[U-Boot] [PATCH v2] socfpga: Adding Freeze Controller driver
Adding Freeze Controller driver. All HPS IOs need to be in freeze state during pin mux or IO buffer configuration. It is to avoid any glitch which might happen during the configuration from propagating to external devices.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Wolfgang Denk wd@denx.de CC: Pavel Machek pavel@denx.de Cc: Dinh Nguyen dinguyen@altera.com --- Changes for v2 - Removed FREEZE_CONTROLLER_FSM_HW - Removed the get_timer_count_masked and convert to use delay in us - Used shorter local variables --- arch/arm/cpu/armv7/socfpga/Makefile | 2 +- arch/arm/cpu/armv7/socfpga/freeze_controller.c | 249 ++++++++++++++++++++ arch/arm/cpu/armv7/socfpga/spl.c | 16 ++ .../include/asm/arch-socfpga/freeze_controller.h | 71 ++++++ 4 files changed, 337 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/armv7/socfpga/freeze_controller.c create mode 100644 arch/arm/include/asm/arch-socfpga/freeze_controller.h
diff --git a/arch/arm/cpu/armv7/socfpga/Makefile b/arch/arm/cpu/armv7/socfpga/Makefile index 0859e44..10d20f2 100644 --- a/arch/arm/cpu/armv7/socfpga/Makefile +++ b/arch/arm/cpu/armv7/socfpga/Makefile @@ -14,7 +14,7 @@ LIB = $(obj)lib$(SOC).o
SOBJS := lowlevel_init.o COBJS-y := misc.o timer.o reset_manager.o system_manager.o -COBJS-$(CONFIG_SPL_BUILD) += spl.o +COBJS-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
COBJS := $(COBJS-y) SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/socfpga/freeze_controller.c b/arch/arm/cpu/armv7/socfpga/freeze_controller.c new file mode 100644 index 0000000..668c6d6 --- /dev/null +++ b/arch/arm/cpu/armv7/socfpga/freeze_controller.c @@ -0,0 +1,249 @@ +/* + * Copyright (C) 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/freeze_controller.h> +#include <asm/arch/timer.h> +#include <asm/errno.h> + +DECLARE_GLOBAL_DATA_PTR; + + + +static const struct socfpga_freeze_controller *freeze_controller_base = + (void *)(SOCFPGA_SYSMGR_ADDRESS + SYSMGR_FRZCTRL_ADDRESS); + +/* + * Default state from cold reset is FREEZE_ALL; the global + * flag is set to TRUE to indicate the IO banks are frozen + */ +static uint32_t frzctrl_channel_freeze[FREEZE_CHANNEL_NUM] + = { FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN, + FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN}; + + +/* Freeze HPS IOs */ +u32 sys_mgr_frzctrl_freeze_req(FreezeChannelSelect channel_id, + FreezeControllerFSMSelect fsm_select) +{ + u32 ioctrl_reg_offset; + u32 reg_value; + u32 reg_cfg_mask; + + if (FREEZE_CONTROLLER_FSM_SW != fsm_select) + return -EINVAL; + + /* select software FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, &freeze_controller_base->src); + + /* Freeze channel ID checking and base address */ + switch (channel_id) { + case FREEZE_CHANNEL_0: + case FREEZE_CHANNEL_1: + case FREEZE_CHANNEL_2: + ioctrl_reg_offset = (u32)( + &freeze_controller_base->vioctrl + + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + + /* + * Assert active low enrnsl, plniotri + * and niotri signals + */ + reg_cfg_mask = + SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK + | SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; + clrbits_le32(ioctrl_reg_offset, reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * Assert active low bhniotri signal and de-assert + * active high csrdone + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; + clrbits_le32(ioctrl_reg_offset, reg_cfg_mask); + + /* Set global flag to indicate channel is frozen */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_FROZEN; + break; + + case FREEZE_CHANNEL_3: + /* + * Assert active low enrnsl, plniotri and + * niotri signals + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK + | SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK; + clrbits_le32(&freeze_controller_base->hioctrl, reg_cfg_mask); + + /* + * Note: Delay for 40ns at min + * assert active low bhniotri & nfrzdrv signals, + * de-assert active high csrdone and assert + * active high frzreg and nfrzdrv signals + */ + reg_value = readl(&freeze_controller_base->hioctrl); + reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK; + reg_value + = (reg_value & ~reg_cfg_mask) + | SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK + | SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; + writel(reg_value, &freeze_controller_base->hioctrl); + + /* + * Note: Delay for 40ns at min + * assert active high reinit signal and de-assert + * active high pllbiasen signals + */ + reg_value = readl(&freeze_controller_base->hioctrl); + reg_value + = (reg_value & + ~SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK) + | SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK; + writel(reg_value, &freeze_controller_base->hioctrl); + + /* Set