[U-Boot] [PATCH 1/2 v3] 8xx, kup4: minor configuration changes
- nfs-options removed - hda->sda changed - mtd parts added - loadaddress changed - cmd-line length increased - lcd stuff removed - code cleanup
Signed-off-by: Klaus Heydeck heydeck@kieback-peter.de
--- - changes since v1: - added comments from Wolfgang Denk - fix Codingstyle issues - rebased against current mainline
- changes since v2 fix boards.cfg entry for kup4x board
board/kup/common/kup.c | 54 ++++-- board/kup/common/kup.h | 44 +++-- board/kup/kup4k/kup4k.c | 439 +++++++++++++++++--------------------------- board/kup/kup4k/s1d13706.h | 174 ----------------- board/kup/kup4x/kup4x.c | 265 ++++++++------------------- boards.cfg | 2 +- include/configs/KUP4K.h | 169 ++++++++++-------- include/configs/KUP4X.h | 64 ++++---- 8 files changed, 427 insertions(+), 784 deletions(-) delete mode 100644 board/kup/kup4k/s1d13706.h
diff --git a/board/kup/common/kup.c b/board/kup/common/kup.c index 2418d59..38259a5 100644 --- a/board/kup/common/kup.c +++ b/board/kup/common/kup.c @@ -24,49 +24,61 @@ #include <common.h> #include <mpc8xx.h> #include "kup.h" +#include <asm/io.h>
-int misc_init_f (void) + +int misc_init_f(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; volatile sysconf8xx_t *siu = &immap->im_siu_conf;
- while (siu->sc_sipend & 0x20000000) { - /* printf("waiting for 5V VCC\n"); */ - ; + while (in_be32(&siu->sc_sipend) & 0x20000000) { + debug("waiting for 5V VCC\n"); }
/* RS232 / RS485 default is RS232 */ - immap->im_ioport.iop_padat &= ~(PA_RS485); - immap->im_ioport.iop_papar &= ~(PA_RS485); - immap->im_ioport.iop_paodr &= ~(PA_RS485); - immap->im_ioport.iop_padir |= (PA_RS485); + clrbits_be16(&immap->im_ioport.iop_padat, PA_RS485); + clrbits_be16(&immap->im_ioport.iop_papar, PA_RS485); + clrbits_be16(&immap->im_ioport.iop_paodr, PA_RS485); + setbits_be16(&immap->im_ioport.iop_padir, PA_RS485); + + /* IO Reset min 1 msec */ + setbits_be16(&immap->im_ioport.iop_padat, + (PA_RESET_IO_01 | PA_RESET_IO_02)); + clrbits_be16(&immap->im_ioport.iop_papar, + (PA_RESET_IO_01 | PA_RESET_IO_02)); + clrbits_be16(&immap->im_ioport.iop_paodr, + (PA_RESET_IO_01 | PA_RESET_IO_02)); + setbits_be16(&immap->im_ioport.iop_padir, + (PA_RESET_IO_01 | PA_RESET_IO_02)); + udelay(1000); + clrbits_be16(&immap->im_ioport.iop_padat, + (PA_RESET_IO_01 | PA_RESET_IO_02)); return (0); }
- #ifdef CONFIG_IDE_LED -void ide_led (uchar led, uchar status) +void ide_led(uchar led, uchar status) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR;
/* We have one led for both pcmcia slots */ - if (status) { /* led on */ - immap->im_ioport.iop_padat &= ~(PA_LED_YELLOW); - } else { - immap->im_ioport.iop_padat |= (PA_LED_YELLOW); - } + if (status) + clrbits_be16(&immap->im_ioport.iop_padat, PA_LED_YELLOW); + else + setbits_be16(&immap->im_ioport.iop_padat, PA_LED_YELLOW); } #endif
-void poweron_key (void) +void poweron_key(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR;
- immap->im_ioport.iop_pcpar &= ~(PC_SWITCH1); - immap->im_ioport.iop_pcdir &= ~(PC_SWITCH1); + clrbits_be16(&immap->im_ioport.iop_pcpar, PC_SWITCH1); + clrbits_be16(&immap->im_ioport.iop_pcdir, PC_SWITCH1);
- if (immap->im_ioport.iop_pcdat & (PC_SWITCH1)) - setenv ("key1", "off"); + if (in_be16(&immap->im_ioport.iop_pcdat) & (PC_SWITCH1)) + setenv("key1", "off"); else - setenv ("key1", "on"); + setenv("key1", "on"); } diff --git a/board/kup/common/kup.h b/board/kup/common/kup.h index b736283..455848c 100644 --- a/board/kup/common/kup.h +++ b/board/kup/common/kup.h @@ -24,23 +24,33 @@ #ifndef __KUP_H #define __KUP_H
-#define PA_8 0x0080 -#define PA_11 0x0010 -#define PA_12 0x0008 - -#define PB_14 0x00020000 -#define PB_17 0x00004000 - -#define PC_9 0x0040 - -#define PA_RS485 PA_11 /* SCC1: 0=RS232 1=RS485 */ -#define PA_LED_YELLOW PA_8 -#define BP_USB_VCC PB_14 /* VCC for USB devices 0=vcc on, 1=vcc off*/ -#define PB_LCD_PWM PB_17 /* PB 17 */ -#define PC_SWITCH1 PC_9 /* Reboot switch */ - -extern void poweron_key (void); - +#define PA_8 0x0080 +#define PA_9 0x0040 +#define PA_10 0x0020 +#define PA_11 0x0010 +#define PA_12 0x0008 + +#define PB_14 0x00020000 +#define PB_15 0x00010000 +#define PB_16 0x00008000 +#define PB_17 0x00004000 + +#define PC_4 0x0800 +#define PC_5 0x0400 +#define PC_9 0x0040 + +#define PA_RS485 PA_11 /* SCC1: 0=RS232 1=RS485 */ +#define PA_LED_YELLOW PA_8 +#define PA_RESET_IO_01 PA_9 /* Reset left IO */ +#define PA_RESET_IO_02 PA_10 /* Reset right IO */ +#define PB_PROG_IO_01 PB_15 /* Program left IO */ +#define PB_PROG_IO_02 PB_16 /* Program right IO */ +#define BP_USB_VCC PB_14 /* VCC for USB devices 0=vcc on, 1=vcc off */ +#define PB_LCD_PWM PB_17 /* PB 17 */ +#define PC_SWITCH1 PC_9 /* Reboot switch */ + + +extern void poweron_key(void); extern void load_sernum_ethaddr(void);
#endif /* __KUP_H */ diff --git a/board/kup/kup4k/kup4k.c b/board/kup/kup4k/kup4k.c index 98f5f5a..7eb36ab 100644 --- a/board/kup/kup4k/kup4k.c +++ b/board/kup/kup4k/kup4k.c @@ -23,35 +23,19 @@ */
#include <common.h> +#include <command.h> #include <mpc8xx.h> +#include <hwconfig.h> +#include <i2c.h> #include "../common/kup.h" -#ifdef CONFIG_KUP4K_LOGO - #include "s1d13706.h" -#endif - -DECLARE_GLOBAL_DATA_PTR; - -#undef DEBUG -#ifdef DEBUG -# define debugk(fmt,args...) printf(fmt ,##args) -#else -# define debugk(fmt,args...) -#endif - -typedef struct { - volatile unsigned char *VmemAddr; - volatile unsigned char *RegAddr; -} FB_INFO_S1D13xxx; +#include <asm/io.h>
+static unsigned char swapbyte(unsigned char c); +static int read_diag(void);
-/* ------------------------------------------------------------------------- */ - -#ifdef CONFIG_KUP4K_LOGO -void lcd_logo(bd_t *bd); -#endif - +DECLARE_GLOBAL_DATA_PTR;
#define _NOT_USED_ 0xFFFFFFFF
@@ -60,7 +44,7 @@ const uint sdram_table[] = { * Single Read. (Offset 0 in UPMA RAM) */ 0x1F07FC04, 0xEEAEFC04, 0x11ADFC04, 0xEFBBBC00, - 0x1FF77C47, /* last */ + 0x1FF77C47, /* last */
/* * SDRAM Initialization (offset 5 in UPMA RAM) @@ -70,28 +54,28 @@ const uint sdram_table[] = { * sequence, which is executed by a RUN command. * */ - 0x1FF77C35, 0xEFEABC34, 0x1FB57C35, /* last */ + 0x1FF77C35, 0xEFEABC34, 0x1FB57C35, /* last */
