[U-Boot] [PATCH v2 0/3] omap: Provide fastboot variables for fastboot.sh
fastboot.sh is a script used for flashing Android images for TI boards (and can be found in corresponding AOSP sources). This script relies on some fastboot variables, which can be accessed with "fastboot getvar" command.
This patch series exports those variables, which fastboot.sh script relies on. The list of added variables: - "cpu": CPU type (string, like "DRA752") - "secure": CPU security index (string, like "GP") - "board_rev": board revision (string, like "A.30") - "userdata_size": size of userdata partition (number, in KiB)
Variables are enabled for AM57x EVM and DRA7 EVM boards, which are mainly supported TI boards, capable of Android running.
Changes in v2: - use get_device_type() instead of omap_get_cpu_type() - guard omap_set_fastboot_vars() with CONFIG_FASTBOOT_FLASH - use correct board names
Sam Protsenko (3): omap: Add routine for setting fastboot variables arm: am57xx: Set fastboot variables in environment arm: dra7: Set fastboot variables in environment
arch/arm/include/asm/omap_common.h | 6 ++ arch/arm/mach-omap2/utils.c | 115 +++++++++++++++++++++++++++++++++++++ board/ti/am57xx/board.c | 1 + board/ti/dra7xx/evm.c | 1 + 4 files changed, 123 insertions(+)
This patch reuses new option, which allows us to expose variables from environment to "fastboot getvar" command. Those variables must be of "fastboot.%s" format.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- Changes in v2: - use get_device_type() instead of omap_get_cpu_type() - guard omap_set_fastboot_vars() with CONFIG_FASTBOOT_FLASH - use correct board names
arch/arm/include/asm/omap_common.h | 6 ++ arch/arm/mach-omap2/utils.c | 115 +++++++++++++++++++++++++++++++++++++ 2 files changed, 121 insertions(+)
diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index c1a70b15d0..a4bfa0c451 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -643,6 +643,12 @@ void omap_die_id_get_board_serial(struct tag_serialnr *serialnr); void omap_die_id_usbethaddr(void); void omap_die_id_display(void);
+#ifdef CONFIG_FASTBOOT_FLASH +void omap_set_fastboot_vars(void); +#else +static inline void omap_set_fastboot_vars(void) { } +#endif + void recalibrate_iodelay(void);
void omap_smc1(u32 service, u32 val); diff --git a/arch/arm/mach-omap2/utils.c b/arch/arm/mach-omap2/utils.c index 2d03ebfbd3..1d0b63350a 100644 --- a/arch/arm/mach-omap2/utils.c +++ b/arch/arm/mach-omap2/utils.c @@ -18,6 +18,121 @@ static void do_cancel_out(u32 *num, u32 *den, u32 factor) } }
+#ifdef CONFIG_FASTBOOT_FLASH +static void omap_set_fastboot_cpu(void) +{ + char *cpu; + u32 cpu_rev = omap_revision(); + + switch (cpu_rev) { + case DRA752_ES1_0: + case DRA752_ES1_1: + case DRA752_ES2_0: + cpu = "DRA752"; + break; + case DRA722_ES1_0: + case DRA722_ES2_0: + cpu = "DRA722"; + break; + default: + cpu = NULL; + printf("Warning: fastboot.cpu: unknown CPU rev: %u\n", cpu_rev); + } + + setenv("fastboot.cpu", cpu); +} + +static void omap_set_fastboot_secure(void) +{ + const char *secure; + u32 dev = get_device_type(); + + switch (dev) { + case EMU_DEVICE: + secure = "EMU"; + break; + case HS_DEVICE: + secure = "HS"; + break; + case GP_DEVICE: + secure = "GP"; + break; + default: + secure = NULL; + printf("Warning: fastboot.secure: unknown CPU sec: %u\n", dev); + } + + setenv("fastboot.secure", secure); +} + +static void omap_set_fastboot_board_rev(void) +{ + const char *board_rev; + + board_rev = getenv("board_rev"); + if (board_rev == NULL) + printf("Warning: