Re: [DNX#2006040142000321] [U-Boot-Users] PATCH cmd_net.c check ethernet avai [...]
1 Apr
2006
1 Apr
'06
12:20 a.m.
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142000321] was created:
<snip>
We have a board where the ethernet is on a plugin module and may or may not be present at boot time. If eth_initialize() doesn't detect the network and a net command is run the system crashes. This patch adds a function to cmd_net.c to check the availability of the ethernet device before trying to access it. If the net device is not found it will print a message and return -1.
- Add check to cmd_net functions to make sure ethernet device is valid
before calling Net_Loop() Patch by Andrew Dyer, 24 Oct 2005
Signed-off-by: Andrew Dyer amdyer@gmail.com
-- Hardware, n.: The parts of a computer system that can be kicked.
</snip>
Your U-Boot support team
6978
DENX Support System