global flag to indicate channel is frozen */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_FROZEN; + break; + + default: + return -EINVAL; + } + + return 0; +} + +/* Unfreeze/Thaw HPS IOs */ +u32 sys_mgr_frzctrl_thaw_req(FreezeChannelSelect channel_id, + FreezeControllerFSMSelect fsm_select) +{ + u32 ioctrl_reg_offset; + u32 reg_cfg_mask; + u32 reg_value; + + if (FREEZE_CONTROLLER_FSM_SW != fsm_select) + return -EINVAL; + + /* select software FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, &freeze_controller_base->src); + + /* Freeze channel ID checking and base address */ + switch (channel_id) { + case FREEZE_CHANNEL_0: + case FREEZE_CHANNEL_1: + case FREEZE_CHANNEL_2: + ioctrl_reg_offset + = (u32)(&freeze_controller_base->vioctrl + + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + + /* + * Assert active low bhniotri signal and + * de-assert active high csrdone + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; + setbits_le32(ioctrl_reg_offset, reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * de-assert active low plniotri and niotri signals + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; + setbits_le32(ioctrl_reg_offset, reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * de-assert active low enrnsl signal + */ + setbits_le32(ioctrl_reg_offset, + SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK); + + /* Set global flag to indicate channel is thawed */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; + + break; + + case FREEZE_CHANNEL_3: + /* de-assert active high reinit signal */ + clrbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK); + + /* + * Note: Delay for 40ns at min + * assert active high pllbiasen signals + */ + setbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK); + + /* + * Delay 1000 intosc. intosc is based on eosc1 + * Use worst case which is fatest eosc1=50MHz, delay required + * is 1/50MHz * 1000 = 20us + */ + udelay(20); + + /* + * de-assert active low bhniotri signals, + * assert active high csrdone and nfrzdrv signal + */ + reg_value = readl(&freeze_controller_base->hioctrl); + reg_value = (reg_value + | SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK) + & ~SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; + writel(reg_value, &freeze_controller_base->hioctrl); + + /* + * Delay 33 intosc + * Use worst case which is fatest eosc1=50MHz, delay required + * is 1/50MHz * 33 = 660ns ~= 1us + */ + udelay(1); + + /* de-assert active low plniotri and niotri signals */ + reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK; + + setbits_le32(&freeze_controller_base->hioctrl, reg_cfg_mask); + + /* + * Note: Delay for 40ns at min + * de-assert active high frzreg signal + */ + clrbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK); + + /* + * Note: Delay for 40ns at min + * de-assert active low enrnsl signal + */ + setbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK); + + /* Set global flag to indicate channel is thawed */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; + + break; + + default: + return -EINVAL; + } + + return 0; +} + diff --git a/arch/arm/cpu/armv7/socfpga/spl.c b/arch/arm/cpu/armv7/socfpga/spl.c index 74bceab..5173c0d 100644 --- a/arch/arm/cpu/armv7/socfpga/spl.c +++ b/arch/arm/cpu/armv7/socfpga/spl.c @@ -13,6 +13,8 @@ #include <asm/arch/reset_manager.h> #include <spl.h> #include <asm/arch/system_manager.h> +#include <asm/arch/freeze_controller.h> +
@@ -27,6 +29,13 @@ u32 spl_boot_device(void) void spl_board_init(void) { #ifndef CONFIG_SOCFPGA_VIRTUAL_TARGET + debug("Freezing all I/O banks\n"); + /* freeze all IO banks */ + sys_mgr_frzctrl_freeze_req(FREEZE_CHANNEL_0, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_freeze_req(FREEZE_CHANNEL_1, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_freeze_req(FREEZE_CHANNEL_2, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_freeze_req(FREEZE_CHANNEL_3, FREEZE_CONTROLLER_FSM_SW); + /* configure the pin muxing through system manager */ sysmgr_pinmux_init(); #endif /* CONFIG_SOCFPGA_VIRTUAL_TARGET */ @@ -34,6 +43,13 @@ void spl_board_init(void) /* de-assert reset for peripherals and bridges based on handoff */ reset_deassert_peripherals_handoff();
