[U-Boot] [PATCH 1/2] fdt: add support the ePAPR "phandle" property
The ePAPR specification says that phandle properties should be called "phandle", and not "linux,phandle". To facilitate the migration from "linux,phandle" to "phandle", we update some functions to support both properties.
Signed-off-by: Timur Tabi timur@freescale.com --- common/fdt_support.c | 6 ++++++ include/libfdt.h | 10 ++++++++++ lib/libfdt/fdt_ro.c | 18 ++++++++++++++++++ 3 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 496040b..85715ff 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1187,6 +1187,12 @@ int fdt_alloc_phandle(void *blob)
for (offset = fdt_next_node(blob, -1, NULL); offset >= 0; offset = fdt_next_node(blob, offset, NULL)) { + /* Check the ePAPR-compliant "phandle" property name */ + val = fdt_getprop(blob, offset, "phandle", &len); + if (val) + phandle = max(*val, phandle); + + /* Also check the deprecated "linux,phandle" property name */ val = fdt_getprop(blob, offset, "linux,phandle", &len); if (val) phandle = max(*val, phandle); diff --git a/include/libfdt.h b/include/libfdt.h index d23d40e..092dd34 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -452,6 +452,11 @@ static inline void *fdt_getprop_w(void *fdt, int nodeoffset, * fdt_get_phandle() retrieves the phandle of the device tree node at * structure block offset nodeoffset. * + * Both the ePAPR "phandle" property as well as the legacy "linux,phandle" + * property are supported. If the device tree node contains both properties, + * then "phandle" is used. However, it is considered an error if the two + * properties contain different values. + * * returns: * the phandle of the node at nodeoffset, on success (!= 0, != -1) * 0, if the node has no phandle, or another error occurs @@ -662,6 +667,11 @@ int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle); * 'compatible' property with the given string as one of its elements, * it returns non-zero otherwise, or on error. * + * Both the ePAPR "phandle" property as well as the legacy "linux,phandle" + * property are supported. If the device tree node contains both properties, + * then "phandle" is used. However, it is considered an error if the two + * properties contain different values. + * * returns: * 0, if the node has a 'compatible' property listing the given string * 1, if the node has a 'compatible' property, but it does not list diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index 1e1e322..57a901f 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -278,6 +278,14 @@ uint32_t fdt_get_phandle(const void *fdt, int nodeoffset) const uint32_t *php; int len;
+ /* First, check the "phandle" property */ + php = fdt_getprop(fdt, nodeoffset, "phandle", &len); + if (php) { + /* If the property exists, then use it if it's valid */ + return len == sizeof(*php) ? fdt32_to_cpu(*php) : 0; + } + + /* No "phandle", so check "linux,phandle" */ php = fdt_getprop(fdt, nodeoffset, "linux,phandle", &len); if (!php || (len != sizeof(*php))) return 0; @@ -440,9 +448,19 @@ int fdt_node_offset_by_prop_value(const void *fdt, int startoffset,
int fdt_node_offset_by_phandle(const void *fdt, uint32_t phandle) { + int ret; + if ((phandle == 0) || (phandle == -1)) return -FDT_ERR_BADPHANDLE; phandle = cpu_to_fdt32(phandle); + + /* First check for a matching "phandle" property */ + ret = fdt_node_offset_by_prop_value(fdt, -1, "phandle", + &phandle, sizeof(phandle)); + if (ret > 0) + return ret; + + /* No "phandle", so check "linux,phandle" */ return fdt_node_offset_by_prop_value(fdt, -1, "linux,phandle", &phandle, sizeof(phandle)); }
The ePAPR specification says that phandle properties should be called "phandle", and not "linux,phandle". To facilitate the migration from "linux,phandle" to "phandle", we update fdt_qportal() to support both properties.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/portals.c | 13 ++++++++++++- 1 files changed, 12 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index c014163..bb0ae70 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -151,8 +151,19 @@ static int fdt_qportal(void *blob, int off, int id, char *name, dev_handle = fdt_get_phandle(blob, dev_off); if (dev_handle <= 0) { dev_handle = fdt_alloc_phandle(blob); - fdt_setprop_cell(blob, dev_off, + ret = fdt_setprop_cell(blob, dev_off, + "phandle", dev_handle); + if (ret < 0) + return ret; + /* + * For now, also set the deprecated + * "linux,phandle" property, so that we don't + * break older kernels. + */ + ret = fdt_setprop_cell(blob, dev_off, "linux,phandle", dev_handle); + if (ret < 0) + return ret; }
ret = fdt_setprop(blob, childoff, "dev-handle",
As discussed on IRC, upstream libfdt already supports the "phandle" property, so u-boot needs to be updated to the latest version from the dtc.git repo on git.jdl.com. You'll still need the change to common/fdt_support.c though.
g.
- /* Check the ePAPR-compliant "phandle" property name */
- val = fdt_getprop(blob, offset, "phandle", &len);
- if (val)
- phandle = max(*val, phandle);
- /* Also check the deprecated "linux,phandle" property name */
- Both the ePAPR "phandle" property as well as the legacy "linux,phandle"
- property are supported. If the device tree node contains both properties,
- then "phandle" is used. However, it is considered an error if the two
- properties contain different values.
- /* First, check the "phandle" property */
- php = fdt_getprop(fdt, nodeoffset, "phandle", &len);
- if (php) {
- /* If the property exists, then use it if it's valid */
- return len == sizeof(*php) ? fdt32_to_cpu(*php) : 0;
- /* No "phandle", so check "linux,phandle" */
- int ret;
- /* First check for a matching "phandle" property */
- ret = fdt_node_offset_by_prop_value(fdt, -1, "phandle",
- &phandle, sizeof(phandle));
- if (ret > 0)
- return ret;
return fdt_node_offset_by_prop_value(fdt, -1, "linux,phandle", &phandle, sizeof(phandle)); } -- 1.7.3.4
Upstream libfdt was fixed back in 2009. Why is U-Boot and Linux so outdated? Shouldn't there be a regular plan to update U-boot and Linux as libfdt is updated? I don't see how an 18-month backlog is acceptable.
No offense, but this sounds like something the U-boot fdt maintainer is supposed to be doing regularly.
Grant Likely
Timur Tabi
