + udelay(10); +#endif + } + scan_code = in8(I8042_DATA_REG); + if (scan_code != 0xfa) + kbd_conv_char(scan_code); + } + ret_chr = kbd_input; + kbd_input = -1;
- return 0; + return ret_chr; } diff --git a/include/i8042.h b/include/i8042.h index 58c85ec..5b4f0d5 100644 --- a/include/i8042.h +++ b/include/i8042.h @@ -10,68 +10,66 @@ #ifndef _I8042_H_ #define _I8042_H_
-#ifdef __I386__ -#include <common.h> -#include <asm/io.h> -#define in8(p) inb(p) -#define out8(p,v) outb(v,p) -#endif - /* defines */
-#define I8042_DATA_REG (CONFIG_SYS_ISA_IO + 0x0060) /* keyboard i/o buffer */ -#define I8042_STATUS_REG (CONFIG_SYS_ISA_IO + 0x0064) /* keyboard status read */ -#define I8042_COMMAND_REG (CONFIG_SYS_ISA_IO + 0x0064) /* keyboard ctrl write */ - -enum { - /* Output register (I8042_DATA_REG) has data for system */ - I8042_STATUS_OUT_DATA = 1 << 0, - I8042_STATUS_IN_DATA = 1 << 1, -}; - -#define KBD_US 0 /* default US layout */ -#define KBD_GER 1 /* german layout */ - -#define KBD_TIMEOUT 1000 /* 1 sec */ -#define KBD_RESET_TRIES 3 - -#define AS 0 /* normal character index */ -#define SH 1 /* shift index */ -#define CN 2 /* control index */ -#define NM 3 /* numeric lock index */ -#define AK 4 /* right alt key */ -#define CP 5 /* capslock index */ -#define ST 6 /* stop output index */ -#define EX 7 /* extended code index */ -#define ES 8 /* escape and extended code index */ - -#define NORMAL 0x0000 /* normal key */ -#define STP 0x0001 /* scroll lock stop output*/ -#define NUM 0x0002 /* numeric lock */ -#define CAPS 0x0004 /* capslock */ -#define SHIFT 0x0008 /* shift */ -#define CTRL 0x0010 /* control*/ -#define EXT 0x0020 /* extended scan code 0xe0 */ -#define ESC 0x0040 /* escape key press */ -#define E1 0x0080 /* extended scan code 0xe1 */ -#define BRK 0x0100 /* make break flag for keyboard */ -#define ALT 0x0200 /* right alt */ +#define I8042_DATA_REG 0x60 /* keyboard i/o buffer */ +#define I8042_STS_REG 0x64 /* keyboard status read */ +#define I8042_CMD_REG 0x64 /* keyboard ctrl write */ + +/* Status register bit defines */ +#define STATUS_OBF (1 << 0) +#define STATUS_IBF (1 << 1) + +/* Configuration byte bit defines */ +#define CONFIG_KIRQ_EN (1 << 0) +#define CONFIG_MIRQ_EN (1 << 1) +#define CONFIG_AT_TRANS (1 << 6) + +/* i8042 commands */ +#define CMD_RD_CONFIG 0x20 /* read configuration byte */ +#define CMD_WR_CONFIG 0x60 /* write configuration byte */ +#define CMD_SELF_TEST 0xaa /* controller self-test */ +#define CMD_KBD_EN 0xae /* keyboard enable */ +#define CMD_SET_KBD_LED 0xed /* set keyboard led */ +#define CMD_RESET_KBD 0xff /* reset keyboard */ + +/* i8042 command result */ +#define KBC_TEST_OK 0x55 +#define KBD_ACK 0xfa +#define KBD_POR 0xaa + +/* keyboard scan codes */ + +#define KBD_US 0 /* default US layout */ +#define KBD_GER 1 /* german layout */ + +#define KBD_TIMEOUT 1000 /* 1 sec */ +#define KBD_RESET_TRIES 3 + +#define AS 0 /* normal character index */ +#define SH 1 /* shift index */ +#define CN 2 /* control index */ +#define NM 3 /* numeric lock index */ +#define AK 4 /* right alt key */ +#define CP 5 /* capslock index */ +#define ST 6 /* stop output index */ +#define EX 7 /* extended code index */ +#define ES 8 /* escape and extended code index */ + +#define NORMAL 0x0000 /* normal key */ +#define STP 0x0001 /* scroll lock stop output*/ +#define NUM 0x0002 /* numeric lock */ +#define CAPS 0x0004 /* capslock */ +#define SHIFT 0x0008 /* shift */ +#define CTRL 0x0010 /* control*/ +#define EXT 0x0020 /* extended scan code 0xe0 */ +#define ESC 0x0040 /* escape key press */ +#define E1 0x0080 /* extended scan code 0xe1 */ +#define BRK 0x0100 /* make break flag for keyboard */ +#define ALT 0x0200 /* right alt */
/* exports */
-/** - * Flush all buffer from keyboard controller to host. - */ -void i8042_flush(void); - -/** - * Disables the keyboard so that key strokes no longer generate scancodes to - * the host. - * - * @return 0 if ok, -1 if keyboard input was found while disabling - */ -int i8042_disable(void); - struct stdio_dev;
int i8042_kbd_init(void);
It would be better to split this into a few patches (e.g. one to remove stuff, one to reorder, one for everything else) but this is a big improvement.
Hi Simon,
Ah, I see. This single patch is hard to review as it is totally different from the original. I will see if I can do a v2 to split this.
Regards, Bin
Bin Meng
