[U-Boot] [PATCH] arm: Correct build error introduced by getenv_ulong() patch
Commit dc8bbea removed a local variable that is used in most ARM boards.
Since we want to avoid an 'unused variable' warning with later compilers, and the #ifdef logic of whether this variable is required is bit painful, this declares the variable local to the block of code that needs it.
Signed-off-by: Simon Glass sjg@chromium.org --- arch/arm/lib/board.c | 12 +++++++++--- 1 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index c764844..3c147d1 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -477,6 +477,8 @@ void board_init_r(gd_t *id, ulong dest_addr) flash_size = flash_init(); if (flash_size > 0) { # ifdef CONFIG_SYS_FLASH_CHECKSUM + char *s; + print_size(flash_size, ""); /* * Compute and print flash CRC if flashchecksum is set to 'y' @@ -566,9 +568,13 @@ void board_init_r(gd_t *id, ulong dest_addr) /* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr); #if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); + { + char *s; + + s = getenv("bootfile"); + if (s != NULL) + copy_filename(BootFile, s, sizeof(BootFile)); + } #endif
#ifdef BOARD_LATE_INIT
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Tidy up to call getenv() in declaration
arch/arm/lib/board.c | 12 ++++++++---- 1 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index c764844..7434b34 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -477,13 +477,14 @@ void board_init_r(gd_t *id, ulong dest_addr) flash_size = flash_init(); if (flash_size > 0) { # ifdef CONFIG_SYS_FLASH_CHECKSUM + char *s = getenv("flashchecksum"); + print_size(flash_size, ""); /* * Compute and print flash CRC if flashchecksum is set to 'y' * * NOTE: Maybe we should add some WATCHDOG_RESET()? XXX */ - s = getenv("flashchecksum"); if (s && (*s == 'y')) { printf(" CRC: %08X", crc32(0, (const unsigned char *) CONFIG_SYS_FLASH_BASE, @@ -566,9 +567,12 @@ void board_init_r(gd_t *id, ulong dest_addr) /* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr); #if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); + { + char *s = getenv("bootfile"); + + if (s != NULL) + copy_filename(BootFile, s, sizeof(BootFile)); + } #endif
Dear Simon Glass,
Changes in v2:
Applied, thanks.
Hi Wolfgang,
Le 24/10/2011 21:13, Wolfgang Denk a écrit :
Dear Simon Glass,
Signed-off-by: Simon Glasssjg@chromium.org
Changes in v2:
Applied, thanks.
I've just fetched u-boot and I don't see this one. Can you push u-boot/master so that I can rebase u-boot-arm/master on it and launch some tests?
Amicalement,
Dear Albert ARIBAUD,
Done.
Done.
Hmm... Weird. I've just fetched u-Boot again, and I cannot find this patch in there ; the last commit of u-boot/master seems to be 4962e38e9a4a053792722918bb11c5408549aebd, dated 2011-10-17.
Can somebody aside from me check this?
Amicalement,
Hi Albert,
On Tue, Oct 25, 2011 at 11:21 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Done.
Yes I see the same.
Amicalement,
Albert.
Done.
Sorry, my fault. Should be fixed now.
Done.
Yes it's fine now, thanks
- Simon
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If you're not part of the solution, you're part of the problem.
- print_size(flash_size, ""); /*
- Compute and print flash CRC if flashchecksum is set to 'y'
- NOTE: Maybe we should add some WATCHDOG_RESET()? XXX
if (s && (*s == 'y')) { printf(" CRC: %08X", crc32(0, (const unsigned char *) CONFIG_SYS_FLASH_BASE,s = getenv("flashchecksum");
- if (s != NULL)
if (s != NULL)
#endif
seems like a better solution would be to use at the top: __maybe_unused char *s;
also, shouldn't these be "const char *s" ? -mike
Hi Mike,
- char *s = getenv("flashchecksum");
- if (s != NULL)
- char *s = getenv("bootfile");
- if (s != NULL)
#endif
We can certainly do this and I agree it is easier than #ifdefs. Does it introduce the possibility that one day the code will stop using the variable but it will still be declared? Is the fact that we need the #ifdefs an indication that the function should be too long and should be refactored? it in fact better to have these explicit so we can see them for the ugliness they are?
I'm not sure, but thought I should ask.
if (s != NULL)
if (s != NULL)
#endif
yes, you're right that it does leave the door open to the variable being declared, never used, and gcc not emitting a warning about it.
both setups suck, but i'd lean towards the less-ifdef state ... wonder if Wolfgang has a preference. -mike
Hi Mike,
if (s != NULL)
if (s != NULL)
#endif
Personally, I think that the nuisance of a potential unused variable is less of an issue than the actual _problems_ that ifdefs induce.
Cheers Detlev
Hi Detlev,
On Tue, Nov 8, 2011 at 1:20 AM, Detlev Zundel dzu@denx.de wrote:
Hi Mike,
- if (s != NULL)
- if (s != NULL)
#endif
Yes the #ifdefs are a pain. I am working on a replacement for board.c - so far I have split things into functions. Next I need to look at Graeme's initcall patch. .. Regards, Simon
Cheers Detlev
-- The best way to predict the future is to invent it. -- Alan Kay -- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-40 Fax: (+49)-8142-66989-80 Email: dzu@denx.de
Le 08/11/2011 16:57, Simon Glass a écrit :
Hi Detlev,
On Tue, Nov 8, 2011 at 1:20 AM, Detlev Zundeldzu@denx.de wrote:
Hi Mike,
flash_size = flash_init(); if (flash_size> 0) {
s = getenv("flashchecksum"); if (s&& (*s == 'y')) { printf(" CRC: %08X", crc32(0, (const unsigned char *)
if (s != NULL)
if (s != NULL)
#endif}
I don't think 'ifdefs are' necessarily 'a pain'. They cater for a need, that is, to mark that some code depends on some condition. I find it *normal* that a checksum-related variable is conditioned on the checksum macro being defined.