/* * Burst Read. (Offset 8 in UPMA RAM) */ 0x1F07FC04, 0xEEAEFC04, 0x10ADFC04, 0xF0AFFC00, - 0xF0AFFC00, 0xF1AFFC00, 0xEFBBBC00, 0x1FF77C47, /* last */ + 0xF0AFFC00, 0xF1AFFC00, 0xEFBBBC00, 0x1FF77C47, /* last */ _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_,
/* * Single Write. (Offset 18 in UPMA RAM) */ - 0x1F27FC04, 0xEEAEBC00, 0x01B93C04, 0x1FF77C47, /* last */ + 0x1F27FC04, 0xEEAEBC00, 0x01B93C04, 0x1FF77C47, /* last */ _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_,
/* * Burst Write. (Offset 20 in UPMA RAM) */ 0x1F07FC04, 0xEEAEBC00, 0x10AD7C00, 0xF0AFFC00, - 0xF0AFFC00, 0xE1BBBC04, 0x1FF77C47, /* last */ - _NOT_USED_, + 0xF0AFFC00, 0xE1BBBC04, 0x1FF77C47, /* last */ + _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_,
@@ -99,156 +83,169 @@ const uint sdram_table[] = { * Refresh (Offset 30 in UPMA RAM) */ 0x1FF5FC84, 0xFFFFFC04, 0xFFFFFC04, 0xFFFFFC04, - 0xFFFFFC84, 0xFFFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, + 0xFFFFFC84, 0xFFFFFC07, /* last */ + _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_,
/* * Exception. (Offset 3c in UPMA RAM) */ - 0x7FFFFC07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, + 0x7FFFFC07, /* last */ + _NOT_USED_, _NOT_USED_, _NOT_USED_, };
/* * Check Board Identity: */
-int checkboard (void) +int checkboard(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - uchar *latch,rev,mod; + uchar rev,mod,tmp,pcf,ak_rev,ak_mod;
/* * Init ChipSelect #4 (CAN + HW-Latch) */ - immap->im_memctl.memc_or4 = 0xFFFF8926; - immap->im_memctl.memc_br4 = 0x90000401; - __asm__ ("eieio"); - latch=(uchar *)0x90000200; - rev = (*latch & 0xF8) >> 3; - mod=(*latch & 0x03); - printf ("Board: KUP4K Rev %d.%d\n",rev,mod); - return (0); -} + out_be32(&immap->im_memctl.memc_or4, CONFIG_SYS_OR4); + out_be32(&immap->im_memctl.memc_br4, CONFIG_SYS_BR4);
-/* ------------------------------------------------------------------------- */ + /* + * Init ChipSelect #5 (S1D13768) + */ + out_be32(&immap->im_memctl.memc_or5, CONFIG_SYS_OR5); + out_be32(&immap->im_memctl.memc_br5, CONFIG_SYS_BR5);
-phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size_b0 = 0; - long int size_b1 = 0; - long int size_b2 = 0; + tmp = swapbyte(in_8((unsigned char*) LATCH_ADDR)); + rev = (tmp & 0xF8) >> 3; + mod = (tmp & 0x07);
- upmconfig (UPMA, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);
+ if (read_diag()) + gd->flags &= ~GD_FLG_SILENT; + + printf("Board: KUP4K Rev %d.%d AK:",rev,mod); /* - * Preliminary prescaler for refresh (depends on number of - * banks): This value is selected for four cycles every 62.4 us - * with two SDRAM banks or four cycles every 31.2 us with one - * bank. It will be adjusted after memory sizing. + * TI Application report: Before using the IO as an input, + * a high must be written to the IO first */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR; + pcf = 0xFF; + i2c_write(0x21, 0, 0 , &pcf, 1); + if (i2c_read(0x21, 0, 0, &pcf, 1)) { + puts("n/a\n"); + } else { + ak_rev = (pcf & 0xF8) >> 3; + ak_mod = (pcf & 0x07); + printf("%d.%d\n", ak_rev, ak_mod); + } + return 0; +} + +/* ----------------------------------------------------------------------- */
- memctl->memc_mar = 0x00000088; + +phys_size_t initdram(int board_type) +{ + volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; + volatile memctl8xx_t *memctl = &immap->im_memctl; + long int size = 0; + uchar *latch,rev,mod,tmp;
/* - * Map controller banks 1 and 2 to the SDRAM banks 2 and 3 at - * preliminary addresses - these have to be modified after the - * SDRAM size has been determined. + * Init ChipSelect #4 (CAN + HW-Latch) to determine Hardware Revision + * Rev 1..6 -> 48 MB RAM; Rev >= 7 -> 96 MB */ -/* memctl->memc_or1 = CONFIG_SYS_OR1_PRELIM; */ -/* memctl->memc_br1 = CONFIG_SYS_BR1_PRELIM; */ - -/* memctl->memc_or2 = CONFIG_SYS_OR2_PRELIM; */ -/* memctl->memc_br2 = CONFIG_SYS_BR2_PRELIM; */ + out_be32(&immap->im_memctl.memc_or4, CONFIG_SYS_OR4); + out_be32(&immap->im_memctl.memc_br4, CONFIG_SYS_BR4);
+ latch = (uchar *)0x90000200; + tmp = swapbyte(*latch); + rev = (tmp & 0xF8) >> 3; + mod = (tmp & 0x07);
- memctl->memc_mamr = CONFIG_SYS_MAMR & (~(MAMR_PTAE)); /* no refresh yet */ + upmconfig(UPMA, (uint *) sdram_table, + sizeof (sdram_table) / sizeof (uint));
- udelay (200); + out_be16(&memctl->memc_mptpr, CONFIG_SYS_MPTPR);
- /* perform SDRAM initializsation sequence */ + out_be32(&memctl->memc_mar, 0x00000088); + /* no refresh yet */ + if(rev >= 7) { + out_be32(&memctl->memc_mamr, + CONFIG_SYS_MAMR_9COL & (~(MAMR_PTAE))); + } else { + out_be32(&memctl->memc_mamr, + CONFIG_SYS_MAMR_8COL & (~(MAMR_PTAE))); + }
- memctl->memc_mcr = 0x80002105; /* SDRAM bank 0 */ - udelay (1); - memctl->memc_mcr = 0x80002830; /* SDRAM bank 0 - execute twice */ - udelay (1); - memctl->memc_mcr = 0x80002106; /* SDRAM bank 0 - RUN MRS Pattern from loc 6 */ - udelay (1); - - memctl->memc_mcr = 0x80004105; /* SDRAM bank 1 */ - udelay (1); - memctl->memc_mcr = 0x80004830; /* SDRAM bank 1 - execute twice */ - udelay (1); - memctl->memc_mcr = 0x80004106; /* SDRAM bank 1 - RUN MRS Pattern from loc 6 */ - udelay (1); - - memctl->memc_mcr = 0x80006105; /* SDRAM bank 2 */ - udelay (1); - memctl->memc_mcr = 0x80006830; /* SDRAM bank 2 - execute twice */ - udelay (1); - memctl->memc_mcr = 0x80006106; /* SDRAM bank 2 - RUN MRS Pattern from loc 6 */ - udelay (1); - - memctl->memc_mamr |= MAMR_PTAE; /* enable refresh */ - udelay (1000); - -#if 0 /* 3 x 8MB */ - size_b0 = 0x00800000; - size_b1 = 0x00800000; - size_b2 = 0x00800000; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - udelay (1000); - memctl->memc_or1 = 0xFF800A00; - memctl->memc_br1 = 0x00000081; - memctl->memc_or2 = 0xFF000A00; - memctl->memc_br2 = 0x00800081; - memctl->memc_or3 = 0xFE000A00; - memctl->memc_br3 = 0x01000081; -#else /* 3 x 16 MB */ - size_b0 = 0x01000000; - size_b1 = 0x01000000; - size_b2 = 0x01000000; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - udelay (1000); - memctl->memc_or1 = 0xFF000A00; - memctl->memc_br1 = 0x00000081; - memctl->memc_or2 = 0xFE000A00; - memctl->memc_br2 = 0x01000081; - memctl->memc_or3 = 0xFC000A00; - memctl->memc_br3 = 0x02000081; -#endif + udelay(200);
- udelay (10000); + /* perform SDRAM initializsation sequence */
