[PATCH v3 0/3] Support Devkit800 device tree
This serie clean-up the devkit8000 configuration to support device tree and fixes CONFIG_DM_* warnings.
v3: Clean-up the first patch and rebase the serie. v2: Override i2c1 frequency in omap3-u-boot.dtsi.
Anthoine Bourgeois (3): ARM: dts: omap3-devkit8000: Add support for Devkit8000 ARM: dts: omap3-devkit8000: Fix CONFIG_DM_I2C warning ARM: dts: omap3-devkit8000: Fix CONFIG_DM_ETH warning
arch/arm/dts/Makefile | 2 + arch/arm/dts/omap3-devkit8000-u-boot.dtsi | 20 ++ arch/arm/dts/omap3-devkit8000.dts | 349 ++++++++++++++++++++++ arch/arm/dts/omap3-u-boot.dtsi | 1 + configs/devkit8000_defconfig | 25 +- include/configs/devkit8000.h | 22 +- 6 files changed, 396 insertions(+), 23 deletions(-) create mode 100644 arch/arm/dts/omap3-devkit8000-u-boot.dtsi create mode 100644 arch/arm/dts/omap3-devkit8000.dts
This commit adds OMAP3 BeagleBoard devicetree files from Linux v5.16.0. This commit fixes CONFIG_DM_MMC warning.
v3: patch clean-up
Signed-off-by: Anthoine Bourgeois anthoine.bourgeois@gmail.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/omap3-devkit8000-u-boot.dtsi | 14 + arch/arm/dts/omap3-devkit8000.dts | 349 ++++++++++++++++++++++ configs/devkit8000_defconfig | 23 +- include/configs/devkit8000.h | 22 +- 5 files changed, 387 insertions(+), 23 deletions(-) create mode 100644 arch/arm/dts/omap3-devkit8000-u-boot.dtsi create mode 100644 arch/arm/dts/omap3-devkit8000.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0a2713c06a..6836b2f805 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1069,6 +1069,8 @@ dtb-$(CONFIG_TARGET_OMAP3_BEAGLE) += \ omap3-beagle-xm.dtb \ omap3-beagle.dtb
+dtb-$(CONFIG_TARGET_DEVKIT8000) += omap3-devkit8000.dtb + dtb-$(CONFIG_TARGET_OMAP3_IGEP00X0) += \ omap3-igep0020.dtb
diff --git a/arch/arm/dts/omap3-devkit8000-u-boot.dtsi b/arch/arm/dts/omap3-devkit8000-u-boot.dtsi new file mode 100644 index 0000000000..2c03701c89 --- /dev/null +++ b/arch/arm/dts/omap3-devkit8000-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * (C) Copyright 2017 Derald D. Woods woods.technical@gmail.com + */ + +#include "omap3-u-boot.dtsi" + +/ { + chosen { + stdout-path = &uart3; + }; +}; diff --git a/arch/arm/dts/omap3-devkit8000.dts b/arch/arm/dts/omap3-devkit8000.dts new file mode 100644 index 0000000000..eee3ba073b --- /dev/null +++ b/arch/arm/dts/omap3-devkit8000.dts @@ -0,0 +1,349 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Author: Anthoine Bourgeois anthoine.bourgeois@gmail.com + */ +/dts-v1/; + +#include "omap34xx.dtsi" +/ { + model = "TimLL OMAP3 Devkit8000"; + compatible = "timll,omap3-devkit8000", "ti,omap3430", "ti,omap3"; + + aliases { + display1 = &dvi0; + display2 = &tv0; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x10000000>; /* 256 MB */ + }; + + leds { + compatible = "gpio-leds"; + + heartbeat { + label = "devkit8000::led1"; + gpios = <&gpio6 26 GPIO_ACTIVE_HIGH>; /* 186 -> LED1 */ + default-state = "on"; + linux,default-trigger = "heartbeat"; + }; + + mmc { + label = "devkit8000::led2"; + gpios = <&gpio6 3 GPIO_ACTIVE_HIGH>; /* 163 -> LED2 */ + default-state = "on"; + linux,default-trigger = "none"; + }; + + usr { + label = "devkit8000::led3"; + gpios = <&gpio6 4 GPIO_ACTIVE_HIGH>; /* 164 -> LED3 */ + default-state = "on"; + linux,default-trigger = "usr"; + }; + + pmu_stat { + label = "devkit8000::pmu_stat"; + gpios = <&twl_gpio 19 GPIO_ACTIVE_HIGH>; /* LEDB */ + }; + }; + + sound { + compatible = "ti,omap-twl4030"; + ti,model = "devkit8000"; + + ti,mcbsp = <&mcbsp2>; + ti,audio-routing = + "Ext Spk", "PREDRIVEL", + "Ext Spk", "PREDRIVER", + "MAINMIC", "Main Mic", + "Main Mic", "Mic Bias 1"; + }; + + tfp410: encoder0 { + compatible = "ti,tfp410"; + powerdown-gpios = <&twl_gpio 7 GPIO_ACTIVE_LOW>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tfp410_in: endpoint { + remote-endpoint = <&dpi_dvi_out>; + }; + }; + + port@1 { + reg = <1>; + + tfp410_out: endpoint { + remote-endpoint = <&dvi_connector_in>; + }; + }; + }; + }; + + dvi0: connector0 { + compatible = "dvi-connector"; + label = "dvi"; + + digital; + + ddc-i2c-bus = <&i2c2>; + + port { + dvi_connector_in: endpoint { + remote-endpoint = <&tfp410_out>; + }; + }; + }; + + tv0: connector1 { + compatible = "svideo-connector"; + label = "tv"; + + port { + tv_connector_in: endpoint { + remote-endpoint = <&venc_out>; + }; + }; + }; +}; + +&i2c1 { + clock-frequency = <2600000>; + + twl: twl@48 { + reg = <0x48>; + interrupts = <7>; /* SYS_NIRQ cascaded to intc */ + + twl_audio: audio { + compatible = "ti,twl4030-audio"; + codec { + }; + }; + }; +}; + +&i2c2 { + clock-frequency = <400000>; +}; + +&i2c3 { + status = "disabled"; +}; + +#include "twl4030.dtsi" +#include "twl4030_omap3.dtsi" + +&mmc1 { + vmmc-supply = <&vmmc1>; + vqmmc-supply = <&vsim>; + bus-width = <8>; +}; + +&mmc2 { + status = "disabled"; +}; + +&mmc3 { + status = "disabled"; +}; + +&twl_gpio { + ti,use-leds; + /* + * pulldowns: + * BIT(1), BIT(2), BIT(6), BIT(7), BIT(8), BIT(13) + * BIT(15), BIT(16), BIT(17) + */ + ti,pulldowns = <0x03a1c6>; +}; + +&wdt2 { + status = "disabled"; +}; + +&mcbsp2 { + status = "okay"; +}; + +&gpmc { + ranges = <0 0 0x30000000 0x1000000 /* CS0: 16MB for NAND */ + 6 0 0x2c000000 0x1000000>; /* CS6: 16MB for DM9000 */ + + nand@0,0 { + compatible = "ti,omap2-nand"; + reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ + interrupt-parent = <&gpmc>; + interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */ + <1 IRQ_TYPE_NONE>; /* termcount */ + nand-bus-width = <16>; + gpmc,device-width = <2>; + ti,nand-ecc-opt = "sw"; + + gpmc,sync-clk-ps = <0>; + gpmc,cs-on-ns = <0>; + gpmc,cs-rd-off-ns = <44>; + gpmc,cs-wr-off-ns = <44>; + gpmc,adv-on-ns = <6>; + gpmc,adv-rd-off-ns = <34>; + gpmc,adv-wr-off-ns = <44>; + gpmc,we-off-ns = <40>; + gpmc,oe-off-ns = <54>; + gpmc,access-ns = <64>; + gpmc,rd-cycle-ns = <82>; + gpmc,wr-cycle-ns = <82>; + gpmc,wr-access-ns = <40>; + gpmc,wr-data-mux-bus-ns = <0>; + + #address-cells = <1>; + #size-cells = <1>; + + x-loader@0 { + label = "X-Loader"; + reg = <0 0x80000>; + }; + + bootloaders@80000 { + label = "U-Boot"; + reg = <0x80000 0x1e0000>; + }; + + bootloaders_env@260000 { + label = "U-Boot Env"; + reg = <0x260000 0x20000>; + }; + + kernel@280000 { + label = "Kernel"; + reg = <0x280000 0x400000>; + }; + + filesystem@680000 { + label = "File System"; + reg = <0x680000 0xf980000>; + }; + }; + + ethernet@6,0 { + compatible = "davicom,dm9000"; + reg = <6 0x000 2 + 6 0x400 2>; /* CS6, offset 0 and 0x400, IO size 2 */ + bank-width = <2>; + interrupt-parent = <&gpio1>; + interrupts = <25 IRQ_TYPE_LEVEL_LOW>; + davicom,no-eeprom; + + gpmc,mux-add-data = <0>; + gpmc,device-width = <1>; + gpmc,wait-pin = <0>; + gpmc,cycle2cycle-samecsen; + gpmc,cycle2cycle-diffcsen; + + gpmc,cs-on-ns = <6>; + gpmc,cs-rd-off-ns = <180>; + gpmc,cs-wr-off-ns = <180>; + gpmc,adv-on-ns = <0>; + gpmc,adv-rd-off-ns = <18>; + gpmc,adv-wr-off-ns = <48>; + gpmc,oe-on-ns = <54>; + gpmc,oe-off-ns = <168>; + gpmc,we-on-ns = <54>; + gpmc,we-off-ns = <168>; + gpmc,rd-cycle-ns = <186>; + gpmc,wr-cycle-ns = <186>; + gpmc,access-ns = <144>; + gpmc,page-burst-access-ns = <24>; + gpmc,bus-turnaround-ns = <90>; + gpmc,cycle2cycle-delay-ns = <90>; + gpmc,wait-monitoring-ns = <0>; + gpmc,clk-activation-ns = <0>; + gpmc,wr-data-mux-bus-ns = <0>; + gpmc,wr-access-ns = <0>; + }; +}; + +&omap3_pmx_core { + dss_dpi_pins: pinmux_dss_dpi_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x20d4, PIN_OUTPUT | MUX_MODE0) /* dss_pclk.dss_pclk */ + OMAP3_CORE1_IOPAD(0x20d6, PIN_OUTPUT | MUX_MODE0) /* dss_hsync.dss_hsync */ + OMAP3_CORE1_IOPAD(0x20d8, PIN_OUTPUT | MUX_MODE0) /* dss_vsync.dss_vsync */ + OMAP3_CORE1_IOPAD(0x20da, PIN_OUTPUT | MUX_MODE0) /* dss_acbias.dss_acbias */ + OMAP3_CORE1_IOPAD(0x20dc, PIN_OUTPUT | MUX_MODE0) /* dss_data0.dss_data0 */ + OMAP3_CORE1_IOPAD(0x20de, PIN_OUTPUT | MUX_MODE0) /* dss_data1.dss_data1 */ + OMAP3_CORE1_IOPAD(0x20e0, PIN_OUTPUT | MUX_MODE0) /* dss_data2.dss_data2 */ + OMAP3_CORE1_IOPAD(0x20e2, PIN_OUTPUT | MUX_MODE0) /* dss_data3.dss_data3 */ + OMAP3_CORE1_IOPAD(0x20e4, PIN_OUTPUT | MUX_MODE0) /* dss_data4.dss_data4 */ + OMAP3_CORE1_IOPAD(0x20e6, PIN_OUTPUT | MUX_MODE0) /* dss_data5.dss_data5 */ + OMAP3_CORE1_IOPAD(0x20e8, PIN_OUTPUT | MUX_MODE0) /* dss_data6.dss_data6 */ + OMAP3_CORE1_IOPAD(0x20ea, PIN_OUTPUT | MUX_MODE0) /* dss_data7.dss_data7 */ + OMAP3_CORE1_IOPAD(0x20ec, PIN_OUTPUT | MUX_MODE0) /* dss_data8.dss_data8 */ + OMAP3_CORE1_IOPAD(0x20ee, PIN_OUTPUT | MUX_MODE0) /* dss_data9.dss_data9 */ + OMAP3_CORE1_IOPAD(0x20f0, PIN_OUTPUT | MUX_MODE0) /* dss_data10.dss_data10 */ + OMAP3_CORE1_IOPAD(0x20f2, PIN_OUTPUT | MUX_MODE0) /* dss_data11.dss_data11 */ + OMAP3_CORE1_IOPAD(0x20f4, PIN_OUTPUT | MUX_MODE0) /* dss_data12.dss_data12 */ + OMAP3_CORE1_IOPAD(0x20f6, PIN_OUTPUT | MUX_MODE0) /* dss_data13.dss_data13 */ + OMAP3_CORE1_IOPAD(0x20f8, PIN_OUTPUT | MUX_MODE0) /* dss_data14.dss_data14 */ + OMAP3_CORE1_IOPAD(0x20fa, PIN_OUTPUT | MUX_MODE0) /* dss_data15.dss_data15 */ + OMAP3_CORE1_IOPAD(0x20fc, PIN_OUTPUT | MUX_MODE0) /* dss_data16.dss_data16 */ + OMAP3_CORE1_IOPAD(0x20fe, PIN_OUTPUT | MUX_MODE0) /* dss_data17.dss_data17 */ + OMAP3_CORE1_IOPAD(0x2100, PIN_OUTPUT | MUX_MODE0) /* dss_data18.dss_data18 */ + OMAP3_CORE1_IOPAD(0x2102, PIN_OUTPUT | MUX_MODE0) /* dss_data19.dss_data19 */ + OMAP3_CORE1_IOPAD(0x2104, PIN_OUTPUT | MUX_MODE0) /* dss_data20.dss_data20 */ + OMAP3_CORE1_IOPAD(0x2106, PIN_OUTPUT | MUX_MODE0) /* dss_data21.dss_data21 */ + OMAP3_CORE1_IOPAD(0x2108, PIN_OUTPUT | MUX_MODE0) /* dss_data22.dss_data22 */ + OMAP3_CORE1_IOPAD(0x210a, PIN_OUTPUT | MUX_MODE0) /* dss_data23.dss_data23 */ + >; + }; +}; + +&vpll1 { + /* Needed for DSS */ + regulator-name = "vdds_dsi"; + + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; +}; + +&dss { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&dss_dpi_pins>; + + vdds_dsi-supply = <&vpll1>; + vdda_dac-supply = <&vdac>; + + port { + #address-cells = <1>; + #size-cells = <0>; + dpi_dvi_out: endpoint@0 { + reg = <0>; + remote-endpoint = <&tfp410_in>; + data-lines = <24>; + }; + + endpoint@1 { + reg = <1>; + }; + }; +}; + +&venc { + status = "okay"; + + vdda-supply = <&vdac>; + + port { + venc_out: endpoint { + remote-endpoint = <&tv_connector_in>; + ti,channels = <2>; + }; + }; +}; diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index be780949ec..42bc39c3e1 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -2,14 +2,20 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_LEN=0x40000 -CONFIG_SYS_MALLOC_F_LEN=0x400 +CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_DEVKIT8000=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL=y +CONFIG_DEFAULT_DEVICE_TREE="omap3-devkit8000" CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run autoboot" +CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SEPARATE_BSS=y +# CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y CONFIG_SPL_NAND_SIMPLE=y @@ -19,8 +25,8 @@ CONFIG_SPL_FALCON_BOOT_MMCSD=y CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x500 # CONFIG_CMD_IMI is not set CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_NAND_OFS=0x680000 -CONFIG_CMD_SPL_WRITE_SIZE=0x400 +CONFIG_CMD_SPL_NAND_OFS=0x280000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y @@ -38,6 +44,11 @@ CONFIG_JFFS2_PART_SIZE=0xF980000 CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot-env),4m(kernel),-(fs)" +# CONFIG_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -47,6 +58,10 @@ CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_TWL4030_LED=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y @@ -59,6 +74,4 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_DRIVER_DM9000=y -CONFIG_CONS_INDEX=3 