fastboot.board_rev: unknown board revision\n"); + + setenv("fastboot.board_rev", board_rev); +} + +#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV +static u32 omap_mmc_get_part_size(const char *part) +{ + int res; + struct blk_desc *dev_desc; + disk_partition_t info; + u64 sz = 0; + + dev_desc = blk_get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); + if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { + error("invalid mmc device\n"); + return 0; + } + + res = part_get_info_by_name(dev_desc, part, &info); + if (res < 0) { + error("cannot find partition: '%s'\n", part); + return 0; + } + + /* Calculate size in bytes */ + sz = (info.size * (u64)info.blksz); + /* to KiB */ + sz >>= 10; + + return (u32)sz; +} + +static void omap_set_fastboot_userdata_size(void) +{ + char buf[16]; + u32 sz_kb; + + sz_kb = omap_mmc_get_part_size("userdata"); + if (sz_kb == 0) { + buf[0] = '\0'; + printf("Warning: fastboot.userdata_size: unable to calc\n"); + } else { + sprintf(buf, "%u", sz_kb); + } + + setenv("fastboot.userdata_size", buf); +} +#else +static inline void omap_set_fastboot_userdata_size(void) +{ +} +#endif /* CONFIG_FASTBOOT_FLASH_MMC_DEV */ +void omap_set_fastboot_vars(void) +{ + omap_set_fastboot_cpu(); + omap_set_fastboot_secure(); + omap_set_fastboot_board_rev(); + omap_set_fastboot_userdata_size(); +} +#endif /* CONFIG_FASTBOOT_FLASH */ + /* * Cancel out the denominator and numerator of a fraction * to get smaller numerator and denominator.
Changes in v2:
- char *cpu;
- u32 cpu_rev = omap_revision();
- switch (cpu_rev) {
- case DRA752_ES1_0:
- case DRA752_ES1_1:
- case DRA752_ES2_0:
cpu = "DRA752";
break;
- case DRA722_ES1_0:
- case DRA722_ES2_0:
cpu = "DRA722";
break;
- default:
cpu = NULL;
- setenv("fastboot.cpu", cpu);
- const char *secure;
- u32 dev = get_device_type();
- switch (dev) {
- case EMU_DEVICE:
secure = "EMU";
break;
- case HS_DEVICE:
secure = "HS";
break;
- case GP_DEVICE:
secure = "GP";
break;
- default:
secure = NULL;
- setenv("fastboot.secure", secure);
OK, this shows that the code we have in arch/arm/mach-omap2/am33xx/sys_info.c and arch/arm/mach-omap2/hwinit-common.c and arch/arm/mach-omap2/omap3/sys_info.c needs to get re-worked a bit so that we: - Don't bloat families that we won't have (since we know at build time what's possible) - Don't repeat the same code in N places to check device type / family / PG.
Yes, this will require a little more work as the fastboot side is OK with "DRA722", the question I have is can we construct that similar to what omap_rev_string() does? Thanks!
One can obtain those variables using next commands:
$ fastboot getvar cpu $ fastboot getvar secure $ fastboot getvar board_rev $ fastboot getvar userdata_size
Those variables are needed for fastboot.sh script.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- Changes in v2: None
board/ti/am57xx/board.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 3be697a6ea..c8ebcdbcc8 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -573,6 +573,7 @@ int board_late_init(void) val);
omap_die_id_serial(); + omap_set_fastboot_vars();
am57x_idk_lcd_detect();
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org Reviewed-by: Tom Rini trini@konsulko.com
board/ti/dra7xx/evm.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 8c02addd08..7d36f03fa1 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -561,6 +561,7 @@ int board_late_init(void) setenv("boot_fit", "1");
omap_die_id_serial(); + omap_set_fastboot_vars(); #endif return 0; }
Sam Protsenko