- return (size_b0 + size_b1 + size_b2); + /* SDRAM bank 0 */ + out_be32(&memctl->memc_mcr, 0x80002105); + udelay(1); + out_be32(&memctl->memc_mcr, 0x80002830); /* execute twice */ + udelay(1); + out_be32(&memctl->memc_mcr, 0x80002106); /* RUN MRS Pattern from loc 6 */ + udelay(1); + + /* SDRAM bank 1 */ + out_be32(&memctl->memc_mcr, 0x80004105); + udelay(1); + out_be32(&memctl->memc_mcr, 0x80004830); /* execute twice */ + udelay(1); + out_be32(&memctl->memc_mcr, 0x80004106); /* RUN MRS Pattern from loc 6 */ + udelay(1); + + /* SDRAM bank 2 */ + out_be32(&memctl->memc_mcr, 0x80006105); + udelay(1); + out_be32(&memctl->memc_mcr, 0x80006830); /* execute twice */ + udelay(1); + out_be32(&memctl->memc_mcr, 0x80006106); /* RUN MRS Pattern from loc 6 */ + udelay(1); + + setbits_be32(&memctl->memc_mamr, MAMR_PTAE); /* enable refresh */ + udelay(1000); + + out_be16(&memctl->memc_mptpr, CONFIG_SYS_MPTPR); + udelay(1000); + if(rev >= 7) { + size = 32 * 3 * 1024 * 1024; + out_be32(&memctl->memc_or1, CONFIG_SYS_OR1_9COL); + out_be32(&memctl->memc_br1, CONFIG_SYS_BR1_9COL); + out_be32(&memctl->memc_or2, CONFIG_SYS_OR2_9COL); + out_be32(&memctl->memc_br2, CONFIG_SYS_BR2_9COL); + out_be32(&memctl->memc_or3, CONFIG_SYS_OR3_9COL); + out_be32(&memctl->memc_br3, CONFIG_SYS_BR3_9COL); + } else { + size = 16 * 3 * 1024 * 1024; + out_be32(&memctl->memc_or1, CONFIG_SYS_OR1_8COL); + out_be32(&memctl->memc_br1, CONFIG_SYS_BR1_8COL); + out_be32(&memctl->memc_or2, CONFIG_SYS_OR2_8COL); + out_be32(&memctl->memc_br2, CONFIG_SYS_BR2_8COL); + out_be32(&memctl->memc_or3, CONFIG_SYS_OR3_8COL); + out_be32(&memctl->memc_br3, CONFIG_SYS_BR3_8COL); + } + return (size); }
-int misc_init_r (void) + +int misc_init_r(void) { -#ifdef CONFIG_STATUS_LED volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; -#endif -#ifdef CONFIG_KUP4K_LOGO - bd_t *bd = gd->bd;
- lcd_logo (bd); -#endif /* CONFIG_KUP4K_LOGO */ #ifdef CONFIG_IDE_LED /* Configure PA8 as output port */ - immap->im_ioport.iop_padir |= 0x80; - immap->im_ioport.iop_paodr |= 0x80; - immap->im_ioport.iop_papar &= ~0x80; - immap->im_ioport.iop_padat |= 0x80; /* turn it off */ + setbits_be16(&immap->im_ioport.iop_padir, PA_8); + setbits_be16(&immap->im_ioport.iop_paodr, PA_8); + clrbits_be16(&immap->im_ioport.iop_papar, PA_8); + setbits_be16(&immap->im_ioport.iop_padat, PA_8); /* turn it off */ #endif load_sernum_ethaddr(); setenv("hw","4k"); @@ -256,149 +253,41 @@ int misc_init_r (void) return (0); }
- -void lcd_logo (bd_t * bd) +static int read_diag(void) { - FB_INFO_S1D13xxx fb_info; - S1D_INDEX s1dReg; - S1D_VALUE s1dValue; - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl; - ushort i; - uchar *fb; - int rs, gs, bs; - int r = 8, g = 8, b = 4; - int r1, g1, b1; - int n; - char tmp[64]; /* long enough for environment variables */ - int tft = 0; - - immr->im_cpm.cp_pbpar &= ~(PB_LCD_PWM); - immr->im_cpm.cp_pbodr &= ~(PB_LCD_PWM); - immr->im_cpm.cp_pbdat &= ~(PB_LCD_PWM); /* set to 0 = enabled */ - immr->im_cpm.cp_pbdir |= (PB_LCD_PWM); - -/*----------------------------------------------------------------------------- */ -/* Initialize the chip and the frame buffer driver. */ -/*----------------------------------------------------------------------------- */ - memctl = &immr->im_memctl; - - - /* - * Init ChipSelect #5 (S1D13768) - */ - memctl->memc_or5 = 0xFFC007F0; /* 4 MB 17 WS or externel TA */ - memctl->memc_br5 = 0x80080801; /* Start at 0x80080000 */ - __asm__ ("eieio"); - - fb_info.VmemAddr = (unsigned char *) (S1D_PHYSICAL_VMEM_ADDR); - fb_info.RegAddr = (unsigned char *) (S1D_PHYSICAL_REG_ADDR); - - if ((((S1D_VALUE *) fb_info.RegAddr)[0] != 0x28) - || (((S1D_VALUE *) fb_info.RegAddr)[1] != 0x14)) { - printf ("Warning:LCD Controller S1D13706 not found\n"); - setenv ("lcd", "none"); - return; - } - - - for (i = 0; i < sizeof(aS1DRegs_prelimn) / sizeof(aS1DRegs_prelimn[0]); i++) { - s1dReg = aS1DRegs_prelimn[i].Index; - s1dValue = aS1DRegs_prelimn[i].Value; - debugk ("s13768 reg: %02x value: %02x\n", - aS1DRegs_prelimn[i].Index, aS1DRegs_prelimn[i].Value); - ((S1D_VALUE *) fb_info.RegAddr)[s1dReg / sizeof (S1D_VALUE)] = - s1dValue; - } - - - n = getenv_r ("lcd", tmp, sizeof (tmp)); - if (n > 0) { - if (!strcmp ("tft", tmp)) - tft = 1; + int diag; + immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; + + clrbits_be16(&immr->im_ioport.iop_pcdir, PC_4); /* input */ + clrbits_be16(&immr->im_ioport.iop_pcpar, PC_4); /* gpio */ + setbits_be16(&immr->im_ioport.iop_pcdir, PC_5); /* output */ + clrbits_be16(&immr->im_ioport.iop_pcpar, PC_4); /* gpio */ + setbits_be16(&immr->im_ioport.iop_pcdat, PC_5); /* 1 */ + udelay(500); + if (in_be16(&immr->im_ioport.iop_pcdat) & PC_4) { + clrbits_be16(&immr->im_ioport.iop_pcdat, PC_5);/* 0 */ + udelay(500); + if(in_be16(&immr->im_ioport.iop_pcdat) & PC_4) + diag = 0; else - tft = 0; - } -#if 0 - if (((S1D_VALUE *) fb_info.RegAddr)[0xAC] & 0x04) - tft = 0; - else - tft = 1; -#endif - - debugk ("Port=0x%02x -> TFT=%d\n", tft, - ((S1D_VALUE *) fb_info.RegAddr)[0xAC]); - - /* init controller */ - if (!tft) { - for (i = 0; i < sizeof(aS1DRegs_stn) / sizeof(aS1DRegs_stn[0]); i++) { - s1dReg = aS1DRegs_stn[i].Index; - s1dValue = aS1DRegs_stn[i].Value; - debugk ("s13768 reg: %02x value: %02x\n", - aS1DRegs_stn[i].Index, - aS1DRegs_stn[i].Value); - ((S1D_VALUE *) fb_info.RegAddr)[s1dReg / sizeof(S1D_VALUE)] = - s1dValue; - } - n = getenv_r ("contrast", tmp, sizeof (tmp)); - ((S1D_VALUE *) fb_info.RegAddr)[0xB3] = - (n > 0) ? (uchar) simple_strtoul (tmp, NULL, 10) * 255 / 100 : 0xA0; - switch (bd->bi_busfreq) { - case 40000000: - ((S1D_VALUE *) fb_info.RegAddr)[0x05] = 0x32; - ((S1D_VALUE *) fb_info.RegAddr)[0x12] = 0x41; - break; - case 48000000: - ((S1D_VALUE *) fb_info.RegAddr)[0x05] = 0x22; - ((S1D_VALUE *) fb_info.RegAddr)[0x12] = 0x34; - break; - default: - printf ("KUP4K S1D1: unknown busfrequency: %ld assuming 64 MHz\n", bd->bi_busfreq); - case 64000000: - ((S1D_VALUE *) fb_info.RegAddr)[0x05] = 0x32; - ((S1D_VALUE *) fb_info.RegAddr)[0x12] = 0x66; - break; - } - /* setenv("lcd","stn"); */ + diag = 1; } else { - for (i = 0; i < sizeof(aS1DRegs_tft) / sizeof(aS1DRegs_tft[0]); i++) { - s1dReg = aS1DRegs_tft[i].Index; - s1dValue = aS1DRegs_tft[i].Value; - debugk ("s13768 reg: %02x value: %02x\n", - aS1DRegs_tft[i].Index, - aS1DRegs_tft[i].Value); - ((S1D_VALUE *) fb_info.RegAddr)[s1dReg / sizeof (S1D_VALUE)] = - s1dValue; - } - - switch (bd->bi_busfreq) { - default: - printf ("KUP4K S1D1: unknown busfrequency: %ld assuming 64 MHz\n", bd->bi_busfreq); - case 40000000: - ((S1D_VALUE *) fb_info.RegAddr)[0x05] = 0x42; - ((S1D_VALUE *) fb_info.RegAddr)[0x12] = 0x30; - break; - } - /* setenv("lcd","tft"); */ + diag = 0; } + clrbits_be16(&immr->im_ioport.iop_pcdir, PC_5); /* input */ + return (diag); +}