CONFIG_JFFS2_NAND=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 5dbd126a2a..877911b258 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -14,23 +14,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-/* High Level Configuration Options */ - -/* - * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM - * 64 bytes before this address should be set aside for u-boot.img's - * header. That is 0x800FFFC0--0x80100000 should not be used for any - * other needs. - */ - -#define CONFIG_SPL_BSS_START_ADDR 0x80000500 /* leave space for bootargs*/ -#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 - -#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 /* 1 MB */ - -/* Physical Memory Map */ - #include <configs/ti_omap3_common.h>
/* Hardware drivers */ @@ -46,9 +29,12 @@
/* BOOTP/DHCP options */
+#define MEM_LAYOUT_ENV_SETTINGS \ + DEFAULT_LINUX_BOOT_ENV + /* Environment information */ #define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=0x82000000\0" \ + MEM_LAYOUT_ENV_SETTINGS \ "console=ttyO2,115200n8\0" \ "mmcdev=0\0" \ "vram=12M\0" \
v3: patch clean-up
Seems that u-boot can't probe i2c bus at 2.6Mhz speed, so lower the speed to the default value 100Khz.
v2: fix i2c1 frequency in the root omap3-u-boot.dtsi include.
Signed-off-by: Anthoine Bourgeois anthoine.bourgeois@gmail.com --- arch/arm/dts/omap3-u-boot.dtsi | 1 + configs/devkit8000_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/arch/arm/dts/omap3-u-boot.dtsi b/arch/arm/dts/omap3-u-boot.dtsi index 32bea6b6d9..96d8ac5453 100644 --- a/arch/arm/dts/omap3-u-boot.dtsi +++ b/arch/arm/dts/omap3-u-boot.dtsi @@ -78,4 +78,5 @@
&i2c1 { u-boot,dm-spl; + clock-frequency = <100000>; }; diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 42bc39c3e1..23b9d2cfb1 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -63,6 +63,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_DM_I2C=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_OMAP_ECCSCHEME_HAM1_CODE_HW=y
Add the missing ethernet node in u-boot dts.
Signed-off-by: Anthoine Bourgeois anthoine.bourgeois@gmail.com --- arch/arm/dts/omap3-devkit8000-u-boot.dtsi | 6 ++++++ configs/devkit8000_defconfig | 1 + 2 files changed, 7 insertions(+)
diff --git a/arch/arm/dts/omap3-devkit8000-u-boot.dtsi b/arch/arm/dts/omap3-devkit8000-u-boot.dtsi index 2c03701c89..a5768b7281 100644 --- a/arch/arm/dts/omap3-devkit8000-u-boot.dtsi +++ b/arch/arm/dts/omap3-devkit8000-u-boot.dtsi @@ -11,4 +11,10 @@ chosen { stdout-path = &uart3; }; + + ethernet@2c000000 { + compatible = "davicom,dm9000"; + reg = <0x2c000000 2 0x2c000400 2>; + bank-width = <2>; + }; }; diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 23b9d2cfb1..59c3d92a62 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -74,5 +74,6 @@ CONFIG_SYS_NAND_OOBSIZE=0x40 CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 +CONFIG_DM_ETH=y CONFIG_DRIVER_DM9000=y CONFIG_JFFS2_NAND=y
Anthoine Bourgeois
