[U-Boot] [PATCH 1/2][v2] pci/layerscape: remove unnecessary pcie_layerscape.h
The patch uses the common function name ft_pci_setup to replace ft_pcie_setup, then removes unnecessary pcie_layerscape.h because all the functions have been declared in common.h.
Signed-off-by: Minghuan Lian Minghuan.Lian@freescale.com --- change log: v1-v2: remove unnecessary pcie_layerscape.h
arch/arm/include/asm/pcie_layerscape.h | 13 ------------- board/freescale/ls1021aqds/ls1021aqds.c | 5 ++--- board/freescale/ls1021atwr/ls1021atwr.c | 5 ++--- drivers/pci/pcie_layerscape.c | 5 ++--- 4 files changed, 6 insertions(+), 22 deletions(-) delete mode 100644 arch/arm/include/asm/pcie_layerscape.h
diff --git a/arch/arm/include/asm/pcie_layerscape.h b/arch/arm/include/asm/pcie_layerscape.h deleted file mode 100644 index fb08578..0000000 --- a/arch/arm/include/asm/pcie_layerscape.h +++ /dev/null @@ -1,13 +0,0 @@ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __PCIE_LAYERSCAPE_H_ -#define __PCIE_LAYERSCAPE_H_ - -void pci_init_board(void); -void ft_pcie_setup(void *blob, bd_t *bd); - -#endif diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 722b88f..bcd4361 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -12,7 +12,6 @@ #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> -#include <asm/pcie_layerscape.h> #include <hwconfig.h> #include <mmc.h> #include <fsl_esdhc.h> @@ -595,8 +594,8 @@ int ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd);
-#ifdef CONFIG_PCIE_LAYERSCAPE - ft_pcie_setup(blob, bd); +#ifdef CONFIG_PCI + ft_pci_setup(blob, bd); #endif
return 0; diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index fb8525f..53fc4f8 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -12,7 +12,6 @@ #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> -#include <asm/pcie_layerscape.h> #include <mmc.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> @@ -475,8 +474,8 @@ int ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd);
return 0; diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index bcad8f2..1b0b814 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -11,7 +11,6 @@ #include <asm/io.h> #include <errno.h> #include <malloc.h> -#include <asm/pcie_layerscape.h>
#ifndef CONFIG_SYS_PCI_MEMORY_BUS #define CONFIG_SYS_PCI_MEMORY_BUS CONFIG_SYS_SDRAM_BASE @@ -486,7 +485,7 @@ static void ft_pcie_ls_setup(void *blob, const char *pci_compat, fdt_set_node_status(blob, off, FDT_STATUS_DISABLED, 0); }
-void ft_pcie_setup(void *blob, bd_t *bd) +void ft_pci_setup(void *blob, bd_t *bd) { #ifdef CONFIG_PCIE1 ft_pcie_ls_setup(blob, FSL_PCIE_COMPAT, CONFIG_SYS_PCIE1_ADDR, PCIE1); @@ -506,7 +505,7 @@ void ft_pcie_setup(void *blob, bd_t *bd) }
#else -void ft_pcie_setup(void *blob, bd_t *bd) +void ft_pci_setup(void *blob, bd_t *bd) { } #endif
1. LS2085a provides PCIE_LUT_DBG register rather than PCIE_LDBG to show the link status, so the patch fixes it. 2. Increase the delay time to make sure that link training has finished. 3. Return invalid value when accessing multi-function device 4. For LS2085a DBI_RO_WR_EN bit is cleared as default, so we must set this bit before change DBI register value.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Minghuan Lian Minghuan.Lian@freescale.com --- change log: v1-v2: no change
drivers/pci/pcie_layerscape.c | 47 ++++++++++++++++++++++++++++++------------- 1 file changed, 33 insertions(+), 14 deletions(-)
diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 1b0b814..402c519 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -49,11 +49,20 @@ #define PCIE_ATU_FUNC(x) (((x) & 0x7) << 16) #define PCIE_ATU_UPPER_TARGET 0x91C
+/* LUT registers */ +#define PCIE_LUT_BASE 0x80000 +#define PCIE_LUT_DBG 0x7FC + +#define PCIE_DBI_RO_WR_EN 0x8bc + #define PCIE_LINK_CAP 0x7c #define PCIE_LINK_SPEED_MASK 0xf #define PCIE_LINK_STA 0x82
-#define PCIE_DBI_SIZE (4 * 1024) /* 4K */ +#define LTSSM_STATE_MASK 0x3f +#define LTSSM_PCIE_L0 0x11 /* L0 state */ + +#define PCIE_DBI_SIZE 0x100000 /* 1M */
struct ls_pcie { int idx; @@ -103,8 +112,6 @@ struct ls_pcie_info {
/* PEX1/2 Misc Ports Status Register */ #define LTSSM_STATE_SHIFT 20 -#define LTSSM_STATE_MASK 0x3f -#define LTSSM_PCIE_L0 0x11 /* L0 state */
static int ls_pcie_link_state(struct ls_pcie *pcie) { @@ -121,18 +128,18 @@ static int ls_pcie_link_state(struct ls_pcie *pcie) return 1; } #else -#define PCIE_LDBG 0x7FC - static int ls_pcie_link_state(struct ls_pcie *pcie) { u32 state;
- state = readl(pcie->dbi + PCIE_LDBG); - if (state) - return 1; + state = readl(pcie->dbi + PCIE_LUT_BASE + PCIE_LUT_DBG) & + LTSSM_STATE_MASK; + if (state < LTSSM_PCIE_L0) { + debug("....PCIe link error. LTSSM=0x%02x.\n", state); + return 0; + }
- debug("....PCIe link error.\n"); - return 0; + return 1; } #endif
@@ -148,7 +155,11 @@ static int ls_pcie_link_up(struct ls_pcie *pcie) /* Try to download speed to gen1 */ cap = readl(pcie->dbi + PCIE_LINK_CAP); writel((cap & (~PCIE_LINK_SPEED_MASK)) | 1, pcie->dbi + PCIE_LINK_CAP); - udelay(2000); + /* + * Notice: the following delay has critical impact on link training + * if too short (<30ms) the link doesn't get up. + */ + mdelay(100); state = ls_pcie_link_state(pcie); if (state) return state; @@ -250,6 +261,10 @@ static int ls_pcie_addr_valid(struct pci_controller *hose, pci_dev_t d) if (PCI_DEV(d) > 0) return -EINVAL;
+ /* Controller does not support multi-function in RC mode */ + if ((PCI_BUS(d) == hose->first_busno) && (PCI_FUNC(d) > 0)) + return -EINVAL; + return 0; }
@@ -326,8 +341,12 @@ static void ls_pcie_setup_ctrl(struct ls_pcie *pcie, pci_hose_write_config_dword(hose, dev, PCI_BASE_ADDRESS_0, 0);
/* program correct class for RC */ + writel(1, pcie->dbi + PCIE_DBI_RO_WR_EN); pci_hose_write_config_word(hose, dev, PCI_CLASS_DEVICE, PCI_CLASS_BRIDGE_PCI); +#ifndef CONFIG_LS102XA + writel(0, pcie->dbi + PCIE_DBI_RO_WR_EN); +#endif }
int ls_pcie_init_ctrl(int busno, enum srds_prtcl dev, struct ls_pcie_info *info) @@ -416,9 +435,9 @@ int ls_pcie_init_ctrl(int busno, enum srds_prtcl dev, struct ls_pcie_info *info) }
/* Print the negotiated PCIe link width */ - pci_hose_read_config_word(hose, dev, PCIE_LINK_STA, &temp16); - printf("x%d gen%d, regs @ 0x%lx\n", (temp16 & 0x3f0) >> 4, - (temp16 & 0xf), info->regs); + pci_hose_read_config_word(hose, pdev, PCIE_LINK_STA, &temp16); + printf("x%d gen%d, regs @ 0x%lx\n", (temp16 & 0x3f0) >> 4, + (temp16 & 0xf), info->regs);
if (ep_mode) return busno;
On 03/11/2015 07:58 PM, Minghuan Lian wrote:
- LS2085a provides PCIE_LUT_DBG register rather than PCIE_LDBG to show the link status, so the patch fixes it.
- Increase the delay time to make sure that link training has finished.
- Return invalid value when accessing multi-function device
- For LS2085a DBI_RO_WR_EN bit is cleared as default, so we must set this bit before change DBI register value.
Applied to fsl-qoriq master, awaiting upstream.
York
Thanks for reworking things!
York
Minghuan Lian
York Sun
