[PATCH 0/2] ARM: meson: Add initial support for BPI-CM4 module with BPI-CM4IO baseboard
Add support for both the BananaPi BPI-CM4 module and the BananaPi baseboard which is compatible with the RaspberryPi CM4IO baseboard.
The BananaPi BPI-CM4 module follows the CM4 specifications at [1], but with a single HDMI port and a single DSI output.
The current CM4IO baseboard DT should work fine on the Raspberry CM4 baseboard and other derivatives baseboards, but proper DT should be written for other baseboards.
The DT is imported from the submission done at [2] and applied at [3].
[1] https://datasheets.raspberrypi.com/cm4io/cm4io-datasheet.pdf [2] https://lore.kernel.org/all/20230303-topic-amlogic-upstream-bpi-cm4-v2-0-2ec... [3] https://git.kernel.org/amlogic/c/0262f2736978b1763363224698f47112a148dab0
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- Neil Armstrong (2): ARM: dts: import initial DT for BPI-CM4 module with BPI-CM4IO baseboard ARM: meson: Add initial support for BPI-CM4 module with BPI-CM4IO baseboard
arch/arm/dts/Makefile | 1 + .../dts/meson-g12b-bananapi-cm4-cm4io-u-boot.dtsi | 6 + arch/arm/dts/meson-g12b-bananapi-cm4-cm4io.dts | 165 +++++++++ arch/arm/dts/meson-g12b-bananapi-cm4.dtsi | 388 +++++++++++++++++++++ board/amlogic/u200/MAINTAINERS | 1 + configs/bananapi-cm4-cm4io_defconfig | 84 +++++ doc/board/amlogic/index.rst | 1 + 7 files changed, 646 insertions(+) --- base-commit: b08ffdffdce95e267e782366f4a77bf6b5537b28 change-id: 20230307-u-boot-cm4-1311815d8371
Import initial support for BPI-CM4 module with BPI-CM4IO baseboard from the Linux submission applied at [1].
The BananaPi BPI-CM4 module follows the CM4 specifications at [2], but with a single HDMI port and a single DSI output.
[1] https://git.kernel.org/amlogic/c/0262f2736978b1763363224698f47112a148dab0 [2] https://datasheets.raspberrypi.com/cm4io/cm4io-datasheet.pdf
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- arch/arm/dts/Makefile | 1 + arch/arm/dts/meson-g12b-bananapi-cm4-cm4io.dts | 165 +++++++++++ arch/arm/dts/meson-g12b-bananapi-cm4.dtsi | 388 +++++++++++++++++++++++++ 3 files changed, 554 insertions(+)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c160e884bf..0c149b636a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -212,6 +212,7 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-g12b-odroid-n2.dtb \ meson-g12b-odroid-n2l.dtb \ meson-g12b-odroid-n2-plus.dtb \ + meson-g12b-bananapi-cm4-cm4io.dtb \ meson-sm1-bananapi-m5.dtb \ meson-sm1-khadas-vim3l.dtb \ meson-sm1-odroid-c4.dtb \ diff --git a/arch/arm/dts/meson-g12b-bananapi-cm4-cm4io.dts b/arch/arm/dts/meson-g12b-bananapi-cm4-cm4io.dts new file mode 100644 index 0000000000..1b0c3881c6 --- /dev/null +++ b/arch/arm/dts/meson-g12b-bananapi-cm4-cm4io.dts @@ -0,0 +1,165 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Neil Armstrong neil.armstrong@linaro.org + */ + +/dts-v1/; + +#include "meson-g12b-bananapi-cm4.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h> + +/ { + compatible = "bananapi,bpi-cm4io", "bananapi,bpi-cm4", "amlogic,a311d", "amlogic,g12b"; + model = "BananaPi BPI-CM4IO Baseboard with BPI-CM4 Module"; + + aliases { + ethernet0 = ðmac; + i2c0 = &i2c1; + i2c1 = &i2c3; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 2>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1710000>; + + button-function { + label = "Function"; + linux,code = <KEY_FN>; + press-threshold-microvolt = <10000>; + }; + }; + + hdmi_connector: hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + led-blue { + color = <LED_COLOR_ID_BLUE>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio_ao GPIOAO_7 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + led-green { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>; + }; + }; + + sound { + compatible = "amlogic,axg-sound-card"; + model = "BPI-CM4IO"; + audio-aux-devs = <&tdmout_b>; + audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", + "TDMOUT_B IN 1", "FRDDR_B OUT 1", + "TDMOUT_B IN 2", "FRDDR_C OUT 1", + "TDM_B Playback", "TDMOUT_B OUT"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-3 { + sound-dai = <&tdmif_b>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; + }; + }; + + /* hdmi glue */ + dai-link-4 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&cecb_AO { + status = "okay"; +}; + +ðmac { + status = "okay"; +}; + +&hdmi_tx { + status = "okay"; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +/* CSI port */ +&i2c1 { + status = "okay"; +}; + +/* DSI port for touchscreen */ +&i2c3 { + status = "okay"; +}; + +/* miniPCIe port with USB + SIM slot */ +&pcie { + status = "okay"; +}; + +&sd_emmc_b { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; + +/* Peripheral Only USB-C port */ +&usb { + dr_mode = "peripheral"; + + status = "okay"; +}; diff --git a/arch/arm/dts/meson-g12b-bananapi-cm4.dtsi b/arch/arm/dts/meson-g12b-bananapi-cm4.dtsi new file mode 100644 index 0000000000..97e522921b --- /dev/null +++ b/arch/arm/dts/meson-g12b-bananapi-cm4.dtsi @@ -0,0 +1,388 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Neil Armstrong neil.armstrong@linaro.org + */ + +#include "meson-g12b-a311d.dtsi" +#include <dt-bindings/gpio/meson-g12a-gpio.h> + +/ { + aliases { + serial0 = &uart_AO; + rtc1 = &vrtc; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x40000000>; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&gpio GPIOAO_6 GPIO_ACTIVE_LOW>; + clocks = <&wifi32k>; + clock-names = "ext_clock"; + }; + + emmc_1v8: regulator-emmc-1v8 { + compatible = "regulator-fixed"; + regulator-name = "EMMC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + }; + + dc_in: regulator-dc-in { + compatible = "regulator-fixed"; + regulator-name = "DC_IN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + vddio_c: regulator-vddio-c { + compatible = "regulator-gpio"; + regulator-name = "VDDIO_C"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + enable-gpio = <&gpio_ao GPIOAO_3 GPIO_OPEN_DRAIN>; + enable-active-high; + regulator-always-on; + + gpios = <&gpio_ao GPIOAO_9 GPIO_OPEN_DRAIN>; + gpios-states = <1>; + + states = <1800000 0>, + <3300000 1>; + }; + + vddao_1v8: regulator-vddao-1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + }; + + vddao_3v3: regulator-vddao-3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_in>; + regulator-always-on; + }; + + vddcpu_a: regulator-vddcpu-a { + /* + * MP8756GD DC/DC Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU_A"; + regulator-min-microvolt = <680000>; + regulator-max-microvolt = <1040000>; + + pwm-supply = <&dc_in>; + + pwms = <&pwm_ab 0 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + vddcpu_b: regulator-vddcpu-b { + /* + * SY8120B1ABC DC/DC Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU_B"; + regulator-min-microvolt = <680000>; + regulator-max-microvolt = <1040000>; + + pwm-supply = <&dc_in>; + + pwms = <&pwm_AO_cd 1 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + wifi32k: wifi32k { + compatible = "pwm-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ + }; +}; + +&arb { + status = "okay"; +}; + +&clkc_audio { + status = "okay"; +}; + +&cec_AO { + pinctrl-0 = <&cec_ao_a_h_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; +}; + +&cecb_AO { + pinctrl-0 = <&cec_ao_b_h_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; +}; + +&cpu0 { + cpu-supply = <&vddcpu_b>; + operating-points-v2 = <&cpu_opp_table_0>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu1 { + cpu-supply = <&vddcpu_b>; + operating-points-v2 = <&cpu_opp_table_0>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu100 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu101 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu102 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu103 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&ext_mdio { + external_phy: ethernet-phy@0 { + /* Realtek RTL8211F (0x001cc916) */ + reg = <0>; + max-speed = <1000>; + + interrupt-parent = <&gpio_intc>; + /* MAC_INTR on GPIOZ_14 */ + interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +/* Ethernet to be enabled in baseboard DT */ +ðmac { + pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; + pinctrl-names = "default"; + phy-mode = "rgmii-txid"; + phy-handle = <&external_phy>; +}; + +&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + +/* HDMI to be enabled in baseboard DT */ +&hdmi_tx { + pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; + pinctrl-names = "default"; + hdmi-supply = <&dc_in>; +}; + +/* "Camera" I2C bus */ +&i2c1 { + pinctrl-0 = <&i2c1_sda_h6_pins>, <&i2c1_sck_h7_pins>; + pinctrl-names = "default"; +}; + +/* Main I2C bus */ +&i2c2 { + pinctrl-0 = <&i2c2_sda_x_pins>, <&i2c2_sck_x_pins>; + pinctrl-names = "default"; +}; + +/* "ID" I2C bus */ +&i2c3 { + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; +}; + +&pcie { + reset-gpios = <&gpio GPIOA_8 GPIO_ACTIVE_LOW>; +}; + +&pwm_ab { + pinctrl-0 = <&pwm_a_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin0"; + + status = "okay"; +}; + +&pwm_ef { + pinctrl-0 = <&pwm_e_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; + +&pwm_AO_cd { + pinctrl-0 = <&pwm_ao_d_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin1"; + + status = "okay"; +}; + +&saradc { + vref-supply = <&vddao_1v8>; + + status = "okay"; +}; + +/* on-module SDIO WiFi */ +&sd_emmc_a { + pinctrl-0 = <&sdio_pins>; + pinctrl-1 = <&sdio_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + #address-cells = <1>; + #size-cells = <0>; + + bus-width = <4>; + sd-uhs-sdr104; + max-frequency = <50000000>; + + non-removable; + disable-wp; + + /* WiFi firmware requires power in suspend */ + keep-power-in-suspend; + + mmc-pwrseq = <&sdio_pwrseq>; + + vmmc-supply = <&vddao_3v3>; + vqmmc-supply = <&vddao_3v3>; + + status = "okay"; + + rtl8822cs: wifi@1 { + reg = <1>; + }; +}; + +/* SD card to be enabled in baseboard DT */ +&sd_emmc_b { + pinctrl-0 = <&sdcard_c_pins>; + pinctrl-1 = <&sdcard_clk_gate_c_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <50000000>; + disable-wp; + + cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; + vmmc-supply = <&vddao_3v3>; + vqmmc-supply = <&vddio_c>; +}; + +/* on-module eMMC */ +&sd_emmc_c { + pinctrl-0 = <&emmc_ctrl_pins>, <&emmc_data_8b_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vddao_3v3>; + vqmmc-supply = <&vddao_1v8>; + + status = "okay"; +}; + +&tdmif_b { + status = "okay"; +}; + +&tdmout_b { + status = "okay"; +}; + +/* on-module UART BT */ +&uart_A { + pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; + pinctrl-names = "default"; + uart-has-rtscts; + + status = "okay"; + + bluetooth { + compatible = "realtek,rtl8822cs-bt"; + enable-gpios = <&gpio GPIOX_17 GPIO_ACTIVE_HIGH>; + host-wake-gpios = <&gpio GPIOX_19 GPIO_ACTIVE_HIGH>; + device-wake-gpios = <&gpio GPIOX_18 GPIO_ACTIVE_HIGH>; + }; +}; + +&uart_AO { + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; + +&usb { + phys = <&usb2_phy0>, <&usb2_phy1>; + phy-names = "usb2-phy0", "usb2-phy1"; +};