- /* create and set colormap */ - rs = 256 / (r - 1); - gs = 256 / (g - 1); - bs = 256 / (b - 1); - for (i = 0; i < 256; i++) { - r1 = (rs * ((i / (g * b)) % r)) * 255; - g1 = (gs * ((i / b) % g)) * 255; - b1 = (bs * ((i) % b)) * 255; - debugk ("%d %04x %04x %04x\n", i, r1 >> 4, g1 >> 4, b1 >> 4); - S1D_WRITE_PALETTE (fb_info.RegAddr, i, (r1 >> 4), (g1 >> 4), - (b1 >> 4)); - } +static unsigned char swapbyte(unsigned char c) +{ + unsigned char result = 0; + int i = 0;
- /* copy bitmap */ - fb = (uchar *) (fb_info.VmemAddr); - memcpy (fb, (uchar *) CONFIG_KUP4K_LOGO, 320 * 240); + for(i = 0; i < 8; ++i) { + result = result << 1; + result |= (c & 1); + c = c >> 1; + } + return result; } -#endif /* CONFIG_KUP4K_LOGO */ diff --git a/board/kup/kup4k/s1d13706.h b/board/kup/kup4k/s1d13706.h deleted file mode 100644 index cd5eccc..0000000 --- a/board/kup/kup4k/s1d13706.h +++ /dev/null @@ -1,174 +0,0 @@ -/*---------------------------------------------------------------------------- */ -/* */ -/* File generated by S1D13706CFG.EXE */ -/* */ -/* Copyright (c) 2000,2001 Epson Research and Development, Inc. */ -/* All rights reserved. */ -/* */ -/*---------------------------------------------------------------------------- */ - -/* Panel: 320x240x8bpp 70Hz Color Single STN 8-bit (PCLK=6.250MHz) (Format 2) */ - -#define S1D_DISPLAY_WIDTH 320 -#define S1D_DISPLAY_HEIGHT 240 -#define S1D_DISPLAY_BPP 8 -#define S1D_DISPLAY_SCANLINE_BYTES 320 -#define S1D_PHYSICAL_VMEM_ADDR 0x800A0000L -#define S1D_PHYSICAL_VMEM_SIZE 0x14000L -#define S1D_PHYSICAL_REG_ADDR 0x80080000L -#define S1D_PHYSICAL_REG_SIZE 0x100 -#define S1D_DISPLAY_PCLK 6250 -#define S1D_PALETTE_SIZE 256 -#define S1D_REGDELAYOFF 0xFFFE -#define S1D_REGDELAYON 0xFFFF - -#define S1D_WRITE_PALETTE(p,i,r,g,b) \ -{ \ - ((volatile S1D_VALUE*)(p))[0x0A/sizeof(S1D_VALUE)] = (S1D_VALUE)((r)>>4); \ - ((volatile S1D_VALUE*)(p))[0x09/sizeof(S1D_VALUE)] = (S1D_VALUE)((g)>>4); \ - ((volatile S1D_VALUE*)(p))[0x08/sizeof(S1D_VALUE)] = (S1D_VALUE)((b)>>4); \ - ((volatile S1D_VALUE*)(p))[0x0B/sizeof(S1D_VALUE)] = (S1D_VALUE)(i); \ -} - -#define S1D_READ_PALETTE(p,i,r,g,b) \ -{ \ - ((volatile S1D_VALUE*)(p))[0x0F/sizeof(S1D_VALUE)] = (S1D_VALUE)(i); \ - r = ((volatile S1D_VALUE*)(p))[0x0E/sizeof(S1D_VALUE)]; \ - g = ((volatile S1D_VALUE*)(p))[0x0D/sizeof(S1D_VALUE)]; \ - b = ((volatile S1D_VALUE*)(p))[0x0C/sizeof(S1D_VALUE)]; \ -} - -typedef unsigned short S1D_INDEX; -typedef unsigned char S1D_VALUE; - - -typedef struct -{ - S1D_INDEX Index; - S1D_VALUE Value; -} S1D_REGS; - - -static S1D_REGS aS1DRegs_prelimn[] = -{ - {0x10,0x00}, /* PANEL Type Register */ - {0xA8,0x00}, /* GPIO Config Register 0 */ - {0xA9,0x80}, /* GPIO Config Register 1 */ - -}; - -static S1D_REGS aS1DRegs_stn[] = -{ - {0x04,0x10}, /* BUSCLK MEMCLK Config Register */ - {0x10,0xD0}, /* PANEL Type Register */ - {0x11,0x00}, /* MOD Rate Register */ - {0x14,0x27}, /* Horizontal Display Period Register */ - {0x16,0x00}, /* Horizontal Display Period Start Pos Register 0 */ - {0x17,0x00}, /* Horizontal Display Period Start Pos Register 1 */ - {0x18,0xF0}, /* Vertical Total Register 0 */ - {0x19,0x00}, /* Vertical Total Register 1 */ - {0x1C,0xEF}, /* Vertical Display Period Register 0 */ - {0x1D,0x00}, /* Vertical Display Period Register 1 */ - {0x1E,0x00}, /* Vertical Display Period Start Pos Register 0 */ - {0x1F,0x00}, /* Vertical Display Period Start Pos Register 1 */ - {0x20,0x87}, /* Horizontal Sync Pulse Width Register */ - {0x22,0x00}, /* Horizontal Sync Pulse Start Pos Register 0 */ - {0x23,0x00}, /* Horizontal Sync Pulse Start Pos Register 1 */ - {0x24,0x80}, /* Vertical Sync Pulse Width Register */ - {0x26,0x01}, /* Vertical Sync Pulse Start Pos Register 0 */ - {0x27,0x00}, /* Vertical Sync Pulse Start Pos Register 1 */ - {0x70,0x83}, /* Display Mode Register */ - {0x71,0x00}, /* Special Effects Register */ - {0x74,0x00}, /* Main Window Display Start Address Register 0 */ - {0x75,0x00}, /* Main Window Display Start Address Register 1 */ - {0x76,0x00}, /* Main Window Display Start Address Register 2 */ - {0x78,0x50}, /* Main Window Address Offset Register 0 */ - {0x79,0x00}, /* Main Window Address Offset Register 1 */ - {0x7C,0x00}, /* Sub Window Display Start Address Register 0 */ - {0x7D,0x00}, /* Sub Window Display Start Address Register 1 */ - {0x7E,0x00}, /* Sub Window Display Start Address Register 2 */ - {0x80,0x50}, /* Sub Window Address Offset Register 0 */ - {0x81,0x00}, /* Sub Window Address Offset Register 1 */ - {0x84,0x00}, /* Sub Window X Start Pos Register 0 */ - {0x85,0x00}, /* Sub Window X Start Pos Register 1 */ - {0x88,0x00}, /* Sub Window Y Start Pos Register 0 */ - {0x89,0x00}, /* Sub Window Y Start Pos Register 1 */ - {0x8C,0x4F}, /* Sub Window X End Pos Register 0 */ - {0x8D,0x00}, /* Sub Window X End Pos Register 1 */ - {0x90,0xEF}, /* Sub Window Y End Pos Register 0 */ - {0x91,0x00}, /* Sub Window Y End Pos Register 1 */ - {0xA0,0x00}, /* Power Save Config Register */ - {0xA1,0x00}, /* CPU Access Control Register */ - {0xA2,0x00}, /* Software Reset Register */ - {0xA3,0x00}, /* BIG Endian Support Register */ - {0xA4,0x00}, /* Scratch Pad Register 0 */ - {0xA5,0x00}, /* Scratch Pad Register 1 */ - {0xA8,0x01}, /* GPIO Config Register 0 */ - {0xA9,0x80}, /* GPIO Config Register 1 */ - {0xAC,0x01}, /* GPIO Status Control Register 0 */ - {0xAD,0x00}, /* GPIO Status Control Register 1 */ - {0xB0,0x10}, /* PWM CV Clock Control Register */ - {0xB1,0x80}, /* PWM CV Clock Config Register */ - {0xB2,0x00}, /* CV Clock Burst Length Register */ - {0xAD,0x80}, /* reset seq */ - {0x70,0x03}, -}; - -static