[U-Boot] [PATCH] net: fec_mxc: fix phy-reset-gpios logic
'phy-reset-gpios' property is optional, don't return error when it is missing. Read 'phy-reset-duration' property only if 'phy-reset-gpios' exists. The binding defines the duration value in milliseconds, so use mdelay() for waiting.
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/fec_mxc.c | 20 ++++++++------------ 1 file changed, 8 insertions(+), 12 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index d0fdbcb771..5a1a8bc897 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1254,7 +1254,7 @@ static void fec_gpio_reset(struct fec_priv *priv) debug("fec_gpio_reset: fec_gpio_reset(dev)\n"); if (dm_gpio_is_valid(&priv->phy_reset_gpio)) { dm_gpio_set_value(&priv->phy_reset_gpio, 1); - udelay(priv->reset_delay); + mdelay(priv->reset_delay); dm_gpio_set_value(&priv->phy_reset_gpio, 0); } } @@ -1352,22 +1352,18 @@ static int fecmxc_ofdata_to_platdata(struct udevice *dev)
#ifdef CONFIG_DM_GPIO ret = gpio_request_by_name(dev, "phy-reset-gpios", 0, - &priv->phy_reset_gpio, GPIOD_IS_OUT); - if (ret == 0) { - ret = dev_read_u32_array(dev, "phy-reset-duration", - &priv->reset_delay, 1); - } else if (ret == -ENOENT) { - priv->reset_delay = 1000; - ret = 0; - } + &priv->phy_reset_gpio, GPIOD_IS_OUT); + if (ret < 0) + return 0; /* property is optional, don't return error! */
+ priv->reset_delay = dev_read_u32_default(dev, "phy-reset-duration", 1); if (priv->reset_delay > 1000) { - printf("FEX MXC: gpio reset timeout should be less the 1000\n"); - priv->reset_delay = 1000; + /* property value wrong, use default value */ + priv->reset_delay = 1; } #endif
- return ret; + return 0; }
static const struct udevice_id fecmxc_ids[] = {
Hi Anatolij,
This is already covered in https://patchwork.ozlabs.org/patch/979099/ and https://patchwork.ozlabs.org/patch/979101/
Hi Joe,
On Mon, 22 Oct 2018 21:02:22 +0000 Joe Hershberger joe.hershberger@ni.com wrote: ...
Okay, thanks!
-- Anatolij
Anatolij Gustschin
Joe Hershberger