+ debug("Unfreezing/Thaw all I/O banks\n"); + /* unfreeze / thaw all IO banks */ + sys_mgr_frzctrl_thaw_req(FREEZE_CHANNEL_0, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_thaw_req(FREEZE_CHANNEL_1, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_thaw_req(FREEZE_CHANNEL_2, FREEZE_CONTROLLER_FSM_SW); + sys_mgr_frzctrl_thaw_req(FREEZE_CHANNEL_3, FREEZE_CONTROLLER_FSM_SW); + /* enable console uart printing */ preloader_console_init(); } diff --git a/arch/arm/include/asm/arch-socfpga/freeze_controller.h b/arch/arm/include/asm/arch-socfpga/freeze_controller.h new file mode 100644 index 0000000..b25ff99 --- /dev/null +++ b/arch/arm/include/asm/arch-socfpga/freeze_controller.h @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _FREEZE_CONTROLLER_H_ +#define _FREEZE_CONTROLLER_H_ + +struct socfpga_freeze_controller { + u32 vioctrl; + u32 padding[3]; + u32 hioctrl; + u32 src; + u32 hwctrl; +}; + +#define SYSMGR_FRZCTRL_LOOP_PARAM (1000) +#define SYSMGR_FRZCTRL_DELAY_LOOP_PARAM (10) +#define SYSMGR_FRZCTRL_INTOSC_33 (33) +#define SYSMGR_FRZCTRL_INTOSC_1000 (1000) +#define FREEZE_CHANNEL_NUM (4) + +typedef enum { + FREEZE_CTRL_FROZEN = 0, + FREEZE_CTRL_THAWED = 1 +} FREEZE_CTRL_CHAN_STATE; + +typedef enum { + FREEZE_CHANNEL_0 = 0, /* EMAC_IO & MIXED2_IO */ + FREEZE_CHANNEL_1, /* MIXED1_IO and FLASH_IO */ + FREEZE_CHANNEL_2, /* General IO */ + FREEZE_CHANNEL_3, /* DDR IO */ + FREEZE_CHANNEL_UNDEFINED +} FreezeChannelSelect; + +typedef enum { + FREEZE_CONTROLLER_FSM_SW = 0, + FREEZE_CONTROLLER_FSM_HW, + FREEZE_CONTROLLER_FSM_UNDEFINED +} FreezeControllerFSMSelect; + +#define SYSMGR_FRZCTRL_ADDRESS 0x40 +#define SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW 0x0 +#define SYSMGR_FRZCTRL_SRC_VIO1_ENUM_HW 0x1 +#define SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK 0x00000010 +#define SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK 0x00000008 +#define SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK 0x00000004 +#define SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK 0x00000002 +#define SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK 0x00000010 +#define SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK 0x00000008 +#define SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK 0x00000004 +#define SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK 0x00000002 +#define SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK 0x00000080 +#define SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK 0x00000040 +#define SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK 0x00000100 +#define SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK 0x00000020 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1REQ_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_FROZEN 0x2 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_THAWED 0x1 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_GET(x) (((x) & 0x00000006) >> 1) +#define SYSMGR_FRZCTRL_VIOCTRL_SHIFT 0x2 + +u32 sys_mgr_frzctrl_freeze_req(FreezeChannelSelect channel_id, + FreezeControllerFSMSelect fsm_select); +u32 sys_mgr_frzctrl_thaw_req(FreezeChannelSelect channel_id, + FreezeControllerFSMSelect fsm_select); + +#endif /* _FREEZE_CONTROLLER_H_ */
Hi!
So... code that is currently in u-boot appears to work, but may produce some unwanted electrical spikes. They don't matter on development boards, but we'd like to get rid of them for production. ?
It would be nice to put some explanation as a comment into code.
Changes for v2
Thanks! Still there's a bit to go:
We no longer need these, right?
Check this one, it may not be needed.
+typedef enum {
- FREEZE_CTRL_FROZEN = 0,
- FREEZE_CTRL_THAWED = 1
This definitely should not be needed.
+typedef enum {
- FREEZE_CHANNEL_0 = 0, /* EMAC_IO & MIXED2_IO */
- FREEZE_CHANNEL_1, /* MIXED1_IO and FLASH_IO */
- FREEZE_CHANNEL_2, /* General IO */
- FREEZE_CHANNEL_3, /* DDR IO */
- FREEZE_CHANNEL_UNDEFINED
CamelCaseIsUnwelcome. And actually haveing enum for numbers 0..3 looks like overkill. Could we just use plain numbers?
+typedef enum {
- FREEZE_CONTROLLER_FSM_SW = 0,
- FREEZE_CONTROLLER_FSM_HW,
- FREEZE_CONTROLLER_FSM_UNDEFINED
No longer needed.
Is this still used?
- FreezeControllerFSMSelect fsm_select);
We can remove second parameter here. And maybe use some more reasonable names.
sysmgr_freeze_req / sysmgr_thaw_req?
Thanks, and sorry for two-phase review. Pavel
Hi Pavel,
On Fri, 2013-09-20 at 00:55 +0200, ZY - pavel wrote:
Hi!
Actually with current code, we still not yet to boot on real board yet. That why I am working hard to get the code upstreamed asap. Of course, appreciate your help too as you are very helpful.
Changes for v2
Yup, actually I miss out the header file after update the source file.
Yup
Actually we still need this to maintain the state of IO. It would be useful for the next new driver "Scan Manager".
+typedef enum {
Same as above
+typedef enum {
Good suggestion. We put that initially due to potential hardware change in initial design. We can remove this now.
+typedef enum {
No longer needed.
Yup :)
Is this still used?
Nope, no more.
Yup removed the second parameter. About the name freeze and thaw, its how its labeled in hardware documentation. :)
No problem as you are very supportive.
Thanks
Chin Liang
Pavel
Chin Liang See
Pavel Machek