S1D_REGS aS1DRegs_tft[] = -{ - {0x04,0x10}, /* BUSCLK MEMCLK Config Register */ - {0x05,0x42}, /* PCLK Config Register */ - {0x10,0x61}, /* PANEL Type Register */ - {0x11,0x00}, /* MOD Rate Register */ - {0x12,0x30}, /* Horizontal Total Register */ - {0x14,0x27}, /* Horizontal Display Period Register */ - {0x16,0x11}, /* Horizontal Display Period Start Pos Register 0 */ - {0x17,0x00}, /* Horizontal Display Period Start Pos Register 1 */ - {0x18,0xFA}, /* Vertical Total Register 0 */ - {0x19,0x00}, /* Vertical Total Register 1 */ - {0x1C,0xEF}, /* Vertical Display Period Register 0 */ - {0x1D,0x00}, /* Vertical Display Period Register 1 */ - {0x1E,0x00}, /* Vertical Display Period Start Pos Register 0 */ - {0x1F,0x00}, /* Vertical Display Period Start Pos Register 1 */ - {0x20,0x07}, /* Horizontal Sync Pulse Width Register */ - {0x22,0x00}, /* Horizontal Sync Pulse Start Pos Register 0 */ - {0x23,0x00}, /* Horizontal Sync Pulse Start Pos Register 1 */ - {0x24,0x00}, /* Vertical Sync Pulse Width Register */ - {0x26,0x00}, /* Vertical Sync Pulse Start Pos Register 0 */ - {0x27,0x00}, /* Vertical Sync Pulse Start Pos Register 1 */ - {0x70,0x03}, /* Display Mode Register */ - {0x71,0x00}, /* Special Effects Register */ - {0x74,0x00}, /* Main Window Display Start Address Register 0 */ - {0x75,0x00}, /* Main Window Display Start Address Register 1 */ - {0x76,0x00}, /* Main Window Display Start Address Register 2 */ - {0x78,0x50}, /* Main Window Address Offset Register 0 */ - {0x79,0x00}, /* Main Window Address Offset Register 1 */ - {0x7C,0x00}, /* Sub Window Display Start Address Register 0 */ - {0x7D,0x00}, /* Sub Window Display Start Address Register 1 */ - {0x7E,0x00}, /* Sub Window Display Start Address Register 2 */ - {0x80,0x50}, /* Sub Window Address Offset Register 0 */ - {0x81,0x00}, /* Sub Window Address Offset Register 1 */ - {0x84,0x00}, /* Sub Window X Start Pos Register 0 */ - {0x85,0x00}, /* Sub Window X Start Pos Register 1 */ - {0x88,0x00}, /* Sub Window Y Start Pos Register 0 */ - {0x89,0x00}, /* Sub Window Y Start Pos Register 1 */ - {0x8C,0x4F}, /* Sub Window X End Pos Register 0 */ - {0x8D,0x00}, /* Sub Window X End Pos Register 1 */ - {0x90,0xEF}, /* Sub Window Y End Pos Register 0 */ - {0x91,0x00}, /* Sub Window Y End Pos Register 1 */ - {0xA0,0x00}, /* Power Save Config Register */ - {0xA1,0x00}, /* CPU Access Control Register */ - {0xA2,0x00}, /* Software Reset Register */ - {0xA3,0x00}, /* BIG Endian Support Register */ - {0xA4,0x00}, /* Scratch Pad Register 0 */ - {0xA5,0x00}, /* Scratch Pad Register 1 */ - {0xA8,0x01}, /* GPIO Config Register 0 */ - {0xA9,0x80}, /* GPIO Config Register 1 */ - {0xAC,0x01}, /* GPIO Status Control Register 0 */ - {0xAD,0x00}, /* GPIO Status Control Register 1 */ - {0xB0,0x10}, /* PWM CV Clock Control Register */ - {0xB1,0x80}, /* PWM CV Clock Config Register */ - {0xB2,0x00}, /* CV Clock Burst Length Register */ - {0xAD,0x80}, /* reset seq */ - {0x70,0x03}, -}; diff --git a/board/kup/kup4x/kup4x.c b/board/kup/kup4x/kup4x.c index 65a222b..1686eff 100644 --- a/board/kup/kup4x/kup4x.c +++ b/board/kup/kup4x/kup4x.c @@ -26,28 +26,8 @@ #include <mpc8xx.h> #include <post.h> #include "../common/kup.h" -#ifdef CONFIG_KUP4K_LOGO -/* #include "s1d13706.h" */ -#endif - -#define KUP4X_USB - - -typedef struct { - volatile unsigned char *VmemAddr; - volatile unsigned char *RegAddr; -} FB_INFO_S1D13xxx; - -/* ------------------------------------------------------------------------- */ - -int usb_init_kup4x (void); - +#include <asm/io.h>
-#ifdef CONFIG_KUP4K_LOGO -void lcd_logo (bd_t * bd); -#endif - -/* ------------------------------------------------------------------------- */
@@ -106,207 +86,116 @@ const uint sdram_table[] = { _NOT_USED_, _NOT_USED_, _NOT_USED_, };
-int checkboard (void) +int checkboard(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; volatile memctl8xx_t *memctl = &immap->im_memctl; - volatile uchar *latch; - uchar rev, mod; + uchar latch, rev, mod;
/* * Init ChipSelect #4 (CAN + HW-Latch) */ - memctl->memc_or4 = 0xFFFF8926; - memctl->memc_br4 = 0x90000401; - __asm__ ("eieio"); - latch = (volatile uchar *) 0x90000200; - rev = (*latch & 0xF8) >> 3; - mod = (*latch & 0x03); - printf ("Board: KUP4X Rev %d.%d\n",rev,mod); - return (0); + out_be32(&memctl->memc_or4, 0xFFFF8926); + out_be32(&memctl->memc_br4, 0x90000401); + + latch = in_8( (unsigned char *) LATCH_ADDR); + rev = (latch & 0xF8) >> 3; + mod = (latch & 0x03); + + printf("Board: KUP4X Rev %d.%d\n", rev, mod); + + return 0; }
-phys_size_t initdram (int board_type) +phys_size_t initdram(int board_type) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size_b0 = 0; - long int size_b1 = 0; - long int size_b2 = 0; - long int size_b3 = 0;
- upmconfig (UPMA, (uint *) sdram_table, + upmconfig(UPMA, (uint *) sdram_table, sizeof (sdram_table) / sizeof (uint)); - /* - * Preliminary prescaler for refresh (depends on number of - * banks): This value is selected for four cycles every 62.4 us - * with two SDRAM banks or four cycles every 31.2 us with one - * bank. It will be adjusted after memory sizing. - */ - memctl->memc_mptpr = CONFIG_SYS_MPTPR;
- memctl->memc_mar = 0x00000088; + out_be16(&memctl->memc_mptpr, CONFIG_SYS_MPTPR);
- /* - * Map controller banks 1 and 2 to the SDRAM banks 2 and 3 at - * preliminary addresses - these have to be modified after the - * SDRAM size has been determined. - */ -/* memctl->memc_or1 = CONFIG_SYS_OR1_PRELIM; */ -/* memctl->memc_br1 = CONFIG_SYS_BR1_PRELIM; */ + out_be32(&memctl->memc_mar, 0x00000088);
-/* memctl->memc_or2 = CONFIG_SYS_OR2_PRELIM; */ -/* memctl->memc_br2 = CONFIG_SYS_BR2_PRELIM; */ + out_be32(&memctl->memc_mamr, + CONFIG_SYS_MAMR & (~(MAMR_PTAE))); /* no refresh yet */
- memctl->memc_mamr = CONFIG_SYS_MAMR & (~(MAMR_PTAE)); /* no refresh yet */ - - udelay (200); + udelay(200);