Amicalement,
Hi Albert,
On Tue, Nov 8, 2011 at 11:46 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Detlev,
Hi Mike,
On Sunday 23 October 2011 23:44:35 Simon Glass wrote: > > --- a/arch/arm/lib/board.c > +++ b/arch/arm/lib/board.c > > flash_size = flash_init(); > if (flash_size> 0) { > # ifdef CONFIG_SYS_FLASH_CHECKSUM > + char *s = getenv("flashchecksum"); > + > print_size(flash_size, ""); > /* > * Compute and print flash CRC if flashchecksum is set > to > 'y' * > * NOTE: Maybe we should add some WATCHDOG_RESET()? XXX > */ > - s = getenv("flashchecksum"); > if (s&& (*s == 'y')) { > printf(" CRC: %08X", crc32(0, > (const unsigned char *) > CONFIG_SYS_FLASH_BASE, @@ -566,9 +567,12 @@ void board_init_r(gd_t > *id, > ulong dest_addr) /* Initialize from environment */ > load_addr = getenv_ulong("loadaddr", 16, load_addr); > #if defined(CONFIG_CMD_NET) > - s = getenv("bootfile"); > - if (s != NULL) > - copy_filename(BootFile, s, sizeof(BootFile)); > + { > + char *s = getenv("bootfile"); > + > + if (s != NULL) > + copy_filename(BootFile, s, sizeof(BootFile)); > + } > #endif
This discussion was regarding the need to #ifdef the variable declaration, viz:
#if defined(THING1) || defined(THING2) const char *cat; #endif
#ifdef THING1 cat = getenv("cat");
send_back(cat); #endif
#ifdef THING2 cat = check_outside("cat");
if (cat) wibble(cat); #endif
and whether the top bit would be better as:
__maybe_unused const char *cat;
But more generally, lots of #ifdefs do make the code harder to read, and potentially more brittle in the face of config changes.
Amicalement,
Albert.
Dear Simon Glass,
In message CAPnjgZ15f_gva5+MM1Em-L2sMxt1WAATxqiKUHOQAT893t9MMw@mail.gmail.com you wrote:
I would like to see only a minimal number of "__maybe_unused" in the code - in cases, where this is the way that hurts least.
In the examples above, it might be better to use local blocks, like:
#ifdef THING1 { const char *cat = getenv("cat");
send_back(cat); } #endif
Hi Wolfgang
On Wed, Nov 9, 2011 at 9:49 AM, Wolfgang Denk wd@denx.de wrote:
Dear Simon Glass,
send_back(cat); }
#endif
I honestly think most of these cases can be factored out into functions. The compiler should inline them anyway so the overhead should be zero. The various board.c files are a prime example of where this should be done as a matter of principle to reduce the complexity and lenght of the primary function anyway
Regards,
Graeme
Hi Graeme,
Hi Wolfgang
Dear Simon Glass,
send_back(cat); }
#endif
I would even like to skip the ifdefs completely. Modern compilers with dead code elimination will completely do away unneeded code _but still do syntax checks on the parts every time_.
So maybe we should simply try to use
if (THING1) { ... }
I know that this would need an "#ifdef THING1 1" but errors in this would be caught immediately (and not only under a certain combination of ifdefs) by the compiler so I don't think this is a problem.
I don't know how often I repeat my mantra, but every ifdef doubles the number of _different source codes_ that we deal with.
Cheers Detlev
Hi Detlev,
On Wed, Nov 9, 2011 at 5:45 AM, Detlev Zundel dzu@denx.de wrote:
Hi Graeme,
Hi Wolfgang
Dear Simon Glass,
Yes I agree it is better and we are heading that way (e.g. debug macro). But there are details...
if (THING1) { ... }
Do you mean '#define THING1 1"?
Can you please restate this without the code inside {} removed? And let's change the example to CONFIG. Sadly I much prefer #ifdef to #if.
#ifdef CONFIG_THING1 { const char *cat;
Things to consider:
- do we include the cat.h header file unconditionally? I assume yes - iwc does the cat.h header file have #ifdefs to hide its functions / data structures? If so you get compile errors when you make a mistake; if not you get link errors which are normally worse - under what circs. should we define static inline send_back(void) {} for the case where CONFIG_THING1 is not defined (or is 0)? - if send_back() is in a C file which is only linked in if THING1 is defined, does this work as expected? - CONFIG_THING1 is normally defined but not given a '1' value. Doesn't this break things?
Yes of course at the compiler level. Look at all the build errors/warnings when the new debug() macro came in. But if() creates different executable code too, and if we resort to hiding lots of things in static inlines and dead code calls to functions which are not linked, it can create confusion. It would be good to get some guidelines on this.
Cheers Detlev
-- Lotus Notes (GUI): Run away from it. -- linux/Documentation/email-clients.txt -- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-40 Fax: (+49)-8142-66989-80 Email: dzu@denx.de _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Wolfgang,
On Tue, Nov 8, 2011 at 2:49 PM, Wolfgang Denk wd@denx.de wrote:
Dear Simon Glass,
Noted, thanks.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "There is such a fine line between genius and stupidity."
- David St. Hubbins, "Spinal Tap"
participants (6)
Albert ARIBAUD
Detlev Zundel
Graeme Russ
Mike Frysinger
