Some questions about the U-Boot verified boot
Hello everyone,
I have a question about the verified boot, is it possible to sign both images and configurations in the same fitimage?
I ask the question because when I try to do that then the image signature checking always fails, when calling the source command, without preventing the loading of the bootscr.
I would like that the loading is strictly interrupted, in case of failure of an image signature checking or a configuration signature checking.
Moreover, when configurations aren’t signed or with an invalid key then an error is well raised and loading interrupted.
In addition, from the dtb, the property “required” of the signature node is set to config. Then it doesn’t seem possible to sign images and configurations with the same key, even using different fitimage. Could using two keys solve my issue?
Is there a way to make the verified boot strict, to prohibit the use of fitimage which does not contain any signature, and ensure that either the images or the configurations are always signed? In my case, setting the variable verify=yes seems doesn’t work correctly.
NB. I’m using the version 2020.04.
Best regards, Thomas Perrot
Thomas Perrot
