[PATCH] rtc: move pcf8563 to Kconfig
add Kconfig option for pcf8563 driver and run tools/moveconfig.py
Signed-off-by: Heiko Schocher hs@denx.de --- travis build: https://travis-ci.org/github/hsdenx/u-boot-test/builds/736276882
configs/ethernut5_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012aqds_tfa_defconfig | 1 + configs/ls2081ardb_defconfig | 1 + drivers/rtc/Kconfig | 6 ++++++ include/configs/ethernut5.h | 1 - include/configs/ids8313.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls2080ardb.h | 1 - scripts/config_whitelist.txt | 1 - 12 files changed, 12 insertions(+), 5 deletions(-)
diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 9a07940278..9f57f34eab 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_DATAFLASH=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y +CONFIG_RTC_PCF8563=y CONFIG_DM_SERIAL=y CONFIG_ATMEL_USART=y CONFIG_SPI=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 383c8cd0e3..3f5824d76f 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -175,5 +175,6 @@ CONFIG_PHY_VITESSE=y CONFIG_MII=y CONFIG_TSEC_ENET=y # CONFIG_PCI is not set +CONFIG_RTC_PCF8563=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 3c431af81b..1e8e3110f3 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -72,6 +72,7 @@ CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y +CONFIG_RTC_PCF8563=y CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index 2e79536e5c..dc405c725a 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -61,6 +61,7 @@ CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y +CONFIG_RTC_PCF8563=y CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index 10d9a67d86..bf03216202 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -72,6 +72,7 @@ CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y +CONFIG_RTC_PCF8563=y CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index f5cb3bc7da..39e5d7d421 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -51,6 +51,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y +CONFIG_RTC_PCF8563=y CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index 59e2fc44ba..63662001c2 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -75,6 +75,12 @@ config RTC_ISL1208 This driver supports reading and writing the RTC/calendar and detects total power failures.
+config RTC_PCF8563 + tristate "Philips PCF8563" + help + If you say yes here you get support for the Philips PCF8563 RTC + and compatible chips. + config RTC_RV3029 bool "Enable RV3029 driver" depends on DM_RTC diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index d121b395df..b513b4bc68 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -92,7 +92,6 @@
/* RTC */ #if defined(CONFIG_CMD_DATE) || defined(CONFIG_CMD_SNTP) -#define CONFIG_RTC_PCF8563 #define CONFIG_SYS_I2C_RTC_ADDR 0x51 #endif
diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index bcd8aee7c3..362e2892d1 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -168,7 +168,6 @@ #define CONFIG_SYS_FSL_I2C_SPEED 400000 #define CONFIG_SYS_FSL_I2C_SLAVE 0x7F #define CONFIG_SYS_FSL_I2C_OFFSET 0x3100 -#define CONFIG_RTC_PCF8563 #define CONFIG_SYS_I2C_RTC_ADDR 0x51
/* diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 9498a03f40..df2a613eaf 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -50,7 +50,6 @@ * RTC configuration */ #define RTC -#define CONFIG_RTC_PCF8563 1 #define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* Channel 3*/
/* EEPROM */ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index b7a7dc0a64..ab4214c265 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -279,7 +279,6 @@ unsigned long get_board_sys_clk(void); */ #define RTC #ifdef CONFIG_TARGET_LS2081ARDB -#define CONFIG_RTC_PCF8563 1 #define CONFIG_SYS_I2C_RTC_ADDR 0x51 #else #define CONFIG_RTC_DS3231 1 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 12f1209aa8..54d5a4d9e7 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1415,7 +1415,6 @@ CONFIG_RTC_MC13XXX CONFIG_RTC_MCFRRTC CONFIG_RTC_MCP79411 CONFIG_RTC_MXS -CONFIG_RTC_PCF8563 CONFIG_RTC_PT7C4338 CONFIG_RUN_FROM_DDR0 CONFIG_RUN_FROM_DDR1
Thanks, Stefan
+config RTC_PCF8563
- tristate "Philips PCF8563"
- help
- config RTC_RV3029 bool "Enable RV3029 driver" depends on DM_RTC
- RTC configuration
Viele Grüße, Stefan
Signed-off-by: Heiko Schocher hs@denx.de Reviewed-by: Stefan Roese sr@denx.de
Heiko Schocher
Stefan Roese
