[U-Boot] [PATCH] Revert "ARM: move interrupt_init to before relocation"
Revert commit 0f5141e9 which causes boards starting in FLASH to try and write to a FLASH location.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- arch/arm/lib/board.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 34f50b0..9c72a53 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -435,7 +435,6 @@ void board_init_f(ulong bootflag) addr_sp += 128; /* leave 32 words for abort-stack */ gd->irq_sp = addr_sp; #endif - interrupt_init();
debug("New Stack Pointer is: %08lx\n", addr_sp);
@@ -637,6 +636,8 @@ void board_init_r(gd_t *id, ulong dest_addr) misc_init_r(); #endif
+ /* set up exceptions */ + interrupt_init(); /* enable exceptions */ enable_interrupts();
On Fri, 8 Nov 2013 22:37:33 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
interrupt_init();
- interrupt_init(); /* enable exceptions */ enable_interrupts();
Applied to u-boot-arm/master.
Amicalement,
Albert ARIBAUD
