[PATCH 1/1] efi_loader: efi_dp_from_lo() unused parameter size
Parameter size is never used in function efi_dp_from_lo(). Remove it.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/efidebug.c | 3 +-- include/efi_loader.h | 1 - lib/efi_loader/efi_device_path.c | 2 -- lib/efi_loader/efi_helper.c | 2 +- 4 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 70a4658012..33a5135ee1 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -1144,7 +1144,6 @@ static void show_efi_boot_opt_data(u16 *varname16, void *data, size_t *size) struct efi_device_path *initrd_path = NULL; struct efi_load_option lo; efi_status_t ret; - efi_uintn_t initrd_dp_size; const efi_guid_t lf2_initrd_guid = EFI_INITRD_MEDIA_GUID;
ret = efi_deserialize_load_option(&lo, data, size); @@ -1166,7 +1165,7 @@ static void show_efi_boot_opt_data(u16 *varname16, void *data, size_t *size)
printf(" file_path: %pD\n", lo.file_path);
- initrd_path = efi_dp_from_lo(&lo, &initrd_dp_size, &lf2_initrd_guid); + initrd_path = efi_dp_from_lo(&lo, &lf2_initrd_guid); if (initrd_path) { printf(" initrd_path: %pD\n", initrd_path); efi_free_pool(initrd_path); diff --git a/include/efi_loader.h b/include/efi_loader.h index 6e806f9b0d..3e5ac38042 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -842,7 +842,6 @@ struct efi_load_option { };
struct efi_device_path *efi_dp_from_lo(struct efi_load_option *lo, - efi_uintn_t *size, const efi_guid_t *guid); struct efi_device_path *efi_dp_concat(const struct efi_device_path *dp1, const struct efi_device_path *dp2); diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index c3139f8e64..aaf1999d46 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1263,7 +1263,6 @@ ssize_t efi_dp_check_length(const struct efi_device_path *dp, * initrd location * * @lo: EFI_LOAD_OPTION containing a valid device path - * @size: size of the discovered device path * @guid: guid to search for * * Return: @@ -1272,7 +1271,6 @@ ssize_t efi_dp_check_length(const struct efi_device_path *dp, */ struct efi_device_path *efi_dp_from_lo(struct efi_load_option *lo, - efi_uintn_t *size, const efi_guid_t *guid) { struct efi_device_path *fp = lo->file_path; diff --git a/lib/efi_loader/efi_helper.c b/lib/efi_loader/efi_helper.c index 4c5b7cd2e1..89833de222 100644 --- a/lib/efi_loader/efi_helper.c +++ b/lib/efi_loader/efi_helper.c @@ -83,7 +83,7 @@ struct efi_device_path *efi_get_dp_from_boot(const efi_guid_t guid) if (ret != EFI_SUCCESS) goto out;
- tmp = efi_dp_from_lo(&lo, &size, &guid); + tmp = efi_dp_from_lo(&lo, &guid); if (!tmp) goto out;
-- 2.30.2
- initrd_path = efi_dp_from_lo(&lo, &lf2_initrd_guid); if (initrd_path) { printf(" initrd_path: %pD\n", initrd_path); efi_free_pool(initrd_path);
initrd location
- @lo: EFI_LOAD_OPTION containing a valid device path
- @size: size of the discovered device path
- @guid: guid to search for
- Return:
- tmp = efi_dp_from_lo(&lo, &guid); if (!tmp) goto out;
-- 2.30.2
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
