[U-Boot] [PATCH v2] i2c_eeprom: Add reading support
This patch implements the reading functionality for the generic I2C EEPROM driver, which was just a non-functional stub until now.
Since the page size will be of importance for the writing support, we add suitable members to the private data structure to keep track of it.
Compatibility strings for a range of at24c* chips are added.
Signed-off-by: Mario Six mario.six@gdsys.cc ---
Changes in v2: - Simplified and documented the i2c_eeprom struct - Simplified the read function - Corrected Kconfig dependency (from DM to MISC)
--- drivers/misc/Kconfig | 5 +++++ drivers/misc/i2c_eeprom.c | 39 +++++++++++++++++++++++++++++++-------- include/i2c_eeprom.h | 4 ++++ 3 files changed, 40 insertions(+), 8 deletions(-)
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 2373037..b84e351 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -144,4 +144,9 @@ config QFW Hidden option to enable QEMU fw_cfg interface. This will be selected by either CONFIG_CMD_QFW or CONFIG_GENERATE_ACPI_TABLE.
+config I2C_EEPROM + bool "Enable driver for generic I2C-attached EEPROMs" + depends on MISC + help + Enable a generic driver for EEPROMs attached via I2C. endmenu diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index 814134a..c9f4174 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -13,7 +13,7 @@ static int i2c_eeprom_read(struct udevice *dev, int offset, uint8_t *buf, int size) { - return -ENODEV; + return dm_i2c_read(dev, offset, buf, size); }
static int i2c_eeprom_write(struct udevice *dev, int offset, @@ -27,23 +27,46 @@ struct i2c_eeprom_ops i2c_eeprom_std_ops = { .write = i2c_eeprom_write, };
+static int i2c_eeprom_std_ofdata_to_platdata(struct udevice *dev) +{ + struct i2c_eeprom *priv = dev_get_priv(dev); + u64 data = dev_get_driver_data(dev); + + /* 6 bit -> page size of up to 2^63 (should be sufficient) */ + priv->pagewidth = data & 0x3F; + priv->pagesize = (1 << priv->pagewidth); + + return 0; +} + int i2c_eeprom_std_probe(struct udevice *dev) { return 0; }
static const struct udevice_id i2c_eeprom_std_ids[] = { - { .compatible = "i2c-eeprom" }, + { .compatible = "i2c-eeprom", .data = 0 }, + { .compatible = "atmel,24c01a", .data = 3 }, + { .compatible = "atmel,24c02", .data = 3 }, + { .compatible = "atmel,24c04", .data = 4 }, + { .compatible = "atmel,24c08a", .data = 4 }, + { .compatible = "atmel,24c16a", .data = 4 }, + { .compatible = "atmel,24c32", .data = 5 }, + { .compatible = "atmel,24c64", .data = 5 }, + { .compatible = "atmel,24c128", .data = 6 }, + { .compatible = "atmel,24c256", .data = 6 }, + { .compatible = "atmel,24c512", .data = 6 }, { } };
U_BOOT_DRIVER(i2c_eeprom_std) = { - .name = "i2c_eeprom", - .id = UCLASS_I2C_EEPROM, - .of_match = i2c_eeprom_std_ids, - .probe = i2c_eeprom_std_probe, - .priv_auto_alloc_size = sizeof(struct i2c_eeprom), - .ops = &i2c_eeprom_std_ops, + .name = "i2c_eeprom", + .id = UCLASS_I2C_EEPROM, + .of_match = i2c_eeprom_std_ids, + .probe = i2c_eeprom_std_probe, + .ofdata_to_platdata = i2c_eeprom_std_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct i2c_eeprom), + .ops = &i2c_eeprom_std_ops, };
UCLASS_DRIVER(i2c_eeprom) = { diff --git a/include/i2c_eeprom.h b/include/i2c_eeprom.h index ea6c962..0452892 100644 --- a/include/i2c_eeprom.h +++ b/include/i2c_eeprom.h @@ -14,6 +14,10 @@ struct i2c_eeprom_ops { };
struct i2c_eeprom { + /* The EEPROM's page size in byte */ + unsigned long pagesize; + /* The EEPROM's page width in bits (pagesize = 2^pagewidth) */ + unsigned pagewidth; };
#endif -- 2.7.0.GIT
Changes in v2:
Hello Mario,
Am 22.06.2016 um 15:14 schrieb Mario Six:
Changes in v2:
Thanks!
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
+config I2C_EEPROM
- bool "Enable driver for generic I2C-attached EEPROMs"
- depends on MISC
- help
endmenuEnable a generic driver for EEPROMs attached via I2C.
- return -ENODEV;
- struct i2c_eeprom *priv = dev_get_priv(dev);
- u64 data = dev_get_driver_data(dev);
- /* 6 bit -> page size of up to 2^63 (should be sufficient) */
- priv->pagewidth = data & 0x3F;
- priv->pagesize = (1 << priv->pagewidth);
struct i2c_eeprom {
#endif
-- 2.7.0.GIT
Signed-off-by: Mario Six mario.six@gdsys.cc Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Heiko Schocher hs@denx.de
Heiko Schocher invitel
Mario Six