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- .../dts/meson-g12b-bananapi-cm4-cm4io-u-boot.dtsi | 6 ++ board/amlogic/u200/MAINTAINERS | 1 + configs/bananapi-cm4-cm4io_defconfig | 84 ++++++++++++++++++++++ doc/board/amlogic/index.rst | 1 + 4 files changed, 92 insertions(+)
diff --git a/arch/arm/dts/meson-g12b-bananapi-cm4-cm4io-u-boot.dtsi b/arch/arm/dts/meson-g12b-bananapi-cm4-cm4io-u-boot.dtsi new file mode 100644 index 0000000000..a60ba27806 --- /dev/null +++ b/arch/arm/dts/meson-g12b-bananapi-cm4-cm4io-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Neil Armstrong neil.armstrong@linaro.org + */ + +#include "meson-g12-common-u-boot.dtsi" diff --git a/board/amlogic/u200/MAINTAINERS b/board/amlogic/u200/MAINTAINERS index 47cec234a1..7535e489d1 100644 --- a/board/amlogic/u200/MAINTAINERS +++ b/board/amlogic/u200/MAINTAINERS @@ -4,6 +4,7 @@ S: Maintained L: u-boot-amlogic@groups.io F: board/amlogic/u200/ F: configs/u200_defconfig +F: configs/bananapi-cm4-cm4io_defconfig F: configs/bananapi-m5_defconfig F: configs/radxa-zero_defconfig F: doc/board/amlogic/u200.rst diff --git a/configs/bananapi-cm4-cm4io_defconfig b/configs/bananapi-cm4-cm4io_defconfig new file mode 100644 index 0000000000..0801b9d06f --- /dev/null +++ b/configs/bananapi-cm4-cm4io_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_TEXT_BASE=0x01000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="meson-g12b-bananapi-cm4-cm4io" +CONFIG_MESON_G12A=y +CONFIG_DEBUG_UART_BASE=0xff803000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING="bpi-cm4io" +CONFIG_SYS_LOAD_ADDR=0x1000000 +CONFIG_DEBUG_UART=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x20000000 +CONFIG_REMAKE_ELF=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_MISC_INIT_R=y +CONFIG_SYS_MAXARGS=32 +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ADC=y +CONFIG_SARADC_MESON=y +CONFIG_BUTTON=y +CONFIG_BUTTON_ADC=y +CONFIG_MMC_MESON_GX=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_ETH_DESIGNWARE_MESON8B=y +CONFIG_MDIO_MUX_MESON_G12A=y +CONFIG_PCI=y +CONFIG_PCIE_DW_MESON=y +CONFIG_MESON_G12A_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_G12A=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_EE_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_SYSINFO=y +CONFIG_SYSINFO_SMBIOS=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_MESON_G12A=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP16 is not set +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_BMP_16BPP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/doc/board/amlogic/index.rst b/doc/board/amlogic/index.rst index f945f672dd..e51b904582 100644 --- a/doc/board/amlogic/index.rst +++ b/doc/board/amlogic/index.rst @@ -22,6 +22,7 @@ This matrix concerns the actual source code version. | | | JetHub J80 | | | | Odroid-Go- | BananaPi-M5 | | | | | | | | Ultra | | | | | | | | | Odroid-N2L | | +| | | | | | | BPI-M4 | | +-------------------------------+-----------+-----------------+--------------+-------------+------------+-------------+--------------+ | UART | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | +-------------------------------+-----------+-----------------+--------------+-------------+------------+-------------+--------------+
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-amlogic (u-boot-amlogic-next)
[1/2] ARM: dts: import initial DT for BPI-CM4 module with BPI-CM4IO baseboard https://source.denx.de/u-boot/custodians/u-boot-amlogic/-/commit/384bfe31c8d... [2/2] ARM: meson: Add initial support for BPI-CM4 module with BPI-CM4IO baseboard https://source.denx.de/u-boot/custodians/u-boot-amlogic/-/commit/cc073f6c224...
Neil Armstrong