- memctl->memc_mcr = 0x80002105; /* SDRAM bank 0 */ - udelay (1); - memctl->memc_mcr = 0x80002830; /* SDRAM bank 0 - execute twice */ - udelay (1); - memctl->memc_mcr = 0x80002106; /* SDRAM bank 0 - RUN MRS Pattern from loc 6 */ - udelay (1); - - memctl->memc_mcr = 0x80004105; /* SDRAM bank 1 */ - udelay (1); - memctl->memc_mcr = 0x80004830; /* SDRAM bank 1 - execute twice */ - udelay (1); - memctl->memc_mcr = 0x80004106; /* SDRAM bank 1 - RUN MRS Pattern from loc 6 */ - udelay (1); - - memctl->memc_mcr = 0x80006105; /* SDRAM bank 2 */ - udelay (1); - memctl->memc_mcr = 0x80006830; /* SDRAM bank 2 - execute twice */ - udelay (1); - memctl->memc_mcr = 0x80006106; /* SDRAM bank 2 - RUN MRS Pattern from loc 6 */ - udelay (1); - - memctl->memc_mcr = 0x8000C105; /* SDRAM bank 2 */ - udelay (1); - memctl->memc_mcr = 0x8000C830; /* SDRAM bank 2 - execute twice */ - udelay (1); - memctl->memc_mcr = 0x8000C106; /* SDRAM bank 2 - RUN MRS Pattern from loc 6 */ - udelay (1); - - memctl->memc_mamr |= MAMR_PTAE; /* enable refresh */ - udelay (1000); -#if 0 /* 4 x 8MB */ - size_b0 = 0x00800000; - size_b1 = 0x00800000; - size_b2 = 0x00800000; - size_b3 = 0x00800000; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - udelay (1000); - memctl->memc_or1 = 0xFF800A00; - memctl->memc_br1 = 0x00000081; - memctl->memc_or2 = 0xFF000A00; - memctl->memc_br2 = 0x00800081; - memctl->memc_or3 = 0xFE000A00; - memctl->memc_br3 = 0x01000081; - memctl->memc_or6 = 0xFE000A00; - memctl->memc_br6 = 0x01800081; -#else /* 4 x 16 MB */ - size_b0 = 0x01000000; - size_b1 = 0x01000000; - size_b2 = 0x01000000; - size_b3 = 0x01000000; - memctl->memc_mptpr = CONFIG_SYS_MPTPR; - udelay (1000); - memctl->memc_or1 = 0xFF000A00; - memctl->memc_br1 = 0x00000081; - memctl->memc_or2 = 0xFE000A00; - memctl->memc_br2 = 0x01000081; - memctl->memc_or3 = 0xFD000A00; - memctl->memc_br3 = 0x02000081; - memctl->memc_or6 = 0xFC000A00; - memctl->memc_br6 = 0x03000081; -#endif - udelay (10000); - - return (size_b0 + size_b1 + size_b2 + size_b3); + /* SDRAM bank 0 */ + out_be32(&memctl->memc_mcr, 0x80002105); + udelay(1); + out_be32(&memctl->memc_mcr, 0x80002830); /* execute twice */ + udelay(1); + out_be32(&memctl->memc_mcr, 0x80002106); /* RUN MRS Pattern from loc 6 */ + udelay(1); + + /* SDRAM bank 1 */ + out_be32(&memctl->memc_mcr, 0x80004105); + udelay(1); + out_be32(&memctl->memc_mcr, 0x80004830); /* execute twice */ + udelay(1); + out_be32(&memctl->memc_mcr, 0x80004106); /* RUN MRS Pattern from loc 6 */ + udelay(1); + + /* SDRAM bank 2 */ + out_be32(&memctl->memc_mcr, 0x80006105); + udelay(1); + out_be32(&memctl->memc_mcr, 0x80006830); /* execute twice */ + udelay(1); + out_be32(&memctl->memc_mcr, 0x80006106); /* RUN MRS Pattern from loc 6 */ + udelay(1); + + /* SDRAM bank 3 */ + out_be32(&memctl->memc_mcr, 0x8000C105); + udelay(1); + out_be32(&memctl->memc_mcr, 0x8000C830); /* execute twice */ + udelay(1); + out_be32(&memctl->memc_mcr, 0x8000C106); /* RUN MRS Pattern from loc 6 */ + udelay(1); + + setbits_be32(&memctl->memc_mamr, MAMR_PTAE); /* enable refresh */ + + udelay(1000); + /* 4 x 16 MB */ + out_be16(&memctl->memc_mptpr, CONFIG_SYS_MPTPR); + udelay(1000); + out_be32(&memctl->memc_or1, 0xFF000A00); + out_be32(&memctl->memc_br1, 0x00000081); + out_be32(&memctl->memc_or2, 0xFE000A00); + out_be32(&memctl->memc_br2, 0x01000081); + out_be32(&memctl->memc_or3, 0xFD000A00); + out_be32(&memctl->memc_br3, 0x02000081); + out_be32(&memctl->memc_or6, 0xFC000A00); + out_be32(&memctl->memc_br6, 0x03000081); + udelay(10000); + + return (4 * 16 * 1024 * 1024); }
-/* ------------------------------------------------------------------------- */ - -/* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ -#if 0 -static long int dram_size (long int mamr_value, long int *base, - long int maxsize) +int misc_init_r(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - volatile long int *addr; - ulong cnt, val; - ulong save[32]; /* to make test non-destructive */ - unsigned char i = 0; - - memctl->memc_mamr = mamr_value; - - for (cnt = maxsize / sizeof (long); cnt > 0; cnt >>= 1) { - addr = base + cnt; /* pointer arith! */ - - save[i++] = *addr; - *addr = ~cnt; - } - - /* write 0 to base address */ - addr = base; - save[i] = *addr; - *addr = 0; - - /* check at base address */ - if ((val = *addr) != 0) { - *addr = save[i]; - return (0); - } - - for (cnt = 1; cnt <= maxsize / sizeof (long); cnt <<= 1) { - addr = base + cnt; /* pointer arith! */ - - val = *addr; - *addr = save[--i]; - - if (val != (~cnt)) { - return (cnt * sizeof (long)); - } - } - return (maxsize); -} -#endif
-int misc_init_r (void) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; #ifdef CONFIG_IDE_LED /* Configure PA8 as output port */ - immap->im_ioport.iop_padir |= 0x80; - immap->im_ioport.iop_paodr |= 0x80; - immap->im_ioport.iop_papar &= ~0x80; - immap->im_ioport.iop_padat |= 0x80; /* turn it off */ -#endif -#ifdef KUP4X_USB - usb_init_kup4x (); + setbits_be16(&immap->im_ioport.iop_padir, PA_8); + setbits_be16(&immap->im_ioport.iop_paodr, PA_8); + clrbits_be16(&immap->im_ioport.iop_papar, PA_8); + setbits_be16(&immap->im_ioport.iop_padat, PA_8); /* turn it off */ #endif load_sernum_ethaddr(); - setenv ("hw", "4x"); - poweron_key (); - return (0); + setenv("hw", "4x"); + poweron_key(); + return 0; } diff --git a/boards.cfg b/boards.cfg index b82f530..9d5639e 100644 --- a/boards.cfg +++ b/boards.cfg @@ -160,7 +160,7 @@ TOP860 powerpc mpc8xx top860 emk kmsupx4 powerpc mpc8xx km8xx keymile mgsuvd powerpc mpc8xx km8xx keymile KUP4K powerpc mpc8xx kup4k kup -KUP4X powerpc mpc8xx kup4k kup +KUP4X powerpc mpc8xx kup4x kup ELPT860 powerpc mpc8xx elpt860 LEOX CCM powerpc mpc8xx - siemens IAD210 powerpc mpc8xx - siemens diff --git a/include/configs/KUP4K.h b/include/configs/KUP4K.h index a829984..ab708ae 100644 --- a/include/configs/KUP4K.h +++ b/include/configs/KUP4K.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2005 + * (C) Copyright 2000-2010 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * Klaus Heydeck, Kieback & Peter GmbH & Co KG, heydeck@kieback-peter.de * @@ -42,46 +42,46 @@ #undef CONFIG_8xx_CONS_SMC2 #undef CONFIG_8xx_CONS_NONE #define CONFIG_BAUDRATE 115200 /* console baudrate */ -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else #define CONFIG_BOOTDELAY 1 /* autoboot after 1 second */ -#endif
#define CONFIG_BOARD_TYPES 1 /* support board types */
- #undef CONFIG_BOOTARGS
