[PATCH v2 0/5] Enable power domain driver in ZynqMP and Versal
This patch series enables power domain driver in ZynqMP and Versal platforms and its dependencies. - Add a preliminary check by loading overlay for APU0 and see if the pmufw accepts the config objects, based on that continue to load further objects or not. - This is needed to dynamically request for node of the IP's based on DT. - Load pmufw config object dynamically based on DT.
Changes in v2: - Move static variable to inside zynqmp_pmufw_node and change name to skip_config from config_enabled - Use zynqmp_pmufw_node() in zynqmp_power_probe() to check for APU_0 config loading instead of calling zynqmp_pmufw_load_config_object()
Ashok Reddy Soma (5): firmware: zynqmp: Change prototype of zynqmp_pmufw_load_config_object() firmware: zynqmp: Load config overlay for core0 to pmufw arm64: zynqmp: Enable power domain driver mailbox: zynqmp: Move struct zynqmp_ipi_msg from sys_proto.h arm64: versal: Enable power domain driver and its dependencies
arch/arm/mach-zynqmp/include/mach/sys_proto.h | 5 ---- configs/xilinx_versal_virt_defconfig | 4 ++++ configs/xilinx_zynqmp_virt_defconfig | 2 ++ drivers/firmware/firmware-zynqmp.c | 24 +++++++++++++++---- drivers/mailbox/Kconfig | 2 +- drivers/mailbox/zynqmp-ipi.c | 2 +- include/zynqmp_firmware.h | 7 +++++- 7 files changed, 33 insertions(+), 13 deletions(-)
zynqmp_pmufw_load_config_object() has some error cases and it is better to return those errors. Change prototype of this function to return errors.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com ---
(no changes since v1)
drivers/firmware/firmware-zynqmp.c | 8 +++++--- include/zynqmp_firmware.h | 2 +- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index 0f0d2b07c0..34d9b47003 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -210,7 +210,7 @@ int zynqmp_pm_is_function_supported(const u32 api_id, const u32 id) * @cfg_obj: Pointer to the configuration object * @size: Size of @cfg_obj in bytes */ -void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size) +int zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size) { int err; u32 ret_payload[PAYLOAD_ARG_CNT]; @@ -224,12 +224,12 @@ void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size) 0, ret_payload); if (err == XST_PM_NO_ACCESS) { printf("PMUFW no permission to change config object\n"); - return; + return -EACCES; }
if (err == XST_PM_ALREADY_CONFIGURED) { debug("PMUFW Node is already configured\n"); - return; + return -ENODEV; }
if (err) @@ -240,6 +240,8 @@ void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size)
if ((err || ret_payload[0]) && IS_ENABLED(CONFIG_SPL_BUILD)) panic("PMUFW config object loading failed in EL3\n"); + + return 0; }
static int zynqmp_power_probe(struct udevice *dev) diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index 6c4fd9a6c5..1c22a62207 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -449,7 +449,7 @@ enum pm_gem_config_type { unsigned int zynqmp_firmware_version(void); int zynqmp_pmufw_node(u32 id); int zynqmp_pmufw_config_close(void); -void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size); +int zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size); int xilinx_pm_request(u32 api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, u32 *ret_payload); int zynqmp_pm_set_sd_config(u32 node, enum pm_sd_config_type config, u32 value);
Try loading pmufw config overlay for core0, if it doesn't return any error it means pmufw is accepting nodes for other IP's. Otherwise dont try to load config object for any other IP, just return from zynqmp_pmufw_node function.
drivers/firmware/firmware-zynqmp.c | 16 ++++++++++++++-- 1 file changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index 34d9b47003..aedc4dd2df 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -70,11 +70,20 @@ int zynqmp_pmufw_config_close(void)
int zynqmp_pmufw_node(u32 id) { + static bool skip_config; + int ret; + + if (skip_config) + return 0; + /* Record power domain id */ xpm_configobject[NODE_ID_LOCATION] = id;
- zynqmp_pmufw_load_config_object(xpm_configobject, - sizeof(xpm_configobject)); + ret = zynqmp_pmufw_load_config_object(xpm_configobject, + sizeof(xpm_configobject)); + + if (ret && id == NODE_APU_0) + skip_config = true;
return 0; } @@ -267,6 +276,9 @@ static int zynqmp_power_probe(struct udevice *dev) ret >> ZYNQMP_PM_VERSION_MAJOR_SHIFT, ret & ZYNQMP_PM_VERSION_MINOR_MASK);
+ if (IS_ENABLED(CONFIG_ARCH_ZYNQMP)) + zynqmp_pmufw_node(NODE_APU_0); + return 0; };
Enable power domain driver to configure pmufw config object and request node for all the IP's that are enabled in DT.
