[PATCH] env: Switch the callback static list to Kconfig
Switch the callback static list from the board configuration varibale CFG_ENV_CALLBACK_LIST_STATIC to Kconfig CONFIG_ENV_CALLBACK_LIST_STATIC.
Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com --- Cc: Joe Hershberger joe.hershberger@ni.com Cc: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com --- doc/develop/environment.rst | 4 ++-- env/Kconfig | 13 +++++++++++++ include/env_callback.h | 7 +------ 3 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/doc/develop/environment.rst b/doc/develop/environment.rst index e1783462bb..e46cd39d60 100644 --- a/doc/develop/environment.rst +++ b/doc/develop/environment.rst @@ -18,8 +18,8 @@ The callbacks are named and associated with a function using the U_BOOT_ENV_CALLBACK macro in your board or driver code.
These callbacks are associated with variables in one of two ways. The -static list can be added to by defining CFG_ENV_CALLBACK_LIST_STATIC -in the board configuration to a string that defines a list of +static list can be added to by defining CONFIG_ENV_CALLBACK_LIST_STATIC +in the board defconfig via menuconfig to a string that defines a list of associations. The list must be in the following format::
entry = variable_name[:callback_name] diff --git a/env/Kconfig b/env/Kconfig index 031cf58186..aaf0b1fe9a 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -21,6 +21,19 @@ config ENV_SOURCE_FILE environment is assumed to come from the ad-hoc CFG_EXTRA_ENV_SETTINGS #define
+config ENV_CALLBACK_LIST_STATIC + string "Static callbacks list" + default "" + help + The environment callbacks are associated with variables in a + static list. Define this list in the following format: + + entry = variable_name[:callback_name] + list = entry[,list] + + If the callback name is not specified, then the callback is deleted. + Spaces are also allowed anywhere in the list. + config SAVEENV def_bool y if CMD_SAVEENV
diff --git a/include/env_callback.h b/include/env_callback.h index bc8ff1923e..47a31f6cf5 100644 --- a/include/env_callback.h +++ b/include/env_callback.h @@ -14,11 +14,6 @@
#define ENV_CALLBACK_VAR ".callbacks"
-/* Board configs can define additional static callback bindings */ -#ifndef CFG_ENV_CALLBACK_LIST_STATIC -#define CFG_ENV_CALLBACK_LIST_STATIC -#endif - #ifdef CONFIG_SILENT_CONSOLE #define SILENT_CALLBACK "silent:silent," #else @@ -90,7 +85,7 @@ SILENT_CALLBACK \ "stdin:console,stdout:console,stderr:console," \ "serial#:serialno," \ - CFG_ENV_CALLBACK_LIST_STATIC + CONFIG_ENV_CALLBACK_LIST_STATIC
#ifndef CONFIG_XPL_BUILD void env_callback_init(struct env_entry *var_entry);
variable , typo
With the above typo fixed:
From: Marek Vasut marex@denx.de Sent: Tuesday, November 19, 2024 3:22 PM
variable , typo
OK, I will fix it in V2.
Regards Christoph