- #define CONFIG_EXTRA_ENV_SETTINGS \ -"slot_a_boot=setenv bootargs root=/dev/hda2 ip=off;" \ - "run addhw; diskboot 200000 0:1; bootm 200000\0" \ -"slot_b_boot=setenv bootargs root=/dev/hda2 ip=off;" \ - "run addhw; diskboot 200000 2:1; bootm 200000\0" \ -"nfs_boot=dhcp; run nfsargs addip addhw; bootm 200000\0" \ +"slot_a_boot=setenv bootargs root=/dev/sda2 ip=off;" \ + "run addhw; mw.b 400000 00 80; diskboot 400000 0:1; bootm 400000\0" \ +"slot_b_boot=setenv bootargs root=/dev/sda2 ip=off;" \ + "run addhw; mw.b 400000 00 80; diskboot 400000 2:1; bootm 400000\0" \ +"nfs_boot=mw.b 400000 00 80; dhcp; run nfsargs addip addhw; bootm 400000\0" \ +"fat_boot=mw.b 400000 00 80; fatload ide 2:1 400000 st.bin; run addhw; \ + bootm 400000 \0" \ "panic_boot=echo No Bootdevice !!! reset\0" \ -"nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath}\0" \ +"nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${rootpath}\0" \ "ramargs=setenv bootargs root=/dev/ram rw\0" \ -"addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}" \ +"addip=setenv bootargs ${bootargs} ip=${ipaddr}::${gatewayip}" \ ":${netmask}:${hostname}:${netdev}:off\0" \ -"addhw=setenv bootargs ${bootargs} hw=${hw} key1=${key1} panic=1\0" \ +"addhw=setenv bootargs ${bootargs} ${mtdparts} console=${console} ${debug} \ + hw=${hw} key1=${key1} panic=1 mem=${mem}\0" \ +"console=ttyCPM0,115200\0" \ "netdev=eth0\0" \ -"contrast=55\0" \ +"contrast=20\0" \ "silent=1\0" \ +"mtdparts=" MTDPARTS_DEFAULT "\0" \ "load=tftp 200000 bootloader-4k.bitmap;tftp 100000 bootloader-4k.bin\0" \ -"update=protect off 1:0-7;era 1:0-7;cp.b 100000 40000000 ${filesize};" \ +"update=protect off 1:0-9;era 1:0-9;cp.b 100000 40000000 ${filesize};" \ "cp.b 200000 40050000 14000\0"
#define CONFIG_BOOTCOMMAND \ - "run slot_a_boot;run slot_b_boot;run nfs_boot;run panic_boot" + "run fat_boot;run slot_b_boot;run slot_a_boot;run nfs_boot;run panic_boot"
+#define CONFIG_PREBOOT "setenv preboot; saveenv"
#define CONFIG_MISC_INIT_R 1 #define CONFIG_MISC_INIT_F 1
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ +#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */
#define CONFIG_WATCHDOG 1 /* watchdog enabled */
@@ -98,19 +98,17 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- #define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION
- /* * enable I2C and select the hardware/software driver */ -#undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ +#undef CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_SOFT_I2C /* I2C bit-banged */
-#define CONFIG_SYS_I2C_SPEED 93000 /* 93 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_SPEED 93000 /* 93 kHz is supposed to work */ +#define CONFIG_SYS_I2C_SLAVE 0xFE
#ifdef CONFIG_SOFT_I2C /* @@ -130,14 +128,12 @@ #define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ #endif /* CONFIG_SOFT_I2C */
- /*----------------------------------------------------------------------- * I2C Configuration */
-#define CONFIG_SYS_I2C_PICIO_ADDR 0x21 /* PCF8574 IO Expander */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* PCF8563 RTC */ - +#define CONFIG_SYS_I2C_PICIO_ADDR 0x21 /* PCF8574 IO Expander */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* PCF8563 RTC */
/* List of I2C addresses to be verified by POST */
@@ -145,27 +141,13 @@ CONFIG_SYS_I2C_RTC_ADDR, \ }
- #define CONFIG_RTC_PCF8563 /* use Philips PCF8563 RTC */
#define CONFIG_SYS_DISCOVER_PHY #define CONFIG_MII
-#if 0 -#define CONFIG_ETHADDR 00:0B:64:00:00:00 /* our OUI from IEEE */ -#endif -#define CONFIG_KUP4K_LOGO 0x40050000 /* Address of logo bitmap */ - /* Define to allow the user to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE -#if 1 -/* POST support */ - -#define CONFIG_POST (CONFIG_SYS_POST_CPU | \ - CONFIG_SYS_POST_RTC | \ - CONFIG_SYS_POST_I2C) -#endif -
/* * Command line configuration. @@ -176,7 +158,9 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_I2C #define CONFIG_CMD_IDE +#define CONFIG_CMD_MII #define CONFIG_CMD_NFS +#define CONFIG_CMD_FAT #define CONFIG_CMD_SNTP
#ifdef CONFIG_POST @@ -191,18 +175,21 @@ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
-#define CONFIG_SYS_MEMTEST_START 0x000400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x002C00000 /* 4 ... 44 MB in DRAM */ +#define CONFIG_SYS_MEMTEST_START 0x000400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x005C00000 /* 4 ... 92 MB in DRAM */ +#define CONFIG_SYS_ALT_MEMTEST 1 +#define CONFIG_SYS_MEMTEST_SCRATCH 0x90000200 /* using latch as scratch register */
-#define CONFIG_SYS_LOAD_ADDR 0x200000 /* default load address */ +#define CONFIG_SYS_LOAD_ADDR 0x400000 /* default load address */
-#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */
#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 115200 }
@@ -259,19 +246,22 @@ #define CONFIG_ENV_SIZE 0x1000 /* Total Size of Environment Sector */ #define CONFIG_ENV_SECT_SIZE 0x10000
-/* Address and size of Redundant Environment Sector */ -#if 0 -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) -#endif +/*----------------------------------------------------------------------- + * Dynamic MTD partition support + */ +#define MTDPARTS_DEFAULT "mtdparts=40000000.flash:256k(u-boot)," \ + "64k(env)," \ + "128k(splash)," \ + "512k(etc)," \ + "64k(hw-info)" + /*----------------------------------------------------------------------- * Hardware Information Block */ -#if 1 #define CONFIG_SYS_HWINFO_OFFSET 0x000F0000 /* offset of HW Info block */ #define CONFIG_SYS_HWINFO_SIZE 0x00000100 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x4B26500D /* 'K&P<CR>' */ -#endif +#define CONFIG_SYS_HWINFO_MAGIC 0x4B26500D /* 'K&P<CR>' */ + /*----------------------------------------------------------------------- * Cache Configuration */ @@ -286,12 +276,7 @@ *----------------------------------------------------------------------- * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze */ -#if 0 && defined(CONFIG_WATCHDOG) /* KUP uses external TPS3705 WD */ -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else #define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif
/*----------------------------------------------------------------------- * SIUMCR - SIU Module Configuration 11-6 @@ -391,7 +376,6 @@ /* Offset for alternate registers */ #define CONFIG_SYS_ATA_ALT_OFFSET 0x0100