configs/xilinx_zynqmp_virt_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 35894076c5..85cd5d6d9e 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -162,6 +162,8 @@ CONFIG_PHY_XILINX_GMII2RGMII=y CONFIG_PHY_FIXED=y CONFIG_XILINX_AXIEMAC=y CONFIG_ZYNQ_GEM=y +CONFIG_POWER_DOMAIN=y +CONFIG_ZYNQMP_POWER_DOMAIN=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_PWM=y
Mailbox driver might be need for Versal and other future platforms. To remove the dependency, move struct zynqmp_ipi_msg to zynqmp_firmware.h so that mailbox driver compiles for other platforms easily.
arch/arm/mach-zynqmp/include/mach/sys_proto.h | 5 ----- drivers/mailbox/zynqmp-ipi.c | 2 +- include/zynqmp_firmware.h | 5 +++++ 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-zynqmp/include/mach/sys_proto.h b/arch/arm/mach-zynqmp/include/mach/sys_proto.h index 1c12eac715..9fffb4e541 100644 --- a/arch/arm/mach-zynqmp/include/mach/sys_proto.h +++ b/arch/arm/mach-zynqmp/include/mach/sys_proto.h @@ -46,11 +46,6 @@ enum { TCM_SPLIT, };
-struct zynqmp_ipi_msg { - size_t len; - u32 *buf; -}; - int zynq_board_read_rom_ethaddr(unsigned char *ethaddr); unsigned int zynqmp_get_silicon_version(void);
diff --git a/drivers/mailbox/zynqmp-ipi.c b/drivers/mailbox/zynqmp-ipi.c index 959cce923c..3e4ec47389 100644 --- a/drivers/mailbox/zynqmp-ipi.c +++ b/drivers/mailbox/zynqmp-ipi.c @@ -11,10 +11,10 @@ #include <dm.h> #include <mailbox-uclass.h> #include <dm/device_compat.h> -#include <mach/sys_proto.h> #include <linux/ioport.h> #include <linux/io.h> #include <wait_bit.h> +#include <zynqmp_firmware.h>
/* IPI bitmasks, register base */ /* TODO: move reg base to DT */ diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index 1c22a62207..fa969bf336 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -492,4 +492,9 @@ enum zynqmp_pm_request_ack { /* PM API versions */ #define PM_API_VERSION_2 2
+struct zynqmp_ipi_msg { + size_t len; + u32 *buf; +}; + #endif /* _ZYNQMP_FIRMWARE_H_ */
This driver depends on mailbox and IPI driver, hence enable them as well. Add ARCH_VERSAL in the depends on of mailbox Kconfig to compile for Versal platforms.
configs/xilinx_versal_virt_defconfig | 4 ++++ drivers/mailbox/Kconfig | 2 +- 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 0419992be4..a2d4debbf5 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -66,6 +66,8 @@ CONFIG_FPGA_XILINX=y CONFIG_FPGA_VERSALPL=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_CADENCE=y +CONFIG_DM_MAILBOX=y +CONFIG_ZYNQMP_IPI=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y CONFIG_SUPPORT_EMMC_BOOT=y @@ -96,6 +98,8 @@ CONFIG_PHY_GIGE=y CONFIG_XILINX_AXIEMAC=y CONFIG_XILINX_AXIMRMAC=y CONFIG_ZYNQ_GEM=y +CONFIG_POWER_DOMAIN=y +CONFIG_ZYNQMP_POWER_DOMAIN=y CONFIG_ARM_DCC=y CONFIG_PL01X_SERIAL=y CONFIG_XILINX_UARTLITE=y diff --git a/drivers/mailbox/Kconfig b/drivers/mailbox/Kconfig index 73db2af0b8..acbdce11b7 100644 --- a/drivers/mailbox/Kconfig +++ b/drivers/mailbox/Kconfig @@ -54,7 +54,7 @@ config K3_SEC_PROXY
config ZYNQMP_IPI bool "Xilinx ZynqMP IPI controller support" - depends on DM_MAILBOX && ARCH_ZYNQMP + depends on DM_MAILBOX && (ARCH_ZYNQMP || ARCH_VERSAL) help This enables support for the Xilinx ZynqMP Inter Processor Interrupt communication controller.
Changes in v2:
applied. M
Ashok Reddy Soma
Michal Simek