- /*----------------------------------------------------------------------- * *----------------------------------------------------------------------- @@ -416,18 +400,20 @@ /* * FLASH timing: */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_2_CLK | OR_EHTR | OR_BI) +#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV2 | OR_CSNT_SAM | \ + OR_SCY_5_CLK | OR_EHTR | OR_BI)
-#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V ) +#define CONFIG_SYS_OR0_REMAP \ + (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) +#define CONFIG_SYS_OR0_PRELIM \ + (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) +#define CONFIG_SYS_BR0_PRELIM \ + ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_16 | BR_V )
/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ #define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00
- /* * Memory Periodic Timer Prescaler * @@ -475,7 +461,39 @@ /* * MAMR settings for SDRAM */ -#define CONFIG_SYS_MAMR 0x80802114 + +/* 8 column SDRAM */ +#define CONFIG_SYS_MAMR_8COL 0x68802114 +/* 9 column SDRAM */ +#define CONFIG_SYS_MAMR_9COL 0x68904114 + +/* + * Chip Selects + */ +#define CONFIG_SYS_OR0 +#define CONFIG_SYS_BR0 + +#define CONFIG_SYS_OR1_8COL 0xFF000A00 +#define CONFIG_SYS_BR1_8COL 0x00000081 +#define CONFIG_SYS_OR2_8COL 0xFE000A00 +#define CONFIG_SYS_BR2_8COL 0x01000081 +#define CONFIG_SYS_OR3_8COL 0xFC000A00 +#define CONFIG_SYS_BR3_8COL 0x02000081 + +#define CONFIG_SYS_OR1_9COL 0xFE000A00 +#define CONFIG_SYS_BR1_9COL 0x00000081 +#define CONFIG_SYS_OR2_9COL 0xFE000A00 +#define CONFIG_SYS_BR2_9COL 0x02000081 +#define CONFIG_SYS_OR3_9COL 0xFE000A00 +#define CONFIG_SYS_BR3_9COL 0x04000081 + +#define CONFIG_SYS_OR4 0xFFFF8926 +#define CONFIG_SYS_BR4 0x90000401 + +#define CONFIG_SYS_OR5 0xFFC007F0 /* EPSON: 4 MB 17 WS or externel TA */ +#define CONFIG_SYS_BR5 0x80080801 /* Start at 0x80080000 */ + +#define LATCH_ADDR 0x90000200
/* * Internal Definitions @@ -487,11 +505,10 @@
#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ -#if 0 -#define CONFIG_AUTOBOOT_PROMPT \ - "Boote in %d Sekunden - stop mit "2"\n", bootdelay -#endif -#define CONFIG_AUTOBOOT_STOP_STR "." /* easy to stop for now */ -#define CONFIG_SILENT_CONSOLE 1 +#define CONFIG_AUTOBOOT_STOP_STR "." +#define CONFIG_SILENT_CONSOLE 1 +#define CONFIG_SYS_DEVICE_NULLDEV 1 /* enble null device */ +#define CONFIG_VERSION_VARIABLE 1
#endif /* __CONFIG_H */ + diff --git a/include/configs/KUP4X.h b/include/configs/KUP4X.h index be6dfda..ab535e1 100644 --- a/include/configs/KUP4X.h +++ b/include/configs/KUP4X.h @@ -35,23 +35,20 @@ * (easy to change) */
-#define CONFIG_MPC859T 1 /* This is a MPC859T CPU */ -#define CONFIG_KUP4X 1 /* ...on a KUP4X module */ +#define CONFIG_MPC859T 1 /* This is a MPC859T CPU */ +#define CONFIG_KUP4X 1 /* ...on a KUP4X module */
-#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ +#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ #undef CONFIG_8xx_CONS_SMC2 #undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 115200 /* console baudrate */ -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 1 /* autoboot after 1 second */ -#endif +#define CONFIG_BAUDRATE 115200 /* console baudrate */
-#define CONFIG_BOARD_TYPES 1 /* support board types */ +#define CONFIG_BOOTDELAY 1 /* autoboot after 1 second */
-#define CONFIG_SYS_8XX_FACT 8 /* Multiply by 8 */ -#define CONFIG_SYS_8XX_XIN 16000000 /* 16 MHz in */ +#define CONFIG_BOARD_TYPES 1 /* support board types */ + +#define CONFIG_SYS_8XX_FACT 8 /* Multiply by 8 */ +#define CONFIG_SYS_8XX_XIN 16000000 /* 16 MHz in */
#define MPC8XX_HZ ((CONFIG_SYS_8XX_XIN) * (CONFIG_SYS_8XX_FACT)) @@ -67,9 +64,9 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "slot_a_boot=setenv bootargs root=/dev/hda2 ip=off;" \ "run addhw;diskboot 200000 0:1;bootm 200000\0" \ -"usb_boot=setenv bootargs root=/dev/sda2 ip=off;\ - run addhw; sleep 2; usb reset; usb scan; usbboot 200000 0:1;\ - usb stop; bootm 200000\0" \ +"usb_boot=setenv bootargs root=/dev/sda2 ip=off; \ + run addhw; sleep 2; usb reset; usb scan; usbboot 200000 0:1; \ + usb stop; bootm 200000\0" \ "nfs_boot=dhcp;run nfsargs addip addhw;bootm 200000\0" \ "panic_boot=echo No Bootdevice !!! reset\0" \ "nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath}\0" \ @@ -84,14 +81,14 @@ "cp.b 200000 40040000 14000\0"
#define CONFIG_BOOTCOMMAND \ - "run usb_boot;run_slot_a_boot;run nfs_boot;run panic_boot" + "run usb_boot;run slot_a_boot;run nfs_boot;run panic_boot"
@@ -144,8 +141,8 @@ * I2C Configuration */
-#define CONFIG_SYS_I2C_PICIO_ADDR 0x21 /* PCF8574 IO Expander */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* PCF8563 RTC */ +#define CONFIG_SYS_I2C_PICIO_ADDR 0x21 /* PCF8574 IO Expander */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* PCF8563 RTC */
/* List of I2C addresses to be verified by POST */ @@ -160,22 +157,16 @@ #define CONFIG_SYS_DISCOVER_PHY #define CONFIG_MII
-#if 0 -#define CONFIG_ETHADDR 00:0B:64:80:00:00 /* our OUI from IEEE */ -#endif #undef CONFIG_KUP4K_LOGO
-#if 1 /* POST support */ - #define CONFIG_POST (CONFIG_SYS_POST_CPU | \ CONFIG_SYS_POST_RTC | \ CONFIG_SYS_POST_I2C) -#endif
/* @@ -426,9 +417,12 @@ #define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ OR_SCY_2_CLK | OR_EHTR | OR_BI)
/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ @@ -444,6 +438,15 @@
/* + * Chip Selects + */ + +#define CONFIG_SYS_OR4 0xFFFF8926 +#define CONFIG_SYS_BR4 0x90000401 + +#define LATCH_ADDR 0x90000200 + +/* * Internal Definitions * * Boot Flags @@ -453,10 +456,7 @@
#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ -#if 0 -#define CONFIG_AUTOBOOT_PROMPT \ - "Boote in %d Sekunden - stop mit "2"\n", bootdelay -#endif + #define CONFIG_AUTOBOOT_STOP_STR "." /* easy to stop for now */ #define CONFIG_SILENT_CONSOLE 1
Dear Heiko Schocher,
- hda->sda changed
- mtd parts added
- lcd stuff removed
- code cleanup
changes since v1:
Backed out previous version, applied this one instead.
Heiko, please make sure to set the In-reply-to: / References: headers to keep threading in place, so I can see in the mailer when a later version of a patch gets posted. Thanks.
I still had the same merge conflicts in board/kup/kup4k/kup4k.c
Could you please check that the result is what you expect?
Heiko Schocher
